#include <ossimMultiBandHistogramTileSource.h>
Public Types | |
enum | ossimMultiBandHistogramAlgorithm { OSSIM_HISTOGRAM_NO_ALGORITHM = 0, OSSIM_HISTOGRAM_LINEAR_STRETCH_ALGORITHM = 1 } |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
ossimMultiBandHistogramTileSource () | |
ossimMultiBandHistogramTileSource (double minValuePercent, double maxValuePercent, ossimImageSource *inputSource, ossimMultiResLevelHistogram *histogram) | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual void | setMinValuePercent (const std::vector< double > &arrayPercents) |
virtual void | setMaxValuePercent (const std::vector< double > &arrayPercents) |
virtual void | setMinValuePercent (ossim_uint32 arrayIndex, double minValue) |
virtual void | setMaxValuePercent (ossim_uint32 arrayIndex, double maxValue) |
virtual double | getMinValuePercent (ossim_uint32 arrayIndex) const |
virtual double | getMaxValuePercent (ossim_uint32 arrayIndex) const |
virtual ossim_uint32 | getNumberOfMinValues () const |
virtual ossim_uint32 | getNumberOfMaxValues () const |
virtual void | initialize () |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
Method to the load (recreate) the state of an object from a keyword list. More... | |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
ossimImageSourceHistogramFilter () | |
ossimImageSourceHistogramFilter (ossimImageSource *inputSource, ossimRefPtr< ossimMultiResLevelHistogram > histogram) | |
virtual void | setHistogram (ossimRefPtr< ossimMultiResLevelHistogram > histogram) |
virtual bool | setHistogram (const ossimFilename &filename) |
virtual const ossimFilename & | getHistogramFilename () const |
virtual ossimRefPtr< ossimMultiResLevelHistogram > | getHistogram () |
virtual const ossimRefPtr< ossimMultiResLevelHistogram > | getHistogram () const |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimImageSourceFilter (ossimObject *owner=NULL) | |
ossimImageSourceFilter (ossimImageSource *inputSource) | |
ossimImageSourceFilter (ossimObject *owner, ossimImageSource *inputSource) | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
virtual ossim_uint32 | getNumberOfInputBands () const |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual void | refreshEvent (ossimRefreshEvent &event) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
This will return the bounding rect of the source. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
virtual | ~ossimMultiBandHistogramTileSource () |
void | allocate () |
template<class T > | |
ossimRefPtr< ossimImageData > | runLinearStretchAlgorithm (T dummyVariable, ossimRefPtr< ossimImageData > &tile) |
virtual | ~ossimImageSourceHistogramFilter () |
virtual | ~ossimImageSourceFilter () |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Definition at line 13 of file ossimMultiBandHistogramTileSource.h.
Enumerator | |
OSSIM_HISTOGRAM_NO_ALGORITHM | |
OSSIM_HISTOGRAM_LINEAR_STRETCH_ALGORITHM |
Definition at line 16 of file ossimMultiBandHistogramTileSource.h.
ossimMultiBandHistogramTileSource::ossimMultiBandHistogramTileSource | ( | ) |
ossimMultiBandHistogramTileSource::ossimMultiBandHistogramTileSource | ( | double | minValuePercent, |
double | maxValuePercent, | ||
ossimImageSource * | inputSource, | ||
ossimMultiResLevelHistogram * | histogram | ||
Definition at line 37 of file ossimMultiBandHistogramTileSource.cpp.
References ossimSource::disableSource().
protectedvirtual |
Definition at line 49 of file ossimMultiBandHistogramTileSource.cpp.
protected |
Definition at line 142 of file ossimMultiBandHistogramTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::getNumberOfBands(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theMaxValuePercentArray, theMinValuePercentArray, theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
inlinevirtual |
Definition at line 61 of file ossimMultiBandHistogramTileSource.h.
References ossim::nan().
inlinevirtual |
Definition at line 53 of file ossimMultiBandHistogramTileSource.h.
inlinevirtual |
Definition at line 73 of file ossimMultiBandHistogramTileSource.h.
inlinevirtual |
Definition at line 69 of file ossimMultiBandHistogramTileSource.h.
Definition at line 53 of file ossimMultiBandHistogramTileSource.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), ossimImageData::loadTile(), OSSIM_DOUBLE, OSSIM_EMPTY, ossimErrorCodes::OSSIM_ERROR, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SCALAR_UNKNOWN, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimSetError(), runLinearStretchAlgorithm(), ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, theMaxValuePercentArray, theMinValuePercentArray, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Definition at line 134 of file ossimMultiBandHistogramTileSource.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
Reimplemented from ossimImageSourceHistogramFilter.
Definition at line 202 of file ossimMultiBandHistogramTileSource.cpp.
References ossimImageSourceHistogramFilter::loadState(), ossimNotify(), ossimNotifyLevel_INFO, theMaxValuePercentArray, and theMinValuePercentArray.
protected |
Definition at line 310 of file ossimMultiBandHistogramTileSource.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageSourceHistogramFilter::getHistogram(), ossimMultiBandHistogram::getHistogram(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimMultiResLevelHistogram::getMultiBandHistogram(), ossimImageData::getNullPix(), ossimMultiBandHistogram::getNumberOfBands(), ossimImageData::getNumberOfBands(), ossimHistogram::GetRes(), ossimImageData::getWidth(), ossimHistogram::HighClipVal(), ossimHistogram::LowClipVal(), ossimImageSourceHistogramFilter::theCurrentResLevel, theMaxValuePercentArray, theMinValuePercentArray, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Definition at line 260 of file ossimMultiBandHistogramTileSource.cpp.
References ossimKeywordlist::add(), ossimImageSourceHistogramFilter::saveState(), and theMinValuePercentArray.
inlinevirtual |
Definition at line 33 of file ossimMultiBandHistogramTileSource.h.
inlinevirtual |
Definition at line 45 of file ossimMultiBandHistogramTileSource.h.
inlinevirtual |
Definition at line 29 of file ossimMultiBandHistogramTileSource.h.
inlinevirtual |
Definition at line 37 of file ossimMultiBandHistogramTileSource.h.
protected |
Definition at line 90 of file ossimMultiBandHistogramTileSource.h.
protected |
Definition at line 92 of file ossimMultiBandHistogramTileSource.h.
Referenced by allocate(), getTile(), loadState(), and runLinearStretchAlgorithm().
protected |
Definition at line 91 of file ossimMultiBandHistogramTileSource.h.
Referenced by allocate(), getTile(), loadState(), runLinearStretchAlgorithm(), and saveState().
protected |
Definition at line 89 of file ossimMultiBandHistogramTileSource.h.
Referenced by allocate(), getTile(), and initialize().
