ossimTiledElevationDatabase.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // File: ossimTiledElevationDatabase.cpp
4 //
5 // License: LGPL
6 //
7 // See LICENSE.txt file in the top level directory for more details.
8 //
9 // Author: David Burken
10 //
11 // Description: See class desciption in header file.
12 //
13 //----------------------------------------------------------------------------
14 // $Id$
15
19 #include <ossim/base/ossimDpt.h>
22 #include <ossim/base/ossimString.h>
23 #include <ossim/base/ossimTrace.h>
32 #include <cmath>
33
34 static ossimTrace traceDebug(ossimString("ossimTiledElevationDatabase:debug"));
35
36 RTTI_DEF1(ossimTiledElevationDatabase, "ossimTiledElevationDatabase", ossimElevationDatabase);
37
39  :
42  m_entries(0),
43  m_grid(0),
44  m_referenceProj(0),
45  m_requestedRect(),
46  m_entryListRect(),
47  m_fileWalker(0)
48 {
51
52  //---
53  // Use the ossimElevSource::theGroundRect to hold the mapped rect expanded to even post
54  // boundaries.
55  //---
57 }
58
59 // Protected destructor as this is derived from ossimRefenced.
61 {
62  m_referenceProj = 0;
63  m_entries.clear();
64  if ( m_grid )
65  {
66  delete m_grid;
67  m_grid = 0;
68  }
69  if ( m_fileWalker )
70  {
71  delete m_fileWalker;
72  m_fileWalker = 0;
73  }
74 }
75
76 bool ossimTiledElevationDatabase::open(const ossimString& connectionString)
77 {
78  static const char M[] = "ossimTiledElevationDatabase::open";
79  if(traceDebug())
80  {
82  << M << " entered...\n"
83  << "\nConnection string: " << connectionString << "\n";
84  }
85
86  bool result = false;
87
88  close();
89
90  if ( connectionString.size() )
91  {
92  m_connectionString = connectionString.c_str();
93  result = true;
94  }
95
96  if ( m_entries.size() ) result = true;
97
98  if(traceDebug())
99  {
100  ossimNotify(ossimNotifyLevel_DEBUG) << M << " result=" << (result?"true\n":"false\n");
101  }
102
103  return result;
104 }
105
107 {
111  m_referenceProj = 0;
112  m_entries.clear();
113  if ( m_grid )
114  {
115  delete m_grid;
116  m_grid = 0;
117  }
118  m_meanSpacing = 0.0;
119  m_geoid = 0;
121 }
122
124 {
125  static const char M[] = "ossimTiledElevationDatabase::mapRegion";
126  if(traceDebug())
127  {
129  << M << " entered...\n" << "region: " << region << "\n";
130  }
131
132  if ( m_connectionString.size() )
133  {
134  // Wrap in try catch block as excptions can be thrown under the hood.
135  try
136  {
137  m_requestedRect = region;
138
140  if ( f.exists() )
141  {
142  if ( !m_fileWalker )
143  {
146
148
149  // Must set this so we can stop recursion on directory based images.
151
152  // This links the file walker back to our "processFile" method.
154  }
155
156  // Walk the directory:
157  m_fileWalker->walk(f);
158
159  mapRegion();
160  }
161  else
162  {
164  << M << " ERROR: Connection string does not exists: "
165  << m_connectionString.c_str() << endl;
166  }
167  }
168  catch (const ossimException& e)
169  {
171  << "Caught exception: " << e.what() << endl;
172  m_entries. clear();
173  }
174
175  // cleanup:
176  if ( m_fileWalker )
177  {
178  delete m_fileWalker;
179  m_fileWalker = 0;
180  }
181 }
182
183  if(traceDebug())
184  {
185  ossimNotify(ossimNotifyLevel_DEBUG) << M << " exited...\n";
186  }
187 }
188
190 {
191  static const char M[] = "ossimTiledElevationDatabase::processFile";
192  if(traceDebug())
193  {
195  << M << " entered...\n" << "file: " << file << "\n";
196  }
197
199  if ( sic->open(file, false) ) // False for do not open overviews.
200  {
201  if ( isDirectoryBasedImage( sic->getImageHandler() ) )
202  {
203  // Tell the walker not to recurse this directory.
205  }
206
208  if ( ih.valid() && (m_requestedRect.isLonLatNan() == false) )
209  {
211  if ( geom.valid() == false )
212  {
213  std::string errMsg = M;
214  errMsg += " ERROR:\nNo image geometry for image: ";
215  errMsg += ih->getFilename().string();
216  throw ossimException(errMsg);
217  }
218
220  if ( proj.valid() == false )
221  {
222  std::string errMsg = M;
223  errMsg += " ERROR:\nNo image projection for image: ";
224  errMsg += ih->getFilename().string();
225  throw ossimException(errMsg);
226  }
227
228  // Get the bounding rect:
229  ossimGrect boundingRect;
230  getBoundingRect(geom, boundingRect);
231
232  if ( boundingRect.isLonLatNan() )
233  {
234  std::string errMsg = M;
235  errMsg += " ERROR:\nBounding rect has nans for image: ";
236  errMsg += ih->getFilename().string();
237  throw ossimException(errMsg);
238  }
239
240  if ( boundingRect.intersects(m_requestedRect) )
241  {
242  bool addEntryToList = false;
243
244  if ( m_entries.size() == 0 ) // First time through.
245  {
246  addEntryToList = true;
247  m_entryListRect = boundingRect;
248  m_referenceProj = proj;
249  m_meanSpacing = (geom->getMetersPerPixel().x + geom->getMetersPerPixel().y) / 2.0;
250  }
251  else
252  {
253  addEntryToList = isCompatible( ih.get(), geom.get(), proj.get() );
254  if ( addEntryToList )
255  {
256  // Expand the rectangle.
257  m_entryListRect.combine(boundingRect);
258  }
259  }
260
261  if ( addEntryToList )
262  {
263  // If we're keeping it add a cache to the chain.
264  sic->addCache();
265
266  //---
267  // Create the entry and give to addEntry which checks for duplicates in case
268  // mapRegion was called consecutively.
269  //---
270  ossimTiledElevationEntry entry(boundingRect, sic);
271  addEntry(entry);
272
273  // Once the requested rect is filled abort the file walk.
275  {
276  m_fileWalker->setAbortFlag(true);
277  }
278  }
279  }
280  }
281  else
282  {
283  std::string errMsg = M;
284  errMsg += " ERROR:\nNo image geometry for image: ";
285  errMsg += ih->getFilename().string();
286  throw ossimException(errMsg);
287  }
288  }
289
290  if(traceDebug())
291  {
292  // Since ossimFileWalker is threaded output the file so we know which job exited.
293  ossimNotify(ossimNotifyLevel_DEBUG) << M << "\nfile: " << file << "\nexited...\n";
294  }
295 }
296
298 {
299  bool result = true;
300  std::vector<ossimTiledElevationEntry>::const_iterator i = m_entries.begin();
301  while ( i != m_entries.end() )
302  {
303  if ( (*i).m_sic->getFilename() == entry.m_sic->getFilename() )
304  {
305  result = false; // In list already.
306  break;
307  }
308  ++i;
309  }
310  if ( result )
311  {
312  m_entries.push_back(entry); // Add to list.
313  }
314 }
315
317 {
318  if ( m_entries.size() )
319  {
320  ossimRefPtr<ossimImageHandler> ih = m_entries[0].m_sic->getImageHandler();
321  if ( ih.valid() )
322  {
324  if ( geom.valid() )
325  {
326  m_referenceProj = geom->getProjection();
327  }
328  // else throw exception ??? (drb)
329  }
330  }
331 }
332
334 {
335  if ( m_grid )
336  {
337  return (*m_grid)(gpt.lon, gpt.lat);
338  }
339  return ossim::nan();
340 }
341
343 {
344  double h = getHeightAboveMSL(gpt);
345  if(h != ossim::nan())
346  {
347  h += getOffsetFromEllipsoid(gpt);
348  }
349  return h;
350 }
351
353 {
354  if ( theGroundRect.isLonLatNan() == false)
355  {
356  return theGroundRect.pointWithin(gpt);
357  }
358  return false;
359 }
360
361 bool ossimTiledElevationDatabase::loadState(const ossimKeywordlist& kwl, const char* prefix)
362 {
363  static const char M[] = "ossimTiledElevationDatabase::loadState";
364  if(traceDebug())
365  {
367  << M << " entered..." << "\nkwl:\n" << kwl << "\n";
368  }
369  bool result = false;
370  const char* lookup = kwl.find(prefix, "type");
371  if ( lookup )
372  {
373  std::string type = lookup;
374  if ( ( type == "image_directory" ) || ( type == "ossimTiledElevationDatabase" ) )
375  {
376  result = ossimElevationDatabase::loadState(kwl, prefix);
377  }
378  }
379
380  if(traceDebug())
381  {
382  ossimNotify(ossimNotifyLevel_DEBUG) << M << " result=" << (result?"true\n":"false\n");
383  }
384
385  return result;
386 }
387
388 bool ossimTiledElevationDatabase::saveState(ossimKeywordlist& kwl, const char* prefix) const
389 {
390  return ossimElevationDatabase::saveState(kwl, prefix);
391 }
392
393 // Private method:
395 {
396  bool result = false;
397  if ( ih.valid() )
398  {
399  // Get the image handler name.
400  ossimString imageHandlerName = ih->getClassName();
401  if ( (imageHandlerName == "ossimAdrgTileSource") ||
402  (imageHandlerName == "ossimCibCadrgTileSource") )
403  {
404  result = true;
405  }
406  }
407  return result;
408 }
409
411  ossimImageGeometry* geom,
412  ossimProjection* proj) const
413 {
414  //---
415  // Check for match of the following against the first entry:
416  // bands
417  // projection
418  // scalar type
419  // scale
420  //---
421  bool result = false;
422
423  if ( m_entries.size() && ih && geom && proj )
424  {
425  ossimRefPtr<const ossimImageHandler> entry0_ih = m_entries[0].m_sic->getImageHandler();
426
427  // Check scalar type and bands.
428  if ( (entry0_ih->getOutputScalarType() == ih->getOutputScalarType()) &&
429  (entry0_ih->getNumberOfOutputBands() == ih->getNumberOfOutputBands()) )
430  {
431  // Check the scale.
433  dynamic_cast<const ossimMapProjection*>(proj);
434  if ( mapProj.valid() )
435  {
437  dynamic_cast<const ossimMapProjection*>(m_referenceProj.get());
438
439  if ( mapProj->isGeographic() )
440  {
441  if ( refMapProj->getDecimalDegreesPerPixel() ==
442  mapProj->getDecimalDegreesPerPixel() )
443  {
444  result = true;
445  }
446  else if ( refMapProj->getMetersPerPixel() ==
447  mapProj->getMetersPerPixel() )
448  {
449  result = true;
450  }
451  }
452  }
453  else // sensor model
454  {
456  {
457  result = true;
458  }
459  }
460  }
461  }
462
463  return result;
464 }
465
467  ossimRefPtr<ossimImageGeometry> geom, ossimGrect& boundingRect) const
468 {
469  if ( geom.valid() )
470  {
471  std::vector<ossimGpt> corner(4);
472  if ( geom->getCornerGpts(corner[0], corner[1], corner[2], corner[3]) )
473  {
474  ossimGpt ulGpt(corner[0]);
475  ossimGpt lrGpt(corner[0]);
476  for ( ossim_uint32 i = 1; i < 4; ++i )
477  {
478  if ( corner[i].lon < ulGpt.lon ) ulGpt.lon = corner[i].lon;
479  if ( corner[i].lat > ulGpt.lat ) ulGpt.lat = corner[i].lat;
480  if ( corner[i].lon > lrGpt.lon ) lrGpt.lon = corner[i].lon;
481  if ( corner[i].lat < lrGpt.lat ) lrGpt.lat = corner[i].lat;
482  }
483  boundingRect = ossimGrect(ulGpt, lrGpt);
484  }
485  else
486  {
487  boundingRect.makeNan();
488  }
489  }
490 }
492 {
493  static const char M[] = "ossimTiledElevationDatabase::mapRegion";
494
495  if ( m_entries.size() && ( m_requestedRect.isLonLatNan() == false ) )
496  {
498  std::vector<ossimTiledElevationEntry>::iterator i = m_entries.begin();
499  while ( i != m_entries.end() )
500  {
501  mosaic->connectMyInputTo( (*i).m_sic.get() );
502  ++i;
503  }
504
505  // Compute the requested rectangle in view space.
507  if ( geom.valid() )
508  {
509  ossimDpt ulDpt;
510  ossimDpt lrDpt;
511  geom->worldToLocal(m_requestedRect.ul(), ulDpt);
512  geom->worldToLocal(m_requestedRect.lr(), lrDpt);
513
514  // Expand out to fall on even view coordinates.
515  ulDpt.x = std::floor(ulDpt.x);
516  ulDpt.y = std::floor(ulDpt.y);
517  lrDpt.x = std::ceil(lrDpt.x);
518  lrDpt.y = std::floor(lrDpt.y);
519
520  // Get new(expanded) corners in ground space.
521  ossimGpt ulGpt;
522  ossimGpt lrGpt;
523  geom->localToWorld(ulDpt, ulGpt);
524  geom->localToWorld(lrDpt, lrGpt);
525  theGroundRect = ossimGrect(ulGpt, lrGpt);
526
527  // Expanded requested rect in view space.
528  ossimIpt ulIpt = ulDpt;
529  ossimIpt lrIpt = lrDpt;
530  const ossimIrect VIEW_RECT(ulIpt, lrIpt);
531
532  // Get the data.
533  ossimRefPtr<ossimImageData> data = mosaic->getTile(VIEW_RECT, 0);
534  if ( data.valid() )
535  {
536  // Initialize the grid:
537  const ossimIpt SIZE( data->getWidth(), data->getHeight() );
538  const ossimDpt ORIGIN(ulGpt.lon, lrGpt.lat); // SouthWest corner
539  const ossimDpt SPACING( (lrGpt.lon-ulGpt.lon)/(SIZE.x-1),
540  (ulGpt.lat-lrGpt.lat)/(SIZE.y-1) );
541  if ( !m_grid ) m_grid = new ossimDblGrid();
542  m_grid->initialize(SIZE, ORIGIN, SPACING, ossim::nan());
543
544  if ( traceDebug() )
545  {
547  << M
548  << "\nrequested view rect: " << VIEW_RECT
549  << "\nexpanded ground rect: " << theGroundRect
550  << "\norigin: " << ORIGIN
551  << "\nsize: " << SIZE
552  << "\nspacing: " << SPACING << std::endl;
553  }
554
555  // Fill the grid:
556  switch( data->getScalarType() )
557  {
558  case OSSIM_SINT16:
559  {
560  fillGrid(ossim_sint16(0), data);
561  break;
562  }
563  case OSSIM_SINT32:
564  {
565  fillGrid(ossim_sint32(0), data);
566  break;
567  }
568  case OSSIM_FLOAT32:
569  {
570  fillGrid(ossim_float32(0), data);
571  break;
572  }
573  case OSSIM_FLOAT64:
574  {
575  fillGrid(ossim_float64(0), data);
576  break;
577  }
578  case OSSIM_UINT8:
579  case OSSIM_SINT8:
580  case OSSIM_USHORT11:
581  case OSSIM_USHORT12:
582  case OSSIM_USHORT13:
583  case OSSIM_USHORT14:
584  case OSSIM_USHORT15:
585  case OSSIM_UINT16:
586  case OSSIM_UINT32:
590  default:
591  {
592  std::string errMsg = M;
593  errMsg += " ERROR:\nUnhandled scalar type: ";
594  errMsg += data->getScalarTypeAsString().string();
595  throw ossimException(errMsg);
596  }
597  }
598
599  } // if ( data.valid() )
600
601  } // if ( geom.valid() )
602
603  } // if ( m_entries.size() && ...
604 }
605
606 template <class T> void ossimTiledElevationDatabase::fillGrid(T /* dummyTemplate */,
608 {
609  if ( data.valid() )
610  {
611  // Copy to grid reversing the lines as the ossimDblGrid's origin is the SW corner.
612  const ossim_float64 NP = data->getNullPix(0);
613  const T* buf = static_cast<T*>(data->getBuf(0));
614  if ( buf )
615  {
616  const ossimIpt SIZE( data->getWidth(), data->getHeight() );
617  ossim_int32 bufIdx = (SIZE.y-1) * data->getWidth();
618  ossim_int32 grdY = 0;
619  for (ossim_int32 y = SIZE.y-1; y >= 0; --y)
620  {
621  for (ossim_int32 x = 0; x < SIZE.x; ++ x)
622  {
623  ossim_float64 v = static_cast<ossim_float64>(buf[bufIdx+x]);
624  m_grid->setNode(x, grdY, (v!=NP?v:ossim::nan()) );
625  }
626  bufIdx -= data->getWidth();
627  ++grdY;
628  }
629  }
630  }
631 }
632
633 // Hidden from use...
635  const ossimTiledElevationDatabase& /* copy_this */)
636 {
637 }
638
639 // Private container class:
641  : m_rect(),
642  m_sic(0)
643 {}
644
647  : m_rect(rect),
648  m_sic(sic)
649 {}
650
652 {
653  ossimKeywordlist kwl;
654  saveState(kwl,0);
655  out << "\nossimTiledElevationDatabase @ "<< (ossim_uint64) this << "\n"
656  << kwl <<ends;
657  return out;
658 }
659
8 bit signed integer
void clear()
Erases the entire container.
Definition: ossimString.h:432
ossim_uint32 x
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
ossimTiledElevationDatabase()
default constructor
64 bit floating point
void setFileProcessor(ossimFileProcessorInterface *fpi)
Sets ossimFileProcessorInterfacecallback method to process files.
16 bit unsigned integer
void setRecurseFlag(bool flag)
Sets recurse flag.
virtual ~ossimTiledElevationDatabase()
ossimRefPtr< const ossimImageHandler > getImageHandler() const
ossim_uint32 y
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimProjection > m_referenceProj
Projection of the first entry.
void makeNan()
Definition: ossimGrect.h:284
float ossim_float32
double nan()
Definition: ossimCommon.h:135
double y
Definition: ossimDpt.h:165
ossimFilename getFilename() const
void addEntry(const ossimTiledElevationEntry &entry)
adds entry to the list checking for duplicates.
virtual bool isGeographic() const
16 bit signed integer
void initialize(const ossimIpt &size, const ossimDpt &origin, const ossimDpt &spacing, double null_value=OSSIM_DEFAULT_NULL_PIX_DOUBLE)
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
bool getCornerGpts(ossimGpt &ul, ossimGpt &ur, ossimGpt &lr, ossimGpt &ll) const
Assigns the ossimGpts with the ground coordinates of the four corresponding image corner points...
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &origin, ossim_uint32 resLevel=0)
Elevation source used for working with generic images opened by an ossimImageHandler.
32 bit floating point
Utility class to walk through directories and get a list of files to process.
32 bit unsigned integer
virtual void processFile(const ossimFilename &file)
ProcessFile method.
bool completely_within(const ossimGrect &rect) const
Definition: ossimGrect.cpp:218
void fillGrid(T dummyTemplate, ossimRefPtr< ossimImageData > data)
Templated fill grid method.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the geometry associated with the full mosaic.
Single image chain class.
OSSIM_DLL ossim_uint32 getNumberOfThreads()
Get the number threads to use from ossimPreferences or ossim::Thread.
double ossim_float64
virtual double getHeightAboveEllipsoid(const ossimGpt &)
Get height above ellipsoid for point.
bool isCompatible(ossimImageHandler *ih, ossimImageGeometry *geom, ossimProjection *proj) const
Check for match of the following against the first entry of: bands, projection, scalar type and scale...
bool pointWithin(const ossimGpt &gpt, bool considerHgt=false) const
METHOD: pointWithin(ossimGpt)
Definition: ossimGrect.h:232
ossimGrect theGroundRect
bool exists() const
ossim_float64 lon
Definition: ossimGpt.h:266
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual const ossimFilename & getFilename() const
Returns the filename.
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
signed short ossim_sint16
virtual const char * what() const
Returns the error message.
ossimDblGrid * m_grid
Hold region of elevation.
virtual bool pointHasCoverage(const ossimGpt &gpt) const
Satisfies pure virtual ossimElevSource::pointHasCoverage.
ossimRefPtr< ossimGeoid > m_geoid
std::string::size_type size() const
Definition: ossimString.h:405
32 bit signed integer
virtual ossimDpt getMetersPerPixel() const =0
unsigned long long ossim_uint64
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
Returns the GSD associated with this image in the active projection.
void setNumberOfThreads(ossim_uint32 nThreads)
Sets the max number of threads(jobs) to run at one time.
void mapRegion()
Loads m_requestedRect into m_grid from m_entries.
void getBoundingRect(ossimRefPtr< ossimImageGeometry > geom, ossimGrect &boundingRect) const
Initialize bounding rectangle from image handler.
virtual void close()
close method.
signed int ossim_sint32
virtual ossimString getScalarTypeAsString() const
const ossimGpt & ul() const
Definition: ossimGrect.h:252
bool isDirectoryBasedImage(ossimRefPtr< ossimImageHandler > ih)
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
ossimRefPtr< ossimCacheTileSource > addCache()
Adds a new cache to the current end of the chain.
void initializeDefaultFilterList()
Initializes the filter list with a default set of filtered out file names.
void initializeReferenceProjection()
Initializes m_referenceProj from the first entry.
ossimGrect combine(const ossimGrect &rect) const
Definition: ossimGrect.h:213
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual double getOffsetFromEllipsoid(const ossimGpt &gpt)
virtual double getHeightAboveMSL(const ossimGpt &gpt)
Get height above MSL for point.
double x
Definition: ossimDpt.h:164
Initialize from keyword list.
bool open(const ossimFilename &file, bool openOverview=true)
open method that takes an image file.
const char * c_str() const
Definition: ossimString.h:396
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
ossim_float64 lat
Definition: ossimGpt.h:265
8 bit unsigned integer
virtual bool open(const ossimString &connectionString)
Open a connection to a database.
Save the state to a keyword list.
ossimRefPtr< ossimSingleImageChain > m_sic
Hold pointer to single image chain.
void setWaitOnDirFlag(bool flag)
Sets waitOnDir flag.
bool isLonLatNan() const
Definition: ossimGrect.h:290
bool intersects(const ossimGrect &rect) const
Definition: ossimGrect.cpp:266
const ossimGpt & lr() const
Definition: ossimGrect.h:269
std::vector< ossimTiledElevationEntry > m_entries
void walk(const std::vector< ossimFilename > &files)
Takes an array of files.
void setNode(const ossimIpt &p, const double &value)
Definition: ossimDblGrid.h:107
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
int ossim_int32
const std::string & string() const
Definition: ossimString.h:414
void setAbortFlag(bool flag)
If set to true this stops files walking (aborts).
