18 static ossimTrace traceDebug(
"ossimElevRemapper::debug");
23 :m_replacementType(ReplacementType_ELLIPSOID)
46 <<
"ossimElevRemapper::getTile entered..." << endl;
109 <<
"ossimElevRemapper::getTile Unsupported scalar type!" << endl;
116 <<
"ossimElevRemapper::getTile leaving..." << endl;
127 if (!inputTile)
return;
141 ossim_float32 height = 0.0, xpercent, ypercent, uppery, lowery;
168 ossim_float32 height = 0.0, xpercent, ypercent, uppery, lowery;
169 for(bandIdx = 0; bandIdx < bands; ++bandIdx)
171 T* bandPtr =
static_cast<T*
>(inputTile->
getBuf(bandIdx)) + originOffset;
172 for(
y = 0;
y < h; ++
y)
174 for(
x = 0;
x < w; ++
x)
176 xpercent =
x / clipRect.
width();
177 ypercent =
y / clipRect.
height();
178 uppery = hul + xpercent * ( hur - hul);
179 lowery = hll + xpercent * ( hlr - hll);
180 height = uppery + ypercent * ( lowery - uppery );
183 bandPtr[
x] += height;
195 for(bandIdx = 0; bandIdx < bands; ++bandIdx)
197 T* bandPtr =
static_cast<T*
>(inputTile->
getBuf(bandIdx));
200 for(idx = 0; idx <
size;++idx)
204 xpercent =
x / clipRect.
width();
205 ypercent =
y / clipRect.
height();
206 uppery = hul + xpercent * ( hur - hul);
207 lowery = hll + xpercent * ( hlr - hll);
208 height = uppery + ypercent * ( lowery - uppery );
211 (*bandPtr) += height;
220 const char* prefix)
const 227 remapMode =
"ellipsoid";
233 remapMode =
"ellipsoid";
255 <<
"ossimElevRemapper::loadState entered..." << endl;
265 if (mode ==
"ELLIPSOID")
269 else if (mode ==
"GEOID")
This will return the bounding rect of the source.
bool loadState(const ossimKeywordlist &kwl, const char *prefix)
static ossimString upcase(const ossimString &aString)
ossim_uint32 numberOf(const char *str) const
static const char REMAP_MODE_KW[]
void elevRemap(T dummy, ossimImageData *inpuTile, ossim_uint32 resLevel)
bool saveState(ossimKeywordlist &kwl, const char *prefix) const
Attempts to initialize a transform and a projection given the KWL.
ossim_uint32 height() const
const ossimIpt & ul() const
bool intersects(const ossimIrect &rect) const
unsigned short ossim_uint16
const ossimIpt & ll() const
bool completely_within(const ossimIrect &rect) const
signed short ossim_sint16
virtual void initialize()
unsigned int ossim_uint32
static ossimGeoidManager * instance()
Implements singelton pattern:
virtual ~ossimElevRemapper()
virtual ossimIrect getImageRectangle() const
const ossimIpt & lr() const
void rnToWorld(const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimGpt &wpt) const
rnToWorld is a utility method that takes a rn resolution image point and maps it to the world point...
ossim_uint32 width() const
ReplacementType m_replacementType
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
const ossimIpt & ur() const
ossimRefPtr< ossimImageGeometry > m_imageGeometry
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
Saves the transform (if any) and projection (if any) states to the KWL.
ossimDataObjectStatus
Definitions for data object status.
virtual double offsetFromEllipsoid(const ossimGpt &gpt)
unsigned char ossim_uint8
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tile_rect, ossim_uint32 resLevel=0)
RTTI_DEF1(ossimElevRemapper, "ossimElevRemapper", ossimImageSourceFilter)
