#include <ossimMiscProjectionFactory.h>
virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
virtual ossimProjection * | createProjection (const ossimString &name) const |
Take a projection type name. More... | |
virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
Take a keywordlist. More... | |
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimMiscProjectionFactory * | instance () |
ossimMiscProjectionFactory () | |
ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
This method takes the filename and tries to find an external ".geom" file. More... | |
virtual | ~ossimReferenced () |
Static Protected Attributes | |
static ossimMiscProjectionFactory * | theInstance = 0 |
Definition at line 24 of file ossimMiscProjectionFactory.h.
inlineprotected |
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 156 of file ossimMiscProjectionFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 165 of file ossimMiscProjectionFactory.cpp.
METHOD: create() Attempts to create an instance of the projection specified by name. Returns successfully constructed projection or NULL.
Implements ossimProjectionFactoryBase.
Definition at line 59 of file ossimMiscProjectionFactory.cpp.
References ossimProjectionFactoryBase::createProjectionFromGeometryFile().
Referenced by createObject(), and createProjection().
Definition at line 115 of file ossimMiscProjectionFactory.cpp.
References STATIC_TYPE_NAME.
Take a keywordlist.
Definition at line 71 of file ossimMiscProjectionFactory.cpp.
References ossimKeywordlist::addFile(), createProjection(), ossimKeywordlist::find(), ossimProjection::loadState(), and ossimKeywordNames::TYPE_KW.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 174 of file ossimMiscProjectionFactory.cpp.
static |
METHOD: instance() Instantiates singleton instance of this class:
Definition at line 48 of file ossimMiscProjectionFactory.cpp.
References ossimMiscProjectionFactory(), and theInstance.
Referenced by ossimProjectionFactoryRegistry::initializeDefaults().
staticprotected |
Definition at line 61 of file ossimMiscProjectionFactory.h.
Referenced by instance().
