#include <ossimStereographicProjection.h>
ossimStereographicProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimStereographicProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, const double falseEasting, const double falseNorthing) | |
~ossimStereographicProjection () | |
virtual ossimObject * | dup () const |
virtual void | update () |
virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
Will take a point in meters and convert it to ground. More... | |
virtual ossimDpt | forward (const ossimGpt &latLon) const |
All map projections will convert the world coordinate to an easting northing (Meters). More... | |
void | setFalseEasting (double falseEasting) |
void | setFalseNorthing (double falseNorthing) |
void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
void | setDefaults () |
double | getFalseEasting () const |
double | getFalseNorthing () const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimMapProjection (const ossimMapProjection &src) | |
virtual ossimGpt | origin () const |
virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
virtual double | getStandardParallel1 () const |
Derived classes should implement as needed. More... | |
virtual double | getStandardParallel2 () const |
virtual void | setPcsCode (ossim_uint32 pcsCode) |
virtual ossim_uint32 | getPcsCode () const |
Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
virtual ossimString | getProjectionName () const |
Returns the projection name. More... | |
virtual double | getA () const |
ACCESS METHODS: More... | |
virtual double | getB () const |
virtual double | getF () const |
virtual ossimDpt | getMetersPerPixel () const |
virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
virtual const ossimDpt & | getUlEastingNorthing () const |
virtual const ossimGpt & | getUlGpt () const |
virtual const ossimDatum * | getDatum () const |
const ossimEllipsoid & | getEllipsoid () const |
const ossimGpt & | getOrigin () const |
virtual bool | isGeographic () const |
virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
SET METHODS: More... | |
virtual void | setAB (double a, double b) |
virtual void | setDatum (const ossimDatum *datum) |
Sets theDatum to datum. More... | |
virtual void | setOrigin (const ossimGpt &origin) |
Sets theOrigin to origin. More... | |
virtual void | setMetersPerPixel (const ossimDpt &gsd) |
virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
virtual void | setUlTiePoints (const ossimGpt &gpt) |
virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
virtual void | setUlGpt (const ossimGpt &ulGpt) |
virtual void | assign (const ossimProjection &aProjection) |
virtual std::ostream & | print (std::ostream &out) const |
Prints data members to stream. More... | |
virtual bool | operator== (const ossimProjection &projection) const |
Compares this to arg projection and returns TRUE if the same. More... | |
virtual void | computeDegreesPerPixel () |
Computes the approximate resolution in degrees/pixel. More... | |
virtual void | computeMetersPerPixel () |
This will go from the ground point and give you an approximate meters per pixel. More... | |
void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
void | setMatrixScale (const ossimDpt &scale) |
void | setMatrixRotation (double rotation) |
void | setMatrixTranslation (const ossimDpt &translation) |
void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
Utility method to snap the tie point to some multiple. More... | |
void | snapTiePointToOrigin () |
void | setElevationLookupFlag (bool flag) |
bool | getElevationLookupFlag () const |
ossimUnitType | getModelTransformUnitType () const |
void | setModelTransformUnitType (ossimUnitType unit) |
bool | hasModelTransform () const |
virtual bool | isAffectedByElevation () const |
Implementation of pure virtual ossimProjection::isAffectedByElevation method. More... | |
void | setProjectionUnits (ossimUnitType units) |
ossimUnitType | getProjectionUnits () const |
OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimProjection () | |
virtual | ~ossimProjection () |
virtual void | getRoundTripError (const ossimDpt &imagePoint, ossimDpt &errorResult) const |
virtual void | getRoundTripError (const ossimGpt &groundPoint, ossimDpt &errorResult) const |
virtual void | getGroundClipPoints (ossimGeoPolygon &gpts) const |
virtual bool | operator!= (const ossimProjection &projection) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
Private Member Functions | |
long | Set_Stereographic_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing) |
void | Get_Stereographic_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *False_Easting, double *False_Northing) const |
long | Convert_Geodetic_To_Stereographic (double Latitude, double Longitude, double *Easting, double *Northing) const |
long | Convert_Stereographic_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
double | Stereo_a |
double | Stereo_f |
double | Stereo_Ra |
double | Two_Stereo_Ra |
long | Stereo_At_Pole |
double | Stereo_Origin_Lat |
double | Stereo_Origin_Long |
double | Stereo_False_Easting |
double | Stereo_False_Northing |
double | Sin_Stereo_Origin_Lat |
double | Cos_Stereo_Origin_Lat |
double | Stereo_Delta_Easting |
double | Stereo_Delta_Northing |
virtual | ~ossimMapProjection () |
void | updateFromTransform () |
virtual | ~ossimReferenced () |
ossimEllipsoid | theEllipsoid |
This method verifies that the projection parameters match the current pcs code. More... | |
ossimGpt | theOrigin |
const ossimDatum * | theDatum |
This is only set if we want to have built in datum shifting. More... | |
ossimDpt | theMetersPerPixel |
Holds the number of meters per pixel. More... | |
ossimDpt | theDegreesPerPixel |
Hold the decimal degrees per pixel. More... | |
ossimGpt | theUlGpt |
Hold tie point in decimal degrees. More... | |
ossimDpt | theUlEastingNorthing |
Hold tie point as easting northing. More... | |
ossimDpt | theFalseEastingNorthing |
Hold the false easting northing. More... | |
ossim_uint32 | thePcsCode |
Projection Coordinate System(PCS) code. More... | |
bool | theElevationLookupFlag |
ossimMatrix4x4 | theModelTransform |
ossimMatrix4x4 | theInverseModelTransform |
ossimUnitType | theModelTransformUnitType |
ossimUnitType | theProjectionUnits |
Linear units of the projection as indicated in the projection's specification: More... | |
ossimErrorCode | theErrorStatus |
Definition at line 17 of file ossimStereographicProjection.h.
ossimStereographicProjection::ossimStereographicProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid() , |
const ossimGpt & | origin = ossimGpt() |
Definition at line 37 of file ossimStereographicProjection.cpp.
References setDefaults(), and update().
ossimStereographicProjection::ossimStereographicProjection | ( | const ossimEllipsoid & | ellipsoid, |
const ossimGpt & | origin, | ||
const double | falseEasting, | ||
const double | falseNorthing | ||
Definition at line 45 of file ossimStereographicProjection.cpp.
References Stereo_Delta_Easting, Stereo_Delta_Northing, Stereo_False_Easting, Stereo_False_Northing, and update().
inline |
Definition at line 26 of file ossimStereographicProjection.h.
private |
The function Convert_Geodetic_To_Stereographic converts geodetic coordinates (latitude and longitude) to Stereographic coordinates (easting and northing), according to the current ellipsoid and Stereographic projection parameters. If any errors occur, error code(s) are returned by the function, otherwise STEREO_NO_ERROR is returned.
Latitude : Latitude, in radians (input) Longitude : Longitude, in radians (input) Easting : Easting (X), in meters (output) Northing : Northing (Y), in meters (output)
Definition at line 286 of file ossimStereographicProjection.cpp.
References Cos_Stereo_Origin_Lat, PI_OVER_2, PI_OVER_4, Sin_Stereo_Origin_Lat, Stereo_At_Pole, Stereo_False_Easting, Stereo_False_Northing, STEREO_LON_ERROR, STEREO_NO_ERROR, Stereo_Origin_Lat, Stereo_Origin_Long, Stereo_Ra, and Two_Stereo_Ra.
Referenced by forward(), and Set_Stereographic_Parameters().
private |
The function Convert_Stereographic_To_Geodetic converts Stereographic projection (easting and northing) coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Stereographic projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise STEREO_NO_ERROR is returned.
Easting : Easting (X), in meters (input) Northing : Northing (Y), in meters (input) Latitude : Latitude (phi), in radians (output) Longitude : Longitude (lambda), in radians (output)
Definition at line 390 of file ossimStereographicProjection.cpp.
References Cos_Stereo_Origin_Lat, Sin_Stereo_Origin_Lat, Stereo_At_Pole, Stereo_False_Easting, Stereo_False_Northing, STEREO_NO_ERROR, Stereo_Origin_Lat, Stereo_Origin_Long, and Two_Stereo_Ra.
Referenced by inverse().
inlinevirtual |
Implements ossimProjection.
Definition at line 27 of file ossimStereographicProjection.h.
Definition at line 118 of file ossimStereographicProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Stereographic(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
private |
The function Get_Stereographic_Parameters returns the current ellipsoid parameters and Stereographic projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude, in radians, at the center of (output) the projection Central_Meridian : Longitude, in radians, at the center of (output) the projection False_Easting : A coordinate value, in meters, assigned to the central meridian of the projection. (output) False_Northing : A coordinate value, in meters, assigned to the origin latitude of the projection (output)
Definition at line 252 of file ossimStereographicProjection.cpp.
References Stereo_a, Stereo_f, Stereo_False_Easting, Stereo_False_Northing, Stereo_Origin_Lat, and Stereo_Origin_Long.
inlinevirtual |
Definition at line 57 of file ossimStereographicProjection.h.
inlinevirtual |
Definition at line 58 of file ossimStereographicProjection.h.
Definition at line 105 of file ossimStereographicProjection.cpp.
References Convert_Stereographic_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 145 of file ossimStereographicProjection.cpp.
References ossimKeywordlist::find(), ossimMapProjection::loadState(), setDefaults(), STATIC_TYPE_NAME, Stereo_False_Easting, Stereo_False_Northing, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 140 of file ossimStereographicProjection.cpp.
References ossimMapProjection::saveState().
private |
The function Set_Stereographic_Parameters receives the ellipsoid parameters and Stereograpic projection parameters as inputs, and sets the corresponding state variables. If any errors occur, error code(s) are returned by the function, otherwise STEREO_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Origin_Latitude : Latitude, in radians, at the center of (input) the projection Central_Meridian : Longitude, in radians, at the center of (input) the projection False_Easting : Easting (X) at center of projection, in meters (input) False_Northing : Northing (Y) at center of projection, in meters (input)
Definition at line 169 of file ossimStereographicProjection.cpp.
References Convert_Geodetic_To_Stereographic(), Cos_Stereo_Origin_Lat, M_PI, ONE, PI_OVER_2, Sin_Stereo_Origin_Lat, Stereo_a, Stereo_At_Pole, Stereo_Delta_Easting, Stereo_f, Stereo_False_Easting, Stereo_False_Northing, STEREO_NO_ERROR, Stereo_Origin_Lat, Stereo_Origin_Long, Stereo_Ra, and Two_Stereo_Ra.
Referenced by update().
void ossimStereographicProjection::setDefaults | ( | ) |
Definition at line 88 of file ossimStereographicProjection.cpp.
References Stereo_Delta_Easting, Stereo_Delta_Northing, Stereo_False_Easting, and Stereo_False_Northing.
Referenced by loadState(), and ossimStereographicProjection().
void ossimStereographicProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 74 of file ossimStereographicProjection.cpp.
References Stereo_False_Easting, and update().
void ossimStereographicProjection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 96 of file ossimStereographicProjection.cpp.
References Stereo_False_Easting, Stereo_False_Northing, and update().
void ossimStereographicProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 81 of file ossimStereographicProjection.cpp.
References Stereo_False_Northing, and update().
Definition at line 59 of file ossimStereographicProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latr(), ossimGpt::lonr(), Set_Stereographic_Parameters(), Stereo_False_Easting, Stereo_False_Northing, ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimStereographicProjection(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprivate |
Definition at line 92 of file ossimStereographicProjection.h.
Referenced by Convert_Geodetic_To_Stereographic(), Convert_Stereographic_To_Geodetic(), and Set_Stereographic_Parameters().
mutableprivate |
Definition at line 91 of file ossimStereographicProjection.h.
mutableprivate |
Definition at line 80 of file ossimStereographicProjection.h.
Referenced by Get_Stereographic_Parameters(), and Set_Stereographic_Parameters().
mutableprivate |
Definition at line 84 of file ossimStereographicProjection.h.
mutableprivate |
Definition at line 95 of file ossimStereographicProjection.h.
Referenced by ossimStereographicProjection(), Set_Stereographic_Parameters(), and setDefaults().
mutableprivate |
Definition at line 96 of file ossimStereographicProjection.h.
Referenced by ossimStereographicProjection(), and setDefaults().
mutableprivate |
Definition at line 81 of file ossimStereographicProjection.h.
mutableprivate |
Definition at line 89 of file ossimStereographicProjection.h.
Referenced by Convert_Geodetic_To_Stereographic(), Convert_Stereographic_To_Geodetic(), Get_Stereographic_Parameters(), loadState(), ossimStereographicProjection(), Set_Stereographic_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprivate |
Definition at line 90 of file ossimStereographicProjection.h.
Referenced by Convert_Geodetic_To_Stereographic(), Convert_Stereographic_To_Geodetic(), Get_Stereographic_Parameters(), loadState(), ossimStereographicProjection(), Set_Stereographic_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprivate |
Definition at line 87 of file ossimStereographicProjection.h.
Referenced by Convert_Geodetic_To_Stereographic(), Convert_Stereographic_To_Geodetic(), Get_Stereographic_Parameters(), and Set_Stereographic_Parameters().
mutableprivate |
Definition at line 88 of file ossimStereographicProjection.h.
mutableprivate |
Definition at line 82 of file ossimStereographicProjection.h.
Referenced by Convert_Geodetic_To_Stereographic(), and Set_Stereographic_Parameters().
mutableprivate |
Definition at line 83 of file ossimStereographicProjection.h.
