ossimBrightnessContrastSource Class Reference
#include <ossimBrightnessContrastSource.h>
Inheritance diagram for ossimBrightnessContrastSource:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimBrightnessContrastSource ()
 Currently works in hsi space so must be one or three bands. More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
 Will apply the algorithm: i*c + b where b is brightnes c is contrast i is the input value. More...
virtual void setBrightnessContrast (ossim_float64 brightness, ossim_float64 contrast)
virtual void setBrightness (ossim_float64 brightness)
virtual void setContrast (ossim_float64 contrast)
virtual ossim_float64 getBrightness () const
virtual ossim_float64 getContrast () const
virtual void initialize ()
 Calls base ossimImageSourceFilter::initialize() to reset connection if needed then nulls out tiles. More...
 Keywords searched for by this method. More...
 Keywords saved to list by this method. More...
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimBrightnessContrastSource ()
void allocate ()
 Called to initialize tiles by first get tile when theTile or theNormTile are not initialized. More...
void processRgbTile ()
 Applies the brightness contrast to tile. More...
void processNBandTile ()
virtual ~ossimReferenced ()
Protected Attributes
ossim_float64 theBrightness
ossim_float64 theContrast
ossimRefPtr< ossimImageDatatheNormTile
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
Definition at line 14 of file ossimBrightnessContrastSource.h.
◆ ossimBrightnessContrastSource()
ossimBrightnessContrastSource::ossimBrightnessContrastSource ( )
Todo: Make work with nband.
◆ ~ossimBrightnessContrastSource()
ossimBrightnessContrastSource::~ossimBrightnessContrastSource ( )
protectedvirtual
Definition at line 37 of file ossimBrightnessContrastSource.cpp.
38 {
39 }
Member Function Documentation
◆ allocate()
void ossimBrightnessContrastSource::allocate ( )
protected
Definition at line 177 of file ossimBrightnessContrastSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::getNumberOfBands(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), OSSIM_FLOAT32, ossimImageSourceFilter::theInputConnection, theNormTile, theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
178 {
180  {
182  if(theTile.valid())
183  {
187  }
188  if(theTile.valid() && theNormTile.valid())
189  {
190  theTile->initialize();
192  }
193  else
194  {
195  theTile = 0;
196  theNormTile = 0;
197  }
198  }
199 }
bool valid() const
Definition: ossimRefPtr.h:75
32 bit floating point
virtual void initialize()
Initialize the data buffer.
ossimRefPtr< ossimImageData > theNormTile
◆ getBrightness()
ossim_float64 ossimBrightnessContrastSource::getBrightness ( ) const
virtual
Returns
Brightness value between -1.0 and +1.0.
Definition at line 306 of file ossimBrightnessContrastSource.cpp.
References theBrightness.
Referenced by getProperty(), and setContrast().
307 {
308  return theBrightness;
309 }
◆ getContrast()
ossim_float64 ossimBrightnessContrastSource::getContrast ( ) const
virtual
Returns
Contrast value between 0.0 and +2.0.
Definition at line 311 of file ossimBrightnessContrastSource.cpp.
References theContrast.
Referenced by getProperty(), and setBrightness().
312 {
313  return theContrast;
314 }
◆ getProperty()
ossimRefPtr< ossimProperty > ossimBrightnessContrastSource::getProperty ( const ossimString name) const
virtual
Definition at line 222 of file ossimBrightnessContrastSource.cpp.
References getBrightness(), getContrast(), ossimImageSourceFilter::getProperty(), ossimNumericProperty::ossimNumericPropertyType_FLOAT64, ossimProperty::setCacheRefreshBit(), ossimNumericProperty::setNumericType(), and ossimString::toString().
223 {
224  if(name == "brightness")
225  {
226  ossimNumericProperty* numeric = new ossimNumericProperty(name,
228  -1.0, 1.0);
230  numeric->setCacheRefreshBit();
231  return numeric;
232  }
233  else if(name == "contrast")
234  {
235  ossimNumericProperty* numeric = new ossimNumericProperty(name,
237  0.0, 20.0);
239  numeric->setCacheRefreshBit();
240  return numeric;
241  }
242
244 }
Numeric to string methods.
virtual void setNumericType(ossimNumericPropertyType type)
virtual ossim_float64 getContrast() const
virtual ossim_float64 getBrightness() const
void setCacheRefreshBit()
◆ getPropertyNames()
void ossimBrightnessContrastSource::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 246 of file ossimBrightnessContrastSource.cpp.
References ossimImageSourceFilter::getPropertyNames().
247 {
249
250  propertyNames.push_back("brightness");
251  propertyNames.push_back("contrast");
252 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimBrightnessContrastSource::getTile ( const ossimIrect tileRect,
ossim_uint32  resLevel = 0
virtual
Definition at line 41 of file ossimBrightnessContrastSource.cpp.
References allocate(), ossimImageData::copyNormalizedBufferToTile(), ossimImageData::copyTileToNormalizedBuffer(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), OSSIM_EMPTY, OSSIM_NULL, processNBandTile(), processRgbTile(), ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangle(), theBrightness, theContrast, ossimImageSourceFilter::theInputConnection, theNormTile, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Referenced by ossimBrightnessMatch::getTile().
43 {
44  ossimRefPtr<ossimImageData> tile = NULL;
45
47  {
48  tile = theInputConnection->getTile(tileRect, resLevel);
49
50  if(!tile.valid())
51  {
52  return tile;
53  }
54
55  if(!isSourceEnabled() ||
56  (tile->getDataObjectStatus()==OSSIM_NULL)||
57  (tile->getDataObjectStatus()==OSSIM_EMPTY)||
58  ( (theBrightness == 0.0) && (theContrast == 1.0) ) )
59  {
60  return tile;
61  }
62
63  if(!theTile.valid() || !theNormTile.valid())
64  {
65  allocate();
66  }
67
68  if(!theTile.valid() || !theNormTile.valid())
69  {
70  return tile;
71  }
72
73  theTile->setImageRectangle(tileRect);
74  theNormTile->setImageRectangle(tileRect);
75
78
79  if (theNormTile->getNumberOfBands() == 3)
80  {
82  }
83  else
84  {
86  }
87
89  theNormTile->getBuf());
90  theTile->validate();
91  return theTile;
92  }
93
94  return tile;
95 }
bool valid() const
float ossim_float32
void allocate()
void processRgbTile()
virtual void copyTileToNormalizedBuffer(ossim_float64 *buf) const
Copies entire tile to buf passed in.
virtual void copyNormalizedBufferToTile(ossim_float64 *buf)
Copies buf passed in to tile.
virtual void setDataObjectStatus(ossimDataObjectStatus status) const
Full list found in ossimConstants.h.
void processNBandTile()
◆ initialize()
void ossimBrightnessContrastSource::initialize ( )
virtual
Note
This does not initialize tiles intentionally to avoid repeated deletes and news. Tiles will be initialized by allocate() method on the first getTile call after an initialize.
Definition at line 169 of file ossimBrightnessContrastSource.cpp.
References ossimImageSourceFilter::initialize(), theNormTile, and theTile.
170 {
172
173  theTile = 0;
174  theNormTile = 0;
175 }
◆ loadState()
bool ossimBrightnessContrastSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
brightness: 0.0
contrast: 1.0
Definition at line 255 of file ossimBrightnessContrastSource.cpp.
References ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), theBrightness, theContrast, and ossimString::toDouble().
257 {
258  const char* brightness = kwl.find(prefix, "brightness");
259  const char* contrast = kwl.find(prefix, "contrast");
260
261  if(brightness)
262  {
263  theBrightness = ossimString(brightness).toDouble();
264  }
265  if(contrast)
266  {
267  theContrast = ossimString(contrast).toDouble();
268  }
269
270  return ossimImageSourceFilter::loadState(kwl, prefix);
271 }
double toDouble() const
◆ processNBandTile()
void ossimBrightnessContrastSource::processNBandTile ( )
protected
This method simply applies brightness contrast to all bands. Called if input does not have three bands.
Definition at line 148 of file ossimBrightnessContrastSource.cpp.
References ossimImageData::getFloatBuf(), ossimImageData::getMinNormalizedPix(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), theBrightness, theContrast, and theNormTile.
149 {
150  const ossim_uint32 BANDS = theNormTile->getNumberOfBands();
151  const ossim_uint32 PPB = theNormTile->getSizePerBand();
153
154  for (ossim_uint32 band = 0; band < BANDS; ++band)
155  {
156  ossim_float32* buf = theNormTile->getFloatBuf(band);
157
158  for (ossim_uint32 i = 0; i < PPB; ++i)
159  {
160  if (buf[i] != 0.0)
161  {
162  ossim_float32 p = buf[i] * theContrast + theBrightness;
163  buf[i] = (p < 1.0) ? ( (p > MP) ? p : 0.0 ) : 1.0;
164  }
165  }
166  }
167 }
virtual ossim_float64 getMinNormalizedPix() const
returns normalized minimum pixel value of band zero.
float ossim_float32
virtual ossim_uint32 getSizePerBand() const
Returns the number of pixels in a single band in a tile.
unsigned int ossim_uint32
virtual const ossim_float32 * getFloatBuf() const
◆ processRgbTile()
void ossimBrightnessContrastSource::processRgbTile ( )
protected
This method works in hsi space on the intensity channel; thus, preserving hue and saturation of an rgb pixel. Called if input has three bands.
Definition at line 97 of file ossimBrightnessContrastSource.cpp.
References ossimNormRgbVector::getB(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimNormRgbVector::getG(), ossimImageData::getHeight(), ossimHsiVector::getI(), ossimNormRgbVector::getR(), ossimImageData::getWidth(), OSSIM_DEFAULT_MIN_PIX_NORM_FLOAT, OSSIM_FULL, ossimHsiVector::setI(), theBrightness, theContrast, and theNormTile.
98 {
99  ossim_float32* bands[3];
100
101  bands[0] = (ossim_float32*)theNormTile->getBuf(0);
102  bands[1] = (ossim_float32*)theNormTile->getBuf(1);
103  bands[2] = (ossim_float32*)theNormTile->getBuf(2);
104
105  ossim_uint32 offset = 0;
107  ossimHsiVector hsi;
108  ossim_float32 i;
110  {
111  for(offset = 0; offset < maxIdx; ++offset)
112  {
113  ossimNormRgbVector rgb(bands[0][offset], bands[1][offset], bands[2][offset]);
114  hsi = rgb;
115  i = (hsi.getI()*theContrast + theBrightness);
117  if(i > 1.0) i = 1.0;
118  hsi.setI(i);
119  rgb = hsi;
120  bands[0][offset] = rgb.getR();
121  bands[1][offset] = rgb.getG();
122  bands[2][offset] = rgb.getB();
123  }
124  }
125  else
126  {
127  for(offset = 0; offset < maxIdx; ++offset)
128  {
129  if((bands[0][offset] != 0.0)&&
130  (bands[1][offset] != 0.0)&&
131  (bands[2][offset] != 0.0))
132  {
133  ossimNormRgbVector rgb(bands[0][offset], bands[1][offset], bands[2][offset]);
134  hsi = rgb;
135  i = (hsi.getI()*theContrast + theBrightness);
137  if(i > 1.0) i = 1.0;
138  hsi.setI(i);
139  rgb = hsi;
140  bands[0][offset] = rgb.getR();
141  bands[1][offset] = rgb.getG();
142  bands[2][offset] = rgb.getB();
143  }
144  }
145  }
146 }
float ossim_float32
void setI(ossim_float64 I)
ossim_float64 getI() const
#define OSSIM_DEFAULT_MIN_PIX_NORM_FLOAT
◆ saveState()
bool ossimBrightnessContrastSource::saveState ( ossimKeywordlist kwl,
) const
virtual
brightness: 0.0
contrast: 1.0
Definition at line 273 of file ossimBrightnessContrastSource.cpp.
References ossimKeywordlist::add(), ossimImageSourceFilter::saveState(), theBrightness, and theContrast.
275 {
276  kwl.add(prefix,
277  "brightness",
279  true);
280  kwl.add(prefix,
281  "contrast",
282  theContrast,
283  true);
284
285  return ossimImageSourceFilter::saveState(kwl, prefix);
286 }
◆ setBrightness()
void ossimBrightnessContrastSource::setBrightness ( ossim_float64  brightness)
virtual
Parameters
brightnessValue between -1.0 and +1.0 with zero being no brightness offset.
Definition at line 296 of file ossimBrightnessContrastSource.cpp.
References getContrast(), and setBrightnessContrast().
Referenced by ossimBrightnessMatch::computeInputBrightness(), and ossimBrightnessMatch::setProperty().
297 {
298  setBrightnessContrast(brightness, getContrast());
299 }
virtual void setBrightnessContrast(ossim_float64 brightness, ossim_float64 contrast)
◆ setBrightnessContrast()
void ossimBrightnessContrastSource::setBrightnessContrast ( ossim_float64  brightness,
virtual
Parameters
contrastValue between 0.0 and 2.0 with 1.0 being no contrast adjustment.
Definition at line 289 of file ossimBrightnessContrastSource.cpp.
References theBrightness, and theContrast.
Referenced by setBrightness(), and setContrast().
291 {
292  theBrightness = brightness;
293  theContrast = contrast;
294 }
◆ setContrast()
void ossimBrightnessContrastSource::setContrast ( ossim_float64  contrast)
virtual
Parameters
Definition at line 301 of file ossimBrightnessContrastSource.cpp.
References getBrightness(), and setBrightnessContrast().
302 {
304 }
◆ setProperty()
void ossimBrightnessContrastSource::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 201 of file ossimBrightnessContrastSource.cpp.
References ossimImageSourceFilter::setProperty(), theBrightness, and theContrast.
202 {
203  if(!property)
204  {
205  return;
206  }
207  ossimString name = property->getName();
208  if(name == "brightness")
209  {
210  theBrightness = property->valueToString().toDouble();
211  }
212  else if(name == "contrast")
213  {
214  theContrast = property->valueToString().toDouble();
215  }
216  else
217  {
219  }
220 }
Member Data Documentation
◆ theBrightness
ossim_float64 ossimBrightnessContrastSource::theBrightness
protected
◆ theContrast
ossim_float64 ossimBrightnessContrastSource::theContrast
protected
◆ theNormTile
ossimRefPtr<ossimImageData> ossimBrightnessContrastSource::theNormTile
protected
◆ theTile
ossimRefPtr<ossimImageData> ossimBrightnessContrastSource::theTile
protected
Definition at line 126 of file ossimBrightnessContrastSource.h.
Referenced by allocate(), getTile(), and initialize().
