16 #ifndef ossimTiledElevationDatabase_HEADER 17 #define ossimTiledElevationDatabase_HEADER 1 134 duped->
open(m_connectionString);
169 void initializeReferenceProjection();
virtual double getHeightAboveMSL(const ossimGpt &)=0
Height access methods:
ossimGrect m_requestedRect
ossimRefPtr< ossimProjection > m_referenceProj
Projection of the first entry.
virtual ossimObject * dup() const
Elevation source used for working with generic images opened by an ossimImageHandler.
Utility class to walk through directories and get a list of files to process.
Single image chain class.
bool getAccuracyInfo(ossimElevationAccuracyInfo &info, const ossimGpt &) const
ossimGrect m_rect
Bounding rectangle in decimal degrees.
ossimDblGrid * m_grid
Hold region of elevation.
virtual bool pointHasCoverage(const ossimGpt &) const =0
METHOD: pointHasCoverage(gpt) Returns TRUE if coverage exists over gpt:
This class defines an abstract Handler which all image handlers(loaders) should derive from...
ossimGrect m_entryListRect
virtual bool open(const ossimString &connectionString)
Open a connection to a database.
virtual double getHeightAboveEllipsoid(const ossimGpt &)
ossimRefPtr< ossimSingleImageChain > m_sic
Hold pointer to single image chain.
ossimFileWalker * m_fileWalker
std::vector< ossimTiledElevationEntry > m_entries
virtual bool open(const ossimString &connectionString)=0
std::basic_ostream< char > ostream
Base class for char output streams.
virtual void processFile(const ossimFilename &file)=0
Pure virtual processFile method.
