#include <ossimUtmProjection.h>
ossimUtmProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimUtmProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, ossim_int32 zone, char hemisphere) | |
ossimUtmProjection (ossim_int32 zone) | |
ossimUtmProjection (const ossimUtmProjection &src) | |
virtual ossimObject * | dup () const |
virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
Will take a point in meters and convert it to ground. More... | |
virtual ossimDpt | forward (const ossimGpt &latLon) const |
All map projections will convert the world coordinate to an easting northing (Meters). More... | |
virtual void | update () |
virtual void | setOrigin (const ossimGpt &origin) |
This will set the utm zone and utm origin base on origin passed in. More... | |
void | setZone (const ossimGpt &ground) |
void | setZone (ossim_int32 zone) |
void | setHemisphere (const ossimGpt &ground) |
void | setHemisphere (char hemisphere) |
ossim_int32 | getZone () const |
char | getHemisphere () const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
virtual std::ostream & | print (std::ostream &out) const |
Prints data members to stream. More... | |
virtual double | getFalseEasting () const |
virtual double | getFalseNorthing () const |
virtual bool | operator== (const ossimProjection &projection) const |
Returns TRUE if principal parameters are within epsilon tolerance. More... | |
virtual ossim_uint32 | getPcsCode () const |
Returns the EPSG PCS code based on datum, zone, and hemisphere. More... | |
ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimMapProjection (const ossimMapProjection &src) | |
virtual ossimGpt | origin () const |
virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
virtual double | getStandardParallel1 () const |
Derived classes should implement as needed. More... | |
virtual double | getStandardParallel2 () const |
virtual void | setPcsCode (ossim_uint32 pcsCode) |
virtual ossimString | getProjectionName () const |
Returns the projection name. More... | |
virtual double | getA () const |
ACCESS METHODS: More... | |
virtual double | getB () const |
virtual double | getF () const |
virtual ossimDpt | getMetersPerPixel () const |
virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
virtual const ossimDpt & | getUlEastingNorthing () const |
virtual const ossimGpt & | getUlGpt () const |
virtual const ossimDatum * | getDatum () const |
const ossimEllipsoid & | getEllipsoid () const |
const ossimGpt & | getOrigin () const |
virtual bool | isGeographic () const |
virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
SET METHODS: More... | |
virtual void | setAB (double a, double b) |
virtual void | setDatum (const ossimDatum *datum) |
Sets theDatum to datum. More... | |
virtual void | setMetersPerPixel (const ossimDpt &gsd) |
virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
virtual void | setUlTiePoints (const ossimGpt &gpt) |
virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
virtual void | setUlGpt (const ossimGpt &ulGpt) |
virtual void | assign (const ossimProjection &aProjection) |
virtual void | computeDegreesPerPixel () |
Computes the approximate resolution in degrees/pixel. More... | |
virtual void | computeMetersPerPixel () |
This will go from the ground point and give you an approximate meters per pixel. More... | |
void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
void | setMatrixScale (const ossimDpt &scale) |
void | setMatrixRotation (double rotation) |
void | setMatrixTranslation (const ossimDpt &translation) |
void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
Utility method to snap the tie point to some multiple. More... | |
void | snapTiePointToOrigin () |
void | setElevationLookupFlag (bool flag) |
bool | getElevationLookupFlag () const |
ossimUnitType | getModelTransformUnitType () const |
void | setModelTransformUnitType (ossimUnitType unit) |
bool | hasModelTransform () const |
virtual bool | isAffectedByElevation () const |
Implementation of pure virtual ossimProjection::isAffectedByElevation method. More... | |
void | setProjectionUnits (ossimUnitType units) |
ossimUnitType | getProjectionUnits () const |
OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimProjection () | |
virtual | ~ossimProjection () |
virtual void | getRoundTripError (const ossimDpt &imagePoint, ossimDpt &errorResult) const |
virtual void | getRoundTripError (const ossimGpt &groundPoint, ossimDpt &errorResult) const |
virtual void | getGroundClipPoints (ossimGeoPolygon &gpts) const |
virtual bool | operator!= (const ossimProjection &projection) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
static ossim_int32 | computeZone (const ossimGpt &gpt) |
static double | computeZoneMeridian (ossim_int32 zone) |
Return in decimal degrees the zone meridian. More... | |
Private Member Functions | |
ossim_int32 | Set_Transverse_Mercator_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing, double Scale_Factor) |
The function Set_Tranverse_Mercator_Parameters receives the ellipsoid parameters and Tranverse Mercator projection parameters as inputs, and sets the corresponding state variables. More... | |
void | Get_Transverse_Mercator_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *False_Easting, double *False_Northing, double *Scale_Factor) const |
The function Get_Transverse_Mercator_Parameters returns the current ellipsoid and Transverse Mercator projection parameters. More... | |
ossim_int32 | Convert_Geodetic_To_Transverse_Mercator (double Latitude, double Longitude, double *Easting, double *Northing) const |
The function Convert_Geodetic_To_Transverse_Mercator converts geodetic (latitude and longitude) coordinates to Transverse Mercator projection (easting and northing) coordinates, according to the current ellipsoid and Transverse Mercator projection coordinates. More... | |
ossim_int32 | Convert_Transverse_Mercator_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
The function Convert_Transverse_Mercator_To_Geodetic converts Transverse Mercator projection (easting and northing) coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Transverse Mercator projection parameters. More... | |
Private Attributes | |
double | theTranMerc_a |
double | theTranMerc_f |
double | theTranMerc_es |
double | theTranMerc_ebs |
double | theTranMerc_Origin_Lat |
double | theTranMerc_Origin_Long |
double | theTranMerc_False_Northing |
double | theTranMerc_False_Easting |
double | theTranMerc_Scale_Factor |
double | theTranMerc_ap |
double | theTranMerc_bp |
double | theTranMerc_cp |
double | theTranMerc_dp |
double | theTranMerc_ep |
double | theTranMerc_Delta_Easting |
double | theTranMerc_Delta_Northing |
ossim_int32 | theZone |
zone can be from 1 through 60 (0 == NOT SET) More... | |
char | theHemisphere |
can be N or S. More... | |
virtual | ~ossimMapProjection () |
void | updateFromTransform () |
virtual | ~ossimReferenced () |
ossimEllipsoid | theEllipsoid |
This method verifies that the projection parameters match the current pcs code. More... | |
ossimGpt | theOrigin |
const ossimDatum * | theDatum |
This is only set if we want to have built in datum shifting. More... | |
ossimDpt | theMetersPerPixel |
Holds the number of meters per pixel. More... | |
ossimDpt | theDegreesPerPixel |
Hold the decimal degrees per pixel. More... | |
ossimGpt | theUlGpt |
Hold tie point in decimal degrees. More... | |
ossimDpt | theUlEastingNorthing |
Hold tie point as easting northing. More... | |
ossimDpt | theFalseEastingNorthing |
Hold the false easting northing. More... | |
ossim_uint32 | thePcsCode |
Projection Coordinate System(PCS) code. More... | |
bool | theElevationLookupFlag |
ossimMatrix4x4 | theModelTransform |
ossimMatrix4x4 | theInverseModelTransform |
ossimUnitType | theModelTransformUnitType |
ossimUnitType | theProjectionUnits |
Linear units of the projection as indicated in the projection's specification: More... | |
ossimErrorCode | theErrorStatus |
Definition at line 16 of file ossimUtmProjection.h.
ossimUtmProjection::ossimUtmProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid() , |
const ossimGpt & | origin = ossimGpt() |
Definition at line 61 of file ossimUtmProjection.cpp.
References ossimMapProjection::origin(), setHemisphere(), setZone(), and update().
Referenced by dup().
ossimUtmProjection::ossimUtmProjection | ( | const ossimEllipsoid & | ellipsoid, |
const ossimGpt & | origin, | ||
ossim_int32 | zone, | ||
char | hemisphere | ||
Definition at line 89 of file ossimUtmProjection.cpp.
References setHemisphere(), setZone(), and update().
ossimUtmProjection::ossimUtmProjection | ( | ossim_int32 | zone | ) |
Definition at line 118 of file ossimUtmProjection.cpp.
References setZone(), and update().
ossimUtmProjection::ossimUtmProjection | ( | const ossimUtmProjection & | src | ) |
Definition at line 143 of file ossimUtmProjection.cpp.
References setHemisphere(), setZone(), theHemisphere, theZone, and update().
static |
Definition at line 304 of file ossimUtmProjection.cpp.
References ossimGpt::latd(), ossimGpt::lond(), ossimGpt::lonr(), and M_PI.
Referenced by loadState(), setZone(), and ossimSonomaSensor::updateModel().
static |
Definition at line 337 of file ossimUtmProjection.cpp.
Referenced by loadState(), setZone(), and update().
private |
If any errors occur, the error code(s) are returned by the function, otherwise TRANMERC_NO_ERROR is returned.
Latitude : Latitude in radians (input) Longitude : Longitude in radians (input) Easting : Easting/X in meters (output) Northing : Northing/Y in meters (output)
Definition at line 558 of file ossimUtmProjection.cpp.
References M_PI, SPHSN, SPHTMD, theTranMerc_ebs, theTranMerc_False_Easting, theTranMerc_False_Northing, theTranMerc_Origin_Lat, theTranMerc_Origin_Long, theTranMerc_Scale_Factor, TWO_PI, and UTM_NO_ERROR.
Referenced by forward(), and Set_Transverse_Mercator_Parameters().
private |
Easting : Easting/X in meters (input) Northing : Northing/Y in meters (input) Latitude : Latitude in radians (output) Longitude : Longitude in radians (output)
Definition at line 713 of file ossimUtmProjection.cpp.
References M_PI, RAD_PER_DEG, SPHSN, SPHSR, SPHTMD, theTranMerc_ebs, theTranMerc_False_Easting, theTranMerc_False_Northing, theTranMerc_Origin_Lat, theTranMerc_Origin_Long, theTranMerc_Scale_Factor, TWO_PI, and UTM_NO_ERROR.
Referenced by inverse().
Implements ossimProjection.
Definition at line 227 of file ossimUtmProjection.cpp.
References ossimUtmProjection().
Definition at line 205 of file ossimUtmProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Transverse_Mercator(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
Referenced by ossimApplanixUtmModel::updateModel(), and ossimSonomaSensor::updateModel().
private |
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude in radians at the origin of the (output) projection Central_Meridian : Longitude in radians at the center of the (output) projection False_Easting : Easting/X at the center of the projection (output) False_Northing : Northing/Y at the center of the projection (output) Scale_Factor : Projection scale factor (output)
Definition at line 521 of file ossimUtmProjection.cpp.
References theTranMerc_a, theTranMerc_f, theTranMerc_False_Easting, theTranMerc_False_Northing, theTranMerc_Origin_Lat, theTranMerc_Origin_Long, and theTranMerc_Scale_Factor.
Definition at line 886 of file ossimUtmProjection.cpp.
References theTranMerc_False_Easting.
Definition at line 891 of file ossimUtmProjection.cpp.
References theTranMerc_False_Northing.
char ossimUtmProjection::getHemisphere | ( | ) | const |
Definition at line 238 of file ossimUtmProjection.cpp.
References theHemisphere.
Referenced by ossimEpsgProjectionDatabase::getCodeFromUtmProj(), ossimPdfWriter::getLgiDictProjectionType(), ossimGpkgSpatialRefSysRecord::init(), ossimChipProcTool::newIdentityProjection(), ossimGeoTiff::parseProjection(), and ossimNitfWriterBase::writeGeometry().
This overrides ossimMapProjection::getPcsCode(). Sets ossimMapProjection::thePcsCode on success.
Definition at line 927 of file ossimUtmProjection.cpp.
References ossimEpsgProjectionDatabase::getCodeFromUtmProj(), and ossimEpsgProjectionDatabase::instance().
ossim_int32 ossimUtmProjection::getZone | ( | ) | const |
Definition at line 233 of file ossimUtmProjection.cpp.
References theZone.
Definition at line 192 of file ossimUtmProjection.cpp.
References Convert_Transverse_Mercator_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Referenced by ossimSonomaSensor::lineSampleHeightToWorld(), ossimSonomaSensor::lineSampleToWorld(), and ossimApplanixUtmModel::updateModel().
Definition at line 342 of file ossimUtmProjection.cpp.
References ossimString::c_str(), computeZone(), computeZoneMeridian(), ossimKeywordlist::find(), ossimKeywordNames::HEMISPHERE_KW, ossimGpt::latd(), ossimMapProjection::loadState(), ossimGpt::lond(), setHemisphere(), ossimMapProjection::theOrigin, theZone, ossimString::trim(), ossimString::upcase(), update(), and ossimKeywordNames::ZONE_KW.
Definition at line 899 of file ossimUtmProjection.cpp.
References ossimMapProjection::operator==(), theHemisphere, and theZone.
Returns stream&.
Definition at line 876 of file ossimUtmProjection.cpp.
References ossimMapProjection::print(), theHemisphere, and theZone.
Definition at line 399 of file ossimUtmProjection.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::HEMISPHERE_KW, ossimMapProjection::saveState(), theHemisphere, theZone, and ossimKeywordNames::ZONE_KW.
private |
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Origin_Latitude : Latitude in radians at the origin of the (input) projection Central_Meridian : Longitude in radians at the center of the (input) projection False_Easting : Easting/X at the center of the projection (input) False_Northing : Northing/Y at the center of the projection (input) Scale_Factor : Projection scale factor (input)
Definition at line 414 of file ossimUtmProjection.cpp.
References Convert_Geodetic_To_Transverse_Mercator(), M_PI, MAX_DELTA_LONG, MAX_LAT, theTranMerc_a, theTranMerc_ap, theTranMerc_bp, theTranMerc_cp, theTranMerc_Delta_Easting, theTranMerc_Delta_Northing, theTranMerc_dp, theTranMerc_ebs, theTranMerc_ep, theTranMerc_es, theTranMerc_f, theTranMerc_False_Easting, theTranMerc_False_Northing, theTranMerc_Origin_Lat, theTranMerc_Origin_Long, TWO_PI, and UTM_NO_ERROR.
Referenced by update().
void ossimUtmProjection::setHemisphere | ( | const ossimGpt & | ground | ) |
Definition at line 275 of file ossimUtmProjection.cpp.
References ossimGpt::latd().
Referenced by ossimEpsgProjectionFactory::createProjFromAutoCode(), ossimEpsgProjectionDatabase::createProjFromUtmCode(), ossimChipperUtil::getNewUtmProjection(), loadState(), ossimChipProcTool::newIdentityProjection(), ossimChipProcTool::newUtmProjection(), ossimUtmProjection(), setOrigin(), and ossimSonomaSensor::updateModel().
void ossimUtmProjection::setHemisphere | ( | char | hemisphere | ) |
Definition at line 281 of file ossimUtmProjection.cpp.
References ossimGpt::latd(), theHemisphere, ossimMapProjection::theOrigin, and theTranMerc_False_Northing.
Definition at line 243 of file ossimUtmProjection.cpp.
References ossimGpt::latd(), ossimMapProjection::origin(), setHemisphere(), ossimMapProjection::setOrigin(), and setZone().
Referenced by ATP::AtpGenerator::constructChain(), and ossimEpsgProjectionFactory::createProjFromAutoCode().
void ossimUtmProjection::setZone | ( | const ossimGpt & | ground | ) |
Definition at line 254 of file ossimUtmProjection.cpp.
References computeZone().
Referenced by ossimEpsgProjectionFactory::createProjFromAutoCode(), ossimEpsgProjectionDatabase::createProjFromUtmCode(), ossimChipperUtil::getNewUtmProjection(), ossimChipProcTool::newIdentityProjection(), ossimChipProcTool::newUtmProjection(), newUtmView(), ossimUtmProjection(), setOrigin(), ossimApplanixUtmModel::updateModel(), and ossimSonomaSensor::updateModel().
void ossimUtmProjection::setZone | ( | ossim_int32 | zone | ) |
Definition at line 259 of file ossimUtmProjection.cpp.
References computeZone(), computeZoneMeridian(), ossimGpt::datum(), ossimGpt::latd(), ossimGpt::lond(), ossimGpt::lonr(), ossimMapProjection::theDatum, ossimMapProjection::theOrigin, theTranMerc_Origin_Long, and theZone.
Definition at line 168 of file ossimUtmProjection.cpp.
References computeZoneMeridian(), ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latd(), ossimGpt::latr(), ossimGpt::lond(), ossimGpt::lonr(), ossimMapProjection::origin(), Set_Transverse_Mercator_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, theHemisphere, ossimMapProjection::theOrigin, theTranMerc_False_Easting, theTranMerc_False_Northing, theTranMerc_Scale_Factor, theZone, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimEpsgProjectionFactory::createProjFromAutoCode(), loadState(), and ossimUtmProjection().
private |
can be N or S.
Definition at line 223 of file ossimUtmProjection.h.
Referenced by getHemisphere(), operator==(), ossimUtmProjection(), print(), saveState(), setHemisphere(), and update().
private |
Definition at line 188 of file ossimUtmProjection.h.
Referenced by Get_Transverse_Mercator_Parameters(), and Set_Transverse_Mercator_Parameters().
private |
Definition at line 205 of file ossimUtmProjection.h.
Referenced by Set_Transverse_Mercator_Parameters().
private |
Definition at line 206 of file ossimUtmProjection.h.
private |
Definition at line 207 of file ossimUtmProjection.h.
private |
Definition at line 212 of file ossimUtmProjection.h.
private |
Definition at line 213 of file ossimUtmProjection.h.
private |
Definition at line 208 of file ossimUtmProjection.h.
private |
Definition at line 194 of file ossimUtmProjection.h.
Referenced by Convert_Geodetic_To_Transverse_Mercator(), Convert_Transverse_Mercator_To_Geodetic(), and Set_Transverse_Mercator_Parameters().
private |
Definition at line 209 of file ossimUtmProjection.h.
private |
Definition at line 192 of file ossimUtmProjection.h.
private |
Definition at line 189 of file ossimUtmProjection.h.
private |
Definition at line 201 of file ossimUtmProjection.h.
Referenced by Convert_Geodetic_To_Transverse_Mercator(), Convert_Transverse_Mercator_To_Geodetic(), Get_Transverse_Mercator_Parameters(), getFalseEasting(), Set_Transverse_Mercator_Parameters(), and update().
private |
Definition at line 200 of file ossimUtmProjection.h.
Referenced by Convert_Geodetic_To_Transverse_Mercator(), Convert_Transverse_Mercator_To_Geodetic(), Get_Transverse_Mercator_Parameters(), getFalseNorthing(), Set_Transverse_Mercator_Parameters(), setHemisphere(), and update().
private |
Definition at line 198 of file ossimUtmProjection.h.
Referenced by Convert_Geodetic_To_Transverse_Mercator(), Convert_Transverse_Mercator_To_Geodetic(), Get_Transverse_Mercator_Parameters(), and Set_Transverse_Mercator_Parameters().
private |
Definition at line 199 of file ossimUtmProjection.h.
Referenced by Convert_Geodetic_To_Transverse_Mercator(), Convert_Transverse_Mercator_To_Geodetic(), Get_Transverse_Mercator_Parameters(), Set_Transverse_Mercator_Parameters(), and setZone().
private |
Definition at line 202 of file ossimUtmProjection.h.
Referenced by Convert_Geodetic_To_Transverse_Mercator(), Convert_Transverse_Mercator_To_Geodetic(), Get_Transverse_Mercator_Parameters(), and update().
private |
Definition at line 218 of file ossimUtmProjection.h.
Referenced by getZone(), loadState(), operator==(), ossimUtmProjection(), print(), saveState(), setZone(), and update().
