Functions
reproject.cpp File Reference
#include <iostream>
#include <iterator>
#include "base/data_types/ossimFilename.h"
#include "base/data_types/ossimString.h"
#include "imaging/factory/ossimImageHandlerRegistry.h"
#include "imaging/formats/ossimImageHandler.h"
#include "imaging/formats/ossimImageFileWriter.h"
#include "imaging/factory/ossimImageWriterFactoryRegistry.h"
#include "base/data_types/ossimGpt.h"
#include "projections/ossimProjection.h"
#include "projections/map_projections/ossimUtmProjection.h"
#include "projections/factory/ossimProjectionFactoryRegistry.h"
#include "imaging/tile_sources/ossimImageRenderer.h"
#include "init/ossimInit.h"
Go to the source code of this file.
Functions
void usage ()
void printOutputTypes ()
ossimProjectionnewUtmView (const ossimGpt &centerGround, const ossimDpt &metersPerPixel)
int main (int argc, char *argv[])
Function Documentation
◆ main()
int main ( int  argc,
char *  argv[]
Definition at line 53 of file reproject.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimProjectionFactoryRegistry::createProjection(), ossimImageWriterFactoryRegistry::createWriter(), ossimImageFileWriter::execute(), ossimImageHandler::getBoundingRect(), ossimImageHandler::getImageGeometry(), ossimProjection::getMetersPerPixel(), ossimInit::initialize(), ossimProjectionFactoryRegistry::instance(), ossimImageWriterFactoryRegistry::instance(), ossimInit::instance(), ossimImageHandlerRegistry::instance(), ossimProjection::lineSampleToWorld(), ossimIrect::midPoint(), newUtmView(), ossimImageHandlerRegistry::open(), ossimImageFileWriter::setFilename(), ossimImageRenderer::setView(), and usage().
54 {
55  ossimInit::instance()->initialize(argc, argv);
56
57  if(argc!=4)
58  {
59  usage();
60  }
61  else
62  {
63  // try to open up the passed in image
64  //
66
67  // try to create a writer for the output image type.
68  //
70
71
72  if(!handler)
73  {
74  cout << "Unable to open input image: "<< argv[2] << endl;
75  return 1;
76  }
77  if(!writer)
78  {
79  cout << "Unable to create writer of type: " << argv[1] << endl;
80  delete handler;
81  return 1;
82  }
83
84  ossimKeywordlist geom;
85  handler->getImageGeometry(geom);
86
87  // grab a projection if it exists
88  //
90
91  if (!inputProjection)
92  {
93  cout << "the input image has no input projection and can't be reprojected" << endl;
94  delete handler;
95  delete writer;
96  return 1;
97  }
98
99  // --------------------- SETUP The Resampleing process -------------
100  //
101  // the renderer is the resampler that fits into the chain.
102  // we will set it to a UTM view. We first get the inputs geometry and
103  // then get the scale from its projector.
104  //
105  // now lets set up the renderer
106  ossimImageRenderer* renderer = new ossimImageRenderer;
107
108  //
109  // get the center ground by running the center pixel
110  // through the handler's projection object
111  ossimIrect bounds = handler->getBoundingRect();
112  ossimGpt centerGround;
113  inputProjection->lineSampleToWorld(bounds.midPoint(), centerGround);
114
115  // now set the view to a new UTM view.
116  // I pass true in to tell the renderer that it owns the
117  // projection and will be responsible for deleting
118  //
119  renderer->setView(newUtmView(centerGround,
120  inputProjection->getMetersPerPixel()),
121  true);
122
123  // connect the renderer to the handler
124  renderer->connectMyInputTo(handler);
125
126  // specify the output file name
127  writer->setFilename(ossimFilename(argv[3]));
128
129  // now connect the writer to the renderer
130  writer->connectMyInputTo(0, renderer);
131
132  // execute the reprojection process.
133  writer->execute();
134
135  delete writer;
136  delete handler;
137  }
138
139  return 0;
140 }
void initialize(int &argc, char **argv)
Definition: ossimInit.cpp:119
virtual ossimImageHandler * open(const ossimFilename &fileName, bool trySuffixFirst=true, bool openOverview=true) const
open that takes a filename.
static ossimImageWriterFactoryRegistry * instance()
Pure virtual base class for image file writers.
ossimProjection * newUtmView(const ossimGpt &centerGround, const ossimDpt &metersPerPixel)
Definition: reproject.cpp:160
ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
ossimIpt midPoint() const
Definition: ossimIrect.h:750
void usage()
Definition: reproject.cpp:143
virtual ossimDpt getMetersPerPixel() const =0
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
static ossimProjectionFactoryRegistry * instance()
virtual void setFilename(const ossimFilename &file)
This class defines an abstract Handler which all image handlers(loaders) should derive from...
static ossimInit * instance()
Definition: ossimInit.cpp:89
ossimImageFileWriter * createWriter(const ossimFilename &filename) const
static ossimImageHandlerRegistry * instance()
Returns zero-based bounding rectangle of the image.
virtual void lineSampleToWorld(const ossimDpt &lineSampPt, ossimGpt &worldPt) const =0
virtual bool setView(ossimObject *baseObject)
virtual bool execute()
Calls: writeFile() writeMetaDataFiles()
◆ newUtmView()
ossimProjection * newUtmView ( const ossimGpt centerGround,
const ossimDpt metersPerPixel
Definition at line 160 of file reproject.cpp.
References ossimMapProjection::setMetersPerPixel(), ossimUtmProjection::setZone(), ossimDpt::x, and ossimDpt::y.
Referenced by main().
162 {
164
165  // we will make it a square pixel in meters
166  double averageGsd = (metersPerPixel.x + metersPerPixel.y)*.5;
167  utm->setZone(centerGround);
168  utm->setMetersPerPixel(ossimDpt(metersPerPixel));
169
170
171  return utm;
172 }
double y
Definition: ossimDpt.h:165
virtual void setMetersPerPixel(const ossimDpt &gsd)
void setZone(const ossimGpt &ground)
double x
Definition: ossimDpt.h:164
◆ printOutputTypes()
void printOutputTypes ( )
Definition at line 150 of file reproject.cpp.
References ossimImageWriterFactoryRegistry::getImageTypeList(), and ossimImageWriterFactoryRegistry::instance().
Referenced by usage().
151 {
152  std::vector<ossimString> outputType;
153
155  std::copy(outputType.begin(),
156  outputType.end(),
157  std::ostream_iterator<ossimString>(std::cout, "\n"));
158 }
virtual void getImageTypeList(std::vector< ossimString > &imageTypeList) const
getImageTypeList.
◆ usage()
void usage ( )
Definition at line 143 of file reproject.cpp.
References printOutputTypes().
144 {
145  cout << "repoject <output_type> <input filename> <output filename>" << endl
146  << "where output types are: " << endl;
148 }
void printOutputTypes()
Definition: reproject.cpp:150
