#include <ossimGdalProjectionFactory.h>
virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
takes a filename. More... | |
virtual ossimProjection * | createProjection (const ossimString &name) const |
virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
Take a keywordlist. More... | |
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
virtual std::list< ossimString > | getList () const |
virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimGdalProjectionFactory * | instance () |
ossimGdalProjectionFactory () | |
ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
This method takes the filename and tries to find an external ".geom" file. More... | |
virtual | ~ossimReferenced () |
Protected Attributes | |
ossimOgcWktTranslator | theWktTranslator |
Static Protected Attributes | |
static ossimGdalProjectionFactory * | theInstance = 0 |
Definition at line 21 of file ossimGdalProjectionFactory.h.
inlineprotected |
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 544 of file ossimGdalProjectionFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 549 of file ossimGdalProjectionFactory.cpp.
takes a filename.
This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful.
Implements ossimProjectionFactoryBase.
Definition at line 48 of file ossimGdalProjectionFactory.cpp.
References ossimString::c_str(), ossimString::empty(), ossimNotify(), and ossimNotifyLevel_WARN.
Referenced by createObject(), and createProjection().
METHOD: create() Attempts to create an instance of the projection specified by name. Returns successfully constructed projection or NULL.
Definition at line 512 of file ossimGdalProjectionFactory.cpp.
Take a keywordlist.
Definition at line 479 of file ossimGdalProjectionFactory.cpp.
References ossimKeywordlist::add(), createProjection(), ossimKeywordlist::find(), ossimObject::getClassName(), ossimProjection::loadState(), ossimProjection::saveState(), and ossimKeywordNames::TYPE_KW.
METHOD: getList() Returns list of all projections represented by this factory:
Definition at line 559 of file ossimGdalProjectionFactory.cpp.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 555 of file ossimGdalProjectionFactory.cpp.
static |
METHOD: instance() Instantiates singleton instance of this class:
Definition at line 38 of file ossimGdalProjectionFactory.cpp.
References ossimGdalProjectionFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
staticprotected |
Definition at line 65 of file ossimGdalProjectionFactory.h.
Referenced by instance().
protected |
Definition at line 64 of file ossimGdalProjectionFactory.h.
