class for vertical or horizontal convolution More...
#include <ossimConvolutionFilter1D.h>
ossimConvolutionFilter1D (ossimObject *owner=NULL) | |
own class methods More... | |
virtual const std::vector< ossim_float64 > & | getKernel () const |
virtual void | setKernel (const std::vector< ossim_float64 > &aKernel) |
virtual bool | isHorizontal () const |
virtual void | setIsHorizontal (bool aIsHz) |
virtual ossim_int32 | getCenterOffset () const |
virtual void | setCenterOffset (ossim_int32 aCenterOffset) |
virtual bool | isStrictNoData () const |
virtual void | setStrictNoData (bool aStrict) |
virtual ossimString | getShortName () const |
inherited methods More... | |
virtual ossimString | getLongName () const |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual void | initialize () |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
ossimImageSourceFilter (ossimObject *owner=NULL) | |
ossimImageSourceFilter (ossimImageSource *inputSource) | |
ossimImageSourceFilter (ossimObject *owner, ossimImageSource *inputSource) | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
virtual ossim_uint32 | getNumberOfInputBands () const |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual void | refreshEvent (ossimRefreshEvent &event) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
This will return the bounding rect of the source. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
virtual | ~ossimConvolutionFilter1D () |
void | allocate () |
Allocates theTile. More... | |
void | clearNullMinMax () |
Clears data members theNullPixValue, theMinPixValue, and theMaxPixValue. More... | |
void | computeNullMinMax () |
Computes null, min, and max considering input connection and theKernel. More... | |
template<class T > | |
void | convolveFull (T, ossimRefPtr< ossimImageData > inputData, ossimRefPtr< ossimImageData > outputData) |
void | convolvePartial (T, ossimRefPtr< ossimImageData > inputData, ossimRefPtr< ossimImageData > outputData) |
virtual | ~ossimImageSourceFilter () |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Protected Attributes | |
ossim_int32 | theCenterOffset |
offset of center point in the Kernel More... | |
ossimRefPtr< ossimImageData > | theTile |
std::vector< ossim_float64 > | theKernel |
bool | theIsHz |
bool | theStrictNoData |
isHorizontal convolution? More... | |
std::vector< double > | theNullPixValue |
strictly no NODATA values used More... | |
std::vector< double > | theMinPixValue |
std::vector< double > | theMaxPixValue |
ossimImageSource * | theInputConnection |
bool | theEnableFlag |
bool | theInitializedFlag |
ossimId | theId |
ossimString | theDescription |
ossimObject * | theOwner |
bool | theInputListIsFixedFlag |
Indicates whether the theInputObjectList is fixed. More... | |
bool | theOutputListIsFixedFlag |
Indicates whether the theOutputObjectList is fixed. More... | |
ConnectableObjectList | theInputObjectList |
Holds a list of input objects. More... | |
ConnectableObjectList | theOutputObjectList |
Holds a list of output objects. More... | |
std::list< ossimListener * > | theListenerList |
bool | theEnabledFlag |
std::list< ossimListener * > | theDelayedAdd |
std::list< ossimListener * > | theDelayedRemove |
bool | theFireEventFlag |
ossimErrorCode | theErrorStatus |
bool | theListenerEnableFlag |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
PROPERTIES: -KernelSize : length of linear kernel (>=1) NOTE - you need to exit the property editor for the kernel to be resized -Kernel : Kernel vector (line matrix) -Horizontal : boolean, otherwise vertical kernel -CenterOffset : center pixel position in the kernel, starting at 0 -StrictNoData : controls NODATA use true : any NODATA pixel in the convolution will make the center pixel NODATA false : if center is NODATA, then output center is NODATA, other NODATA pixels are processed as if they were zero in the convolution
Definition at line 32 of file ossimConvolutionFilter1D.h.
ossimConvolutionFilter1D::ossimConvolutionFilter1D | ( | ossimObject * | owner = NULL | ) |
own class methods
Definition at line 24 of file ossimConvolutionFilter1D.cpp.
References theKernel.
protectedvirtual |
Definition at line 38 of file ossimConvolutionFilter1D.cpp.
protected |
Allocates theTile.
Definition at line 353 of file ossimConvolutionFilter1D.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
Referenced by getTile().
protected |
Definition at line 600 of file ossimConvolutionFilter1D.cpp.
References theMaxPixValue, theMinPixValue, and theNullPixValue.
Referenced by initialize(), loadState(), setKernel(), and setProperty().
protected |
Definition at line 607 of file ossimConvolutionFilter1D.cpp.
References ossim::defaultMax(), ossim::defaultMin(), ossim::defaultNull(), ossimImageSource::getMaxPixelValue(), ossimImageSource::getMinPixelValue(), ossimImageSource::getNullPixelValue(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimImageSourceFilter::theInputConnection, theKernel, theMaxPixValue, theMinPixValue, and theNullPixValue.
protected |
Convolve full means that the input data is full and has no null data. We don't have to compare for nulls here
Definition at line 277 of file ossimConvolutionFilter1D.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), getMaxPixelValue(), getMinPixelValue(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), theIsHz, and theKernel.
protected |
Convolve partial means that the input data is has some null data. We will have to compare nulls
Definition at line 191 of file ossimConvolutionFilter1D.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), getMaxPixelValue(), getMinPixelValue(), ossimImageData::getNullPix(), getNullPixelValue(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), theCenterOffset, theIsHz, theKernel, and theStrictNoData.
inlinevirtual |
Definition at line 46 of file ossimConvolutionFilter1D.h.
inlinevirtual |
Definition at line 40 of file ossimConvolutionFilter1D.h.
inlinevirtual |
Definition at line 56 of file ossimConvolutionFilter1D.h.
Definition at line 590 of file ossimConvolutionFilter1D.cpp.
References ossimImageSource::getMaxPixelValue(), ossimSource::isSourceEnabled(), and theMaxPixValue.
Referenced by convolveFull(), and convolvePartial().
Definition at line 580 of file ossimConvolutionFilter1D.cpp.
References ossimImageSource::getMinPixelValue(), ossimSource::isSourceEnabled(), and theMinPixValue.
Definition at line 570 of file ossimConvolutionFilter1D.cpp.
References ossim::defaultNull(), ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), and theNullPixValue.
Referenced by convolvePartial().
Definition at line 422 of file ossimConvolutionFilter1D.cpp.
References ossimImageSourceFilter::getProperty(), ossimNumericProperty::ossimNumericPropertyType_INT, PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNEL, PROPNAME_KERNELSIZE, PROPNAME_STRICTNODATA, theCenterOffset, theIsHz, theKernel, theStrictNoData, and ossimString::toString().
Definition at line 456 of file ossimConvolutionFilter1D.cpp.
References ossimImageSourceFilter::getPropertyNames(), PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNEL, PROPNAME_KERNELSIZE, and PROPNAME_STRICTNODATA.
inlinevirtual |
inherited methods
Definition at line 55 of file ossimConvolutionFilter1D.h.
Definition at line 42 of file ossimConvolutionFilter1D.cpp.
References allocate(), computeNullMinMax(), convolveFull(), convolvePartial(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), ossimIrect::lr(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_FULL, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), theCenterOffset, ossimImageSourceFilter::theInputConnection, theIsHz, theKernel, theNullPixValue, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
Referenced by ossimImageGaussianFilter::getTile().
Definition at line 340 of file ossimConvolutionFilter1D.cpp.
References clearNullMinMax(), and theTile.
Referenced by ossimImageGaussianFilter::initializeProcesses().
inlinevirtual |
Definition at line 43 of file ossimConvolutionFilter1D.h.
inlinevirtual |
Definition at line 49 of file ossimConvolutionFilter1D.h.
Definition at line 499 of file ossimConvolutionFilter1D.cpp.
References ossimString::c_str(), clearNullMinMax(), ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNELSIZE, PROPNAME_STRICTNODATA, setCenterOffset(), setIsHorizontal(), setStrictNoData(), theKernel, ossimString::toDouble(), ossimString::toString(), and ossimString::toUInt32().
Definition at line 466 of file ossimConvolutionFilter1D.cpp.
References ossimKeywordlist::add(), PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNELSIZE, PROPNAME_STRICTNODATA, ossimImageSourceFilter::saveState(), theCenterOffset, theIsHz, theKernel, theStrictNoData, and ossimString::toString().
inlinevirtual |
Definition at line 47 of file ossimConvolutionFilter1D.h.
Referenced by loadState(), and ossimImageGaussianFilter::updateKernels().
inlinevirtual |
Definition at line 44 of file ossimConvolutionFilter1D.h.
Referenced by loadState(), and ossimImageGaussianFilter::ossimImageGaussianFilter().
Definition at line 563 of file ossimConvolutionFilter1D.cpp.
References clearNullMinMax(), and theKernel.
Referenced by ossimImageGaussianFilter::updateKernels().
Definition at line 366 of file ossimConvolutionFilter1D.cpp.
References ossimNumericProperty::asInt32(), ossimNumericProperty::asUInt32(), clearNullMinMax(), ossimRefPtr< T >::get(), ossimBooleanProperty::getBoolean(), ossimProperty::getName(), ossimMatrixProperty::getNumberOfCols(), PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNEL, PROPNAME_KERNELSIZE, PROPNAME_STRICTNODATA, PTR_CAST, ossimImageSourceFilter::setProperty(), theCenterOffset, theIsHz, theKernel, and theStrictNoData.
inlinevirtual |
Definition at line 50 of file ossimConvolutionFilter1D.h.
Referenced by loadState(), ossimImageGaussianFilter::ossimImageGaussianFilter(), and ossimImageGaussianFilter::setStrictNoData().
protected |
Definition at line 111 of file ossimConvolutionFilter1D.h.
Referenced by convolvePartial(), getProperty(), getTile(), saveState(), and setProperty().
protected |
Definition at line 114 of file ossimConvolutionFilter1D.h.
Referenced by convolveFull(), convolvePartial(), getProperty(), getTile(), saveState(), and setProperty().
protected |
Definition at line 113 of file ossimConvolutionFilter1D.h.
Referenced by computeNullMinMax(), convolveFull(), convolvePartial(), getProperty(), getTile(), loadState(), ossimConvolutionFilter1D(), saveState(), setKernel(), and setProperty().
protected |
Definition at line 119 of file ossimConvolutionFilter1D.h.
Referenced by clearNullMinMax(), computeNullMinMax(), and getMaxPixelValue().
protected |
Definition at line 118 of file ossimConvolutionFilter1D.h.
Referenced by clearNullMinMax(), computeNullMinMax(), and getMinPixelValue().
protected |
Definition at line 117 of file ossimConvolutionFilter1D.h.
Referenced by clearNullMinMax(), computeNullMinMax(), getNullPixelValue(), and getTile().
protected |
Definition at line 115 of file ossimConvolutionFilter1D.h.
Referenced by convolvePartial(), getProperty(), saveState(), and setProperty().
protected |
Definition at line 112 of file ossimConvolutionFilter1D.h.
Referenced by allocate(), getTile(), and initialize().
