Classes | Public Member Functions | Private Member Functions | Private Attributes | List of all members
ATP::ossimDescriptorSource Class Reference
Finds auto-tie-points using the descriptor-based matching algorithm. More...
#include <ossimDescriptorSource.h>
Inheritance diagram for ATP::ossimDescriptorSource:
ATP::AtpTileSource ossimImageCombiner ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Classes
struct  SortFunc
 ossimDescriptorSource (AtpGenerator *generator)
virtual ~ossimDescriptorSource ()
virtual void initialize ()
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &origin, ossim_uint32 rLevel=0)
 Derived classes implement their particular tiepoint matching algorithms for the requested tile. More...
- Public Member Functions inherited from ATP::AtpTileSource
 AtpTileSource (AtpGenerator *generator)
virtual ~AtpTileSource ()
AtpListgetTiePoints ()
 This list resets with every getTile() call , so make sure tiepoints from previous getTile() calls are being accumulated. More...
void filterPoints ()
void setTiePoints (ossim::TiePointList &atpList)
 Used for testing. More...
- Public Member Functions inherited from ossimImageCombiner
 ossimImageCombiner ()
 ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag)
 ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual bool saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const
virtual void updateRects ()
 This will go through and precompute the bounding rects of each input image. More...
 Returns the number of bands available from the input. More...
virtual ossim_uint32 getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to retrieve the number of overlapping images withint the given rect. More...
virtual void getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to populate the result with the index of the overlapping images. More...
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool hasDifferentInputs () const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
 ossimDescriptorSource (ossimConnectableObject::ConnectableObjectList &inputSources)
Private Attributes
struct ATP::ossimDescriptorSource::SortFunc sortFunc
unsigned int m_cmpPatchInflation
Additional Inherited Members
- Protected Member Functions inherited from ATP::AtpTileSource
 AtpTileSource ()
 AtpTileSource (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual void allocate ()
void filterWithParallax ()
void computeParallax ()
void computeParallaxStatistics ()
void filterWithoutParallax ()
void pruneList ()
 Caps the max number of TPs given the list, which is the list of filtered TPs for the tile. More...
void initializeStaticMembers ()
- Protected Member Functions inherited from ossimImageCombiner
virtual ~ossimImageCombiner ()
void precomputeBounds () const
virtual ~ossimReferenced ()
- Protected Attributes inherited from ATP::AtpTileSource
std::shared_ptr< AtpGeneratorm_generator
AtpList m_tiePoints
ParallaxInfo m_paxInfo
bool m_considerParallax
- Protected Attributes inherited from ossimImageCombiner
ossim_uint32 theLargestNumberOfInputBands
ossim_uint32 theInputToPassThrough
bool theHasDifferentInputs
ossimRefPtr< ossimImageDatatheNormTile
std::vector< ossimIrecttheFullResBounds
bool theComputeFullResBoundsFlag
ossim_uint32 theCurrentIndex
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
- Static Protected Attributes inherited from ATP::AtpTileSource
static double s_minVectorResDiff = 0
static double s_maxDiffRatio = 1.0
static double s_cosMaxAngleDiff = 0
static double s_maxPaxDev = 1.0
static double s_maxPaxPix = 2.0
static unsigned int s_minNumConsistent = 3
static unsigned int s_percentConsistent = 50
static unsigned int s_numTpsPerTile = 2
static bool s_useRasterMode = false
static bool s_initialized = false
static unsigned int s_numFilterIterations = 0
Detailed Description
Definition at line 23 of file ossimDescriptorSource.h.
◆ ossimDescriptorSource() [1/3]
ATP::ossimDescriptorSource::ossimDescriptorSource ( AtpGenerator generator)
Definition at line 32 of file ossimDescriptorSource.cpp.
33 : AtpTileSource(generator)
34 {
35  // PRIVATE, SHOULD NEVER BE CALLED. WOULD NEED TO CALL INITIALIZE
36 }
◆ ~ossimDescriptorSource()
ATP::ossimDescriptorSource::~ossimDescriptorSource ( )
virtual
Definition at line 38 of file ossimDescriptorSource.cpp.
39 {
40 }
◆ ossimDescriptorSource() [2/3]
ATP::ossimDescriptorSource::ossimDescriptorSource ( )
private
Definition at line 21 of file ossimDescriptorSource.cpp.
22 {
23  // PRIVATE, SHOULD NEVER BE CALLED. WOULD NEED TO CALL INITIALIZE
24 }
◆ ossimDescriptorSource() [3/3]
ATP::ossimDescriptorSource::ossimDescriptorSource ( ossimConnectableObject::ConnectableObjectList inputSources)
private
Definition at line 26 of file ossimDescriptorSource.cpp.
References initialize().
27 : AtpTileSource(inputSources)
28 {
29  initialize();
30 }
Member Function Documentation
◆ getTile()
ossimRefPtr< ossimImageData > ATP::ossimDescriptorSource::getTile ( const ossimIrect origin,
ossim_uint32  rLevel = 0
virtual
It is not clear what the output tile needs to be, since the product of this filter is the list of tiepoints (available through the getTiePoints() method). Recommend simply passing through the corresponding REF image tile.
Implements ATP::AtpTileSource.
Definition at line 69 of file ossimDescriptorSource.cpp.
References ATP::AtpTileSource::allocate(), ossim::JsonParam::asString(), ossim::JsonParam::asUint(), CINFO, ATP::convertToIpl(), CWARN, ossim::JsonConfig::diagnosticLevel(), ossimIrect::expand(), ATP::AtpTileSource::filterPoints(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimConnectableObject::getNumberOfInputs(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), m_cmpPatchInflation, ATP::AtpTileSource::m_generator, ATP::AtpTileSource::m_tiePoints, ATP::AtpTileSource::m_tile, n, OSSIM_EMPTY, ossim::JsonConfig::paramExists(), ossimImageData::setImageRectangle(), sortFunc, ossimString::upcase(), and ossimImageData::write().
71 {
72  static const char* MODULE = "ossimDescriptorSource::getTile() ";
73  AtpConfig& config = AtpConfig::instance();
74
75  if (config.diagnosticLevel(2))
76  CINFO<<"\n\n"<< MODULE << " -- tileRect: "<<tileRect<<endl;
77  m_tiePoints.clear();
78  if (!m_tile)
79  allocate();
80
81  // The tile rect (in view space) is referenced by the tiepoint filtering code:
82  m_tile->setImageRectangle(tileRect);
83
84  // Make sure there are at least two images as input.
85  if(getNumberOfInputs() < 2)
86  {
87  CINFO << MODULE << " ERROR: wrong number of inputs " << getNumberOfInputs() << " when expecting at least 2 \n";
88  return 0;
89  }
90
91  // The tileRect passed in is in a common map-projected view space. Need to transform the rect
92  // into image space for both ref and cmp images:
93  ossimIrect cmpViewRect (tileRect);
94  cmpViewRect.expand(ossimIpt(m_cmpPatchInflation, m_cmpPatchInflation));
95  ossimIrect refRect (m_generator->getRefIVT()->getViewToImageBounds(tileRect));
96  ossimIrect cmpRect (m_generator->getCmpIVT()->getViewToImageBounds(cmpViewRect));
97
98  // Retrieve both the ref and cmp image data
99  ossimRefPtr<ossimImageData> ref_tile = m_generator->getRefChain()->getTile(refRect, resLevel);
100  if (ref_tile->getDataObjectStatus() == OSSIM_EMPTY)
101  {
102  CWARN << MODULE << " ERROR: could not get REF tile with rect " << refRect << "\n";
103  return m_tile;
104  }
105  if (config.diagnosticLevel(5))
106  ref_tile->write("REF_TILE.RAS");
107
108
109  ossimRefPtr<ossimImageData> cmp_tile = m_generator->getCmpChain()->getTile(cmpRect, resLevel);
110  if (cmp_tile->getDataObjectStatus() == OSSIM_EMPTY)
111  {
112  CWARN << MODULE << " ERROR: could not get CMP tile with rect " << cmpRect << "\n";
113  return m_tile;
114  }
115  if (config.diagnosticLevel(5))
116  cmp_tile->write("CMP_TILE.RAS");
117
118  //m_tile = ref_tile;
119
120  // Convert both into OpenCV Mat objects using the Ipl image.
121  IplImage* refImage = convertToIpl(ref_tile.get());
122  IplImage* cmpImage = convertToIpl(cmp_tile.get());
123  cv::Mat queryImg = cv::cvarrToMat(refImage);
124  cv::Mat trainImg = cv::cvarrToMat(cmpImage);
125
126  // Get the KeyPoints using appropriate descriptor.
127  vector<cv::KeyPoint> kpA;
128  vector<cv::KeyPoint> kpB;
129  cv::Mat desA;
130  cv::Mat desB;
131
132  ossimString descriptorType (config.getParameter("descriptor").asString());
133  descriptorType.upcase();
134
135  // Search for features and compute descriptors for all:
136  cv::Ptr<cv::Feature2D> detector;
137  if(descriptorType == "AKAZE")
138  detector = cv::AKAZE::create();
139  else if(descriptorType == "KAZE")
140  detector = cv::KAZE::create();
141  else if(descriptorType == "ORB")
142  detector = cv::ORB::create();
143  else if(descriptorType == "SURF")
144  detector = cv::xfeatures2d::SURF::create();
145  else if(descriptorType == "SIFT")
146  detector = cv::xfeatures2d::SIFT::create();
147  else
148  {
149  CWARN << MODULE << " WARNING: No such descriptor as " << descriptorType << "\n";
150  return m_tile;
151  }
152
153 #if 1
154  detector->detectAndCompute(queryImg, cv::noArray(), kpA, desA);
155  detector->detectAndCompute(trainImg, cv::noArray(), kpB, desB);
156
157 #else
158  // Separate detect and compute to limit the number of features for which descriptors are
159  // computed... Perform detection:
160  detector->detect(queryImg, kpA);
161  detector->detect(trainImg, kpB);
162
163  //CINFO<<"\n -- Ref tileRect: "<<refRect<<endl;
164  //CINFO<<"\n -- Cmp tileRect: "<<cmpRect<<endl;
165  CINFO << "DETECTIONS: "<<kpA.size() << ", "<<kpB.size() << endl;//TODO REMOVE
166
167  // Limit strongest detections to max number of features per tile on query image:
168  unsigned int maxNumFeatures = config.getParameter("numFeaturesPerTile").asUint();
169  //CINFO << "\n numFeatures= "<<maxNumFeatures << endl;
170  if (kpA.size() > maxNumFeatures)
171  {
172  sort(kpA.begin(), kpA.end(), sortFunc);
173  kpA.resize(maxNumFeatures);
174  }
175
176  //if (kpB.size() > maxNumFeatures)
177  //{
178  // sort(kpB.begin(), kpB.end(), sortFunc);
179  // kpB.resize(maxNumFeatures);
180  //}
181  //CINFO << "\nTRIM:\n kpA.size = "<<kpA.size() << endl;
182  //CINFO << " kpb.size = "<<kpA.size() << endl;
183
184  // Now perform descriptor computations on remaining features:
185  detector->compute(queryImg, kpA, desA);
186  detector->compute(trainImg, kpB, desB);
187  //CINFO << "\nCOMPUTE:\n desA.size = "<<desA.size() << endl;
188  //CINFO << " desB.size = "<<desB.size() << endl;
189
190 #endif
191
192  if (config.diagnosticLevel(5))
193  {
194  CINFO << "\nDETECT:\n kpA.size = " << kpA.size() << endl;
195  CINFO << " kpb.size = " << kpA.size() << endl;
196  CINFO << "\nCOMPUTE:\n desA.size = " << desA.size() << endl;
197  CINFO << " desB.size = " << desB.size() << endl;
198  }
199
200  // Get the DPoints using the appropriate matcher.
201  std::vector< std::vector<cv::DMatch> > matches;
202  if(!(desA.empty() || desB.empty()))
203  {
204  std::string matcherType = config.getParameter("matcher").asString();
205  uint k = config.getParameter("maxNumMatchesPerFeature").asUint();
206  if (config.paramExists("k")) // support legacy keywords
207  k = config.getParameter("k").asUint();
208  if (kpA.size() < k)
209  k = kpA.size();
210  transform(matcherType.begin(), matcherType.end(), matcherType.begin(),::toupper);
211
212  shared_ptr<cv::DescriptorMatcher> matcher;
213  if(matcherType == "FLANN")
214  {
215  if(desA.type()!=CV_32F)
216  desA.convertTo(desA, CV_32F);
217  if(desB.type()!=CV_32F)
218  desB.convertTo(desB, CV_32F);
219
220  matcher.reset(new cv::FlannBasedMatcher);
221  }
222  else if(matcherType == "BF")
223  {
224  if(desA.type()!=CV_8U)
225  desA.convertTo(desA, CV_8U);
226  if(desB.type()!=CV_8U)
227  desB.convertTo(desB, CV_8U);
228
229  int normType;
230  std::string ErrorFunction = config.getParameter("normType").asString();
231  if(ErrorFunction == "NORM_L1"){
232  normType = cv::NORM_L1;
233  } else if(ErrorFunction == "NORM_L2") {
234  normType = cv::NORM_L2;
235  } else if(ErrorFunction == "NORM_HAMMING") {
236  normType = cv::NORM_HAMMING;
237  } else {
238  std::string descriptorUsed = config.getParameter("descriptor").asString();
239  if(descriptorUsed == "SURF" || descriptorUsed == "SIFT"){
240  normType = cv::NORM_L2;
241  } else {
242  normType = cv::NORM_HAMMING;
243  }
244  }
245
246  matcher.reset(new cv::BFMatcher(normType, true));
247  }
248  else
249  {
250  CWARN << MODULE << " WARNING: No such matcher as " << matcherType << "\n";
251  return m_tile;
252  }
253
254  matcher->knnMatch(desA, desB, matches, k);
255  }
256
257  float minDistance = INT_MAX;
258  float maxDistance = 0;
259
260  // Find the highest distance to compute the relative confidence of each match
261  for (auto &featureMatches : matches)
262  {
263  for (auto &match : featureMatches)
264  {
265  if (minDistance >match.distance)
266  minDistance = match.distance;
267  if (maxDistance < match.distance)
268  maxDistance = match.distance;
269  }
270  }
271
272  // Experimental: force min distance to be the perfect match case = 0:
273  minDistance = 0.0;
274  float delta = maxDistance - minDistance;
275
276  // Sort the matches in order of strength (i.e., confidence) using stl map:
277  multimap<double, shared_ptr<AutoTiePoint> > tpMap;
278
279  // Convert the openCV match points to something Atp could understand.
280  string sid(""); // Leave blank to have it auto-assigned by CorrelationTiePoint constructor
281
282  for (auto &featureMatches : matches)
283  {
284  if (featureMatches.empty())
285  continue;
286
287  shared_ptr<AutoTiePoint> atp (new AutoTiePoint(m_generator, sid));
288  cv::KeyPoint cv_A = kpA[(featureMatches[0]).queryIdx];
289  cv::KeyPoint cv_B;
290
291  ossimDpt refImgPt (refRect.ul().x + cv_A.pt.x, refRect.ul().y + cv_A.pt.y);
292  atp->setRefImagePt(refImgPt);
293
294  // Create the match points
295  double strength = 0;
296  for (auto &match : featureMatches)
297  {
298  cv_B = kpB[(match).trainIdx];
299  ossimDpt cmpImgPt (cmpRect.ul().x + cv_B.pt.x, cmpRect.ul().y + cv_B.pt.y);
300  double strength_j = 1.0 - (match.distance-minDistance)/delta;
301  if (strength_j > strength)
302  strength = strength_j;
303  atp->addImageMatch(cmpImgPt, strength_j);
304  }
305
306  // Insert into sorted map using one's complement as key since in ascending order:
307  tpMap.insert(pair<double, shared_ptr<AutoTiePoint> >(1.0-strength, atp));
308  sid.clear();
309  }
310
311  if (config.diagnosticLevel(2))
312  {
313  CINFO<<" Detections R,C: "<<kpA.size() << ", "<<kpB.size() << endl;//TODO REMOVE
314  CINFO<<" Matches (Before filtering): "<<matches.size()<<endl;
315
316  }
317
318  // Now skim off the best matches and copy them to the list being returned:
319  unsigned int N = config.getParameter("numFeaturesPerTile").asUint();
320  unsigned int n = 0;
321  auto tp_iter = tpMap.begin();
322  while ((tp_iter != tpMap.end()) && (n < N))
323  {
324  m_tiePoints.push_back(tp_iter->second);
325  tp_iter++;
326  n++;
327  }
328
329  if (config.diagnosticLevel(2))
330  CINFO<<" After capping to max num features ("<<N<<"), num TPs in tile = "<<n<<endl;
331
332  filterPoints();
333  return m_tile;
334 }
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
std::shared_ptr< AtpGenerator > m_generator
Definition: AtpTileSource.h:85
virtual bool write(const ossimFilename &f) const
Writes tile to stream.
os2<< "> n<< " > nendobj n
ossimRefPtr< ossimImageData > m_tile
Definition: AtpTileSource.h:87
IplImage * convertToIpl(const ossimImageData *data)
Converts an ossimImageData pointer to an IplImage for use in OpenCV.
Definition: AtpOpenCV.cpp:25
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
static AtpConfig & instance()
Singleton implementation.
Definition: AtpConfig.cpp:20
#define CWARN
virtual void allocate()
#define CINFO
◆ initialize()
void ATP::ossimDescriptorSource::initialize ( )
virtual
Reimplemented from ATP::AtpTileSource.
Definition at line 42 of file ossimDescriptorSource.cpp.
References ossimSensorModel::getNominalPosError(), ATP::AtpTileSource::initialize(), m_cmpPatchInflation, ATP::AtpTileSource::m_generator, ossimDpt::x, and ossimDpt::y.
Referenced by ossimDescriptorSource().
43 {
44  // Base class initializes ref and cmp chain datat members and associated IVTs. Subsequent call
45  // to base class setViewGeom() will initialize the associated IVTs:
47
48  ossimDpt gsd = m_generator->getRefIVT()->getOutputMetersPerPixel();
49  double nominalGsd = (gsd.x + gsd.y)/2.0;
50
51  // Fetch the CE90 of both images to determine cmp image search patch size:
52  ossimSensorModel* ref_sm = dynamic_cast<ossimSensorModel*>(
53  m_generator->getRefIVT()->getImageGeometry()->getProjection());
54  ossimSensorModel* cmp_sm = dynamic_cast<ossimSensorModel*>(
55  m_generator->getCmpIVT()->getImageGeometry()->getProjection());
56  if (ref_sm && cmp_sm)
57  {
58  double ref_ce = ref_sm->getNominalPosError();
59  double cmp_ce = cmp_sm->getNominalPosError();
60  double total_error = ref_ce + cmp_ce; // meters -- being conservative here and not doing rss
61  m_cmpPatchInflation = 2.0*total_error/nominalGsd;
62  }
63  else
64  {
65  m_cmpPatchInflation = 2.0*DEFAULT_NOMINAL_POSITION_ERROR/nominalGsd;
66  }
67 }
virtual const double & getNominalPosError() const
Returns the estimated Absolute horizontal position error (CE90) of the sensor model.
double y
Definition: ossimDpt.h:165
virtual void initialize()
double x
Definition: ossimDpt.h:164
Member Data Documentation
◆ m_cmpPatchInflation
unsigned int ATP::ossimDescriptorSource::m_cmpPatchInflation
private
Definition at line 44 of file ossimDescriptorSource.h.
Referenced by getTile(), and initialize().
◆ sortFunc
struct ATP::ossimDescriptorSource::SortFunc ATP::ossimDescriptorSource::sortFunc
private
Referenced by getTile().
