#include <ossimLambertConformalConicProjection.h>
ossimLambertConformalConicProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimLambertConformalConicProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, double stdParallel1, double stdParallel2, double falseEasting, double falseNorthing) | |
virtual | ~ossimLambertConformalConicProjection () |
virtual ossimObject * | dup () const |
virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
Will take a point in meters and convert it to ground. More... | |
virtual ossimDpt | forward (const ossimGpt &latLon) const |
All map projections will convert the world coordinate to an easting northing (Meters). More... | |
virtual void | update () |
void | setStandardParallel1 (double degree) |
void | setStandardParallel2 (double degree) |
void | setStandardParallels (double parallel1Degree, double prallel2Degree) |
void | setFalseEasting (double falseEasting) |
void | setFalseNorthing (double falseNorthing) |
void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
void | setParameters (double parallel1, double parallel2, double falseEasting, double falseNorthing) |
Allows one to set all parameters for this projections. More... | |
virtual double | getStandardParallel1 () const |
virtual double | getStandardParallel2 () const |
void | setDefaults () |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Prints data members to stream. More... | |
virtual bool | operator== (const ossimProjection &projection) const |
Returns TRUE if principal parameters are within epsilon tolerance. More... | |
ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimMapProjection (const ossimMapProjection &src) | |
virtual ossimGpt | origin () const |
virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
virtual double | getFalseEasting () const |
virtual double | getFalseNorthing () const |
virtual void | setPcsCode (ossim_uint32 pcsCode) |
virtual ossim_uint32 | getPcsCode () const |
Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
virtual ossimString | getProjectionName () const |
Returns the projection name. More... | |
virtual double | getA () const |
ACCESS METHODS: More... | |
virtual double | getB () const |
virtual double | getF () const |
virtual ossimDpt | getMetersPerPixel () const |
virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
virtual const ossimDpt & | getUlEastingNorthing () const |
virtual const ossimGpt & | getUlGpt () const |
virtual const ossimDatum * | getDatum () const |
const ossimEllipsoid & | getEllipsoid () const |
const ossimGpt & | getOrigin () const |
virtual bool | isGeographic () const |
virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
SET METHODS: More... | |
virtual void | setAB (double a, double b) |
virtual void | setDatum (const ossimDatum *datum) |
Sets theDatum to datum. More... | |
virtual void | setOrigin (const ossimGpt &origin) |
Sets theOrigin to origin. More... | |
virtual void | setMetersPerPixel (const ossimDpt &gsd) |
virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
virtual void | setUlTiePoints (const ossimGpt &gpt) |
virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
virtual void | setUlGpt (const ossimGpt &ulGpt) |
virtual void | assign (const ossimProjection &aProjection) |
virtual void | computeDegreesPerPixel () |
Computes the approximate resolution in degrees/pixel. More... | |
virtual void | computeMetersPerPixel () |
This will go from the ground point and give you an approximate meters per pixel. More... | |
void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
void | setMatrixScale (const ossimDpt &scale) |
void | setMatrixRotation (double rotation) |
void | setMatrixTranslation (const ossimDpt &translation) |
void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
Utility method to snap the tie point to some multiple. More... | |
void | snapTiePointToOrigin () |
void | setElevationLookupFlag (bool flag) |
bool | getElevationLookupFlag () const |
ossimUnitType | getModelTransformUnitType () const |
void | setModelTransformUnitType (ossimUnitType unit) |
bool | hasModelTransform () const |
virtual bool | isAffectedByElevation () const |
Implementation of pure virtual ossimProjection::isAffectedByElevation method. More... | |
void | setProjectionUnits (ossimUnitType units) |
ossimUnitType | getProjectionUnits () const |
OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimProjection () | |
virtual | ~ossimProjection () |
virtual void | getRoundTripError (const ossimDpt &imagePoint, ossimDpt &errorResult) const |
virtual void | getRoundTripError (const ossimGpt &groundPoint, ossimDpt &errorResult) const |
virtual void | getGroundClipPoints (ossimGeoPolygon &gpts) const |
virtual bool | operator!= (const ossimProjection &projection) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
Private Member Functions | |
long | Set_Lambert_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double Std_Parallel_1, double Std_Parallel_2, double False_Easting, double False_Northing) |
void | Get_Lambert_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *Std_Parallel_1, double *Std_Parallel_2, double *False_Easting, double *False_Northing) const |
long | Convert_Geodetic_To_Lambert (double Latitude, double Longitude, double *Easting, double *Northing) const |
long | Convert_Lambert_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
double | Lambert_a |
double | Lambert_f |
double | es |
double | es2 |
double | es_OVER_2 |
double | n |
double | F |
double | rho0 |
double | Lambert_aF |
double | Lambert_Std_Parallel_1 |
double | Lambert_Std_Parallel_2 |
double | Lambert_Origin_Lat |
double | Lambert_Origin_Long |
double | Lambert_False_Northing |
double | Lambert_False_Easting |
virtual | ~ossimMapProjection () |
void | updateFromTransform () |
virtual | ~ossimReferenced () |
ossimEllipsoid | theEllipsoid |
This method verifies that the projection parameters match the current pcs code. More... | |
ossimGpt | theOrigin |
const ossimDatum * | theDatum |
This is only set if we want to have built in datum shifting. More... | |
ossimDpt | theMetersPerPixel |
Holds the number of meters per pixel. More... | |
ossimDpt | theDegreesPerPixel |
Hold the decimal degrees per pixel. More... | |
ossimGpt | theUlGpt |
Hold tie point in decimal degrees. More... | |
ossimDpt | theUlEastingNorthing |
Hold tie point as easting northing. More... | |
ossimDpt | theFalseEastingNorthing |
Hold the false easting northing. More... | |
ossim_uint32 | thePcsCode |
Projection Coordinate System(PCS) code. More... | |
bool | theElevationLookupFlag |
ossimMatrix4x4 | theModelTransform |
ossimMatrix4x4 | theInverseModelTransform |
ossimUnitType | theModelTransformUnitType |
ossimUnitType | theProjectionUnits |
Linear units of the projection as indicated in the projection's specification: More... | |
ossimErrorCode | theErrorStatus |
Definition at line 19 of file ossimLambertConformalConicProjection.h.
ossimLambertConformalConicProjection::ossimLambertConformalConicProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid() , |
const ossimGpt & | origin = ossimGpt() |
Definition at line 57 of file ossimLambertConformalConicProjection.cpp.
References setDefaults(), and update().
Referenced by dup().
ossimLambertConformalConicProjection::ossimLambertConformalConicProjection | ( | const ossimEllipsoid & | ellipsoid, |
const ossimGpt & | origin, | ||
double | stdParallel1, | ||
double | stdParallel2, | ||
double | falseEasting, | ||
double | falseNorthing | ||
ellipsoid | |
origin | latitude longitude in decimal degrees. |
stdParallel1 | First parallel in DEGREES. |
stdParallel2 | Second parallel in DEGREES. |
falseEasting | False easting in meters. |
falseNorthing | False northing in meters. |
Definition at line 65 of file ossimLambertConformalConicProjection.cpp.
References Lambert_False_Easting, Lambert_False_Northing, Lambert_Std_Parallel_1, Lambert_Std_Parallel_2, RAD_PER_DEG, and update().
Definition at line 81 of file ossimLambertConformalConicProjection.cpp.
private |
The function Convert_Geodetic_To_Lambert converts Geodetic (latitude and longitude) coordinates to Lambert Conformal Conic projection (easting and northing) coordinates, according to the current ellipsoid and Lambert Conformal Conic projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise LAMBERT_NO_ERROR is returned.
Latitude : Latitude in radians (input) Longitude : Longitude in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 428 of file ossimLambertConformalConicProjection.cpp.
References ES_SIN, Lambert_aF, Lambert_False_Easting, Lambert_False_Northing, LAMBERT_LAT_ERROR, LAMBERT_NO_ERROR, Lambert_Origin_Long, LAMBERT_t, n, PI_OVER_2, and rho0.
Referenced by forward().
private |
The function Convert_Lambert_To_Geodetic converts Lambert Conformal Conic projection (easting and northing) coordinates to Geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Lambert Conformal Conic projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise LAMBERT_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude in radians (output) Longitude : Longitude in radians (output)
Definition at line 507 of file ossimLambertConformalConicProjection.cpp.
References es_OVER_2, ES_SIN, Lambert_aF, Lambert_False_Easting, Lambert_False_Northing, LAMBERT_NO_ERROR, Lambert_Origin_Long, M_PI, n, PI_OVER_2, and rho0.
Referenced by inverse().
Implements ossimProjection.
Definition at line 85 of file ossimLambertConformalConicProjection.cpp.
References ossimLambertConformalConicProjection().
Definition at line 182 of file ossimLambertConformalConicProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Lambert(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
private |
The function Get_Lambert_Parameters returns the current ellipsoid parameters and Lambert Conformal Conic projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude of origin, in radians (output) Central_Meridian : Longitude of origin, in radians (output) Std_Parallel_1 : First standard parallel (output) Std_Parallel_2 : Second standard parallel (output) False_Easting : False easting, in meters (output) False_Northing : False northing, in meters (output)
Definition at line 390 of file ossimLambertConformalConicProjection.cpp.
References Lambert_a, Lambert_f, Lambert_False_Easting, Lambert_False_Northing, Lambert_Origin_Lat, Lambert_Origin_Long, Lambert_Std_Parallel_1, and Lambert_Std_Parallel_2.
Definition at line 622 of file ossimLambertConformalConicProjection.cpp.
References Lambert_Std_Parallel_1, and RAD_PER_DEG.
Referenced by ossimStatePlaneProjectionInfo::matchesProjection().
Definition at line 627 of file ossimLambertConformalConicProjection.cpp.
References Lambert_Std_Parallel_2, and RAD_PER_DEG.
Definition at line 169 of file ossimLambertConformalConicProjection.cpp.
References Convert_Lambert_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 219 of file ossimLambertConformalConicProjection.cpp.
References ossimKeywordlist::find(), Lambert_False_Easting, Lambert_False_Northing, Lambert_Std_Parallel_1, Lambert_Std_Parallel_2, ossimMapProjection::loadState(), RAD_PER_DEG, setDefaults(), STATIC_TYPE_NAME, ossimKeywordNames::STD_PARALLEL_1_KW, ossimKeywordNames::STD_PARALLEL_2_KW, ossimMapProjection::theFalseEastingNorthing, ossimString::toDouble(), ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 635 of file ossimLambertConformalConicProjection.cpp.
References ossim::almostEqual(), Lambert_Std_Parallel_1, and Lambert_Std_Parallel_2.
Returns stream&.
Definition at line 247 of file ossimLambertConformalConicProjection.cpp.
References DEG_PER_RAD, Lambert_Std_Parallel_1, Lambert_Std_Parallel_2, ossimMapProjection::print(), ossimKeywordNames::STD_PARALLEL_1_KW, and ossimKeywordNames::STD_PARALLEL_2_KW.
Definition at line 204 of file ossimLambertConformalConicProjection.cpp.
References ossimKeywordlist::add(), DEG_PER_RAD, Lambert_Std_Parallel_1, Lambert_Std_Parallel_2, ossimMapProjection::saveState(), ossimKeywordNames::STD_PARALLEL_1_KW, and ossimKeywordNames::STD_PARALLEL_2_KW.
private |
The function Set_Lambert_Parameters receives the ellipsoid parameters and Lambert Conformal Conic projection parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise LAMBERT_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Origin_Latitude : Latitude of origin in radians (input) Central_Meridian : Longitude of origin in radians (input) Std_Parallel_1 : First standard parallel (input) Std_Parallel_2 : Second standard parallel (input) False_Easting : False easting in meters (input) False_Northing : False northing in meters (input)
Definition at line 272 of file ossimLambertConformalConicProjection.cpp.
References es, es2, es_OVER_2, ES_SIN, F, Lambert_a, Lambert_aF, Lambert_f, Lambert_False_Easting, Lambert_False_Northing, LAMBERT_m, LAMBERT_NO_ERROR, Lambert_Origin_Lat, Lambert_Origin_Long, Lambert_Std_Parallel_1, Lambert_Std_Parallel_2, LAMBERT_t, n, and rho0.
Referenced by update().
void ossimLambertConformalConicProjection::setDefaults | ( | ) |
Definition at line 161 of file ossimLambertConformalConicProjection.cpp.
References Lambert_False_Easting, Lambert_False_Northing, Lambert_Std_Parallel_1, Lambert_Std_Parallel_2, and RAD_PER_DEG.
Referenced by loadState(), and ossimLambertConformalConicProjection().
void ossimLambertConformalConicProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 128 of file ossimLambertConformalConicProjection.cpp.
References Lambert_False_Easting, and update().
void ossimLambertConformalConicProjection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 140 of file ossimLambertConformalConicProjection.cpp.
References Lambert_False_Easting, Lambert_False_Northing, and update().
void ossimLambertConformalConicProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 134 of file ossimLambertConformalConicProjection.cpp.
References Lambert_False_Northing, and update().
void ossimLambertConformalConicProjection::setParameters | ( | double | parallel1, |
double | parallel2, | ||
Update is then called so we can pre-compute paramters.
stdParallel1 | First parallel in decimal degrees. |
stdParallel2 | Second parallel in decimal degrees. |
Definition at line 148 of file ossimLambertConformalConicProjection.cpp.
void ossimLambertConformalConicProjection::setStandardParallel1 | ( | double | degree | ) |
The passed in Argument is in degrees and will convert it to radians for Geotrans. Update is then called so we can pre-compute paramters.
Definition at line 107 of file ossimLambertConformalConicProjection.cpp.
References Lambert_Std_Parallel_1, RAD_PER_DEG, and update().
Referenced by ossimWktProjectionFactory::doLambertConformalConic().
void ossimLambertConformalConicProjection::setStandardParallel2 | ( | double | degree | ) |
Definition at line 113 of file ossimLambertConformalConicProjection.cpp.
References Lambert_Std_Parallel_2, RAD_PER_DEG, and update().
void ossimLambertConformalConicProjection::setStandardParallels | ( | double | parallel1Degree, |
double | prallel2Degree | ||
Will allow you to set both parallels. both are passed in degrees.
Definition at line 119 of file ossimLambertConformalConicProjection.cpp.
References Lambert_Std_Parallel_1, Lambert_Std_Parallel_2, RAD_PER_DEG, and update().
Definition at line 90 of file ossimLambertConformalConicProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), Lambert_False_Easting, Lambert_False_Northing, Lambert_Std_Parallel_1, Lambert_Std_Parallel_2, ossimGpt::latr(), ossimGpt::lonr(), Set_Lambert_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimLambertConformalConicProjection(), setFalseEasting(), setFalseEastingNorthing(), setFalseNorthing(), setParameters(), setStandardParallel1(), setStandardParallel2(), and setStandardParallels().
mutableprivate |
Definition at line 133 of file ossimLambertConformalConicProjection.h.
Referenced by Set_Lambert_Parameters().
mutableprivate |
Definition at line 134 of file ossimLambertConformalConicProjection.h.
mutableprivate |
Definition at line 135 of file ossimLambertConformalConicProjection.h.
Referenced by Convert_Lambert_To_Geodetic(), and Set_Lambert_Parameters().
mutableprivate |
Definition at line 137 of file ossimLambertConformalConicProjection.h.
mutableprivate |
Definition at line 131 of file ossimLambertConformalConicProjection.h.
Referenced by Get_Lambert_Parameters(), and Set_Lambert_Parameters().
mutableprivate |
Definition at line 139 of file ossimLambertConformalConicProjection.h.
Referenced by Convert_Geodetic_To_Lambert(), Convert_Lambert_To_Geodetic(), and Set_Lambert_Parameters().
mutableprivate |
Definition at line 132 of file ossimLambertConformalConicProjection.h.
mutableprivate |
Definition at line 147 of file ossimLambertConformalConicProjection.h.
Referenced by Convert_Geodetic_To_Lambert(), Convert_Lambert_To_Geodetic(), Get_Lambert_Parameters(), loadState(), ossimLambertConformalConicProjection(), Set_Lambert_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), setParameters(), and update().
mutableprivate |
Definition at line 146 of file ossimLambertConformalConicProjection.h.
Referenced by Convert_Geodetic_To_Lambert(), Convert_Lambert_To_Geodetic(), Get_Lambert_Parameters(), loadState(), ossimLambertConformalConicProjection(), Set_Lambert_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), setParameters(), and update().
mutableprivate |
Definition at line 144 of file ossimLambertConformalConicProjection.h.
mutableprivate |
Definition at line 145 of file ossimLambertConformalConicProjection.h.
Referenced by Convert_Geodetic_To_Lambert(), Convert_Lambert_To_Geodetic(), Get_Lambert_Parameters(), and Set_Lambert_Parameters().
mutableprivate |
Definition at line 142 of file ossimLambertConformalConicProjection.h.
Referenced by Get_Lambert_Parameters(), getStandardParallel1(), loadState(), operator==(), ossimLambertConformalConicProjection(), print(), saveState(), Set_Lambert_Parameters(), setDefaults(), setParameters(), setStandardParallel1(), setStandardParallels(), and update().
mutableprivate |
Definition at line 143 of file ossimLambertConformalConicProjection.h.
Referenced by Get_Lambert_Parameters(), getStandardParallel2(), loadState(), operator==(), ossimLambertConformalConicProjection(), print(), saveState(), Set_Lambert_Parameters(), setDefaults(), setParameters(), setStandardParallel2(), setStandardParallels(), and update().
mutableprivate |
Definition at line 136 of file ossimLambertConformalConicProjection.h.
mutableprivate |
Definition at line 138 of file ossimLambertConformalConicProjection.h.
