Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimEckert4Projection Class Reference
#include <ossimEckert4Projection.h>
Inheritance diagram for ossimEckert4Projection:
ossimMapProjection ossimProjection ossimObject ossimErrorStatusInterface ossimReferenced
 ossimEckert4Projection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
 ossimEckert4Projection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, double falseEasting, double falseNorthing)
 ~ossimEckert4Projection ()
virtual ossimDpt forward (const ossimGpt &worldPoint) const
 All map projections will convert the world coordinate to an easting northing (Meters). More...
virtual ossimGpt inverse (const ossimDpt &projectedPoint) const
 Will take a point in meters and convert it to ground. More...
virtual void update ()
void setFalseEasting (double falseEasting)
void setFalseNorthing (double falseNorthing)
void setFalseEastingNorthing (double falseEasting, double falseNorthing)
double getFalseEasting () const
double getFalseNorthing () const
void setDefaults ()
- Public Member Functions inherited from ossimMapProjection
 ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
 ossimMapProjection (const ossimMapProjection &src)
virtual ossimDpt worldToLineSample (const ossimGpt &worldPoint) const
virtual void worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const
virtual ossimGpt lineSampleToWorld (const ossimDpt &projectedPoint) const
virtual void lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const
virtual void lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const
 This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More...
virtual void lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
virtual void eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const
virtual void eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const
virtual double getStandardParallel1 () const
 Derived classes should implement as needed. More...
virtual double getStandardParallel2 () const
virtual void setPcsCode (ossim_uint32 pcsCode)
virtual ossim_uint32 getPcsCode () const
 Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More...
virtual ossimString getProjectionName () const
 Returns the projection name. More...
virtual double getA () const
 ACCESS METHODS: More...
virtual double getB () const
virtual double getF () const
virtual const ossimDptgetDecimalDegreesPerPixel () const
 Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More...
virtual const ossimDptgetUlEastingNorthing () const
virtual const ossimGptgetUlGpt () const
virtual const ossimDatumgetDatum () const
const ossimEllipsoidgetEllipsoid () const
const ossimGptgetOrigin () const
virtual bool isGeographic () const
virtual void applyScale (const ossimDpt &scale, bool recenterTiePoint)
 Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More...
virtual void setEllipsoid (const ossimEllipsoid &ellipsoid)
 SET METHODS: More...
virtual void setAB (double a, double b)
virtual void setDatum (const ossimDatum *datum)
 Sets theDatum to datum. More...
virtual void setOrigin (const ossimGpt &origin)
 Sets theOrigin to origin. More...
virtual void setMetersPerPixel (const ossimDpt &gsd)
virtual void setDecimalDegreesPerPixel (const ossimDpt &gsd)
virtual void setUlTiePoints (const ossimGpt &gpt)
virtual void setUlTiePoints (const ossimDpt &eastingNorthing)
virtual void setUlEastingNorthing (const ossimDpt &ulEastingNorthing)
virtual void setUlGpt (const ossimGpt &ulGpt)
virtual void assign (const ossimProjection &aProjection)
 Prints data members to stream. More...
virtual bool operator== (const ossimProjection &projection) const
 Compares this to arg projection and returns TRUE if the same. More...
virtual void computeDegreesPerPixel ()
 Computes the approximate resolution in degrees/pixel. More...
virtual void computeMetersPerPixel ()
 This will go from the ground point and give you an approximate meters per pixel. More...
void setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation)
void setMatrixScale (const ossimDpt &scale)
void setMatrixRotation (double rotation)
void setMatrixTranslation (const ossimDpt &translation)
void snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType)
 Utility method to snap the tie point to some multiple. More...
void snapTiePointToOrigin ()
void setElevationLookupFlag (bool flag)
bool getElevationLookupFlag () const
ossimUnitType getModelTransformUnitType () const
void setModelTransformUnitType (ossimUnitType unit)
bool hasModelTransform () const
void setProjectionUnits (ossimUnitType units)
ossimUnitType getProjectionUnits () const
 OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More...
 ossimProjection ()
virtual ~ossimProjection ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimErrorStatusInterface ()
bool hasError () const
long Set_Eckert4_Parameters (double a, double f, double Central_Meridian, double False_Easting, double False_Northing)
void Get_Eckert4_Parameters (double *a, double *f, double *Central_Meridian, double *False_Easting, double *False_Northing) const
long Convert_Geodetic_To_Eckert4 (double Latitude, double Longitude, double *Easting, double *Northing) const
long Convert_Eckert4_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const
Private Attributes
double Eck4_a
double Eck4_f
double es2
double es4
double es6
double Ra0
double Ra1
double Eck4_Origin_Long
double Eck4_False_Easting
double Eck4_False_Northing
double Eck4_Delta_Northing
double Eck4_Max_Easting
double Eck4_Min_Easting
Additional Inherited Members
- Protected Member Functions inherited from ossimMapProjection
virtual ~ossimMapProjection ()
void updateFromTransform ()
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimMapProjection
ossimEllipsoid theEllipsoid
 This method verifies that the projection parameters match the current pcs code. More...
ossimGpt theOrigin
const ossimDatumtheDatum
 This is only set if we want to have built in datum shifting. More...
ossimDpt theMetersPerPixel
 Holds the number of meters per pixel. More...
ossimDpt theDegreesPerPixel
 Hold the decimal degrees per pixel. More...
ossimGpt theUlGpt
 Hold tie point in decimal degrees. More...
ossimDpt theUlEastingNorthing
 Hold tie point as easting northing. More...
ossimDpt theFalseEastingNorthing
 Hold the false easting northing. More...
ossim_uint32 thePcsCode
 Projection Coordinate System(PCS) code. More...
bool theElevationLookupFlag
ossimMatrix4x4 theModelTransform
ossimMatrix4x4 theInverseModelTransform
ossimUnitType theModelTransformUnitType
ossimUnitType theProjectionUnits
 Linear units of the projection as indicated in the projection's specification: More...
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 16 of file ossimEckert4Projection.h.
◆ ossimEckert4Projection() [1/2]
ossimEckert4Projection::ossimEckert4Projection ( const ossimEllipsoid ellipsoid = ossimEllipsoid(),
const ossimGpt origin = ossimGpt()
Definition at line 51 of file ossimEckert4Projection.cpp.
References setDefaults(), and update().
53  :ossimMapProjection(ellipsoid, origin)
54 {
55  setDefaults();
56  update();
57 }
virtual ossimGpt origin() const
ossimMapProjection(const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
◆ ossimEckert4Projection() [2/2]
ossimEckert4Projection::ossimEckert4Projection ( const ossimEllipsoid ellipsoid,
const ossimGpt origin,
Definition at line 59 of file ossimEckert4Projection.cpp.
References Eck4_Delta_Northing, Eck4_False_Easting, Eck4_False_Northing, Eck4_Max_Easting, Eck4_Min_Easting, and update().
63  :ossimMapProjection(ellipsoid, origin)
64 {
65
66  Eck4_False_Easting = falseEasting;
67  Eck4_False_Northing = falseNorthing;
68  Eck4_Delta_Northing = 8451144.0;
69  Eck4_Max_Easting = 16902288.0;
70  Eck4_Min_Easting = -16902288.0;
71
72  update();
73 }
◆ ~ossimEckert4Projection()
ossimEckert4Projection::~ossimEckert4Projection ( )
inline
Definition at line 26 of file ossimEckert4Projection.h.
26 {}
Member Function Documentation
◆ Convert_Eckert4_To_Geodetic()
long ossimEckert4Projection::Convert_Eckert4_To_Geodetic ( double  Easting,
double  Northing,
double *  Latitude,
double *  Longitude
) const
private
The function Convert_Eckert4_To_Geodetic converts Eckert IV projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Eckert IV projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise ECK4_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 359 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, Eck4_False_Northing, ECK4_NO_ERROR, Eck4_Origin_Long, NUM, Ra0, Ra1, and two_PLUS_PI_OVER_2.
Referenced by inverse().
363 { /* Begin Convert_Eckert4_To_Geodetic */
364 /*
365  * The function Convert_Eckert4_To_Geodetic converts Eckert IV projection
366  * (easting and northing) coordinates to geodetic (latitude and longitude)
367  * coordinates, according to the current ellipsoid, spherical radius and
368  * Eckert IV projection coordinates.
369  * If any errors occur, the error code(s) are returned by the
370  * function, otherwise ECK4_NO_ERROR is returned.
371  *
372  * Easting : Easting (X) in meters (input)
373  * Northing : Northing (Y) in meters (input)
374  * Latitude : Latitude (phi) in radians (output)
375  * Longitude : Longitude (lambda) in radians (output)
376  */
377
378  double theta;
379  double sin_theta, cos_theta;
380  double num;
381  double dx, dy;
382  double i;
383
384  long Error_Code = ECK4_NO_ERROR;
385
386 // if ((Easting < (Eck4_False_Easting + Eck4_Min_Easting))
387 // || (Easting > (Eck4_False_Easting + Eck4_Max_Easting)))
388 // { /* Easting out of range */
389 // Error_Code |= ECK4_EASTING_ERROR;
390 // }
391 // if ((Northing < (Eck4_False_Northing - Eck4_Delta_Northing))
392 // || (Northing > (Eck4_False_Northing + Eck4_Delta_Northing)))
393 // { /* Northing out of range */
394 // Error_Code |= ECK4_NORTHING_ERROR;
395 // }
396
397  if (!Error_Code)
398  {
399  dy = Northing - Eck4_False_Northing;
400  dx = Easting - Eck4_False_Easting;
401  i = dy / Ra1;
402  if (i > 1.0)
403  i = 1.0;
404  else if (i < -1.0)
405  i = -1.0;
406
407  theta = asin(i);
408  sin_theta = sin(theta);
409  cos_theta = cos(theta);
410  num = NUM(theta, sin_theta, cos_theta);
411
412  *Latitude = asin(num / two_PLUS_PI_OVER_2);
413  *Longitude = Eck4_Origin_Long + dx / (Ra0 * (1 + cos_theta));
414
415 // if (*Latitude > PI_OVER_2) /* force distorted values to 90, -90 degrees */
416 // *Latitude = PI_OVER_2;
417 // else if (*Latitude < -PI_OVER_2)
418 // *Latitude = -PI_OVER_2;
419
420 // if (*Longitude > PI)
421 // *Longitude -= TWO_PI;
422 // if (*Longitude < -PI)
423 // *Longitude += TWO_PI;
424
425 // if (*Longitude > PI) /* force distorted values to 180, -180 degrees */
426 // *Longitude = PI;
427 // else if (*Longitude < -PI)
428 // *Longitude = -PI;
429
430  }
431  return (Error_Code);
432
433 } /* End Convert_Eckert4_To_Geodetic */
#define ECK4_NO_ERROR
#define NUM(Theta, SinTheta, CosTheta)
const double two_PLUS_PI_OVER_2
◆ Convert_Geodetic_To_Eckert4()
long ossimEckert4Projection::Convert_Geodetic_To_Eckert4 ( double  Latitude,
double  Longitude,
double *  Easting,
double *  Northing
) const
private
The function Convert_Geodetic_To_Eckert4 converts geodetic (latitude and longitude) coordinates to Eckert IV projection easting, and northing coordinates, according to the current ellipsoid and Eckert IV projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise ECK4_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 290 of file ossimEckert4Projection.cpp.
Referenced by forward().
295 { /* Begin Convert_Geodetic_To_Eckert4 */
296 /*
297  * The function Convert_Geodetic_To_Eckert4 converts geodetic (latitude and
298  * longitude) coordinates to Eckert IV projection (easting and northing)
299  * coordinates, according to the current ellipsoid, spherical radius and
300  * Eckert IV projection parameters.
301  * If any errors occur, the error code(s) are returned by the
302  * function, otherwise ECK4_NO_ERROR is returned.
303  *
304  * Latitude : Latitude (phi) in radians (input)
305  * Longitude : Longitude (lambda) in radians (input)
306  * Easting : Easting (X) in meters (output)
307  * Northing : Northing (Y) in meters (output)
308  */
309
310  double slat = sin(Latitude);
311  double sin_theta, cos_theta;
312  double num;
313  double dlam; /* Longitude - Central Meridan */
314  double theta = Latitude / 2.0;
315  double delta_theta = 1.0;
316  double dt_tolerance = 4.85e-10; /* approximately 1/1000th of
317  an arc second or 1/10th meter */
318  long Error_Code = ECK4_NO_ERROR;
319
320 // if ((Latitude < -PI_OVER_2) || (Latitude > PI_OVER_2))
321 // { /* Latitude out of range */
322 // Error_Code |= ECK4_LAT_ERROR;
323 // }
324 // if ((Longitude < -PI) || (Longitude > TWO_PI))
325 // { /* Longitude out of range */
326 // Error_Code|= ECK4_LON_ERROR;
327 // }
328
329  if (!Error_Code)
330  { /* no errors */
331
332  dlam = Longitude - Eck4_Origin_Long;
333 // if (dlam > PI)
334 // {
335 // dlam -= TWO_PI;
336 // }
337 // if (dlam < -PI)
338 // {
339 // dlam += TWO_PI;
340 // }
341  while (fabs(delta_theta) > dt_tolerance)
342  {
343  sin_theta = sin(theta);
344  cos_theta = cos(theta);
345  num = NUM(theta, sin_theta, cos_theta);
346  delta_theta = -(num - two_PLUS_PI_OVER_2 * slat) /
347  (2.0 * cos_theta * (1.0 + cos_theta));
348  theta += delta_theta;
349  }
350  *Easting = Ra0 * dlam * (1.0 + cos(theta)) + Eck4_False_Easting;
351  *Northing = Ra1 * sin(theta) + Eck4_False_Northing;
352  }
353
354  return (Error_Code);
355
356 } /* End Convert_Geodetic_To_Eckert4 */
◆ dup()
virtual ossimObject* ossimEckert4Projection::dup ( ) const
inlinevirtual
Implements ossimProjection.
Definition at line 27 of file ossimEckert4Projection.h.
28  {
29  return new ossimEckert4Projection(*this);
30  }
ossimEckert4Projection(const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt())
◆ forward()
ossimDpt ossimEckert4Projection::forward ( const ossimGpt worldPoint) const
virtual
Definition at line 104 of file ossimEckert4Projection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Eckert4(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
105 {
106  double easting = 0.0;
107  double northing = 0.0;
108  ossimGpt gpt = latLon;
109
110  if (theDatum)
111  {
112  if (theDatum->code() != latLon.datum()->code())
113  {
114  gpt.changeDatum(theDatum); // Shift to our datum.
115  }
116  }
117
119  gpt.lonr(),
120  &easting,
121  &northing);
122
123  return ossimDpt(easting, northing);
124 }
virtual const ossimString & code() const
Definition: ossimDatum.h:57
void changeDatum(const ossimDatum *datum)
This will actually perform a shift.
Definition: ossimGpt.cpp:316
double lonr() const
Returns the longitude in radian measure.
Definition: ossimGpt.h:76
double latr() const
latr().
Definition: ossimGpt.h:66
long Convert_Geodetic_To_Eckert4(double Latitude, double Longitude, double *Easting, double *Northing) const
const ossimDatum * theDatum
◆ Get_Eckert4_Parameters()
void ossimEckert4Projection::Get_Eckert4_Parameters ( double *  a,
double *  f,
double *  Central_Meridian,
double *  False_Easting,
double *  False_Northing
) const
private
The function Get_Eckert4_Parameters returns the current ellipsoid parameters and EckertIV projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 261 of file ossimEckert4Projection.cpp.
References Eck4_a, Eck4_f, Eck4_False_Easting, Eck4_False_Northing, and Eck4_Origin_Long.
266 { /* Begin Get_Eckert4_Parameters */
267 /*
268  * The function Get_Eckert4_Parameters returns the current ellipsoid
269  * parameters and Eckert IV projection parameters.
270  *
271  * a : Semi-major axis of ellipsoid, in meters (output)
272  * f : Flattening of ellipsoid (output)
273  * Central_Meridian : Longitude in radians at the center of (output)
274  * the projection
275  * False_Easting : A coordinate value in meters assigned to the
276  * central meridian of the projection. (output)
277  * False_Northing : A coordinate value in meters assigned to the
278  * origin latitude of the projection (output)
279  */
280
281  *a = Eck4_a;
282  *f = Eck4_f;
283  *Central_Meridian = Eck4_Origin_Long;
284  *False_Easting = Eck4_False_Easting;
285  *False_Northing = Eck4_False_Northing;
286  return;
287 } /* End Get_Eckert4_Parameters */
◆ getFalseEasting()
double ossimEckert4Projection::getFalseEasting ( ) const
inlinevirtual
Returns
The false easting.
Definition at line 54 of file ossimEckert4Projection.h.
◆ getFalseNorthing()
double ossimEckert4Projection::getFalseNorthing ( ) const
inlinevirtual
Returns
The false northing.
Definition at line 55 of file ossimEckert4Projection.h.
◆ inverse()
ossimGpt ossimEckert4Projection::inverse ( const ossimDpt projectedPoint) const
virtual
Definition at line 91 of file ossimEckert4Projection.cpp.
References Convert_Eckert4_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
92 {
93  double lat = 0.0;
94  double lon = 0.0;
95
96  Convert_Eckert4_To_Geodetic(eastingNorthing.x,
97  eastingNorthing.y,
98  &lat,
99  &lon);
100
101  return ossimGpt(lat*DEG_PER_RAD, lon*DEG_PER_RAD, 0.0, theDatum);
102 }
#define DEG_PER_RAD
long Convert_Eckert4_To_Geodetic(double Easting, double Northing, double *Latitude, double *Longitude) const
◆ loadState()
bool ossimEckert4Projection::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 160 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, Eck4_False_Northing, ossimKeywordlist::find(), ossimMapProjection::loadState(), setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
161 {
162  bool flag = ossimMapProjection::loadState(kwl, prefix);
163
164  const char* type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
165
166  setDefaults();
167
169  {
172  }
173
174  update();
175
176  return flag;
177 }
double y
Definition: ossimDpt.h:165
static const char * TYPE_KW
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
double x
Definition: ossimDpt.h:164
◆ saveState()
bool ossimEckert4Projection::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 155 of file ossimEckert4Projection.cpp.
References ossimMapProjection::saveState().
156 {
157  return ossimMapProjection::saveState(kwl, prefix);
158 }
◆ Set_Eckert4_Parameters()
long ossimEckert4Projection::Set_Eckert4_Parameters ( double  a,
double  f,
private
The function Set_Eckert4_Parameters receives the ellipsoid parameters and Eckert IV projection parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise ECK4_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 185 of file ossimEckert4Projection.cpp.
References Eck4_a, Eck4_f, Eck4_False_Easting, Eck4_False_Northing, Eck4_Max_Easting, Eck4_Min_Easting, ECK4_NO_ERROR, Eck4_Origin_Long, es2, es4, es6, Ra0, and Ra1.
Referenced by update().
191 { /* Begin Set_Eckert4_Parameters */
192 /*
193  * The function Set_Eckert4_Parameters receives the ellipsoid parameters and
194  * projection parameters as inputs, and sets the corresponding state
195  * variables. If any errors occur, the error code(s) are returned by the
196  * function, otherwise ECK4_NO_ERROR is returned.
197  *
198  * a : Semi-major axis of ellipsoid, in meters (input)
199  * f : Flattening of ellipsoid (input)
200  * Central_Meridian : Longitude in radians at the center of (input)
201  * the projection
202  * False_Easting : A coordinate value in meters assigned to the
203  * central meridian of the projection. (input)
204  * False_Northing : A coordinate value in meters assigned to the
205  * origin latitude of the projection (input)
206  */
207
208  double Ra; /* Spherical radius */
209 // double inv_f = 1 / f;
210  long Error_Code = ECK4_NO_ERROR;
211
212 // if (a <= 0.0)
213 // { /* Semi-major axis must be greater than zero */
214 // Error_Code |= ECK4_A_ERROR;
215 // }
216 // if ((inv_f < 250) || (inv_f > 350))
217 // { /* Inverse flattening must be between 250 and 350 */
218 // Error_Code |= ECK4_INV_F_ERROR;
219 // }
220 // if ((Central_Meridian < -PI) || (Central_Meridian > TWO_PI))
221 // { /* origin longitude out of range */
222 // Error_Code |= ECK4_CENT_MER_ERROR;
223 // }
224  if (!Error_Code)
225  { /* no errors */
226  Eck4_a = a;
227  Eck4_f = f;
228  es2 = 2 * Eck4_f - Eck4_f * Eck4_f;
229  es4 = es2 * es2;
230  es6 = es4 * es2;
231  /* spherical radius */
232  Ra = Eck4_a * (1.0 - es2 / 6.0 - 17.0 * es4 / 360.0 - 67.0 * es6 / 3024.0);
233  Ra0 = 0.4222382 * Ra;
234  Ra1 = 1.3265004 * Ra;
235 // if (Central_Meridian > PI)
236 // Central_Meridian -= TWO_PI;
237  Eck4_Origin_Long = Central_Meridian;
238  Eck4_False_Easting = False_Easting;
239  Eck4_False_Northing = False_Northing;
240  if (Eck4_Origin_Long > 0)
241  {
242  Eck4_Max_Easting = 16808386.0;
243  Eck4_Min_Easting = -16902288.0;
244  }
245  else if (Eck4_Origin_Long < 0)
246  {
247  Eck4_Max_Easting = 16902288.0;
248  Eck4_Min_Easting = -16808386.0;
249  }
250  else
251  {
252  Eck4_Max_Easting = 16902288.0;
253  Eck4_Min_Easting = -16902288.0;
254  }
255
256  } /* End if(!Error_Code) */
257  return (Error_Code);
258 } /* End Set_Eckert4_Parameters */
◆ setDefaults()
void ossimEckert4Projection::setDefaults ( )
Initialize all pramters to default and calls update for pre-computations.
Definition at line 146 of file ossimEckert4Projection.cpp.
References Eck4_Delta_Northing, Eck4_False_Easting, Eck4_False_Northing, Eck4_Max_Easting, and Eck4_Min_Easting.
Referenced by loadState(), and ossimEckert4Projection().
147 {
148  Eck4_Delta_Northing = 8451144.0;
149  Eck4_Max_Easting = 16902288.0;
150  Eck4_Min_Easting = -16902288.0;
151  Eck4_False_Easting = 0.0;
152  Eck4_False_Northing = 0.0;
153 }
◆ setFalseEasting()
void ossimEckert4Projection::setFalseEasting ( double  falseEasting)
Definition at line 126 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, and update().
127 {
128  Eck4_False_Easting = falseEasting;
129  update();
130 }
◆ setFalseEastingNorthing()
void ossimEckert4Projection::setFalseEastingNorthing ( double  falseEasting,
Definition at line 138 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, Eck4_False_Northing, and update().
140 {
141  Eck4_False_Easting = falseEasting;
142  Eck4_False_Northing = falseNorthing;
143  update();
144 }
◆ setFalseNorthing()
void ossimEckert4Projection::setFalseNorthing ( double  falseNorthing)
Definition at line 132 of file ossimEckert4Projection.cpp.
References Eck4_False_Northing, and update().
133 {
134  Eck4_False_Northing = falseNorthing;
135  update();
136 }
◆ update()
void ossimEckert4Projection::update ( )
virtual
Definition at line 76 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, Eck4_False_Northing, ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::lonr(), Set_Eckert4_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimEckert4Projection(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
77 {
78
81  theOrigin.lonr(),
84
87
89 }
long Set_Eckert4_Parameters(double a, double f, double Central_Meridian, double False_Easting, double False_Northing)
double y
const double & getA() const
double lonr() const
double x
const double & getFlattening() const
Member Data Documentation
◆ Eck4_a
double ossimEckert4Projection::Eck4_a
mutableprivate
Definition at line 79 of file ossimEckert4Projection.h.
Referenced by Get_Eckert4_Parameters(), and Set_Eckert4_Parameters().
◆ Eck4_Delta_Northing
double ossimEckert4Projection::Eck4_Delta_Northing
mutableprivate
Definition at line 92 of file ossimEckert4Projection.h.
Referenced by ossimEckert4Projection(), and setDefaults().
◆ Eck4_f
double ossimEckert4Projection::Eck4_f
mutableprivate
Definition at line 80 of file ossimEckert4Projection.h.
◆ Eck4_False_Easting
double ossimEckert4Projection::Eck4_False_Easting
mutableprivate
◆ Eck4_False_Northing
double ossimEckert4Projection::Eck4_False_Northing
mutableprivate
◆ Eck4_Max_Easting
double ossimEckert4Projection::Eck4_Max_Easting
mutableprivate
◆ Eck4_Min_Easting
double ossimEckert4Projection::Eck4_Min_Easting
mutableprivate
◆ Eck4_Origin_Long
double ossimEckert4Projection::Eck4_Origin_Long
mutableprivate
◆ es2
double ossimEckert4Projection::es2
mutableprivate
Definition at line 81 of file ossimEckert4Projection.h.
Referenced by Set_Eckert4_Parameters().
◆ es4
double ossimEckert4Projection::es4
mutableprivate
Definition at line 82 of file ossimEckert4Projection.h.
◆ es6
double ossimEckert4Projection::es6
mutableprivate
Definition at line 83 of file ossimEckert4Projection.h.
◆ Ra0
double ossimEckert4Projection::Ra0
mutableprivate
◆ Ra1
double ossimEckert4Projection::Ra1
mutableprivate
