#include <ossimGeoidManager.h>
virtual | ~ossimGeoidManager () |
virtual bool | open (const ossimFilename &dir, ossimByteOrder byteOrder) |
Permits initialization of geoids from directory name. More... | |
virtual double | offsetFromEllipsoid (const ossimGpt &gpt) |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of the object to a keyword list. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of the object from a keyword list. More... | |
virtual void | addGeoid (ossimRefPtr< ossimGeoid > geoid, bool toFrontFlag=false) |
Permits adding additional geoids to the list: More... | |
ossimGeoid * | findGeoidByShortName (const ossimString &shortName, bool caseSensitive=true) |
virtual void | clear () |
Permits to clear the GeoidList. More... | |
ossimGeoid () | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
static ossimGeoidManager * | instance () |
Implements singelton pattern: More... | |
Private Member Functions | |
ossimGeoidManager () | |
Private constructor. More... | |
Private Attributes | |
std::vector< ossimRefPtr< ossimGeoid > > | theGeoidList |
ossimRefPtr< ossimGeoid > | theIdentityGeoid |
virtual | ~ossimGeoid () |
virtual | ~ossimReferenced () |
ossimErrorCode | theErrorStatus |
Definition at line 26 of file ossimGeoidManager.h.
Definition at line 54 of file ossimGeoidManager.cpp.
References clear().
private |
Use "instance" method.
Definition at line 44 of file ossimGeoidManager.cpp.
References theIdentityGeoid.
Definition at line 94 of file ossimGeoidManager.cpp.
References theGeoidList.
Definition at line 69 of file ossimGeoidManager.cpp.
Referenced by ~ossimGeoidManager().
ossimGeoid * ossimGeoidManager::findGeoidByShortName | ( | const ossimString & | shortName, |
bool | caseSensitive = true |
Definition at line 328 of file ossimGeoidManager.cpp.
References ossimString::downcase(), ossimRefPtr< T >::get(), ossimObject::getShortName(), theGeoidList, and theIdentityGeoid.
Referenced by ossimElevationDatabase::loadState().
static |
Definition at line 78 of file ossimGeoidManager.cpp.
Referenced by ossimElevRemapper::elevRemap(), ossimElevManager::getHeightAboveEllipsoid(), ossimElevManager::getHeightAboveMSL(), ossimElevationDatabase::getOffsetFromEllipsoid(), ossimGpt::heightMSL(), ossimElevationDatabase::loadState(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), and ossimInfo::outputHeight().
Definition at line 116 of file ossimGeoidManager.cpp.
Implements ossimGeoid.
Definition at line 313 of file ossimGeoidManager.cpp.
References ossim::isnan(), ossim::nan(), and theGeoidList.
Referenced by ossimElevRemapper::elevRemap(), ossimElevManager::getHeightAboveEllipsoid(), ossimElevManager::getHeightAboveMSL(), ossimElevationDatabase::getOffsetFromEllipsoid(), ossimGpt::heightMSL(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), and ossimInfo::outputHeight().
Should never be called since called on specific geoid types:
Definition at line 296 of file ossimGeoidManager.cpp.
References ossim::byteOrder(), status, and theGeoidList.
Return true if ok or false on error. DO NOTHING
Definition at line 106 of file ossimGeoidManager.cpp.
mutableprivate |
Definition at line 84 of file ossimGeoidManager.h.
Referenced by addGeoid(), clear(), findGeoidByShortName(), offsetFromEllipsoid(), and open().
private |
Definition at line 88 of file ossimGeoidManager.h.
Referenced by findGeoidByShortName(), and ossimGeoidManager().
