26 "ossimQuickbirdTiffTileSource",
29 static const ossimTrace traceDebug(
"ossimQuickbirdTiffTileSource:debug");
36 static const char M[] =
"ossimQuickbirdTiffTileSource::open()";
126 <<
"ossimQuickbirdTiffTileSource::open() DEBUG:" 127 <<
"\nSub image offset = " << shift << std::endl;
ossimRefPtr< ossimImageGeometry > theGeometry
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
ossimFilename noExtension() const
bool open()
Returns true if no errors initializing object.
static ossimString upcase(const ossimString &aString)
ossimFilename theImageFile
bool open(const ossimFilename tileFile)
RTTI_DEF1(ossimQuickbirdTiffTileSource, "ossimQuickbirdTiffTileSource", ossimTiffTileSource)
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual bool open()
Pure virtual open.
ossimString replaceAllThatMatch(const char *regularExpressionPattern, const char *value="") const
ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
bool getInfo(ossimQuickbirdTileInfo &result, const ossimFilename &filename) const
std::string::size_type size() const
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
static ossimProjectionFactoryRegistry * instance()
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
void setTransform(ossim2dTo2dTransform *transform)
Sets the transform to be used for local-to-full-image coordinate transformation.
ossimFilename m_tileInfoFilename
ossimFilename file() const
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
virtual bool parseFile(const ossimFilename &file)
Public method for parsing generic image file.
