ossimVpfTileSource.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Garrett Potts
6 //
7 // Description:
8 //
9 // $Id: ossimVpfTileSource.cpp 17932 2010-08-19 20:34:35Z dburken $
10 //----------------------------------------------------------------------------
12
14
16  :
18 {
19  theObject = this;
22 }
23
25 {
27 }
28
30  const char* prefix)const
31 {
32  return m_AnnotationSource->saveState(kwl, prefix);
33 }
34
36  const char* prefix)
37 {
38  if (ossimImageHandler::loadState(kwl, prefix))
39  {
40  return m_AnnotationSource->loadState(kwl, prefix);
41  }
42
43  return false;
44 }
45
47 {
49 }
50
52 {
54 }
55
57  const ossimIrect& tileRect, ossim_uint32 resLevel)
58 {
59  return m_AnnotationSource->getTile(tileRect, resLevel);
60 }
61
63 {
65 }
66
68 {
70 }
71
73 {
75
76  if(theBounds.hasNans())
77  {
78  return theBounds.ul().x;
79  }
80
81  return theBounds.height();
82 }
83
85 {
87
88  if(theBounds.hasNans())
89  {
90  return theBounds.ul().x;
91  }
92
93  return theBounds.height();
94 }
95
97 {
98  return 32;
99 }
100
102 {
104 }
105
106 //**************************************************************************************************
107 // Returns the image geometry object associated with this tile source or NULL if non defined.
108 //**************************************************************************************************
110 {
111  if (theGeometry.valid()) return theGeometry;
112
114  if ( annotGeom.valid() )
115  {
116  // Copy the annotation source's geometry as our own:
117  theGeometry = new ossimImageGeometry(*annotGeom);
118
119  // Set image things the geometry object should know about.
121
122  return theGeometry;
123  }
125 }
126
128 {
130 }
131
133 {
134  return m_AnnotationSource->getTileWidth();
135 }
136
138 {
140 }
141
143 {
144  return 0;
145 }
146
148 {
149  return 0;
150 }
151
153 {
154  return m_AnnotationSource->isOpen();
155 }
156
158 {
160 }
161
163 {
164  return m_AnnotationSource->getMinPixelValue(band);
165 }
166
168 {
169  return m_AnnotationSource->getMaxPixelValue(band);
170 }
171
173 {
174  return m_AnnotationSource->getView();
175 }
176
178 {
179  return m_AnnotationSource->getView();
180 }
181
183 {
184  return m_AnnotationSource->setView(baseObject);
185 }
186
187 void ossimVpfTileSource::getAllFeatures(std::vector<ossimVpfAnnotationFeatureInfo*>& featureList)
188 {
189  m_AnnotationSource->getAllFeatures(featureList);
190 }
191
192 void ossimVpfTileSource::setAllFeatures(std::vector<ossimVpfAnnotationFeatureInfo*>& featureList)
193 {
194  m_AnnotationSource->setAllFeatures(featureList);
195 }
196
198 {
200 }
201
203 {
205 }
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
ossimObject * theObject
virtual ossim_uint32 getTileWidth() const
ossimRefPtr< ossimImageGeometry > theGeometry
ossimFilename theImageFile
virtual ossim_uint32 getNumberOfDecimationLevels() const
ossimRefPtr< ossimVpfAnnotationSource > m_AnnotationSource
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual void setAllFeatures(const std::vector< ossimVpfAnnotationFeatureInfo *> &features)
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual ossim_uint32 getNumberOfInputBands() const
virtual void transformObjects(ossimImageGeometry *geom=0)
RTTI_DEF2(ossimVpfTileSource, "ossimVpfTileSource", ossimImageHandler, ossimViewInterface)
const ossimIpt & ul() const
Definition: ossimIrect.h:274
Retuns the min pixel value.
Returns the image geometry object associated with this tile source or NULL if not defined...
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
Saves the current state of this object.
virtual void getAllFeatures(std::vector< ossimVpfAnnotationFeatureInfo *> &features)
virtual void setNumberOfBands(ossim_uint32 bands)
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
Returns the default processing tile width.
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
virtual bool setView(ossimObject *baseObject)
void setAllFeatures(std::vector< ossimVpfAnnotationFeatureInfo *> &featureList)
unsigned int ossim_uint32
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
ossimScalarType
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix)
virtual void close()
virtual ossim_uint32 getImageTileWidth() const
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual bool isOpen() const
bool hasNans() const
Definition: ossimIrect.h:337
ossim_int32 x
Definition: ossimIpt.h:141
virtual ossimObject * getView()
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
virtual ossim_uint32 getImageTileHeight() const
void getAllFeatures(std::vector< ossimVpfAnnotationFeatureInfo *> &featureList)
