#include <ossimCadrgProjection.h>
ossimCadrgProjection () | |
virtual ossimObject * | dup () const |
virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
Will take a point in meters and convert it to ground. More... | |
virtual ossimDpt | forward (const ossimGpt &latLon) const |
All map projections will convert the world coordinate to an easting northing (Meters). More... | |
virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
double | computeXPixConstant (double scale, long zone) const |
double | computeYPixConstant (double scale) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
ossimString | getProjectionName () const |
Returns the projection name. More... | |
virtual bool | operator== (const ossimProjection &projection) const |
Returns TRUE if principal parameters are within epsilon tolerance. More... | |
ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimMapProjection (const ossimMapProjection &src) | |
virtual ossimGpt | origin () const |
virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
virtual double | getFalseEasting () const |
virtual double | getFalseNorthing () const |
virtual double | getStandardParallel1 () const |
Derived classes should implement as needed. More... | |
virtual double | getStandardParallel2 () const |
virtual void | update () |
virtual void | setPcsCode (ossim_uint32 pcsCode) |
virtual ossim_uint32 | getPcsCode () const |
Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
virtual double | getA () const |
ACCESS METHODS: More... | |
virtual double | getB () const |
virtual double | getF () const |
virtual ossimDpt | getMetersPerPixel () const |
virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
virtual const ossimDpt & | getUlEastingNorthing () const |
virtual const ossimGpt & | getUlGpt () const |
virtual const ossimDatum * | getDatum () const |
const ossimEllipsoid & | getEllipsoid () const |
const ossimGpt & | getOrigin () const |
virtual bool | isGeographic () const |
virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
SET METHODS: More... | |
virtual void | setAB (double a, double b) |
virtual void | setDatum (const ossimDatum *datum) |
Sets theDatum to datum. More... | |
virtual void | setOrigin (const ossimGpt &origin) |
Sets theOrigin to origin. More... | |
virtual void | setMetersPerPixel (const ossimDpt &gsd) |
virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
virtual void | setUlTiePoints (const ossimGpt &gpt) |
virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
virtual void | setUlGpt (const ossimGpt &ulGpt) |
virtual void | assign (const ossimProjection &aProjection) |
virtual std::ostream & | print (std::ostream &out) const |
Prints data members to stream. More... | |
virtual void | computeDegreesPerPixel () |
Computes the approximate resolution in degrees/pixel. More... | |
virtual void | computeMetersPerPixel () |
This will go from the ground point and give you an approximate meters per pixel. More... | |
void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
void | setMatrixScale (const ossimDpt &scale) |
void | setMatrixRotation (double rotation) |
void | setMatrixTranslation (const ossimDpt &translation) |
void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
Utility method to snap the tie point to some multiple. More... | |
void | snapTiePointToOrigin () |
void | setElevationLookupFlag (bool flag) |
bool | getElevationLookupFlag () const |
ossimUnitType | getModelTransformUnitType () const |
void | setModelTransformUnitType (ossimUnitType unit) |
bool | hasModelTransform () const |
virtual bool | isAffectedByElevation () const |
Implementation of pure virtual ossimProjection::isAffectedByElevation method. More... | |
void | setProjectionUnits (ossimUnitType units) |
ossimUnitType | getProjectionUnits () const |
OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimProjection () | |
virtual | ~ossimProjection () |
virtual void | getRoundTripError (const ossimDpt &imagePoint, ossimDpt &errorResult) const |
virtual void | getRoundTripError (const ossimGpt &groundPoint, ossimDpt &errorResult) const |
virtual void | getGroundClipPoints (ossimGeoPolygon &gpts) const |
virtual bool | operator!= (const ossimProjection &projection) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
virtual | ~ossimCadrgProjection () |
void | computeParameters () |
virtual | ~ossimMapProjection () |
void | updateFromTransform () |
virtual | ~ossimReferenced () |
Static Protected Attributes | |
static double | theCadrgArcA [8] |
static double | theOldZoneExtents [10] |
static double | theNorthLimit = 90.0*M_PI/180.0 |
static double | theSouthLimit = -90.0*M_PI/180.0 |
Definition at line 15 of file ossimCadrgProjection.h.
ossimCadrgProjection::ossimCadrgProjection | ( | ) |
Definition at line 27 of file ossimCadrgProjection.cpp.
References computeParameters().
Referenced by dup().
protectedvirtual |
Definition at line 37 of file ossimCadrgProjection.cpp.
protected |
Definition at line 163 of file ossimCadrgProjection.cpp.
References computeXPixConstant(), computeYPixConstant(), theCadrgZone, theHeight, theMapScale, thePixelConstant, theUlLineSample, theWidth, ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), and ossimCadrgProjection().
double ossimCadrgProjection::computeXPixConstant | ( | double | scale, |
long | zone | ||
) | const |
Definition at line 126 of file ossimCadrgProjection.cpp.
References theCadrgArcA.
Referenced by computeParameters().
double ossimCadrgProjection::computeYPixConstant | ( | double | scale | ) | const |
Implements ossimProjection.
Definition at line 42 of file ossimCadrgProjection.cpp.
References ossimCadrgProjection().
Definition at line 65 of file ossimCadrgProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), ossimGpt::datum(), and ossimMapProjection::theDatum.
inlinevirtual |
Definition at line 49 of file ossimCadrgProjection.h.
References ossimObject::getClassName().
Definition at line 57 of file ossimCadrgProjection.cpp.
References DEG_PER_RAD, and ossimMapProjection::theDatum.
Definition at line 82 of file ossimCadrgProjection.cpp.
METHOD: lineSampleToWorld() Performs the inverse projection from line, sample to ground (world):
Definition at line 105 of file ossimCadrgProjection.cpp.
References ossimGpt::clampLat(), ossimGpt::clampLon(), ossimGpt::latd(), ossimGpt::lond(), ossimMapProjection::theOrigin, thePixelConstant, theUlLineSample, ossimDpt::x, and ossimDpt::y.
Definition at line 267 of file ossimCadrgProjection.cpp.
References computeParameters(), ossimKeywordlist::find(), ossimGpt::latd(), ossimKeywordNames::LL_LAT_KW, ossimKeywordNames::LL_LON_KW, ossimProjection::loadState(), ossimGpt::lond(), ossimKeywordNames::LR_LAT_KW, ossimKeywordNames::LR_LON_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, theCadrgZone, theHeight, theLlGpt, theLrGpt, theMapScale, theUlGpt, theUrGpt, theWidth, ossimString::toDouble(), ossimString::toLong(), ossimKeywordNames::UL_LAT_KW, ossimKeywordNames::UL_LON_KW, ossimKeywordNames::UR_LAT_KW, ossimKeywordNames::UR_LON_KW, and ossimKeywordNames::ZONE_KW.
Definition at line 407 of file ossimCadrgProjection.cpp.
References ossim::almostEqual(), theCadrgZone, theHeight, theLlGpt, theLrGpt, theUlGpt, theUrGpt, and theWidth.
Definition at line 188 of file ossimCadrgProjection.cpp.
References ossimKeywordlist::add(), ossimDatum::code(), ossimKeywordNames::DATUM_KW, ossimGpt::latd(), ossimKeywordNames::LL_LAT_KW, ossimKeywordNames::LL_LON_KW, ossimGpt::lond(), ossimKeywordNames::LR_LAT_KW, ossimKeywordNames::LR_LON_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimProjection::saveState(), theCadrgZone, ossimMapProjection::theDatum, theHeight, theLlGpt, theLrGpt, theMapScale, theUlGpt, theUrGpt, theWidth, ossimKeywordNames::UL_LAT_KW, ossimKeywordNames::UL_LON_KW, ossimKeywordNames::UR_LAT_KW, ossimKeywordNames::UR_LON_KW, and ossimKeywordNames::ZONE_KW.
Definition at line 48 of file ossimCadrgProjection.cpp.
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 91 of file ossimCadrgProjection.cpp.
References DEG_PER_RAD, ossimGpt::latd(), ossimGpt::lond(), ossimMapProjection::theOrigin, thePixelConstant, theUlLineSample, ossimDpt::x, and ossimDpt::y.
staticprotected |
Definition at line 63 of file ossimCadrgProjection.h.
Referenced by computeXPixConstant().
protected |
Definition at line 71 of file ossimCadrgProjection.h.
Referenced by computeParameters(), loadState(), operator==(), and saveState().
protected |
Definition at line 77 of file ossimCadrgProjection.h.
protected |
Definition at line 82 of file ossimCadrgProjection.h.
Referenced by loadState(), operator==(), and saveState().
protected |
Definition at line 83 of file ossimCadrgProjection.h.
protected |
Definition at line 74 of file ossimCadrgProjection.h.
Referenced by computeParameters(), loadState(), and saveState().
staticprotected |
Definition at line 68 of file ossimCadrgProjection.h.
staticprotected |
Definition at line 66 of file ossimCadrgProjection.h.
protected |
Definition at line 73 of file ossimCadrgProjection.h.
Referenced by computeParameters(), lineSampleToWorld(), and worldToLineSample().
staticprotected |
Definition at line 69 of file ossimCadrgProjection.h.
protected |
Definition at line 81 of file ossimCadrgProjection.h.
protected |
Definition at line 79 of file ossimCadrgProjection.h.
protected |
Definition at line 84 of file ossimCadrgProjection.h.
protected |
Definition at line 76 of file ossimCadrgProjection.h.
