Classes | Public Member Functions | Protected Member Functions | Protected Attributes | Static Protected Attributes | List of all members
ATP::AtpTileSource Class Referenceabstract
Base class for tile sources performing auto tie point extraction. More...
#include <AtpTileSource.h>
Inheritance diagram for ATP::AtpTileSource:
ossimImageCombiner ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ATP::ossimCorrelationSource ATP::ossimDescriptorSource
Classes
struct  ParallaxInfo
 Convenience struct for use between filterWithParallax( and computeParallaxStatistics() More...
 AtpTileSource (AtpGenerator *generator)
virtual ~AtpTileSource ()
virtual void initialize ()
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &origin, ossim_uint32 rLevel=0)=0
 Derived classes implement their particular tiepoint matching algorithms for the requested tile. More...
AtpListgetTiePoints ()
 This list resets with every getTile() call , so make sure tiepoints from previous getTile() calls are being accumulated. More...
void filterPoints ()
void setTiePoints (ossim::TiePointList &atpList)
 Used for testing. More...
- Public Member Functions inherited from ossimImageCombiner
 ossimImageCombiner ()
 ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag)
 ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual bool saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const
virtual void updateRects ()
 This will go through and precompute the bounding rects of each input image. More...
 Returns the number of bands available from the input. More...
virtual ossim_uint32 getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to retrieve the number of overlapping images withint the given rect. More...
virtual void getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to populate the result with the index of the overlapping images. More...
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool hasDifferentInputs () const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
 AtpTileSource ()
 AtpTileSource (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual void allocate ()
void filterWithParallax ()
void computeParallax ()
void computeParallaxStatistics ()
void filterWithoutParallax ()
void pruneList ()
 Caps the max number of TPs given the list, which is the list of filtered TPs for the tile. More...
void initializeStaticMembers ()
- Protected Member Functions inherited from ossimImageCombiner
virtual ~ossimImageCombiner ()
void precomputeBounds () const
virtual ~ossimReferenced ()
std::shared_ptr< AtpGeneratorm_generator
AtpList m_tiePoints
ParallaxInfo m_paxInfo
bool m_considerParallax
- Protected Attributes inherited from ossimImageCombiner
ossim_uint32 theLargestNumberOfInputBands
ossim_uint32 theInputToPassThrough
bool theHasDifferentInputs
ossimRefPtr< ossimImageDatatheNormTile
std::vector< ossimIrecttheFullResBounds
bool theComputeFullResBoundsFlag
ossim_uint32 theCurrentIndex
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
static double s_minVectorResDiff = 0
static double s_maxDiffRatio = 1.0
static double s_cosMaxAngleDiff = 0
static double s_maxPaxDev = 1.0
static double s_maxPaxPix = 2.0
static unsigned int s_minNumConsistent = 3
static unsigned int s_percentConsistent = 50
static unsigned int s_numTpsPerTile = 2
static bool s_useRasterMode = false
static bool s_initialized = false
static unsigned int s_numFilterIterations = 0
Additional Inherited Members
Detailed Description
Implemented as a combiner that establishes the overlap between input sources, and computes tie-points in the getTile() call.
Definition at line 26 of file AtpTileSource.h.
◆ AtpTileSource() [1/3]
ATP::AtpTileSource::AtpTileSource ( AtpGenerator generator)
Definition at line 44 of file AtpTileSource.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::connectMyInputTo(), initialize(), m_generator, and ossimImageCombiner::theComputeFullResBoundsFlag.
45 : m_generator(generator),
46  m_considerParallax (true)
47 {
49  if (m_generator)
50  {
51  connectMyInputTo(0, m_generator->getRefChain().get());
52  connectMyInputTo(1, m_generator->getCmpChain().get());
53  }
55  initialize();
56 }
virtual bool addListener(ossimListener *listener)
std::shared_ptr< AtpGenerator > m_generator
Definition: AtpTileSource.h:85
virtual void initialize()
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
◆ ~AtpTileSource()
virtual ATP::AtpTileSource::~AtpTileSource ( )
inlinevirtual
Definition at line 31 of file AtpTileSource.h.
31 {}
◆ AtpTileSource() [2/3]
ATP::AtpTileSource::AtpTileSource ( )
protected
Definition at line 32 of file AtpTileSource.cpp.
33 : m_considerParallax (true)
34 {
35 }
◆ AtpTileSource() [3/3]
ATP::AtpTileSource::AtpTileSource ( ossimConnectableObject::ConnectableObjectList inputSources)
protected
Definition at line 37 of file AtpTileSource.cpp.
38 : ossimImageCombiner(inputSources),
39  m_considerParallax (true)
40
41 {
42 }
Member Function Documentation
◆ allocate()
void ATP::AtpTileSource::allocate ( )
protectedvirtual
Definition at line 70 of file AtpTileSource.cpp.
References ossimImageDataFactory::create(), ossimConnectableObject::getNumberOfInputs(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_tile, and ossimConnectableObject::theInputObjectList.
Referenced by ATP::ossimCorrelationSource::getTile(), and ATP::ossimDescriptorSource::getTile().
71 {
72  // The AtpTileSources cannot be relied on to return valid pixel data, since their main product
73  // are the tie points, not pixels. However, the tile is used to communicate scalar type, rect,
74  // and other tile metadata, so is still needed:
75  m_tile = NULL;
76  if ( getNumberOfInputs() > 1)
77  {
78  ossimImageSource* firstSource = dynamic_cast<ossimImageSource*>(theInputObjectList[0].get());
79  m_tile = ossimImageDataFactory::instance()->create(this, firstSource);
80  m_tile->initialize();
81  }
82 }
Initialize the data buffer.
ossimRefPtr< ossimImageData > m_tile
Definition: AtpTileSource.h:87
ConnectableObjectList theInputObjectList
Holds a list of input objects.
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
◆ computeParallax()
void ATP::AtpTileSource::computeParallax ( )
protected
Definition at line 261 of file AtpTileSource.cpp.
References ATP::AtpTileSource::ParallaxInfo::denom, ATP::AtpTileSource::ParallaxInfo::dx_dH, ATP::AtpTileSource::ParallaxInfo::dy_dH, ossimIrect::getCenter(), ossimDataObject::getDataObjectStatus(), ossimElevManager::getHeightAboveEllipsoid(), ossimImageData::getImageRectangle(), ossimGpt::hgt, ossimElevManager::instance(), ossimGpt::isHgtNan(), ossimImageGeometry::localToWorld(), m_generator, m_paxInfo, m_tiePoints, m_tile, ossim::nan(), OSSIM_STATUS_UNKNOWN, ATP::AtpTileSource::ParallaxInfo::parallaxSlope, ossimImageGeometry::worldToLocal(), ossimDpt::x, and ossimDpt::y.
Referenced by filterPoints().
262 {
263  // Use the point at tile center to establish reference ground point at two different elevations:
264  static const double DELTA_HEIGHT = 500.0;
265  ossimDpt vpt, ipt0, ipt1;
266  ossimGpt gpt0, gpt1;
267
268  // Possible debug mode will not have a tile assigned:
270  m_tiePoints[0]->getRefViewPoint(vpt);
271  else
273  ossimImageGeometry *geom = m_generator->m_refIVT->getViewGeometry();
274  geom->localToWorld(vpt, gpt0);
275  if (gpt0.isHgtNan())
277  gpt1 = gpt0;
278  gpt1.hgt += DELTA_HEIGHT;
279
280  // Determine dx/dh and dy/dh for ref image:
281  geom = m_generator->m_refIVT->getImageGeometry();
282  geom->worldToLocal(gpt0, ipt0);
283  geom->worldToLocal(gpt1, ipt1);
284  double dx_ref = (ipt1.x - ipt0.x);
285  double dy_ref = (ipt1.y - ipt0.y);
286
287  // Determine dx/dh and dy/dh for cmp image:
288  geom = m_generator->m_cmpIVT->getImageGeometry();
289  geom->worldToLocal(gpt0, ipt0);
290  geom->worldToLocal(gpt1, ipt1);
291  double dx_cmp = (ipt1.x - ipt0.x);
292  double dy_cmp = (ipt1.y - ipt0.y);
293
294  // Compute parallax direction REF-->CMP
295  m_paxInfo.dx_dH = dx_cmp - dx_ref;
296  m_paxInfo.dy_dH = dy_cmp - dy_ref;
297  if (m_paxInfo.dx_dH != 0)
298  {
301  }
302  else
303  {
306  }
307  //CINFO << "### dx_dH: " << m_paxInfo.dx_dH << endl; // TODO REMOVE
308  //CINFO << "### dy_dH: " << m_paxInfo.dy_dH << endl; // TODO REMOVE
309  //CINFO << "### parallaxSlope: " << m_paxInfo.parallaxSlope << endl; // TODO REMOVE
310 }
double nan()
Definition: ossimCommon.h:135
double y
Definition: ossimDpt.h:165
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
bool isHgtNan() const
Definition: ossimGpt.h:143
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
Definition: AtpTileSource.h:88
virtual double getHeightAboveEllipsoid(const ossimGpt &gpt)
virtual ossimIrect getImageRectangle() const
double x
Definition: ossimDpt.h:164
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
void getCenter(ossimDpt &center_point) const
Definition: ossimIrect.cpp:672
◆ computeParallaxStatistics()
void ATP::AtpTileSource::computeParallaxStatistics ( )
protected
Definition at line 313 of file AtpTileSource.cpp.
References ATP::AtpTileSource::ParallaxInfo::denom, distance(), ATP::AtpTileSource::ParallaxInfo::distanceMap, ATP::AtpTileSource::ParallaxInfo::dx_dH, ATP::AtpTileSource::ParallaxInfo::dy_dH, m_paxInfo, m_tiePoints, ATP::AtpTileSource::ParallaxInfo::maxDistance, ATP::AtpTileSource::ParallaxInfo::parallaxOffset, ATP::AtpTileSource::ParallaxInfo::parallaxSlope, s_maxPaxDev, s_maxPaxPix, ossimDpt::x, and ossimDpt::y.
Referenced by filterWithParallax().
314 {
315  // Determining the parallax direction (slope) is easy. It is the offset (y-intercept) that
316  // depends on the collection of residuals.
317  // Use the point at tile center to establish dx/dH and dy/dH in view-space:
318  // Compute parallax slope and intercept:
319  ossimDpt residual;
320  if (m_paxInfo.dx_dH != 0.0)
321  {
322  // Compute parallax intercept using collection of all primary matches:
323  double sum_c_i = 0;
324  for (auto &tiePoint : m_tiePoints)
325  {
326  tiePoint->getVectorResidual(residual);
327  sum_c_i += residual.y - m_paxInfo.parallaxSlope * residual.x;
328  }
329  m_paxInfo.parallaxOffset = sum_c_i/m_tiePoints.size();
330  }
331
332  // Compute statistics of residual vector distribution, saving individual distance samples:
333  m_paxInfo.distanceMap.clear();
334  double distance, sumDistance2=0.0;
335  for (auto &tiePoint : m_tiePoints)
336  {
337  tiePoint->getVectorResidual(residual);
338  if (m_paxInfo.dx_dH == 0)
339  distance = residual.x;
340  else if (m_paxInfo.dy_dH == 0)
341  distance = residual.y;
342  else
343  {
344  distance = fabs(m_paxInfo.parallaxOffset + m_paxInfo.parallaxSlope*residual.x - residual.y)/m_paxInfo.denom;
345  }
346  sumDistance2 += distance*distance;
347  m_paxInfo.distanceMap.emplace(tiePoint->getTiePointId(), distance);
348  //CINFO << "### TP: "<<tiePoint->getTiePointId()<<" distance: " << distance << endl; // TODO REMOVE
349
350  }
351  double sigmaDistance = sqrt(sumDistance2/(m_tiePoints.size()-1));
352  m_paxInfo.maxDistance = s_maxPaxDev*sigmaDistance;
355
356  //CINFO << "### sigmaDistance: " << sigmaDistance << endl; // TODO REMOVE
357  //CINFO << "### maxDistance: " << m_paxInfo.maxDistance << endl; // TODO REMOVE
358 }
double y
std::map< std::string, double > distanceMap
Definition: AtpTileSource.h:66
double x
Definition: AtpTileSource.h:96
float distance(double lat1, double lon1, double lat2, double lon2, int units)
Definition: AtpTileSource.h:95
◆ filterPoints()
void ATP::AtpTileSource::filterPoints ( )
Definition at line 84 of file AtpTileSource.cpp.
References ossim::JsonParam::asBool(), CINFO, computeParallax(), ossim::JsonConfig::diagnosticLevel(), ATP::AtpTileSource::ParallaxInfo::dx_dH, ATP::AtpTileSource::ParallaxInfo::dy_dH, filterWithoutParallax(), filterWithParallax(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), m_considerParallax, m_generator, m_paxInfo, m_tiePoints, ossim::JsonConfig::paramExists(), pruneList(), s_minNumConsistent, s_numFilterIterations, and s_useRasterMode.
Referenced by ATP::ossimCorrelationSource::getTile(), ATP::ossimDescriptorSource::getTile(), and main().
85 {
86  const char* MODULE = "AtpTileSource::filterPoints() -- ";
87  AtpConfig& config = AtpConfig::instance();
88
89  // First remove points with no matches:
90  auto tiePoint = m_tiePoints.begin();
91  while (tiePoint != m_tiePoints.end())
92  {
93  if ((*tiePoint) && (*tiePoint)->hasValidMatch())
94  ++tiePoint;
95  else
96  tiePoint = m_tiePoints.erase(tiePoint);
97  }
98
99  // No filtering done for raster mode:
100  if (s_useRasterMode)
101  return;
102
103  if (config.diagnosticLevel(3))
104  {
105  // Annotate red before filtering:
106  m_generator->m_annotatedRefImage->annotateResiduals(m_tiePoints, 255, 0, 0);
107  m_generator->m_annotatedCmpImage->annotateCorrelations(m_tiePoints, 255, 0, 0);
108  }
109
110  // Check for consistency check override
111  if (s_minNumConsistent == 0)
112  return;
113
114  // Don't accept any if there are an insufficient number of neighbors:
115  if (m_tiePoints.size() < s_minNumConsistent)
116  {
117  m_tiePoints.clear();
118  return;
119  }
120
121  if (config.paramExists("considerParallax"))
122  m_considerParallax = config.getParameter("considerParallax").asBool();
123  if (m_considerParallax)
124  {
125  // If the perspective differences are small, fall back to non-parallax check:
126  computeParallax();
127  if ((fabs(m_paxInfo.dx_dH) < 1.0) && (fabs(m_paxInfo.dy_dH) < 1.0))
128  {
129  if (config.diagnosticLevel(5))
130  CINFO << MODULE << "Insignificant parallax, falling back to non-parallax filtering."
131  << endl;
133  }
134  else
135  {
138  }
139  }
140  else
142
143  if (config.diagnosticLevel(3))
144  {
145  // Annotate yellow before pruning:
146  m_generator->m_annotatedRefImage->annotateResiduals(m_tiePoints, 255, 255, 0);
147  m_generator->m_annotatedCmpImage->annotateCorrelations(m_tiePoints, 255, 255, 0);
148  }
149
150  pruneList();
151
152  if (config.diagnosticLevel(2))
153  {
154  CINFO<<MODULE<<"After filtering & pruning: num TPs in tile = "<<m_tiePoints.size()<<endl;
155  if (config.diagnosticLevel(3))
156  {
157  // Annotate Green after accepting TP:
158  m_generator->m_annotatedRefImage->annotateResiduals(m_tiePoints, 0, 255, 0);
159  m_generator->m_annotatedCmpImage->annotateCorrelations(m_tiePoints, 0, 255, 0);
160  //m_annotatedRefImage->annotateTPIDs(m_tiePoints, 180, 180, 0);
161  }
162  }
163 }
Definition: AtpTileSource.h:97
void pruneList()
Caps the max number of TPs given the list, which is the list of filtered TPs for the tile...
static AtpConfig & instance()
Singleton implementation.
Definition: AtpConfig.cpp:20
#define CINFO
◆ filterWithoutParallax()
void ATP::AtpTileSource::filterWithoutParallax ( )
protected
Definition at line 360 of file AtpTileSource.cpp.
References CINFO, ossim::JsonConfig::diagnosticLevel(), ATP::AtpConfig::instance(), ossimDpt::length(), m_tiePoints, s_cosMaxAngleDiff, s_maxDiffRatio, s_minNumConsistent, s_minVectorResDiff, s_percentConsistent, ossimDpt::x, and ossimDpt::y.
361 {
362  const char* MODULE = "AtpTileSource::filterWithoutParallax() ";
363  AtpConfig& config = AtpConfig::instance();
364
365  // Loop to eliminate bad peaks and inconsistent ATPs in tile:
366  auto tiePoint = m_tiePoints.begin();
367  while (tiePoint != m_tiePoints.end())
368  {
369  // The "tiepoint" may not have any matches -- it may be just a feature:
370  ossimDpt r_atp, r_nbr;
371  (*tiePoint)->getVectorResidual(r_atp);
372
373  if (config.diagnosticLevel(5))
374  {
375  ossimDpt refPt;
376  (*tiePoint)->getRefImagePoint(refPt);
377  CINFO<<"AutoTiePoint::checkConsistency() -- Processing TP "<<(*tiePoint)->getTiePointId()
378  <<" at REF image pt: ("<<refPt.x<<", "<<refPt.y<<")"<<endl;
379  }
380
381  // Loop over all of the TPs neighbors to count the number that are consistent:
382  unsigned int num_consistent_neighbors = 0;
383  for(auto &neighbor : m_tiePoints)
384  {
385  if ((*tiePoint)->getTiePointId() == neighbor->getTiePointId())
386  continue;
387
388  // Check for simple minimum vector difference:
389  neighbor->getVectorResidual(r_nbr);
390  double diff = (r_nbr - r_atp).length();
391  if (diff < s_minVectorResDiff)
392  {
393  num_consistent_neighbors++;;
394  continue;
395  }
396
397  // Compute angle and magnitude ratio between residuals. Note no check for valid peak:
398  double cos_theta=1.0, mag_ratio=0;
399  double r0 = r_atp.length();
400  double r1 = r_nbr.length();
401  mag_ratio = 2.0*fabs(r1-r0)/(r0+r1);
402  if ((r1 > 0.0) && (r0 > 0.0))
403  cos_theta = (r_atp.x*r_nbr.x + r_atp.y*r_nbr.y)/(r0*r1);
404
405  // Test for consistency with this neighbor's peak:
406  if ((mag_ratio < s_maxDiffRatio) && (cos_theta > s_cosMaxAngleDiff))
407  num_consistent_neighbors++;;
408  }
409
410  // Decide if this peak was good or out there:
411  int minConsistent = (int) ceil(s_percentConsistent*(m_tiePoints.size()-1)/100);
412  if (minConsistent < (int)s_minNumConsistent)
413  minConsistent = s_minNumConsistent;
414  if (num_consistent_neighbors < minConsistent)
415  {
416  // Peak was bad, fetch next strongest match or exit loop if no more available:
417  if (!(*tiePoint)->bumpActiveMatch())
418  {
419  if (config.diagnosticLevel(5))
420  CINFO << MODULE << "Removing TP " << (*tiePoint)->getTiePointId() << endl;
421  tiePoint = m_tiePoints.erase(tiePoint);
422  if (m_tiePoints.empty())
423  break;
424  }
425  }
426  else
427  {
428  // Match is consistent, keep the tiepoint in the list an advance to the next tiepoint
429  tiePoint++;
430  }
431  }
432 }
double y
double length() const
Definition: ossimDpt.h:81
Definition: AtpTileSource.h:93
Definition: AtpTileSource.h:98
Definition: AtpTileSource.h:92
Definition: AtpTileSource.h:94
double x
#define CINFO
◆ filterWithParallax()
void ATP::AtpTileSource::filterWithParallax ( )
protected
Definition at line 165 of file AtpTileSource.cpp.
References CINFO, computeParallaxStatistics(), ATP::AtpTileSource::ParallaxInfo::denom, ossim::JsonConfig::diagnosticLevel(), distance(), ATP::AtpTileSource::ParallaxInfo::distanceMap, ATP::AtpTileSource::ParallaxInfo::dx_dH, ATP::AtpConfig::instance(), m_paxInfo, m_tiePoints, ATP::AtpTileSource::ParallaxInfo::maxDistance, ATP::AtpTileSource::ParallaxInfo::parallaxOffset, ATP::AtpTileSource::ParallaxInfo::parallaxSlope, s_maxPaxPix, s_numFilterIterations, ossimDpt::x, and ossimDpt::y.
166 {
167  // May be called recursively, limited by s_numFilterIterations < 5
168
169  const char* MODULE = "AtpTileSource::filterWithParallax() ";
170  AtpConfig& config = AtpConfig::instance();
171  if (m_tiePoints.size() < 2)
172  {
173  m_tiePoints.clear();
174  return;
175  }
176
178
179  // This is where recursion is stopped:
181  {
182  m_tiePoints.clear();
183  if (config.diagnosticLevel(5))
184  {
185  CINFO << MODULE << "Could not establish good parallax statistics for this set. "
186  << "Removing all points for this tile." << endl;
187  }
188  return;
189  }
190
191  // Loop to eliminate bad peaks and inconsistent ATPs in tile:
192  ossimDpt residual;
193  bool statsChanged = false;
194  auto tiePoint = m_tiePoints.begin();
195  while (tiePoint != m_tiePoints.end())
196  {
197  // Check point's active peak against the set of residuals along parallax:
198  auto entry = m_paxInfo.distanceMap.find((*tiePoint)->getTiePointId());
199  if (entry == m_paxInfo.distanceMap.end())
200  { // Should never happen
201  tiePoint = m_tiePoints.erase(tiePoint);
202  continue;
203  }
204  double distance = entry->second;
205
206  // Loop to find a match in this ATP that is consistent.
207  while (distance > m_paxInfo.maxDistance)
208  {
209  // This residual is outside the acceptable limit, try the next match in the tiepoint or
210  // remove it if it has no more peaks.
211  statsChanged = true;
212  if (!(*tiePoint)->bumpActiveMatch())
213  {
214  if (config.diagnosticLevel(5))
215  {
216  CINFO << MODULE << "Removing TP " << (*tiePoint)->getTiePointId() << endl;
217  CINFO << " distance: " << distance << ", maxDistance: " << m_paxInfo.maxDistance << endl;
218  }
219  tiePoint = m_tiePoints.erase(tiePoint);
220  break;
221  }
222  else if (config.diagnosticLevel(5))
223  {
224  CINFO << MODULE << "Bumping active match for TP " << (*tiePoint)->getTiePointId()
225  << endl;
226  CINFO << " distance: " << distance << ", maxDistance: " << m_paxInfo.maxDistance << endl;
227  }
228
229  // A new peak is being used, will need to recompute statistics later.
230  (*tiePoint)->getVectorResidual(residual);
231  if (m_paxInfo.dx_dH == 0.0)
232  distance = residual.x;
233  else if (m_paxInfo.dx_dH == 0.0)
234  distance = residual.y;
235  else
236  {
238  residual.y) / m_paxInfo.denom;
239  }
240  }
242  {
243  // The match was deemed consistent. proceed to next point:
244  ++tiePoint;
245  }
246  }
247
248  if (statsChanged)
249  {
250  // Recursive call to recompute statistics and eliminate suspect points
252  if (config.diagnosticLevel(5))
253  {
254  CINFO << MODULE << "Iterating filterWithParallax after ATP list change (N = "
255  << s_numFilterIterations << ")."<< endl;
256  }
258  }
259 }
double y
void computeParallaxStatistics()
double x
#define CINFO
◆ getNumberOfOutputBands()
virtual ossim_uint32 ATP::AtpTileSource::getNumberOfOutputBands ( ) const
inlinevirtual
Definition at line 48 of file AtpTileSource.h.
48 { return 2; }
◆ getOutputScalarType()
virtual ossimScalarType ATP::AtpTileSource::getOutputScalarType ( ) const
inlinevirtual
Reimplemented from ossimImageCombiner.
Definition at line 47 of file AtpTileSource.h.
References OSSIM_DOUBLE.
47 { return OSSIM_DOUBLE; }
64 bit floating point
◆ getTiePoints()
AtpList& ATP::AtpTileSource::getTiePoints ( )
inline
Definition at line 45 of file AtpTileSource.h.
45 { return m_tiePoints; }
◆ getTile()
virtual ossimRefPtr<ossimImageData> ATP::AtpTileSource::getTile ( const ossimIrect origin,
ossim_uint32  rLevel = 0
pure virtual
It is not clear what the output tile needs to be, since the product of this filter is the list of tiepoints (available through the getTiePoints() method). Recommend simply passing through the corresponding REF image tile.
Implemented in ATP::ossimCorrelationSource, and ATP::ossimDescriptorSource.
◆ initialize()
void ATP::AtpTileSource::initialize ( )
virtual
Reimplemented in ATP::ossimCorrelationSource, and ATP::ossimDescriptorSource.
Definition at line 58 of file AtpTileSource.cpp.
References ossimConnectableObject::getNumberOfInputs(), ossimImageCombiner::initialize(), initializeStaticMembers(), m_tiePoints, and s_initialized.
Referenced by AtpTileSource(), ATP::ossimDescriptorSource::initialize(), and ATP::ossimCorrelationSource::initialize().
59 {
60  const char* MODULE = "AtpTileSource::initialize() -- ";
61  if (!s_initialized)
63
65  m_tiePoints.clear();
66  if ( getNumberOfInputs() < 2)
67  return;
68 }
◆ initializeStaticMembers()
void ATP::AtpTileSource::initializeStaticMembers ( )
protected
Definition at line 473 of file AtpTileSource.cpp.
References ossim::JsonParam::asBool(), ossim::JsonParam::asFloat(), ossim::JsonParam::asUint(), ossim::cosd(), CWARN, ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), ossim::isnan(), ossim::JsonConfig::paramExists(), s_cosMaxAngleDiff, s_initialized, s_maxDiffRatio, s_maxPaxDev, s_maxPaxPix, s_minNumConsistent, s_minVectorResDiff, s_numTpsPerTile, s_percentConsistent, and s_useRasterMode.
Referenced by initialize().
474 {
475  static const char* MODULE = "AtpTileSource::initializeStaticMembers() -- ";
476
477  AtpConfig& config = AtpConfig::instance();
478  s_maxDiffRatio = config.getParameter("maxResMagDiffRatio").asFloat();
480  {
481  CWARN<<MODULE<<"Bad or missing parameter in config: "
482  "maxResMagDiffRatio = "<<s_maxDiffRatio<<". Defaulting to 0.1."<<endl;
483  s_maxDiffRatio = 0.1;
484  }
485
486  double theta = config.getParameter("maxResAngleDiff").asFloat();
487  if (ossim::isnan(theta) || (theta <= 0))
488  {
489  CWARN<<MODULE<<"Bad or missing parameter in config: "
490  "maxAngleDiff = "<<theta<<". Defaulting to 10 deg."<<endl;
491  theta = 10.0;
492  }
494
495  s_minVectorResDiff = config.getParameter("minVectorResDiff").asFloat();
497  {
498  CWARN<<MODULE<<"Bad or missing parameter in config: "
499  "minVectorResDiff = "<<s_minVectorResDiff<<". Defaulting to 1.0."<<endl;
500  s_minVectorResDiff = 1.0;
501  }
502
503  s_minNumConsistent = config.getParameter("minNumConsistentNeighbors").asUint();
504  if (s_minNumConsistent == 0)
505  {
506  CWARN<<MODULE<<"Bad or missing parameter in config: "
507  "minNumConsistentNeighbors = "<<s_minNumConsistent<<". Defaulting to 3."<<endl;
508  s_minNumConsistent = 3.0;
509  }
510
511  s_percentConsistent = config.getParameter("percentConsistentThreshold").asUint();
512  if (s_percentConsistent == 0)
513  {
514  CWARN<<MODULE<<"Bad or missing parameter in config: "
515  "percentConsistentThreshold = "<<s_percentConsistent<<". Defaulting to 50."<<endl;
516  s_percentConsistent = 50;
517  }
518
519  s_numTpsPerTile = config.getParameter("numTiePointsPerTile").asUint();
520  if (s_numTpsPerTile == 0)
521  {
522  CWARN<<MODULE<<"Bad or missing parameter in config: "
523  "numTiePointsPerTile = "<<s_numTpsPerTile<<". Defaulting to 2."<<endl;
524  s_numTpsPerTile = 2;
525  }
526
527  s_maxPaxDev = config.getParameter("maxResParallaxDev").asFloat();
528  if (ossim::isnan(s_maxPaxDev) || (s_maxPaxDev <= 0))
529  {
530  CWARN<<MODULE<<"Bad or missing parameter in config: "
531  "maxResParallaxDev = "<<s_maxPaxDev<<". Defaulting to 1.0."<<endl;
532  s_maxPaxDev = 1.0;
533  }
534
535  s_maxPaxPix = (double) config.getParameter("maxResParallaxPix").asUint();
536  if (ossim::isnan(s_maxPaxPix) || (s_maxPaxPix <= 0))
537  {
538  CWARN<<MODULE<<"Bad or missing parameter in config: "
539  "maxResParallaxPix = "<<s_maxPaxPix<<". Defaulting to 1.0."<<endl;
540  s_maxPaxPix = 2.0;
541  }
542
543  if (config.paramExists("useRasterMode"))
544  s_useRasterMode = config.getParameter("useRasterMode").asBool();
545
546  s_initialized = true;
547 }
double cosd(double x)
Definition: ossimCommon.h:259
Definition: AtpTileSource.h:99
#define CWARN
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ pruneList()
void ATP::AtpTileSource::pruneList ( )
protected
Definition at line 435 of file AtpTileSource.cpp.
References CWARN, ATP::AtpConfig::instance(), m_tiePoints, and s_numTpsPerTile.
436 {
437  const char* MODULE = "AtpTileSource::pruneList() ";
438  AtpConfig &config = AtpConfig::instance();
439
440  // Use a map to sort by confidence measure:
441  multimap<double, shared_ptr<AutoTiePoint> > atpMap;
442  auto atp = m_tiePoints.begin();
443  double confidence;
444  while (atp != m_tiePoints.end())
445  {
446  if (!(*atp)) // Should never happen
447  {
448  CWARN<<MODULE<<"WARNING: Null AutoTiePoint encountred in list. Skipping point."<<endl;
449  ++atp;
450  continue;
451  }
452
453  // The "tiepoint" may not have any matches -- it may be just a feature:
454  bool hasValidMatch = (*atp)->getConfidenceMeasure(confidence);
455  if (hasValidMatch)
456  atpMap.emplace(1.0/confidence, *atp);
457
458  atp++;
459  }
460
461  // Skim off the top best:
462  m_tiePoints.clear();
463  multimap<double, shared_ptr<AutoTiePoint> >::iterator tp = atpMap.begin();
464  while (tp != atpMap.end())
465  {
466  m_tiePoints.push_back(tp->second);
467  if (m_tiePoints.size() == s_numTpsPerTile)
468  break;
469  tp++;
470  }
471 }
#define CWARN
◆ setTiePoints()
void ATP::AtpTileSource::setTiePoints ( ossim::TiePointList atpList)
Used for testing.
Definition at line 549 of file AtpTileSource.cpp.
References m_generator, and m_tiePoints.
Referenced by main().
550 {
551  // Engineering code for manually specifying TPs to test consistency checking
552  string id;
553  ossimDpt rip, cip;
554  NEWMAT::SymmetricMatrix cov;
555  m_tiePoints.clear();
556  for (auto &tp : tpList)
557  {
558  shared_ptr<AutoTiePoint> atp (new AutoTiePoint(m_generator, tp->getTiePointId()));
559  tp->getImagePoint(0,id,rip,cov);
560  tp->getImagePoint(1,id,cip,cov);
561  atp->setRefImagePt(rip);
562  atp->addImageMatch(cip);
563  m_tiePoints.emplace_back(atp);
564  }
565 }
Member Data Documentation
◆ m_considerParallax
bool ATP::AtpTileSource::m_considerParallax
protected
Definition at line 89 of file AtpTileSource.h.
◆ m_generator
std::shared_ptr<AtpGenerator> ATP::AtpTileSource::m_generator
protected
◆ m_paxInfo
ParallaxInfo ATP::AtpTileSource::m_paxInfo
protected
◆ m_tiePoints
AtpList ATP::AtpTileSource::m_tiePoints
protected
◆ m_tile
ossimRefPtr<ossimImageData> ATP::AtpTileSource::m_tile
protected
◆ s_cosMaxAngleDiff
double ATP::AtpTileSource::s_cosMaxAngleDiff = 0
staticprotected
Definition at line 94 of file AtpTileSource.h.
Referenced by filterWithoutParallax(), and initializeStaticMembers().
◆ s_initialized
bool ATP::AtpTileSource::s_initialized = false
staticprotected
Definition at line 101 of file AtpTileSource.h.
Referenced by initialize(), and initializeStaticMembers().
◆ s_maxDiffRatio
double ATP::AtpTileSource::s_maxDiffRatio = 1.0
staticprotected
Definition at line 93 of file AtpTileSource.h.
◆ s_maxPaxDev
double ATP::AtpTileSource::s_maxPaxDev = 1.0
staticprotected
Definition at line 95 of file AtpTileSource.h.
Referenced by computeParallaxStatistics(), and initializeStaticMembers().
◆ s_maxPaxPix
double ATP::AtpTileSource::s_maxPaxPix = 2.0
staticprotected
◆ s_minNumConsistent
unsigned int ATP::AtpTileSource::s_minNumConsistent = 3
staticprotected
Definition at line 97 of file AtpTileSource.h.
Referenced by filterPoints(), filterWithoutParallax(), and initializeStaticMembers().
◆ s_minVectorResDiff
double ATP::AtpTileSource::s_minVectorResDiff = 0
staticprotected
Definition at line 92 of file AtpTileSource.h.
◆ s_numFilterIterations
unsigned int ATP::AtpTileSource::s_numFilterIterations = 0
staticprotected
Definition at line 102 of file AtpTileSource.h.
Referenced by filterPoints(), and filterWithParallax().
◆ s_numTpsPerTile
unsigned int ATP::AtpTileSource::s_numTpsPerTile = 2
staticprotected
Definition at line 99 of file AtpTileSource.h.
Referenced by initializeStaticMembers(), and pruneList().
◆ s_percentConsistent
unsigned int ATP::AtpTileSource::s_percentConsistent = 50
staticprotected
Definition at line 98 of file AtpTileSource.h.
◆ s_useRasterMode
bool ATP::AtpTileSource::s_useRasterMode = false
staticprotected
Definition at line 100 of file AtpTileSource.h.
Referenced by filterPoints(), and initializeStaticMembers().
