#include <ossimAnnotationSource.h>
Public Types | |
typedef std::vector< ossimRefPtr< ossimAnnotationObject > > | AnnotationObjectListType |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
ossimAnnotationSource (ossimImageSource *inputSource=0) | |
virtual | ~ossimAnnotationSource () |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual void | initialize () |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
virtual void | setNumberOfBands (ossim_uint32 bands) |
virtual bool | addObject (ossimAnnotationObject *anObject) |
virtual bool | deleteObject (ossimAnnotationObject *anObject) |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual void | computeBoundingRect () |
AnnotationObjectListType | pickObjects (const ossimDpt &imagePoint) |
AnnotationObjectListType | pickObjects (const ossimDrect &imageRect) |
const AnnotationObjectListType & | getObjectList () const |
AnnotationObjectListType & | getObjectList () |
void | deleteAll () |
virtual void | drawAnnotations (ossimRefPtr< ossimImageData > tile) |
ossimImageSourceFilter (ossimObject *owner=NULL) | |
ossimImageSourceFilter (ossimImageSource *inputSource) | |
ossimImageSourceFilter (ossimObject *owner, ossimImageSource *inputSource) | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
virtual ossim_uint32 | getNumberOfInputBands () const |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual void | refreshEvent (ossimRefreshEvent &event) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
void | allocate (const ossimIrect &rect) |
void | destroy () |
ossimAnnotationSource (const ossimAnnotationSource &rhs) | |
virtual | ~ossimImageSourceFilter () |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Definition at line 33 of file ossimAnnotationSource.h.
typedef std::vector<ossimRefPtr<ossimAnnotationObject> > ossimAnnotationSource::AnnotationObjectListType |
Definition at line 36 of file ossimAnnotationSource.h.
ossimAnnotationSource::ossimAnnotationSource | ( | ossimImageSource * | inputSource = 0 | ) |
inlineprotected |
Definition at line 120 of file ossimAnnotationSource.h.
Will add an object to the list. it will own the object added.
Reimplemented in ossimEsriShapeFileFilter, and ossimGeoAnnotationSource.
Definition at line 213 of file ossimAnnotationSource.cpp.
References theAnnotationObjectList.
Referenced by ossimChipperUtil::addCrossHairAnnotation(), ossimGeoAnnotationSource::addObject(), ATP::AtpAnnotatedImage::annotateCorrelations(), ATP::AtpAnnotatedImage::annotateFeatures(), ATP::AtpAnnotatedImage::annotateOverlap(), ATP::AtpAnnotatedImage::annotateResiduals(), ATP::AtpAnnotatedImage::annotateTPIDs(), ATP::AtpAnnotatedImage::drawBox(), and loadState().
protected |
Definition at line 47 of file ossimAnnotationSource.cpp.
References ossimIrect::height(), ossimImageData::initialize(), theImage, theNumberOfBands, theTile, and ossimIrect::width().
Referenced by ossimMapCompositionSource::getTile(), and getTile().
Reimplemented in ossimEsriShapeFileFilter, ossimGdalOgrVectorAnnotation, ossimGeoAnnotationSource, and ossimVpfAnnotationSource.
Definition at line 316 of file ossimAnnotationSource.cpp.
References ossimDrect::combine(), ossimDrect::hasNans(), ossimDrect::makeNan(), theAnnotationObjectList, and theRectangle.
Referenced by initialize().
void ossimAnnotationSource::deleteAll | ( | ) |
Clears theAnnotationObjectList vector. All elements are deleted.
Definition at line 399 of file ossimAnnotationSource.cpp.
Referenced by ossimEsriShapeFileFilter::loadShapeFile(), ossimVpfAnnotationSource::openDatabase(), and ~ossimAnnotationSource().
Will delete an object from the list. Note: the passed in pointer is no long valid.
Definition at line 224 of file ossimAnnotationSource.cpp.
protected |
Definition at line 38 of file ossimAnnotationSource.cpp.
References theImage, and theTile.
Referenced by initialize(), setNumberOfBands(), and ~ossimAnnotationSource().
Reimplemented in ossimMapCompositionSource, ossimEsriShapeFileFilter, ossimGdalOgrVectorAnnotation, and ossimVpfAnnotationSource.
Definition at line 406 of file ossimAnnotationSource.cpp.
References ossimRgbImage::getImageData(), ossimRgbImage::setCurrentImageData(), theAnnotationObjectList, theImage, and ossimRefPtr< T >::valid().
Referenced by ossimEsriShapeFileFilter::drawAnnotations(), ossimMapCompositionSource::drawAnnotations(), and getTile().
Will return the bounding rectangle.
Reimplemented in ossimMapCompositionSource, ossimEsriShapeFileFilter, and ossimGdalOgrVectorAnnotation.
Definition at line 104 of file ossimAnnotationSource.cpp.
References ossimIrect::combine(), ossimImageSource::getBoundingRect(), ossimIrect::hasNans(), ossimDrect::hasNans(), ossimIrect::makeNan(), ossimImageSourceFilter::theInputConnection, and theRectangle.
Referenced by ossimChipperUtil::addCrossHairAnnotation(), ossimVpfTileSource::getImageRectangle(), ossimVpfTileSource::getNumberOfLines(), and ossimVpfTileSource::getNumberOfSamples().
Reimplemented in ossimMapCompositionSource.
Definition at line 73 of file ossimAnnotationSource.cpp.
References ossimImageSource::getNumberOfOutputBands(), ossimSource::isSourceEnabled(), ossimImageSourceFilter::theInputConnection, and theNumberOfBands.
Referenced by ossimVpfTileSource::getNumberOfInputBands(), ossimOgrGdalTileSource::getNumberOfInputBands(), ossimVpfTileSource::getNumberOfOutputBands(), and ossimOgrGdalTileSource::getNumberOfOutputBands().
const ossimAnnotationSource::AnnotationObjectListType & ossimAnnotationSource::getObjectList | ( | ) | const |
Definition at line 426 of file ossimAnnotationSource.cpp.
Referenced by operator<<().
Definition at line 431 of file ossimAnnotationSource.cpp.
Definition at line 64 of file ossimAnnotationSource.cpp.
References ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), OSSIM_UINT8, and ossimImageSourceFilter::theInputConnection.
Referenced by ossimVpfTileSource::getOutputScalarType(), and ossimOgrGdalTileSource::getOutputScalarType().
Definition at line 143 of file ossimAnnotationSource.cpp.
References allocate(), drawAnnotations(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getTile(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_EMPTY, ossimImageData::setImageRectangleAndBands(), ossimSource::theEnableFlag, ossimImageSourceFilter::theInputConnection, theNumberOfBands, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Referenced by ossimVpfTileSource::getTile(), and ossimOgrGdalTileSource::getTile().
Will allow this source to initialize its data objects. If it needs to it should call its connection to get what it needs.
Definition at line 83 of file ossimAnnotationSource.cpp.
References computeBoundingRect(), destroy(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceFilter::initialize(), setNumberOfBands(), and ossimImageSourceFilter::theInputConnection.
Referenced by ossimMapCompositionSource::initialize().
Reimplemented in ossimEsriShapeFileFilter, ossimMapCompositionSource, ossimGdalOgrVectorAnnotation, ossimGeoAnnotationSource, and ossimVpfAnnotationSource.
Definition at line 266 of file ossimAnnotationSource.cpp.
References addObject(), ossimString::c_str(), ossimKeywordlist::find(), ossimRefPtr< T >::get(), ossimObject::getClassName(), ossimKeywordlist::getNumberOfSubstringKeys(), ossimAnnotationObjectFactory::instance(), ossimImageSourceFilter::loadState(), ossimNotify(), ossimNotifyLevel_WARN, ossimString::toString(), and ossimRefPtr< T >::valid().
Referenced by ossimGeoAnnotationSource::loadState(), ossimGdalOgrVectorAnnotation::loadState(), and ossimEsriShapeFileFilter::loadState().
ossimAnnotationSource::AnnotationObjectListType ossimAnnotationSource::pickObjects | ( | const ossimDpt & | imagePoint | ) |
Calls the isPointWithin all Annotation Objects. Note: Do not delete these objects.
Definition at line 346 of file ossimAnnotationSource.cpp.
ossimAnnotationSource::AnnotationObjectListType ossimAnnotationSource::pickObjects | ( | const ossimDrect & | imageRect | ) |
Note: do not delete the objects returned.
Definition at line 366 of file ossimAnnotationSource.cpp.
References ossimAnnotationObject::isPointWithin(), ossimDrect::ll(), ossimDrect::lr(), theAnnotationObjectList, ossimDrect::ul(), and ossimDrect::ur().
Saves the current state of this object.
Definition at line 244 of file ossimAnnotationSource.cpp.
References ossimString::c_str(), ossimImageSourceFilter::saveState(), theAnnotationObjectList, and ossimString::toString().
Referenced by ossimGeoAnnotationSource::saveState(), ossimGdalOgrVectorAnnotation::saveState(), and ossimEsriShapeFileFilter::saveState().
bands | This can be any number of bands; however, the annotator will only write to a max of 3, so if you have a 4 band image the fourth band will not be annotated. |
Definition at line 127 of file ossimAnnotationSource.cpp.
References destroy(), ossimRefPtr< T >::get(), ossimImageData::getNumberOfBands(), theNumberOfBands, and theTile.
Referenced by initialize(), ossimEsriShapeFileFilter::ossimEsriShapeFileFilter(), ossimGdalOgrVectorAnnotation::ossimGdalOgrVectorAnnotation(), and ossimVpfTileSource::ossimVpfTileSource().
protected |
These will be all your primitives in Example: lines, circles, text ...
Definition at line 149 of file ossimAnnotationSource.h.
Referenced by addObject(), ossimGeoAnnotationSource::computeBoundingRect(), computeBoundingRect(), deleteAll(), deleteObject(), drawAnnotations(), getObjectList(), pickObjects(), saveState(), and ossimGeoAnnotationSource::transformObjects().
protected |
This has all the routines we need for drawing lines, circles and polygons.
Definition at line 141 of file ossimAnnotationSource.h.
Referenced by allocate(), destroy(), ossimVpfAnnotationSource::drawAnnotations(), ossimEsriShapeFileFilter::drawAnnotations(), drawAnnotations(), and ossimMapCompositionSource::drawAnnotations().
protected |
The output band can be set to 1 or 3 for grey or RGB scale. We will default this to a 1 band image.
Definition at line 135 of file ossimAnnotationSource.h.
Referenced by allocate(), getNumberOfOutputBands(), getTile(), and setNumberOfBands().
protected |
What is the size of the image. This class is an image producer and it needs to know about its bounds. We will default the rectangle to an empty region.
Definition at line 128 of file ossimAnnotationSource.h.
Referenced by ossimVpfAnnotationSource::computeBoundingRect(), ossimGeoAnnotationSource::computeBoundingRect(), computeBoundingRect(), and getBoundingRect().
protected |
Definition at line 143 of file ossimAnnotationSource.h.
Referenced by allocate(), destroy(), ossimMapCompositionSource::drawAnnotations(), ossimMapCompositionSource::drawBorders(), ossimMapCompositionSource::getTile(), getTile(), ossimMapCompositionSource::initialize(), and setNumberOfBands().
