#include <ossimOrthoGraphicProjection.h>
ossimOrthoGraphicProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimOrthoGraphicProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, const double falseEasting, const double falseNorthing) | |
~ossimOrthoGraphicProjection () | |
virtual ossimObject * | dup () const |
virtual void | getGroundClipPoints (ossimGeoPolygon &gpts) const |
virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
Will take a point in meters and convert it to ground. More... | |
virtual ossimDpt | forward (const ossimGpt &latLon) const |
All map projections will convert the world coordinate to an easting northing (Meters). More... | |
virtual void | update () |
void | setFalseEasting (double falseEasting) |
void | setFalseNorthing (double falseNorthing) |
void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
void | setDefaults () |
double | getFalseEasting () const |
double | getFalseNorthing () const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimMapProjection (const ossimMapProjection &src) | |
virtual ossimGpt | origin () const |
virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
virtual double | getStandardParallel1 () const |
Derived classes should implement as needed. More... | |
virtual double | getStandardParallel2 () const |
virtual void | setPcsCode (ossim_uint32 pcsCode) |
virtual ossim_uint32 | getPcsCode () const |
Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
virtual ossimString | getProjectionName () const |
Returns the projection name. More... | |
virtual double | getA () const |
ACCESS METHODS: More... | |
virtual double | getB () const |
virtual double | getF () const |
virtual ossimDpt | getMetersPerPixel () const |
virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
virtual const ossimDpt & | getUlEastingNorthing () const |
virtual const ossimGpt & | getUlGpt () const |
virtual const ossimDatum * | getDatum () const |
const ossimEllipsoid & | getEllipsoid () const |
const ossimGpt & | getOrigin () const |
virtual bool | isGeographic () const |
virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
SET METHODS: More... | |
virtual void | setAB (double a, double b) |
virtual void | setDatum (const ossimDatum *datum) |
Sets theDatum to datum. More... | |
virtual void | setOrigin (const ossimGpt &origin) |
Sets theOrigin to origin. More... | |
virtual void | setMetersPerPixel (const ossimDpt &gsd) |
virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
virtual void | setUlTiePoints (const ossimGpt &gpt) |
virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
virtual void | setUlGpt (const ossimGpt &ulGpt) |
virtual void | assign (const ossimProjection &aProjection) |
virtual std::ostream & | print (std::ostream &out) const |
Prints data members to stream. More... | |
virtual bool | operator== (const ossimProjection &projection) const |
Compares this to arg projection and returns TRUE if the same. More... | |
virtual void | computeDegreesPerPixel () |
Computes the approximate resolution in degrees/pixel. More... | |
virtual void | computeMetersPerPixel () |
This will go from the ground point and give you an approximate meters per pixel. More... | |
void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
void | setMatrixScale (const ossimDpt &scale) |
void | setMatrixRotation (double rotation) |
void | setMatrixTranslation (const ossimDpt &translation) |
void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
Utility method to snap the tie point to some multiple. More... | |
void | snapTiePointToOrigin () |
void | setElevationLookupFlag (bool flag) |
bool | getElevationLookupFlag () const |
ossimUnitType | getModelTransformUnitType () const |
void | setModelTransformUnitType (ossimUnitType unit) |
bool | hasModelTransform () const |
virtual bool | isAffectedByElevation () const |
Implementation of pure virtual ossimProjection::isAffectedByElevation method. More... | |
void | setProjectionUnits (ossimUnitType units) |
ossimUnitType | getProjectionUnits () const |
OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimProjection () | |
virtual | ~ossimProjection () |
virtual void | getRoundTripError (const ossimDpt &imagePoint, ossimDpt &errorResult) const |
virtual void | getRoundTripError (const ossimGpt &groundPoint, ossimDpt &errorResult) const |
virtual bool | operator!= (const ossimProjection &projection) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
Private Member Functions | |
long | Set_Orthographic_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing) |
void | Get_Orthographic_Parameters (double *a, double *f, double *Origin_Latitude, double *Origin_Longitude, double *False_Easting, double *False_Northing) const |
long | Convert_Geodetic_To_Orthographic (double Latitude, double Longitude, double *Easting, double *Northing) const |
long | Convert_Orthographic_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
double | Orth_a |
double | Orth_f |
double | es2 |
double | es4 |
double | es6 |
double | Ra |
double | Orth_Origin_Lat |
double | Orth_Origin_Long |
double | Orth_False_Easting |
double | Orth_False_Northing |
double | Sin_Orth_Origin_Lat |
double | Cos_Orth_Origin_Lat |
virtual | ~ossimMapProjection () |
void | updateFromTransform () |
virtual | ~ossimReferenced () |
ossimEllipsoid | theEllipsoid |
This method verifies that the projection parameters match the current pcs code. More... | |
ossimGpt | theOrigin |
const ossimDatum * | theDatum |
This is only set if we want to have built in datum shifting. More... | |
ossimDpt | theMetersPerPixel |
Holds the number of meters per pixel. More... | |
ossimDpt | theDegreesPerPixel |
Hold the decimal degrees per pixel. More... | |
ossimGpt | theUlGpt |
Hold tie point in decimal degrees. More... | |
ossimDpt | theUlEastingNorthing |
Hold tie point as easting northing. More... | |
ossimDpt | theFalseEastingNorthing |
Hold the false easting northing. More... | |
ossim_uint32 | thePcsCode |
Projection Coordinate System(PCS) code. More... | |
bool | theElevationLookupFlag |
ossimMatrix4x4 | theModelTransform |
ossimMatrix4x4 | theInverseModelTransform |
ossimUnitType | theModelTransformUnitType |
ossimUnitType | theProjectionUnits |
Linear units of the projection as indicated in the projection's specification: More... | |
ossimErrorCode | theErrorStatus |
Definition at line 18 of file ossimOrthoGraphicProjection.h.
ossimOrthoGraphicProjection::ossimOrthoGraphicProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid() , |
const ossimGpt & | origin = ossimGpt() |
Definition at line 45 of file ossimOrthoGraphicProjection.cpp.
References setDefaults(), and update().
Referenced by dup().
ossimOrthoGraphicProjection::ossimOrthoGraphicProjection | ( | const ossimEllipsoid & | ellipsoid, |
const ossimGpt & | origin, | ||
const double | falseEasting, | ||
const double | falseNorthing | ||
Definition at line 53 of file ossimOrthoGraphicProjection.cpp.
References Orth_False_Easting, Orth_False_Northing, and update().
inline |
Definition at line 28 of file ossimOrthoGraphicProjection.h.
private |
The function Convert_Geodetic_To_Orthographic converts geodetic (latitude and longitude) coordinates to Orthographic projection easting, and northing coordinates, according to the current ellipsoid and Orthographic projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise ORTH_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 314 of file ossimOrthoGraphicProjection.cpp.
References Cos_Orth_Origin_Lat, M_PI, Orth_False_Easting, Orth_False_Northing, ORTH_LAT_ERROR, ORTH_LON_ERROR, ORTH_NO_ERROR, Orth_Origin_Long, PI_OVER_2, Ra, Sin_Orth_Origin_Lat, and TWO_PI.
Referenced by forward().
private |
The function Convert_Orthographic_To_Geodetic converts Orthographic projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Orthographic projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise ORTH_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 377 of file ossimOrthoGraphicProjection.cpp.
References Cos_Orth_Origin_Lat, MAX_LAT, ORTH_EASTING_ERROR, Orth_False_Easting, Orth_False_Northing, ORTH_NO_ERROR, ORTH_NORTHING_ERROR, Orth_Origin_Lat, Orth_Origin_Long, ORTH_RADIUS_ERROR, Ra, and Sin_Orth_Origin_Lat.
Referenced by inverse().
inlinevirtual |
Implements ossimProjection.
Definition at line 30 of file ossimOrthoGraphicProjection.h.
References ossimOrthoGraphicProjection().
Definition at line 152 of file ossimOrthoGraphicProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Orthographic(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), ossimDpt::makeNan(), ORTH_NO_ERROR, and ossimMapProjection::theDatum.
private |
The function Get_Orthographic_Parameters returns the current ellipsoid parameters and Orthographic projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude in radians at which the (output) point scale factor is 1.0 Origin_Longitude : Longitude in radians at the center of (output) the projection (central meridian) False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 280 of file ossimOrthoGraphicProjection.cpp.
References Orth_a, Orth_f, Orth_False_Easting, Orth_False_Northing, Orth_Origin_Lat, and Orth_Origin_Long.
inlinevirtual |
Definition at line 59 of file ossimOrthoGraphicProjection.h.
References Orth_False_Easting.
inlinevirtual |
Definition at line 60 of file ossimOrthoGraphicProjection.h.
References Orth_False_Northing.
Reimplemented from ossimProjection.
Definition at line 107 of file ossimOrthoGraphicProjection.cpp.
References ossimGeoPolygon::addPoint(), ossimGpt::latd(), ossimGpt::lond(), ossimMapProjection::theDatum, and ossimMapProjection::theOrigin.
Definition at line 130 of file ossimOrthoGraphicProjection.cpp.
References Convert_Orthographic_To_Geodetic(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), ossimGpt::makeNan(), ORTH_NO_ERROR, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 188 of file ossimOrthoGraphicProjection.cpp.
References ossimKeywordlist::find(), ossimMapProjection::loadState(), Orth_False_Easting, Orth_False_Northing, setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 183 of file ossimOrthoGraphicProjection.cpp.
References ossimMapProjection::saveState().
private |
The function Set_Orthographic_Parameters receives the ellipsoid parameters and Orthographic projcetion parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise ORTH_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Origin_Latitude : Latitude in radians at which the (input) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 213 of file ossimOrthoGraphicProjection.cpp.
References Cos_Orth_Origin_Lat, es2, es4, es6, M_PI, Orth_a, ORTH_A_ERROR, ORTH_CENT_MER_ERROR, Orth_f, Orth_False_Easting, Orth_False_Northing, ORTH_NO_ERROR, Orth_Origin_Lat, ORTH_ORIGIN_LAT_ERROR, Orth_Origin_Long, PI_OVER_2, Ra, Sin_Orth_Origin_Lat, and TWO_PI.
Referenced by update().
void ossimOrthoGraphicProjection::setDefaults | ( | ) |
Definition at line 92 of file ossimOrthoGraphicProjection.cpp.
References Orth_False_Easting, and Orth_False_Northing.
Referenced by loadState(), and ossimOrthoGraphicProjection().
void ossimOrthoGraphicProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 80 of file ossimOrthoGraphicProjection.cpp.
References Orth_False_Easting, and update().
void ossimOrthoGraphicProjection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 98 of file ossimOrthoGraphicProjection.cpp.
void ossimOrthoGraphicProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 86 of file ossimOrthoGraphicProjection.cpp.
References Orth_False_Northing, and update().
Definition at line 65 of file ossimOrthoGraphicProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latr(), ossimGpt::lonr(), Orth_False_Easting, Orth_False_Northing, Set_Orthographic_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimEpsgProjectionFactory::createProjFromAutoCode(), loadState(), ossimOrthoGraphicProjection(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprivate |
Definition at line 92 of file ossimOrthoGraphicProjection.h.
Referenced by Convert_Geodetic_To_Orthographic(), Convert_Orthographic_To_Geodetic(), and Set_Orthographic_Parameters().
mutableprivate |
Definition at line 81 of file ossimOrthoGraphicProjection.h.
Referenced by Set_Orthographic_Parameters().
mutableprivate |
Definition at line 82 of file ossimOrthoGraphicProjection.h.
mutableprivate |
Definition at line 83 of file ossimOrthoGraphicProjection.h.
mutableprivate |
Definition at line 79 of file ossimOrthoGraphicProjection.h.
Referenced by Get_Orthographic_Parameters(), and Set_Orthographic_Parameters().
mutableprivate |
Definition at line 80 of file ossimOrthoGraphicProjection.h.
mutableprivate |
Definition at line 89 of file ossimOrthoGraphicProjection.h.
Referenced by Convert_Geodetic_To_Orthographic(), Convert_Orthographic_To_Geodetic(), Get_Orthographic_Parameters(), getFalseEasting(), loadState(), ossimOrthoGraphicProjection(), Set_Orthographic_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprivate |
Definition at line 90 of file ossimOrthoGraphicProjection.h.
Referenced by Convert_Geodetic_To_Orthographic(), Convert_Orthographic_To_Geodetic(), Get_Orthographic_Parameters(), getFalseNorthing(), loadState(), ossimOrthoGraphicProjection(), Set_Orthographic_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprivate |
Definition at line 87 of file ossimOrthoGraphicProjection.h.
Referenced by Convert_Orthographic_To_Geodetic(), Get_Orthographic_Parameters(), and Set_Orthographic_Parameters().
mutableprivate |
Definition at line 88 of file ossimOrthoGraphicProjection.h.
Referenced by Convert_Geodetic_To_Orthographic(), Convert_Orthographic_To_Geodetic(), Get_Orthographic_Parameters(), and Set_Orthographic_Parameters().
mutableprivate |
Definition at line 84 of file ossimOrthoGraphicProjection.h.
mutableprivate |
Definition at line 91 of file ossimOrthoGraphicProjection.h.
