ossimBandAverageFilter Class Reference
This filter outputs a single band that is the weighted average of all the input bands retrieved from the getTile. More...
#include <ossimBandAverageFilter.h>
Inheritance diagram for ossimBandAverageFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimBandAverageFilter ()
 ossimBandAverageFilter (ossimImageSource *input, const std::vector< double > &weights)
virtual ~ossimBandAverageFilter ()
 The data object argument is deprecated and should not be used. More...
 Since this filter is going to operate in native pixel type we will use a tmeplate method to do this. More...
 Since we are merging all bands we will use the null pix of the first input band as our null pix. More...
 We will use the min of all bands as our min. More...
 We will use the max of all bands as our max. More...
double getWeight (ossim_uint32 band) const
 simple access method to get a weight More...
void setWeight (ossim_uint32 band, double weight)
 Sinple access method to set the weight of a band, We make sure that it is a positive weight. More...
virtual void initialize ()
 allocates its tile buffer More...
 loads its weights to a keywordlist More...
 Saves its weights to a keywordlist. More...
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
void checkWeights ()
template<class T >
void averageInput (T dummyVariable, ossimRefPtr< ossimImageData > inputDataObject)
virtual ~ossimReferenced ()
Protected Attributes
std::vector< double > theWeights
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
This filter will work with any input scalar type. Note the OSSIMDLLEXPORT is used for the different compilers that require importing and exporting symbols for shared library support.
Definition at line 24 of file ossimBandAverageFilter.h.
◆ ossimBandAverageFilter() [1/2]
ossimBandAverageFilter::ossimBandAverageFilter ( )
Definition at line 29 of file ossimBandAverageFilter.cpp.
31  theTile(NULL)
32 {
33 }
ossimImageSourceFilter(ossimObject *owner=NULL)
◆ ossimBandAverageFilter() [2/2]
ossimBandAverageFilter::ossimBandAverageFilter ( ossimImageSource input,
const std::vector< double > &  weights
Definition at line 35 of file ossimBandAverageFilter.cpp.
37  :ossimImageSourceFilter(input),
38  theTile(NULL),
39  theWeights(weights)
40 {
41 }
◆ ~ossimBandAverageFilter()
ossimBandAverageFilter::~ossimBandAverageFilter ( )
virtual
Definition at line 43 of file ossimBandAverageFilter.cpp.
44 {
45 }
Member Function Documentation
◆ averageInput()
template<class T >
void ossimBandAverageFilter::averageInput ( dummyVariable,
ossimRefPtr< ossimImageData inputDataObject
protected
Definition at line 257 of file ossimBandAverageFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), theTile, and theWeights.
Referenced by getTile().
260 {
261  // since we have already checked the input for empty or
262  // null we will now execute the algorithm. We will make
263  //
264  //
265  std::vector<T*> inputBands(inputDataObject->getNumberOfBands());
266  std::vector<double> nullValues(inputDataObject->getNumberOfBands());
267  ossim_uint32 i = 0;
268
269  // for efficiency we will copy the band pointers and
270  // null values so we don't have extra function calls
271  // on a per band basis
272  //
273  for(i = 0; i < inputDataObject->getNumberOfBands(); ++i)
274  {
275  inputBands[i] = static_cast<T*>(inputDataObject->getBuf(i));
276  nullValues[i] = inputDataObject->getNullPix(i);
277  }
278
279  // store the output buffer pointer
280  T* outputBuf = static_cast<T*>(theTile->getBuf(0));
281
282  // setup index values and boundary values
283  ossim_uint32 upperBound = theTile->getWidth()*theTile->getHeight();
284  ossim_uint32 bandIndex = 0;
285  ossim_uint32 numberOfBands = inputDataObject->getNumberOfBands();
286  double outputNullPix = theTile->getNullPix(0);
287
288  for(i = 0; i < upperBound; ++i)
289  {
290  double value=0.0;
291  double sumWeights=0.0;
292
293  // loop over each band only using the valid pixel data
294  // in the weighted average.
295  //
296  for(bandIndex = 0; bandIndex < numberOfBands; ++bandIndex)
297  {
298  // if valid then muliply the value by the weight and add it to
299  // current pixel value
300  if(*inputBands[bandIndex] != nullValues[bandIndex])
301  {
302  value += theWeights[bandIndex]*((double)*inputBands[bandIndex]);
303  sumWeights += theWeights[bandIndex];
304  }
305  // increment to the next pixel for the next time around
306  ++inputBands[bandIndex];
307  }
308
309  // check to see if we had any valid data. If we did the weight
310  // should be greater than 0
311  if(sumWeights != 0.0)
312  {
313  value /= sumWeights;
314  }
315  else
316  {
317  // else we set the pixel to the output null value
318  value = outputNullPix;
319  }
320  // store the result in the outputBuffer.
321  *outputBuf = static_cast<T>(value);
322
323  // advance the output buffer to the next pixel value
324  ++outputBuf;
325  }
326 }
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
◆ checkWeights()
void ossimBandAverageFilter::checkWeights ( )
protected
Definition at line 234 of file ossimBandAverageFilter.cpp.
References ossimImageSource::getNumberOfOutputBands(), ossimImageSourceFilter::theInputConnection, theTile, and theWeights.
Referenced by initialize().
235 {
236  // we have not been initialzed yet
237  //
238  if(!theTile)
239  {
240  return;
241  }
242
243  // Check to see if the weights array is the same size as the input
244  // list. If not then resize it and populate them with the same weight
245  // value. It does not matter if they sum to one since we will perform
246  // a weighted average in the execution of the algorithm
247  //
249  {
251
252  std::fill(theWeights.begin(), theWeights.end(), 1);
253  }
254 }
◆ getMaxPixelValue()
double ossimBandAverageFilter::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
If we aredisabled we just return the inputs max
Definition at line 210 of file ossimBandAverageFilter.cpp.
References ossim::defaultMin(), ossimImageSource::getMaxPixelValue(), ossimImageSource::getNumberOfOutputBands(), ossimSource::isSourceEnabled(), OSSIM_DOUBLE, and ossimImageSourceFilter::theInputConnection.
211 {
212  if(!isSourceEnabled())
213  {
215  }
216
217  // loop through each band and find the max pix value
218  ossim_uint32 bandIndex = 0;
220  double maxValue = ossim::defaultMin(OSSIM_DOUBLE);
221  for(bandIndex = 0; bandIndex < inputBands; ++bandIndex)
222  {
223  double maxPix = theInputConnection->getMaxPixelValue(bandIndex);
224
225  if(maxPix > maxValue)
226  {
227  maxValue = maxPix;
228  }
229  }
230
231  return maxValue;
232 }
OSSIM_DLL double defaultMin(ossimScalarType scalarType)
Definition: ossimCommon.cpp:73
64 bit floating point
◆ getMinPixelValue()
double ossimBandAverageFilter::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
If we aredisabled we just return the inputs min
Definition at line 186 of file ossimBandAverageFilter.cpp.
References ossim::defaultMax(), ossimImageSource::getMinPixelValue(), ossimImageSource::getNumberOfOutputBands(), ossimSource::isSourceEnabled(), OSSIM_DOUBLE, and ossimImageSourceFilter::theInputConnection.
187 {
189  {
191  }
192
193  // loop through each band and find the min pix value
194  ossim_uint32 bandIndex = 0;
196  double minValue = ossim::defaultMax(OSSIM_DOUBLE);
197  for(bandIndex = 0; bandIndex < inputBands; ++bandIndex)
198  {
199  double minPix = theInputConnection->getMinPixelValue(bandIndex);
200
201  if(minPix < minValue)
202  {
203  minValue = minPix;
204  }
205  }
206
207  return minValue;
208 }
OSSIM_DLL double defaultMax(ossimScalarType scalarType)
◆ getNullPixelValue()
double ossimBandAverageFilter::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
If we are disabled we just return the input s null
Definition at line 176 of file ossimBandAverageFilter.cpp.
References ossimImageSource::getMinPixelValue(), ossimImageSource::getNullPixelValue(), and ossimSource::isSourceEnabled().
177 {
178  if(!isSourceEnabled())
179  {
181  }
182  // lets use the first band's null value as our null
184 }
◆ getNumberOfOutputBands()
ossim_uint32 ossimBandAverageFilter::getNumberOfOutputBands ( ) const
virtual
eventually we will remove it from the base classes. This method will return 1 if our source is enabled else it calls the base class getNumberOfOutputBands.
Definition at line 47 of file ossimBandAverageFilter.cpp.
References ossimImageSource::getNumberOfOutputBands(), and ossimSource::isSourceEnabled().
48 {
49  if(isSourceEnabled())
50  {
51  return 1;
52  }
53
55 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimBandAverageFilter::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
It will check the scalar tpe of the input and then cat it to set the template variabel to be used within the template method averageInput.
Definition at line 57 of file ossimBandAverageFilter.cpp.
References averageInput(), ossimObject::getClassName(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), initialize(), ossimSource::isSourceEnabled(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_EMPTY, ossimErrorCodes::OSSIM_ERROR, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimSetError(), ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
58 {
59  // first we will check to see if we have an input connection
60  //
62  {
63  // this will probably be null since we aren't initialized.
64  // we really need to creae a default blank tile in OSSIM that is returned
65  return theTile;
66  }
67
68  ossimRefPtr<ossimImageData> inputData =
69  theInputConnection->getTile(rect, resLevel);
70
71  if(!inputData.valid())
72  {
73  return inputData;
74  }
75
76  // If we are disabled or if the data object is empty or NULL or
77  // not enough bands we don't need to run our algorithm so return the input
78  // tile.
79  if(!isSourceEnabled() ||
80  (inputData->getDataObjectStatus() == OSSIM_NULL)||
81  (inputData->getDataObjectStatus() == OSSIM_EMPTY)||
82  (inputData->getNumberOfBands() < 2))
83  {
84  return inputData;
85  }
86
87  // check to see if we are initialized
88  if(!theTile.valid())
89  {
90  initialize();
91  }
92
94
95  // now lets set up the template method to operate in native type and run
96  // the algorithm
97  //
98  switch(inputData->getScalarType())
99  {
100  case OSSIM_UCHAR:
101  {
102  averageInput((ossim_uint8)0, // setup template variable
103  inputData);
104  break;
105  }
106  case OSSIM_USHORT11:
107  case OSSIM_USHORT12:
108  case OSSIM_USHORT13:
109  case OSSIM_USHORT14:
110  case OSSIM_USHORT15:
111  case OSSIM_USHORT16:
112  {
113  averageInput((ossim_uint16)0, // setup template variable
114  inputData);
115  break;
116  }
117  case OSSIM_SSHORT16:
118  {
119  averageInput((ossim_sint16)0, // setup template variable
120  inputData);
121  break;
122  }
124  case OSSIM_FLOAT:
125  {
126  averageInput((float)0, // setup template variable
127  inputData);
128  break;
129  }
131  case OSSIM_DOUBLE:
132  {
133  averageInput((double)0, // setup template variable
134  inputData);
135  break;
136  }
137  default:
138  {
141  "Unsupported scalar type in file %d at line %d",
142  __FILE__,
143  __LINE__);
144
145
146  theTile->makeBlank();
147  break;
148  }
149  }
150
151  theTile->validate();
152
153
154  return theTile;
155 }
OSSIMDLLEXPORT void ossimSetError(const char *className, ossim_int32 error, const char *fmtString=0,...)
virtual void initialize()
bool valid() const
Definition: ossimRefPtr.h:75
static const ossimErrorCode OSSIM_ERROR
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
unsigned short ossim_uint16
signed short ossim_sint16
virtual void makeBlank()
32 bit floating point
16 bit unsigned iteger
16 bit signed integer
unsigned char ossim_uint8
8 bit unsigned iteger
void averageInput(T dummyVariable, ossimRefPtr< ossimImageData > inputDataObject)
◆ getWeight()
double ossimBandAverageFilter::getWeight ( ossim_uint32  band) const
Definition at line 382 of file ossimBandAverageFilter.cpp.
References theWeights.
383 {
384  if(band < theWeights.size())
385  {
386  return theWeights[band];
387  }
388
389  return 0.0;
390 }
◆ initialize()
void ossimBandAverageFilter::initialize ( )
virtual
Definition at line 159 of file ossimBandAverageFilter.cpp.
References checkWeights(), ossimImageDataFactory::create(), ossimImageSourceFilter::initialize(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
160 {
162
163  // theInputConnection is defined in ossimImageSourceFilter
164  // It is automatically set when an input is connected to this
165  // object
167  {
169
170  // now initialize the tile
171  theTile->initialize();
172  checkWeights();
173  }
174 }
Initialize the data buffer.
◆ loadState()
bool ossimBandAverageFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 329 of file ossimBandAverageFilter.cpp.
References ossimKeywordlist::find().
331 {
332  // get the value of the stored keyword
333  ossimString weightString = kwl.find(prefix, WEIGHTS_KW);
334  weightString = weightString.trim();
335
336
337  theWeights.clear();
338  if(weightString != "")
339  {
340  // split the string list into an array of strings
341  std::vector<ossimString> weightList = weightString.split(" ");
342
343  // resize the weights to the size of the weight list
344  //
345  theWeights.resize(weightList.size());
346  ossim_uint32 i = 0;
347
348  // now store the weights to the array
349  for(i = 0; i < theWeights.size(); ++i)
350  {
351  theWeights[i] = weightList[i].toDouble();
352  }
353  }
354
355  // call base class to continue the load state
356  return ossimImageSourceFilter::loadState(kwl, prefix);
357 }
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
◆ saveState()
bool ossimBandAverageFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 359 of file ossimBandAverageFilter.cpp.
References ossimKeywordlist::add(), theWeights, and ossimString::trim().
361 {
362  std::stringstream out;
363
364  // copy the weights to a memory stream separated by space
365  std::copy(theWeights.begin(),
366  theWeights.end(),
367  ostream_iterator<double>(out, " "));
368
369  ossimString weightString = out.str();
370  weightString = weightString.trim();
371
372
373  kwl.add(prefix, // prefix to help uniquely id or attributes
374  WEIGHTS_KW, // the keyword to identity our attribute
375  weightString.c_str(), // the value
376  true); // overwrite if already in the keywordlist
377
378  // call base classes save to allow us to pass the information up
379  return ossimImageSourceFilter::saveState(kwl, prefix);
380 }
std::basic_stringstream< char > stringstream
Class for char mixed input and output memory streams.
Definition: ossimIosFwd.h:38
const char * c_str() const
Definition: ossimString.h:396
◆ setWeight()
void ossimBandAverageFilter::setWeight ( ossim_uint32  band,
double  weight
Definition at line 392 of file ossimBandAverageFilter.cpp.
393 {
394  if(band < theWeights.size())
395  {
396  theWeights[band] = fabs(weight);
397  }
398 }
Member Data Documentation
◆ theTile
ossimRefPtr<ossimImageData> ossimBandAverageFilter::theTile
protected
Definition at line 97 of file ossimBandAverageFilter.h.
Referenced by averageInput(), checkWeights(), getTile(), and initialize().
◆ theWeights
std::vector<double> ossimBandAverageFilter::theWeights
protected
Definition at line 98 of file ossimBandAverageFilter.h.
Referenced by averageInput(), checkWeights(), getWeight(), saveState(), and setWeight().
