24 class RadiometricData;
25 class RadiometricCompensationData;
27 class ProcessingParameters;
28 class DataHistogramSignalData;
This class is able to read the SAR leader file descriptor record of the leader file.
static const int DataHistogramSignalDataID
DataQuality * get_DataQuality()
AttitudeData * get_AttitudeData()
This class is able to read a data quality record.
Trailer & operator=(const Trailer &rhs)
Copy operator.
static const int FileDescriptorID
DataSetSummary * get_DataSetSummary()
DataHistogramProcessedData8 * get_DataHistogramProcessedData8()
static const int RadiometricCompensationDataID
ProcessingParameters * get_ProcessingParameters()
static const int ProcessingParametersID
This class is able to read the trailer file of the RadarSat file structure.
static const int DataSetSummaryID
This class is able to read a data histogram record - Signal data.
void ClearRecords()
Removes all the previous records from the Trailer.
static const int AttitudeDataID
DataHistogramSignalData * get_DataHistogramSignalData()
This class is able to read a radiometric data record.
static const int DataHistogramProcessedData8ID
RadiometricData * get_RadiometricData()
This class is able to read a Radiometric Compensation data record.
static const int DataQualityID
RadiometricCompensationData * get_RadiometricCompensationData()
friend std::istream & operator>>(std::istream &is, Trailer &data)
This function reads a Trailer from a stream.
This class is able to read a Detailed processing parameters record.
std::basic_istream< char > istream
Base class for char input streams.
static const int RadiometricDataID
This class is able to read the SAR leader data set summary record of the leader file.
FileDescriptor * get_FileDescriptor()
std::map< int, RadarSatRecord * > _records
This class is able to read a Attitude data record.
friend std::ostream & operator<<(std::ostream &os, const Trailer &data)
This function writes the Trailer in a stream.
std::basic_ostream< char > ostream
Base class for char output streams.
