Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimLandsatTileSource Class Reference
#include <ossimLandsatTileSource.h>
Inheritance diagram for ossimLandsatTileSource:
ossimGeneralRasterTileSource ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimLandsatTileSource ()
 ossimLandsatTileSource (const ossimKeywordlist &kwl, const char *prefix=0)
virtual bool open ()
 Pure virtual open. More...
 Override base getXXXXPixValue methods since the null/min/max can be set to something different. More...
 Returns the output pixel type of the tile source. More...
bool getAcquisitionDate (ossimDate &date) const
ossimString getSatelliteName () const
ossimFilename getBandFilename (ossim_uint32 idx) const
bool isPan () const
bool isVir () const
bool isTm () const
 Gets a property for matching name. More...
 Gets a list of property names available. More...
- Public Member Functions inherited from ossimGeneralRasterTileSource
 ossimGeneralRasterTileSource ()
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0)
 Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More...
 Method to get a tile. More...
 Returns the number of bands in the image. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 reduced_res_level=0) const
 Returns the number of lines in the image. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 reduced_res_level=0) const
 Returns the number of samples in the image. More...
 Returns the width of the output tile. More...
 Returns the height of the output tile. More...
bool isValidRLevel (ossim_uint32 reduced_res_level) const
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
virtual bool isOpen () const
virtual bool open (const ossimGeneralRasterInfo &info)
 Initializes bandList to the zero based order of output bands. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
virtual ~ossimLandsatTileSource ()
void openHeader (const ossimFilename &file)
Private Attributes
ossimRefPtr< ossimFfL7theFfHdr
Additional Inherited Members
- Protected Member Functions inherited from ossimGeneralRasterTileSource
virtual ~ossimGeneralRasterTileSource ()
virtual bool fillBuffer (const ossimIpt &origin, const ossimIpt &size)
 Methods return true on succes false on error. More...
virtual bool fillBIP (const ossimIpt &origin, const ossimIpt &size)
virtual bool fillBIL (const ossimIpt &origin, const ossimIpt &size)
virtual bool fillBSQ (const ossimIpt &origin, const ossimIpt &size)
virtual bool fillBsqMultiFile (const ossimIpt &origin, const ossimIpt &size)
virtual ossimKeywordlist getHdrInfo (ossimFilename hdrFile)
virtual ossimKeywordlist getXmlInfo (ossimFilename xmlFile)
bool initializeHandler ()
virtual void completeOpen ()
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimGeneralRasterTileSource
ossim_uint8m_buffer
ossim_uint8m_lineBuffer
ossimInterleaveType m_bufferInterleave
std::vector< std::shared_ptr< ossim::istream > > m_fileStrList
ossimGeneralRasterInfo m_rasterInfo
ossimIrect m_bufferRect
bool m_swapBytesFlag
ossim_uint32 m_bufferSizeInPixels
std::vector< ossim_uint32m_outputBandList
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 23 of file ossimLandsatTileSource.h.
◆ ossimLandsatTileSource() [1/2]
ossimLandsatTileSource::ossimLandsatTileSource ( )
◆ ossimLandsatTileSource() [2/2]
ossimLandsatTileSource::ossimLandsatTileSource ( const ossimKeywordlist kwl,
const char *  prefix = 0
◆ ~ossimLandsatTileSource()
virtual ossimLandsatTileSource::~ossimLandsatTileSource ( )
privatevirtual
Member Function Documentation
◆ getAcquisitionDate()
bool ossimLandsatTileSource::getAcquisitionDate ( ossimDate date) const
◆ getBandFilename()
ossimFilename ossimLandsatTileSource::getBandFilename ( ossim_uint32  idx) const
◆ getImageGeometry()
virtual ossimRefPtr<ossimImageGeometry> ossimLandsatTileSource::getImageGeometry ( )
virtual
The geometry contains full-to-local image transform as well as projection (image-to-world)
Reimplemented from ossimGeneralRasterTileSource.
◆ getLongName()
virtual ossimString ossimLandsatTileSource::getLongName ( ) const
virtual
◆ getMaxPixelValue()
virtual double ossimLandsatTileSource::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
◆ getMinPixelValue()
virtual double ossimLandsatTileSource::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
◆ getNullPixelValue()
virtual double ossimLandsatTileSource::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
Currently returns the same value for all bands.
◆ getOutputScalarType()
virtual ossimScalarType ossimLandsatTileSource::getOutputScalarType ( ) const
virtual
◆ getProperty()
virtual ossimRefPtr<ossimProperty> ossimLandsatTileSource::getProperty ( const ossimString name) const
virtual
Parameters
nameThe name of the property to get.
Returns
Returns property matching "name".
◆ getPropertyNames()
virtual void ossimLandsatTileSource::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Parameters
propertyNamesThe list to push back names to.
◆ getSatelliteName()
ossimString ossimLandsatTileSource::getSatelliteName ( ) const
◆ getShortName()
virtual ossimString ossimLandsatTileSource::getShortName ( ) const
virtual
◆ isPan()
bool ossimLandsatTileSource::isPan ( ) const
◆ isTm()
bool ossimLandsatTileSource::isTm ( ) const
◆ isVir()
bool ossimLandsatTileSource::isVir ( ) const
◆ loadState()
virtual bool ossimLandsatTileSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = NULL
virtual
◆ open()
virtual bool ossimLandsatTileSource::open ( )
virtual
Pure virtual open.
Derived classes must implement.
Returns
Note
This method relies on the data member ossimImageData::theImageFile being set. Callers should do a "setFilename" prior to calling this method or use the ossimImageHandler::open that takes a file name and an entry index.
◆ openHeader()
void ossimLandsatTileSource::openHeader ( const ossimFilename file)
private
Member Data Documentation
◆ theFfHdr
ossimRefPtr<ossimFfL7> ossimLandsatTileSource::theFfHdr
private
Definition at line 80 of file ossimLandsatTileSource.h.
The documentation for this class was generated from the following file:
