ossimTilingRect Class Reference
#include <ossimTilingRect.h>
Inheritance diagram for ossimTilingRect:
ossimTiling ossimObject ossimReferenced ossimTilingPoly
Public Member Functions
 ossimTilingRect ()
virtual ~ossimTilingRect ()
virtual bool initialize (const ossimMapProjection &proj, const ossimIrect &boundingRect)
virtual bool next (ossimRefPtr< ossimMapProjection > &resultProjection, ossimIrect &resultingBounds, ossimString &resultingName)
- Public Member Functions inherited from ossimTiling
 ossimTiling ()
bool next (ossimRefPtr< ossimMapProjection > &resultProjection, ossimIrect &resultingBounds, ossimString &resultingName) const
void reset ()
void setTilingDistance (const ossimDpt &tilingDistance, ossimUnitType unitType)
void setDelta (const ossimDpt &delta, ossimTilingDeltaType deltaType)
 This sets the pixel delta. More...
void setTileNameMask (const ossimString &mask)
 This sets the tilename mask. More...
ossimString getTileNameMask () const
bool getRowCol (ossim_int64 &row, ossim_int64 &col, ossim_int64 tileId) const
bool getOrigin (ossimDpt &origin, ossim_int64 tileId) const
bool getOrigin (ossimDpt &origin, ossim_int64 row, ossim_int64 col) const
void setPaddingSizeInPixels (const ossimIpt &pizelOverlap)
ossimDpt getDeltaPerPixel () const
 Generic print method. More...
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Protected Member Functions
bool initializeBase (const ossimMapProjection &proj, const ossimIrect &boundingRect, ossimDpt &convertedTilingDistance)
void getConvertedDistance (ossimDpt &pt, ossimDpt inputDistance) const
ossimDpt getPaddingSize () const
- Protected Member Functions inherited from ossimTiling
void getConvertedTilingDistance (ossimDpt &pt) const
bool validate () const
bool isAngularUnit (ossimUnitType unitType) const
bool isLinearUnit (ossimUnitType unitType) const
void getTileName (ossimString &resultingName, ossim_int64 row, ossim_int64 col, ossim_int64 id) const
void clampGeographic (ossimDrect &rect) const
virtual ~ossimReferenced ()
Protected Attributes
bool m_clipToAoi
ossim_float64 m_lastWidth
ossim_float64 m_lastHeight
bool m_useOffset
ossimDpt m_offsetInPixels
ossimDpt m_tilingDistanceInPixels
ossimDpt m_tilinResolutionDistance
ossimUnitType m_tilingResolutionUnitType
ossimDpt m_fractionalPixelMisalignment
- Protected Attributes inherited from ossimTiling
ossimDpt theTilingDistance
 The size of a tile in theTilingDistanceUnitType. More...
ossimUnitType theTilingDistanceUnitType
 The unit type for "theDelta", and "theTilingDistance". More...
ossimDpt theDelta
 If (theDeltaType == ossimTilingDeltaType_TOTAL_PIXELS) then this is the size of the tile in pixels like 1024 x 1024. More...
ossimTilingDeltaType theDeltaType
ossim_int64 theOutputSizeInBytes
 If set tiling size is controlled by the desired output size in bytes. More...
ossim_uint32 theNumberOfBands
 Output number of bands. More...
ossim_uint32 theNumberOfBytesPerPixelPerBand
 Output number of bytes per pixel. More...
ossimDpt thePaddingSizeInPixels
ossimRefPtr< ossimMapProjectiontheMapProjection
ossimIrect theImageRect
ossimDrect theTilingRect
ossim_int64 theTileId
ossim_int64 theTotalHorizontalTiles
ossim_int64 theTotalVerticalTiles
ossim_int64 theTotalTiles
ossimString theTileNameMask
bool theEdgeToEdgeFlag
 This flags the code to shift the tie point so that the edge of the pixel falls on the tile boundary. More...
Additional Inherited Members
- Public Types inherited from ossimTiling
enum  ossimTilingDeltaType { ossimTilingDeltaType_TOTAL_PIXELS, ossimTilingDeltaType_PER_PIXEL }
Detailed Description
Definition at line 22 of file ossimTilingRect.h.
◆ ossimTilingRect()
ossimTilingRect::ossimTilingRect ( )
Definition at line 29 of file ossimTilingRect.cpp.
30  : ossimTiling(),
31  m_clipToAoi(true),
32  m_lastWidth(0),
33  m_lastHeight(0),
34  m_useOffset(false),
35  m_offsetInPixels(0,0),
40 {
41 }
double nan()
Definition: ossimCommon.h:135
◆ ~ossimTilingRect()
ossimTilingRect::~ossimTilingRect ( )
virtual
Definition at line 43 of file ossimTilingRect.cpp.
44 {
45 }
Member Function Documentation
◆ getConvertedDistance()
void ossimTilingRect::getConvertedDistance ( ossimDpt pt,
) const
protected
Definition at line 856 of file ossimTilingRect.cpp.
References ossimMapProjection::isGeographic(), ossimMapProjection::origin(), OSSIM_DEGREES, OSSIM_METERS, ossimNotify(), ossimNotifyLevel_WARN, ossimUnitConversionTool::setValue(), ossimTiling::theMapProjection, ossimTiling::theTilingDistanceUnitType, ossimDpt::x, and ossimDpt::y.
Referenced by initializeBase().
857 {
858  if (!theMapProjection)
859  {
860  // This should not happen...
862  << "ossimTiling::getConvertedDistance WARNING"
863  << " projection not set!" << endl;
864  pt = inputDistance;
865  return;
866  }
867
869  {
870  pt = inputDistance;
871  }
872  else
873  {
875  1.0,
877
878  unitConverter.setValue(inputDistance.x,
880  pt.x = unitConverter.getValue(OSSIM_METERS);
881
882  unitConverter.setValue(inputDistance.y,
884  pt.y = unitConverter.getValue(OSSIM_METERS);
885  }
886 }
Definition: ossimTiling.h:125
void setValue(double value, ossimUnitType unitType=OSSIM_METERS)
double y
Definition: ossimDpt.h:165
ossimRefPtr< ossimMapProjection > theMapProjection
Definition: ossimTiling.h:173
virtual bool isGeographic() const
virtual ossimGpt origin() const
double x
Definition: ossimDpt.h:164
◆ getPaddingSize()
ossimDpt ossimTilingRect::getPaddingSize ( ) const
protected
Definition at line 832 of file ossimTilingRect.cpp.
References ossimUnitConversionTool::getValue(), ossimMapProjection::isGeographic(), OSSIM_DEGREES, OSSIM_METERS, ossimUnitConversionTool::setValue(), ossimTiling::theMapProjection, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTilingDistanceUnitType, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
833 {
835
836  if (!theMapProjection.valid())
837  return result;
838
840  {
841  return result;
842  }
843  else
844  {
846  unitConverter.setValue(result.x, theTilingDistanceUnitType);
847  result.x = unitConverter.getValue(OSSIM_METERS);
848
849  unitConverter.setValue(result.y, theTilingDistanceUnitType);
850  result.y = unitConverter.getValue(OSSIM_METERS);
851  }
852
853  return result;
854 }
bool valid() const
Definition: ossimRefPtr.h:75
double y
Definition: ossimTiling.h:172
double x
◆ initialize()
bool ossimTilingRect::initialize ( const ossimMapProjection proj,
const ossimIrect boundingRect
virtual
Reimplemented in ossimTilingPoly.
Definition at line 218 of file ossimTilingRect.cpp.
220 {
221  bool result = false;
222  if(traceDebug())
223  {
225  << "ossimTilingRect::initialize DEBUG: Entered..."
226  << "\nBounding rect === " << boundingRect
227  << std::endl;
228  }
229
230  ossimDpt convertedTilingDistance = theTilingDistance;
231  result = initializeBase(proj, boundingRect, convertedTilingDistance);
232  ossimDrect tilingRectInPixels = theImageRect;
233
234  // Let's setup the bounding tile rect.
236  {
237  ossimGpt ul;
238  ossimGpt ur;
239  ossimGpt lr;
240  ossimGpt ll;
241
246
249
250  if(traceDebug())
251  {
253  << "DEBUG: Geographic input bounds = "
254  << theTilingRect
255  << std::endl;
256  }
257
258  if (!m_clipToAoi)
259  {
260  theTilingRect.stretchToTileBoundary(convertedTilingDistance);
261  }
262
263  if(traceDebug())
264  {
266  << "DEBUG: Geographic input bounds stretched = "
267  << theTilingRect << std::endl;
268  }
269
271
272  if(traceDebug())
273  {
275  << "DEBUG: Geographic input bounds clamped = "
276  << theTilingRect << std::endl;
277  }
278
279  } // End "if(theMapProjection->isGeographic())"
280  else // meters
281  {
282  ossimDpt ul;
283  ossimDpt ur;
284  ossimDpt lr;
285  ossimDpt ll;
286
291  theTilingRect = ossimDrect(ul, ur, lr, ll, OSSIM_RIGHT_HANDED);
292
293  if (!m_clipToAoi)
294  {
295  theTilingRect.stretchToTileBoundary(convertedTilingDistance);
296  }
297  }
298
299  theTotalHorizontalTiles = ossim::round<int>(fabs(tilingRectInPixels.ur().x - tilingRectInPixels.ul().x)/m_tilingDistanceInPixels.x);
300  theTotalVerticalTiles = ossim::round<int>(fabs(tilingRectInPixels.ur().y - tilingRectInPixels.lr().y)/m_tilingDistanceInPixels.y);
301
302  if (m_clipToAoi)
303  {
304  if (m_useOffset)
305  {
306  ossim_float32 totalHorizontalTilesAfterOffset =
307  ((fabs(tilingRectInPixels.ur().x - tilingRectInPixels.ul().x))-m_tilingDistanceInPixels.x)/(m_tilingDistanceInPixels.x - m_offsetInPixels.x) + 1;
308  ossim_float32 totalVerticalTilesAfterOffset =
309  ((fabs(tilingRectInPixels.ur().y - tilingRectInPixels.lr().y))-m_tilingDistanceInPixels.y)/(m_tilingDistanceInPixels.y - m_offsetInPixels.y) + 1;
310
311  ossim_float32 lastHorizontal = totalHorizontalTilesAfterOffset - (ossim_int32)totalHorizontalTilesAfterOffset;
312  ossim_float32 lastVertical = totalVerticalTilesAfterOffset - (ossim_int32)totalVerticalTilesAfterOffset;
313
314  m_lastWidth = ossim::round<int>(fabs(lastHorizontal* (m_tilingDistanceInPixels.x - m_offsetInPixels.x) + m_offsetInPixels.x));
315  m_lastHeight = ossim::round<int>(fabs(lastVertical* (m_tilingDistanceInPixels.y - m_offsetInPixels.y) + m_offsetInPixels.y));
316
317  theTotalHorizontalTiles = ossim::round<int>(totalHorizontalTilesAfterOffset);
318  theTotalVerticalTiles = ossim::round<int>(totalVerticalTilesAfterOffset);
319
320  if (m_lastWidth > 0 && (lastHorizontal < 0.5))//if lastHorizontal is less than 0.5, the last tile will not add to total tiles after rounding, do here
321  {
323  }
324  if (m_lastHeight > 0 && (lastVertical < 0.5))
325  {
327  }
328  }
329  else
330  {
331  ossim_int32 tmpX = (ossim_int32)(fabs(tilingRectInPixels.ur().x - tilingRectInPixels.ul().x)) + 1;
332  ossim_int32 tmpY = (ossim_int32)(fabs(tilingRectInPixels.ur().y - tilingRectInPixels.lr().y)) + 1;
333
336  if (modValueX >= 1)
337  {
338  m_lastWidth = modValueX;
339  }
340  else
341  {
343  }
344  if (modValueY >= 1)
345  {
346  m_lastHeight = modValueY;
347  }
348  else
349  {
351  }
352
353  if (m_lastWidth > 0)
354  {
356  {
358  }
359  }
360  if (m_lastHeight > 0)
361  {
363  {
365  }
366  }
367  }
368  }
369
371
372  // reset the tile id to the beginning
373  reset();
374
375  if(traceDebug())
376  {
378
380  << "\nossimTiling::initialize DEBUG: Leaving..." << std::endl;
381  }
382
383  return result;
384 }
float ossim_float32
const ossimDpt & ul() const
Definition: ossimDrect.h:339
double y
const ossimIpt & ul() const
Definition: ossimIrect.h:274
Definition: ossimTiling.h:178
Definition: ossimTiling.h:174
const ossimIpt & ll() const
Definition: ossimIrect.h:277
void clampGeographic(ossimDrect &rect) const
virtual ossimGpt lineSampleToWorld(const ossimDpt &projectedPoint) const
virtual void lineSampleToEastingNorthing(const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
Definition: ossimTiling.h:179
const ossimIpt & lr() const
Definition: ossimIrect.h:276
Definition: ossimTiling.h:177
const ossimIpt & ur() const
Definition: ossimIrect.h:275
Definition: ossimTiling.h:175
Definition: ossimTiling.h:122
void stretchToTileBoundary(const ossimDpt &widthHeight)
Definition: ossimDrect.cpp:396
const ossimDpt & ur() const
Definition: ossimDrect.h:340
double x
bool initializeBase(const ossimMapProjection &proj, const ossimIrect &boundingRect, ossimDpt &convertedTilingDistance)
const ossimDpt & lr() const
Definition: ossimDrect.h:341
int ossim_int32
◆ initializeBase()
bool ossimTilingRect::initializeBase ( const ossimMapProjection proj,
const ossimIrect boundingRect,
protected
Definition at line 47 of file ossimTilingRect.cpp.
References ossimProjection::dup(), ossimRefPtr< T >::get(), getConvertedDistance(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimMapProjection::getMetersPerPixel(), ossimImageGeometry::getMetersPerPixel(), getPaddingSize(), ossimDpt::hasNans(), ossimIrect::height(), ossimMapProjection::isGeographic(), ossimGpt::lat, ossimMapProjection::lineSampleToWorld(), ossimIrect::ll(), ossimGpt::lon, ossimIrect::lr(), m_fractionalPixelMisalignment, m_offsetInPixels, m_tilingDistanceInPixels, m_tilingResolutionUnitType, m_tilinResolutionDistance, m_useOffset, OSSIM_DEGREES, OSSIM_PIXEL, ossimMapProjection::setDecimalDegreesPerPixel(), ossimImageGeometry::setImageSize(), ossimMapProjection::setMetersPerPixel(), ossimTiling::theImageRect, ossimTiling::theMapProjection, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTilingDistance, ossimTiling::theTilingDistanceUnitType, ossimIrect::ul(), ossimIrect::ur(), ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
50 {
52  theImageRect = boundingRect;
53
55  // Find image center and GSD at that point:
57  {
60  gsd = geom->getMetersPerPixel();
61  }
62
64
65  //if resolution and resolution type are defined, need to reset degree/meter per pixel and the image rect. do calculation below
66  ossim_float64 latDiff = 0.0;
67  ossim_float64 lonDiff = 0.0;
68  ossim_uint32 imageWidth = 0;
69  ossim_uint32 imageHeight = 0;
71  {
72  ossimDpt result(0,0);
74  {
75  ossimGpt ulg;
76  ossimGpt llg;
77  ossimGpt lrg;
78  ossimGpt urg;
79
84
85  latDiff = fabs(ulg.lat - llg.lat);
86  lonDiff = fabs(urg.lon - llg.lon);
87
89  {
90  ossim_float64 tileHorizatalNum = lonDiff/m_tilinResolutionDistance.x;
91  ossim_float64 tileVerticalNum = latDiff/m_tilinResolutionDistance.y;
92
93  if (theTilingDistanceUnitType != OSSIM_PIXEL) //convert tiling distance to pixel if unit type is not pixel
94  {
95  ossimDpt convertedDis = m_tilingDistanceInPixels;
97  imageWidth = (ossim_uint32)convertedDis.x/gsd.x*tileHorizatalNum;
98  imageHeight = (ossim_uint32)convertedDis.y/gsd.y*tileVerticalNum;
99  }
100  else
101  {
102  imageWidth = (ossim_uint32)m_tilingDistanceInPixels.x*tileHorizatalNum;
103  imageHeight = (ossim_uint32)m_tilingDistanceInPixels.y*tileVerticalNum;
104  }
105  result = ossimDpt(theImageRect.width()*gsd.x/imageWidth, theImageRect.height()*gsd.y/imageHeight);
106  gsd = result;
107
109  }
110  else
111  {
114
116  }
117  }
118  else //only handle degree type for resolution
119  {
120  return false;
121  }
122  }
123
125  {
126  ossimDpt paddingSize = getPaddingSize();//convert padding size to meters or degree
127  getConvertedDistance(convertedTilingDistance, theTilingDistance);
128
129  ossimDpt convertedOffset = m_offsetInPixels;
130  if (m_useOffset)
131  {
132  getConvertedDistance(convertedOffset, m_offsetInPixels);
133  }
134
136  {
137  thePaddingSizeInPixels.x = ossim::round<int>(paddingSize.x / theMapProjection->getDecimalDegreesPerPixel().x);
138  thePaddingSizeInPixels.y = ossim::round<int>(paddingSize.y / theMapProjection->getDecimalDegreesPerPixel().y);
139
140  double intpart;
141  m_fractionalPixelMisalignment.x = modf(convertedTilingDistance.x / theMapProjection->getDecimalDegreesPerPixel().x, &intpart);
142  m_fractionalPixelMisalignment.y = modf(convertedTilingDistance.y / theMapProjection->getDecimalDegreesPerPixel().y, &intpart);
143
144  m_tilingDistanceInPixels.x = ossim::round<int>(convertedTilingDistance.x / theMapProjection->getDecimalDegreesPerPixel().x);
145  m_tilingDistanceInPixels.y = ossim::round<int>(convertedTilingDistance.y / theMapProjection->getDecimalDegreesPerPixel().y);
146
147  if (m_useOffset)
148  {
149  m_offsetInPixels.x = ossim::round<int>(convertedOffset.x / theMapProjection->getDecimalDegreesPerPixel().x);
150  m_offsetInPixels.y = ossim::round<int>(convertedOffset.y / theMapProjection->getDecimalDegreesPerPixel().y);
151  }
152  }
153  else
154  {
155  thePaddingSizeInPixels.x = ossim::round<int>(paddingSize.x / gsd.x);
156  thePaddingSizeInPixels.y = ossim::round<int>(paddingSize.y / gsd.y);
157
158  double intpart;
159  m_fractionalPixelMisalignment.x = modf(convertedTilingDistance.x / gsd.x, &intpart);
160  m_fractionalPixelMisalignment.y = modf(convertedTilingDistance.y / gsd.y, &intpart);
161
162  m_tilingDistanceInPixels.x = ossim::round<int>(convertedTilingDistance.x / gsd.x);
163  m_tilingDistanceInPixels.y = ossim::round<int>(convertedTilingDistance.y / gsd.y);
164
165  if (m_useOffset)
166  {
167  m_offsetInPixels.x = ossim::round<int>(convertedOffset.x / gsd.x);
168  m_offsetInPixels.y = ossim::round<int>(convertedOffset.y / gsd.y);
169  }
170  }
171  }
172  else
173  {
175  {
178  }
179  else
180  {
183  }
184  }
185
186  //re-calculation the image rect if resolution and resolution type defined
188  {
190  {
191  imageWidth = (ossim_uint32)m_tilingDistanceInPixels.x * lonDiff;
192  imageHeight = (ossim_uint32)m_tilingDistanceInPixels.y * latDiff;
193  }
194
195  //avoid very small pixel offset by calculation if tiling distance unit type is pixel
197  {
198  if (imageWidth % (ossim_int32)m_tilingDistanceInPixels.x != 0)
199  {
200  ossim_int32 numX = ossim::round<int>((double)imageWidth/m_tilingDistanceInPixels.x);
201  imageWidth = m_tilingDistanceInPixels.x * numX;
202  }
203  if (imageHeight % (ossim_int32)m_tilingDistanceInPixels.y != 0)
204  {
205  ossim_int32 numY = ossim::round<int>((double)imageHeight/m_tilingDistanceInPixels.y);
206  imageHeight = m_tilingDistanceInPixels.y * numY;
207  }
208  }
209
210  theImageRect = ossimIrect(boundingRect.ul(),
211  ossimIpt((boundingRect.ul().x + imageWidth), boundingRect.ul().y),
212  ossimIpt((boundingRect.ul().x + imageWidth), (imageHeight - boundingRect.ul().y)),
213  ossimIpt(boundingRect.ul().x , (imageHeight - boundingRect.ul().y)));
214  }
215  return true;
216 }
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
virtual ossimObject * dup() const =0
double y
ossim_uint32 height() const
Definition: ossimIrect.h:487
void getConvertedDistance(ossimDpt &pt, ossimDpt inputDistance) const
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
void setImageSize(const ossimIpt &size)
virtual void setMetersPerPixel(const ossimDpt &gsd)
double ossim_float64
ossim_float64 lon
Definition: ossimGpt.h:266
unsigned int ossim_uint32
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
ossim_uint32 width() const
Definition: ossimIrect.h:500
bool hasNans() const
Definition: ossimDpt.h:67
ossimDpt getPaddingSize() const
ossim_int32 y
Definition: ossimIpt.h:142
double x
ossim_int32 x
Definition: ossimIpt.h:141
ossim_float64 lat
Definition: ossimGpt.h:265
virtual ossimDpt getMetersPerPixel() const
int ossim_int32
◆ loadState()
bool ossimTilingRect::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented from ossimTiling.
Definition at line 733 of file ossimTilingRect.cpp.
References ossimString::contains(), distance(), ossimKeywordlist::find(), ossimUnitTypeLut::getEntryNumber(), ossimUnitTypeLut::instance(), m_clipToAoi, m_offsetInPixels, m_tilingResolutionUnitType, m_tilinResolutionDistance, m_useOffset, ossimTiling::setTileNameMask(), ossimTiling::theDelta, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTileNameMask, ossimTiling::theTilingDistance, ossimTiling::theTilingDistanceUnitType, ossimString::toFloat64(), ossimDpt::x, x, ossimDpt::y, and y.
Referenced by ossimTilingPoly::loadState().
735 {
736  bool result = false;
737
738  // Get the mask if any.
739  theTileNameMask = kwl.find(prefix, "output_file_name");
740  if (!theTileNameMask.contains("%f%")) //%f% format is used for feature id in a shape file
741  {
743  }
744
745  const char* paddingSizeInPixels = kwl.find(prefix, "padding");
746
747  if (paddingSizeInPixels)
748  {
749  ossimString x,y;
750  std::istringstream padding(ossimString(paddingSizeInPixels).c_str());
751  padding >> x >> y;
752  thePaddingSizeInPixels.x = x.toFloat64();
753  thePaddingSizeInPixels.y = y.toFloat64();
754  }
755
756  const char* tilingDistance = kwl.find(prefix, "tile_size");
757
758  const char* tilingDistanceType = kwl.find(prefix, "units");
759
760  result = tilingDistance&&tilingDistanceType&&paddingSizeInPixels;
761
762  ossimString x,y;
763  std::istringstream distance(ossimString(tilingDistance).c_str());
764  distance >> x >> y;
765  theTilingDistance.x = x.toFloat64();
766  theTilingDistance.y = y.toFloat64();
767  if(theTilingDistance.x <= 0.0)
768  {
769  theTilingDistance.x = 1.0;
770  }
771  if(theTilingDistance.y<=0.0)
772  {
774  }
775
778  ossimString(tilingDistanceType).c_str());
779
780  const char* clipToAoi = kwl.find(prefix, "clip_to_aoi");
781  if (clipToAoi)
782  {
783  if (!ossimString(clipToAoi).toBool())
784  {
785  m_clipToAoi = false;
786  }
787  }
788
789  const char* offset = kwl.find(prefix, "use_offset");
790  if (offset)
791  {
792  ossimString width, height;
793  std::istringstream distanceOffset(ossimString(offset).c_str());
794  distanceOffset >> width >> height;
795  m_offsetInPixels.x = width.toFloat64();
796  m_offsetInPixels.y = height.toFloat64();
797  if (m_offsetInPixels.x > 0 || m_offsetInPixels.y > 0.0)
798  {
799  m_useOffset = true;
800  result = true;
801  }
802  }
803
804  const char* tileRes = kwl.find(prefix, "resolution");
805  if (tileRes)
806  {
807  theDelta = ossimDpt(0,0);
808  x="";
809  y="";
810  std::istringstream tileResValues(ossimString(tileRes).c_str());
811  tileResValues >> x >> y;
812
813  m_tilinResolutionDistance.x = x.toFloat64();
814  m_tilinResolutionDistance.y = y.toFloat64();
815  }
816
817  const char* tilingResType = kwl.find(prefix, "resolution_units");
818  if (tilingResType)
819  {
822  ossimString(tilingResType).c_str());
823  }
824
825  if (traceDebug())
826  {
828  }
829  return result;
830 }
ossim_uint32 x
ossimUnitType
ossim_uint32 y
double y
bool contains(char aChar) const
Definition: ossimString.h:58
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
ossimDpt theDelta
If (theDeltaType == ossimTilingDeltaType_TOTAL_PIXELS) then this is the size of the tile in pixels li...
Definition: ossimTiling.h:134
void setTileNameMask(const ossimString &mask)
ossim_float64 toFloat64() const
Definition: ossimTiling.h:180
double x
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
float distance(double lat1, double lon1, double lat2, double lon2, int units)
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
◆ next()
bool ossimTilingRect::next ( ossimRefPtr< ossimMapProjection > &  resultProjection,
ossimIrect resultingBounds,
ossimString resultingName
virtual
Definition at line 386 of file ossimTilingRect.cpp.
References ossimGpt::datum(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimMapProjection::getMetersPerPixel(), ossimTiling::getOrigin(), ossimTiling::getRowCol(), ossimTiling::getTileName(), ossimIrect::height(), ossimMapProjection::isGeographic(), ossimDpt::isNan(), ossimDpt::lat, ossimDpt::lon, m_clipToAoi, m_fractionalPixelMisalignment, m_lastHeight, m_lastWidth, m_offsetInPixels, m_tilingDistanceInPixels, m_useOffset, ossimMapProjection::origin(), ossimMapProjection::setUlTiePoints(), ossimTiling::theMapProjection, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTileId, ossimTiling::theTotalHorizontalTiles, ossimTiling::theTotalTiles, ossimTiling::theTotalVerticalTiles, ossimIrect::width(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
389 {
390  bool result = true;
391
393  {
394  ossimDpt origin;
395  ossim_int64 row=0;
396  ossim_int64 col=0;
397
398  getRowCol(row, col, theTileId);
399
400  getTileName(resultingName,
401  (row+1), (col+1), theTileId);
402
403  getOrigin(origin, row, col);
404
406  {
407  if (row == 0 && col != 0)
408  {
409  if (m_fractionalPixelMisalignment.x >= 0.5)
410  {
412  {
414  }
415  else
416  {
417  origin.x = origin.x + (1 - m_fractionalPixelMisalignment.x) * theMapProjection->getMetersPerPixel().x * col;
418  }
419  }
420  else
421  {
423  {
425  }
426  else
427  {
429  }
430  }
431  }
432  else if (col == 0 && row != 0)
433  {
434  if (m_fractionalPixelMisalignment.y >= 0.5)
435  {
437  {
439  }
440  else
441  {
442  origin.y = origin.y - (1 - m_fractionalPixelMisalignment.y) * theMapProjection->getMetersPerPixel().y * row;
443  }
444  }
445  else
446  {
448  {
450  }
451  else
452  {
454  }
455  }
456  }
457  else if (col != 0 && row != 0)
458  {
459  if (m_fractionalPixelMisalignment.x >= 0.5)
460  {
462  {
464  }
465  else
466  {
467  origin.x = origin.x + (1 - m_fractionalPixelMisalignment.x) * theMapProjection->getMetersPerPixel().x * col;
468  }
469  }
470  else
471  {
473  {
475  }
476  else
477  {
479  }
480  }
481
482  if (m_fractionalPixelMisalignment.y >= 0.5)
483  {
485  {
487  }
488  else
489  {
490  origin.y = origin.y - (1 - m_fractionalPixelMisalignment.y) * theMapProjection->getMetersPerPixel().y * row;
491  }
492  }
493  else
494  {
496  {
498  }
499  else
500  {
502  }
503  }
504  }
505  }
506
508
510  {
512  ossimGpt(origin.lat,
513  origin.lon,
514  0.0,
516  }
517  else
518  {
519  theMapProjection->setUlTiePoints(ossimDpt(origin.x, origin.y));
520  }
521
522  if (m_clipToAoi || m_useOffset)
523  {
524  if (row == 0 && col == 0)
525  {
526  resultingBounds = ossimIrect(0, 0,
527  (pixels.x-1) + (ossim_int32)thePaddingSizeInPixels.x,
528  (pixels.y-1) + (ossim_int32)thePaddingSizeInPixels.y);
529  }
530  else if (row == 0 && col != 0)
531  {
532  if (col == (theTotalHorizontalTiles-1))
533  {
534  resultingBounds = ossimIrect(-(ossim_int32)thePaddingSizeInPixels.x, 0,
535  (m_lastWidth-1),
536  (pixels.y-1) + (ossim_int32)thePaddingSizeInPixels.y);
537
538  if (m_useOffset)
539  {
540  ossim_int32 lr_x = -((ossim_int32)m_offsetInPixels.x*col)- resultingBounds.width();
541  resultingBounds = ossimIrect(-((ossim_int32)m_offsetInPixels.x*col), 0,
542  lr_x, (resultingBounds.height()-1));
543  }
544  }
545  else
546  {
547  resultingBounds = ossimIrect(-(ossim_int32)thePaddingSizeInPixels.x, 0,
548  (pixels.x-1) + (ossim_int32)thePaddingSizeInPixels.x,
549  (pixels.y-1) + (ossim_int32)thePaddingSizeInPixels.y);
550
551  if (m_useOffset)
552  {
553  resultingBounds = ossimIrect(-((ossim_int32)m_offsetInPixels.x*col), 0,
554  (resultingBounds.width()-1)-((ossim_int32)m_offsetInPixels.x*col),
555  (resultingBounds.height()-1));
556  }
557  }
558  }
559  else if (row != 0 && col == 0)
560  {
561  if (row == (theTotalVerticalTiles-1))
562  {
563  resultingBounds = ossimIrect(0, -(ossim_int32)thePaddingSizeInPixels.y,
564  (pixels.x-1) + (ossim_int32)thePaddingSizeInPixels.x,
565  (m_lastHeight-1));
566
567  if (m_useOffset)
568  {
569  ossim_int32 lr_y = -((ossim_int32)m_offsetInPixels.y*row)-resultingBounds.height();
570  resultingBounds = ossimIrect(0, -((ossim_int32)m_offsetInPixels.y*row),
571  (resultingBounds.width()-1), lr_y);
572  }
573  }
574  else
575  {
576  resultingBounds = ossimIrect(0,
578  (pixels.x-1) + (ossim_int32)thePaddingSizeInPixels.x,
579  (pixels.y-1) + (ossim_int32)thePaddingSizeInPixels.y);
580
581  if (m_useOffset)
582  {
583  resultingBounds = ossimIrect(0, -((ossim_int32)m_offsetInPixels.y*row),
584  (resultingBounds.width()-1),
585  (resultingBounds.height()-1)-((ossim_int32)m_offsetInPixels.y*row));
586  }
587  }
588  }
589  else if (row != 0 && col != 0)
590  {
591  if (row == (theTotalVerticalTiles-1) && col == (theTotalHorizontalTiles-1))
592  {
593  resultingBounds = ossimIrect(-(ossim_int32)thePaddingSizeInPixels.x,
595  (m_lastWidth-1),
596  (m_lastHeight-1));
597
598  if (m_useOffset)
599  {
600  ossim_int32 lr_x = -((ossim_int32)m_offsetInPixels.x*col)-resultingBounds.width();
601  ossim_int32 lr_y = -((ossim_int32)m_offsetInPixels.y*row)-resultingBounds.height();
602  resultingBounds = ossimIrect(-((ossim_int32)m_offsetInPixels.x*col),
604  lr_x, lr_y);
605  }
606  }
607  else if (row != (theTotalVerticalTiles-1) && col == (theTotalHorizontalTiles-1))
608  {
609  resultingBounds = ossimIrect(-(ossim_int32)thePaddingSizeInPixels.x,
611  (m_lastWidth-1),
612  (pixels.y-1) + (ossim_int32)thePaddingSizeInPixels.y);
613
614  if (m_useOffset)
615  {
616  ossim_int32 lr_x = -((ossim_int32)m_offsetInPixels.x*col)-resultingBounds.width();
617  resultingBounds = ossimIrect(-((ossim_int32)m_offsetInPixels.x*col),
619  lr_x, (resultingBounds.height()-1)-((ossim_int32)m_offsetInPixels.y*row));
620  }
621  }
622  else if (row == (theTotalVerticalTiles-1) && col != (theTotalHorizontalTiles-1))
623  {
624  resultingBounds = ossimIrect(-(ossim_int32)thePaddingSizeInPixels.x,
626  (pixels.x-1) + (ossim_int32)thePaddingSizeInPixels.x,
627  (m_lastHeight-1));
628
629  if (m_useOffset)
630  {
631  ossim_int32 lr_y = -((ossim_int32)m_offsetInPixels.y*row)-resultingBounds.height();
632  resultingBounds = ossimIrect(-((ossim_int32)m_offsetInPixels.x*col),
634  (resultingBounds.width()-1)-((ossim_int32)m_offsetInPixels.x*col),
635  lr_y);
636  }
637  }
638  else
639  {
640  resultingBounds = ossimIrect(-(ossim_int32)thePaddingSizeInPixels.x,
642  (pixels.x-1) + (ossim_int32)thePaddingSizeInPixels.x,
643  (pixels.y-1) + (ossim_int32)thePaddingSizeInPixels.y);
644
645  if (m_useOffset)
646  {
647  resultingBounds = ossimIrect(-((ossim_int32)m_offsetInPixels.x*col),
649  (resultingBounds.width()-1)-((ossim_int32)m_offsetInPixels.x*col),
650  (resultingBounds.height()-1)-((ossim_int32)m_offsetInPixels.y*row));
651  }
652  }
653  }
654  }
655  else
656  {
657  resultingBounds = ossimIrect(-(ossim_int32)thePaddingSizeInPixels.x,
659  (pixels.x-1) + (ossim_int32)thePaddingSizeInPixels.x,
660  (pixels.y-1) + (ossim_int32)thePaddingSizeInPixels.y);
661
662  if (m_useOffset)
663  {
664  resultingBounds = ossimIrect(-(ossim_int32)m_offsetInPixels.x,
666  (resultingBounds.width()-1), (resultingBounds.height()-1));
667  }
668  }
669
670  if(traceDebug()&&resultProjection.valid())
671  {
672  ossimKeywordlist projKwl;
673
674  resultProjection->saveState(projKwl);
676  << "ossimTilingRect::next DEBUG: rect = " << resultingBounds
677  << "\nproj = " << projKwl
678  << "\ntileName = " << resultingName
679  << "\norigin = " << origin << std::endl;
680  }
681
682  resultProjection = theMapProjection;
683
684  ++theTileId;
685  }
686  else
687  {
688  result = false;
689  }
690
691  return result;
692 }
Definition: ossimTiling.h:176
bool valid() const
double y
bool isNan() const
Definition: ossimDpt.h:72
void getTileName(ossimString &resultingName, ossim_int64 row, ossim_int64 col, ossim_int64 id) const
const ossimDatum * datum() const
datum().
Definition: ossimGpt.h:196
double lat
bool getOrigin(ossimDpt &origin, ossim_int64 tileId) const
bool getRowCol(ossim_int64 &row, ossim_int64 &col, ossim_int64 tileId) const
double lon
ossim_int32 y
double x
long long ossim_int64
virtual void setUlTiePoints(const ossimGpt &gpt)
ossim_int32 x
int ossim_int32
◆ saveState()
bool ossimTilingRect::saveState ( ossimKeywordlist kwl,
) const
virtual
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 694 of file ossimTilingRect.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimUnitTypeLut::instance(), m_clipToAoi, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTileNameMask, ossimTiling::theTilingDistance, ossimTiling::theTilingDistanceUnitType, ossimDpt::x, and ossimDpt::y.
Referenced by ossimTilingPoly::saveState().
696 {
697  std::stringstream tilingDistance;
698
699  tilingDistance << theTilingDistance.x << " " << theTilingDistance.y << std::endl;
700
701  kwl.add(prefix,
702  "tile_size",
703  tilingDistance.str().c_str(),
704  true);
705
706  kwl.add(prefix,
707  "units",
709  getTableIndexString(theTilingDistanceUnitType),
710  true);
711
712  std::ostringstream padding;
713
714  padding << thePaddingSizeInPixels.x << " " << thePaddingSizeInPixels.y;
715  kwl.add(prefix,
716  "padding",
717  padding.str().c_str(),
718  true);
719
720  kwl.add(prefix,
721  "output_file_name",
723  true);
724
725  kwl.add(prefix,
726  "clip_to_aoi",
727  m_clipToAoi,
728  true);
729
730  return true;
731 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
std::basic_stringstream< char > stringstream
Class for char mixed input and output memory streams.
Definition: ossimIosFwd.h:38
double y
double x
const char * c_str() const
Definition: ossimString.h:396
Member Data Documentation
◆ m_clipToAoi
bool ossimTilingRect::m_clipToAoi
protected
Definition at line 53 of file ossimTilingRect.h.
Referenced by loadState(), next(), and saveState().
◆ m_fractionalPixelMisalignment
ossimDpt ossimTilingRect::m_fractionalPixelMisalignment
protected
Definition at line 61 of file ossimTilingRect.h.
Referenced by initializeBase(), and next().
◆ m_lastHeight
ossim_float64 ossimTilingRect::m_lastHeight
protected
Definition at line 55 of file ossimTilingRect.h.
Referenced by next().
◆ m_lastWidth
ossim_float64 ossimTilingRect::m_lastWidth
protected
Definition at line 54 of file ossimTilingRect.h.
◆ m_offsetInPixels
ossimDpt ossimTilingRect::m_offsetInPixels
protected
Definition at line 57 of file ossimTilingRect.h.
Referenced by initializeBase(), loadState(), and next().
◆ m_tilingDistanceInPixels
ossimDpt ossimTilingRect::m_tilingDistanceInPixels
protected
Definition at line 58 of file ossimTilingRect.h.
◆ m_tilingResolutionUnitType
ossimUnitType ossimTilingRect::m_tilingResolutionUnitType
protected
Definition at line 60 of file ossimTilingRect.h.
Referenced by initializeBase(), and loadState().
◆ m_tilinResolutionDistance
ossimDpt ossimTilingRect::m_tilinResolutionDistance
protected
Definition at line 59 of file ossimTilingRect.h.
◆ m_useOffset
bool ossimTilingRect::m_useOffset
protected
Definition at line 56 of file ossimTilingRect.h.
