Classes | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimTilingPoly Class Reference
#include <ossimTilingPoly.h>
Inheritance diagram for ossimTilingPoly:
ossimTilingRect ossimTiling ossimObject ossimReferenced
Classes
struct  ossimShpFeature
 ossimTilingPoly ()
virtual ~ossimTilingPoly ()
virtual bool initialize (const ossimMapProjection &proj, const ossimIrect &boundingRect)
virtual bool next (ossimRefPtr< ossimMapProjection > &resultProjection, ossimIrect &resultingBounds, ossimString &resultingName)
bool useMbr () const
bool hasExteriorCut () const
 return true if exterior cut is initialized. More...
bool hasInteriorCut () const
 return true if interior cut is initialized. More...
ossimRefPtr< ossimGeoPolyCutter > & getExteriorCut ()
ossimRefPtr< ossimGeoPolyCutter > & getInteriorCut ()
bool isFeatureBoundingIntersect () const
- Public Member Functions inherited from ossimTilingRect
 ossimTilingRect ()
virtual ~ossimTilingRect ()
 ossimTiling ()
bool next (ossimRefPtr< ossimMapProjection > &resultProjection, ossimIrect &resultingBounds, ossimString &resultingName) const
void reset ()
void setTilingDistance (const ossimDpt &tilingDistance, ossimUnitType unitType)
void setDelta (const ossimDpt &delta, ossimTilingDeltaType deltaType)
 This sets the pixel delta. More...
void setTileNameMask (const ossimString &mask)
 This sets the tilename mask. More...
ossimString getTileNameMask () const
bool getRowCol (ossim_int64 &row, ossim_int64 &col, ossim_int64 tileId) const
bool getOrigin (ossimDpt &origin, ossim_int64 tileId) const
bool getOrigin (ossimDpt &origin, ossim_int64 row, ossim_int64 col) const
void setPaddingSizeInPixels (const ossimIpt &pizelOverlap)
ossimDpt getDeltaPerPixel () const
 Generic print method. More...
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
bool parseShpFile ()
bool nextFeature ()
void setRect ()
- Protected Member Functions inherited from ossimTilingRect
bool initializeBase (const ossimMapProjection &proj, const ossimIrect &boundingRect, ossimDpt &convertedTilingDistance)
void getConvertedDistance (ossimDpt &pt, ossimDpt inputDistance) const
ossimDpt getPaddingSize () const
void getConvertedTilingDistance (ossimDpt &pt) const
bool validate () const
bool isAngularUnit (ossimUnitType unitType) const
bool isLinearUnit (ossimUnitType unitType) const
void getTileName (ossimString &resultingName, ossim_int64 row, ossim_int64 col, ossim_int64 id) const
void clampGeographic (ossimDrect &rect) const
virtual ~ossimReferenced ()
ossimFilename m_shpFilename
bool m_useMbr
ossim_float64 m_bufferDistance
ossimRefPtr< ossimGeoPolyCutterm_exteriorCut
ossimRefPtr< ossimGeoPolyCutterm_interiorCut
std::vector< ossimShpFeaturem_features
bool m_featureBoundingIntersect
- Protected Attributes inherited from ossimTilingRect
bool m_clipToAoi
ossim_float64 m_lastWidth
ossim_float64 m_lastHeight
bool m_useOffset
ossimDpt m_offsetInPixels
ossimDpt m_tilingDistanceInPixels
ossimDpt m_tilinResolutionDistance
ossimUnitType m_tilingResolutionUnitType
ossimDpt m_fractionalPixelMisalignment
ossimDpt theTilingDistance
 The size of a tile in theTilingDistanceUnitType. More...
ossimUnitType theTilingDistanceUnitType
 The unit type for "theDelta", and "theTilingDistance". More...
ossimDpt theDelta
 If (theDeltaType == ossimTilingDeltaType_TOTAL_PIXELS) then this is the size of the tile in pixels like 1024 x 1024. More...
ossimTilingDeltaType theDeltaType
ossim_int64 theOutputSizeInBytes
 If set tiling size is controlled by the desired output size in bytes. More...
ossim_uint32 theNumberOfBands
 Output number of bands. More...
ossim_uint32 theNumberOfBytesPerPixelPerBand
 Output number of bytes per pixel. More...
ossimDpt thePaddingSizeInPixels
ossimRefPtr< ossimMapProjectiontheMapProjection
ossimIrect theImageRect
ossimDrect theTilingRect
ossim_int64 theTileId
ossim_int64 theTotalHorizontalTiles
ossim_int64 theTotalVerticalTiles
ossim_int64 theTotalTiles
ossimString theTileNameMask
bool theEdgeToEdgeFlag
 This flags the code to shift the tie point so that the edge of the pixel falls on the tile boundary. More...
Additional Inherited Members
- Public Types inherited from ossimTiling
enum  ossimTilingDeltaType { ossimTilingDeltaType_TOTAL_PIXELS, ossimTilingDeltaType_PER_PIXEL }
Detailed Description
Definition at line 20 of file ossimTilingPoly.h.
◆ ossimTilingPoly()
ossimTilingPoly::ossimTilingPoly ( )
Definition at line 29 of file ossimTilingPoly.cpp.
30  : ossimTilingRect(),
31  m_shpFilename(""),
32  m_useMbr(true),
33  m_bufferDistance(0.0),
34  m_exteriorCut(0),
35  m_interiorCut(0),
37 {
38 }
ossimRefPtr< ossimGeoPolyCutter > m_exteriorCut
ossimRefPtr< ossimGeoPolyCutter > m_interiorCut
◆ ~ossimTilingPoly()
ossimTilingPoly::~ossimTilingPoly ( )
virtual
Definition at line 40 of file ossimTilingPoly.cpp.
References m_exteriorCut, m_features, and m_interiorCut.
41 {
42  m_exteriorCut = 0; // Ref ptr, not a leak.
43  m_interiorCut = 0; // ditto...
44  m_features.clear();
45 }
std::vector< ossimShpFeature > m_features
Member Function Documentation
◆ getExteriorCut()
ossimRefPtr< ossimGeoPolyCutter > & ossimTilingPoly::getExteriorCut ( )
Definition at line 356 of file ossimTilingPoly.cpp.
References m_exteriorCut.
Referenced by ossimIgen::outputProduct().
357 {
358  return m_exteriorCut;
359 }
◆ getInteriorCut()
ossimRefPtr< ossimGeoPolyCutter > & ossimTilingPoly::getInteriorCut ( )
Definition at line 361 of file ossimTilingPoly.cpp.
References m_interiorCut.
362 {
363  return m_interiorCut;
364 }
◆ hasExteriorCut()
bool ossimTilingPoly::hasExteriorCut ( ) const
Definition at line 346 of file ossimTilingPoly.cpp.
References m_exteriorCut, and ossimRefPtr< T >::valid().
347 {
348  return m_exteriorCut.valid();
349 }
bool valid() const
Definition: ossimRefPtr.h:75
◆ hasInteriorCut()
bool ossimTilingPoly::hasInteriorCut ( ) const
Definition at line 351 of file ossimTilingPoly.cpp.
References m_interiorCut, and ossimRefPtr< T >::valid().
352 {
353  return m_interiorCut.valid();
354 }
bool valid() const
◆ initialize()
bool ossimTilingPoly::initialize ( const ossimMapProjection proj,
const ossimIrect boundingRect
virtual
Reimplemented from ossimTilingRect.
Definition at line 47 of file ossimTilingPoly.cpp.
49 {
50  bool result = false;
51  if(traceDebug())
52  {
54  << "ossimTilingPoly::initialize DEBUG: Entered..."
55  << "\nBounding rect === " << boundingRect
56  << std::endl;
57  }
58
59  ossimDpt convertedTilingDistance = theTilingDistance;
60  result = initializeBase(proj, boundingRect, convertedTilingDistance);
61  if (result)
62  {
63  return parseShpFile();
64  }
65  return result;
66 }
Definition: ossimTiling.h:122
bool initializeBase(const ossimMapProjection &proj, const ossimIrect &boundingRect, ossimDpt &convertedTilingDistance)
◆ isFeatureBoundingIntersect()
bool ossimTilingPoly::isFeatureBoundingIntersect ( ) const
Definition at line 366 of file ossimTilingPoly.cpp.
References m_featureBoundingIntersect.
367 {
369 }
◆ loadState()
bool ossimTilingPoly::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 115 of file ossimTilingPoly.cpp.
References ossimString::contains(), ossimString::empty(), ossimKeywordlist::find(), ossimTilingRect::loadState(), m_bufferDistance, m_shpFilename, m_useMbr, ossimString::substitute(), ossimTiling::thePaddingSizeInPixels, ossimTiling::theTileNameMask, useMbr(), and ossimDpt::x.
117 {
118  bool result = ossimTilingRect::loadState(kwl, prefix);
119
120  //Get the shp file if any
121  m_shpFilename = kwl.find(prefix, "tile_source");
122
123  // Get the mask if any.
124  if (!m_shpFilename.empty())
125  {
126  if (theTileNameMask.contains("%r%_%c%"))
127  {
128  theTileNameMask = theTileNameMask.substitute("%r%_%c%", "%f%", true);
129  }
130  result = true;
131  }
132
133  const char* useMbr = kwl.find(prefix, "padding_use_mbr");
134  if (useMbr)
135  {
136  if (!ossimString(useMbr).toBool())
137  {
138  m_useMbr = false;
140  }
141  }
142
143  return result;
144 }
ossimString substitute(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) const
Substitutes searchKey string with replacementValue and returns a string.
bool useMbr() const
bool contains(char aChar) const
Definition: ossimString.h:58
Definition: ossimTiling.h:180
Definition: ossimTiling.h:172
double x
Definition: ossimDpt.h:164
bool empty() const
Definition: ossimString.h:411
◆ next()
bool ossimTilingPoly::next ( ossimRefPtr< ossimMapProjection > &  resultProjection,
ossimIrect resultingBounds,
ossimString resultingName
virtual
Definition at line 68 of file ossimTilingPoly.cpp.
References ossimPolyCutter::getRectangle(), m_exteriorCut, m_features, nextFeature(), ossimString::substitute(), ossimTiling::theMapProjection, ossimTiling::theTileId, ossimTiling::theTileNameMask, and ossimTiling::theTotalTiles.
71 {
72  bool result = true;
73
75  {
76  ostringstream idString;
77  ossim_int64 tileId = theTileId + 1;
78  if (tileId < static_cast<ossim_int64>(m_features.size()))
79  {
80  idString << m_features[tileId].m_fid;
81  resultingName = theTileNameMask;
82  resultingName = resultingName.substitute("%f%", idString.str().c_str());
83  }
84  result = nextFeature();
85  resultingBounds = m_exteriorCut->getRectangle();
86
87  resultProjection = theMapProjection;
88
89  ++theTileId;
90  }
91  else
92  {
93  result = false;
94  }
95
96  return result;
97 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
Definition: ossimTiling.h:176
ossimRefPtr< ossimMapProjection > theMapProjection
Definition: ossimTiling.h:173
Definition: ossimTiling.h:179
const ossimIrect & getRectangle() const
long long ossim_int64
◆ nextFeature()
bool ossimTilingPoly::nextFeature ( )
protected
Definition at line 146 of file ossimTilingPoly.cpp.
References ossimGeoPolyCutter::addPolygon(), ossimPolyCutter::clear(), ossimRefPtr< T >::get(), ossimGeoPolygon::getHoleList(), m_exteriorCut, m_features, m_interiorCut, ossimGeoAnnotationPolyObject::OSSIM_POLY_INTERIOR_RING, ossimPolyCutter::OSSIM_POLY_NULL_INSIDE, ossimPolyCutter::setCutType(), ossimGeoPolyCutter::setPolygon(), setRect(), ossimGeoPolyCutter::setView(), ossimTiling::theMapProjection, and ossimTiling::theTileId.
Referenced by next().
147 {
148  if (!m_exteriorCut)
149  {
152  }
153
154  bool result = false;
155  ossim_int64 tileId = theTileId + 1;//use (theTileId+1) because theTileId is intialized as -1
156  if (tileId < static_cast<ossim_int64>(m_features.size()))
157  {
158  if (m_features[tileId].m_polygon.size() > 0)
159  {
161  {
162  if (!m_interiorCut)
163  {
167  }
168  m_interiorCut->setPolygon(m_features[tileId].m_polygon);
169  }
170  else
171  {
172  // std::vector<ossimGpt> points = m_features[tileId].m_polygon;
173  // for (ossim_uint32 i = 0; i < points.size(); i++)
174  // {
175  // ossimGpt point = points[i];
176  // }
177  m_exteriorCut->setPolygon(m_features[tileId].m_polygon);
178  setRect();
179  }
180  result = true;
181  }
182  else if (m_features[tileId].m_multiPolys.size() > 0)
183  {
184  for (ossim_uint32 i = 0; i < m_features[tileId].m_multiPolys.size(); i++)
185  {
186  ossimGeoPolygon geoPoly = m_features[tileId].m_multiPolys[i];
187  std::vector<ossimGeoPolygon> holePolys = geoPoly.getHoleList();
188  if (holePolys.size() > 0)
189  {
190  if (!m_interiorCut)
191  {
195  }
196  m_interiorCut->clear();
197  for (ossim_uint32 j = 0; j < holePolys.size(); j++)
198  {
199  m_interiorCut->addPolygon(holePolys[j]);
200  }
201  }
202  m_exteriorCut->setPolygon(m_features[tileId].m_multiPolys[i]);
203  setRect();
204  }
205  result = true;
206  }
207  }
208  else
209  {
210  result = false;
211  }
212  return result;
213 }
virtual void setPolygon(const vector< ossimDpt > &polygon, ossim_uint32 i=0)
std::vector< ossimGeoPolygon > & getHoleList()
virtual bool setView(ossimObject *baseObject)
unsigned int ossim_uint32
virtual void addPolygon(const vector< ossimIpt > &polygon)
void setCutType(ossimPolyCutterCutType cutType)
◆ parseShpFile()
bool ossimTilingPoly::parseShpFile ( )
protected
Definition at line 246 of file ossimTilingPoly.cpp.
References ossimString::contains(), ossimString::empty(), ossimRefPtr< T >::get(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimEsriShapeFileInterface::getFeatureTable(), ossimImageHandler::getImageGeometry(), ossimMapProjection::getMetersPerPixel(), ossimGeoAnnotationMultiPolyObject::getMultiPolygon(), ossimGeoAnnotationPolyObject::getPoints(), ossimGeoAnnotationPolyObject::getPolyType(), ossimImageGeometry::getProjection(), ossimImageHandlerRegistry::instance(), ossimMapProjection::isGeographic(), m_bufferDistance, m_features, m_shpFilename, m_useMbr, ossimImageHandlerRegistry::open(), OSSIM_DEGREES, OSSIM_METERS, PTR_CAST, ossimEsriShapeFileInterface::setGeometryBuffer(), ossimEsriShapeFileInterface::setQuery(), ossimString::split(), ossimTiling::theMapProjection, ossimTiling::thePaddingSizeInPixels, ossimTiling::theTotalTiles, and ossimDpt::x.
247 {
248  m_features.clear();
249
250  ossimString query = "";
251  bool result = false;
252  if (m_shpFilename.contains("|"))
253  {
254  ossimString fileName = m_shpFilename;
255  std::vector<ossimString> fileList = fileName.split("|");
256  if (fileList.size() > 1)
257  {
258  m_shpFilename = fileList[0];
259  query = fileList[1];
260  }
261  }
262
265  if (shpInterface != 0)
266  {
267  if (!query.empty())
268  {
269  shpInterface->setQuery(query);
270  }
271  if (m_useMbr == false)
272  {
273  ossimProjection* proj = shpHandler->getImageGeometry()->getProjection();
275  if (mapProj)
276  {
277  if (mapProj->isGeographic())
278  {
281  }
282  else
283  {
286  }
287  }
288  }
289  std::multimap<long, ossimAnnotationObject*> features = shpInterface->getFeatureTable();
290  if (features.size() > 0)
291  {
292  std::multimap<long, ossimAnnotationObject*>::iterator it = features.begin();
293  while (it != features.end())
294  {
295  ossimAnnotationObject* anno = it->second;
296  if (anno != 0)
297  {
299  ossimGeoAnnotationMultiPolyObject* annoMultiPoly = 0;
300  if (annoPoly == 0)
301  {
302  annoMultiPoly = PTR_CAST(ossimGeoAnnotationMultiPolyObject, anno);
303  }
304  if (annoPoly != 0)
305  {
306  result = true;
307  std::vector<ossimGpt> polygon;
308
309  //get the points of a polygon
310  std::vector<ossimGpt> points = annoPoly->getPoints();
311  for (ossim_uint32 i = 0; i < points.size(); i++)
312  {
313  polygon.push_back(points[i]);
314  }
315
316  //get polygon type, if it is an internal polygon, initialize the internal cutter
318  ossimShpFeature feature(it->first, polyType, polygon, std::vector<ossimGeoPolygon>());
319  m_features.push_back(feature);
320  }
321  else if (annoMultiPoly != 0)
322  {
323  std::vector<ossimGeoPolygon> multiPolys = annoMultiPoly->getMultiPolygon();
324  ossimShpFeature feature(it->first, 0, std::vector<ossimGpt>(), multiPolys);
325  }
326  }
327  it++;
328  }
329  }
330  }
331  if (m_features.size() > 0)
332  {
333  theTotalTiles = m_features.size();
334  result = true;
335  }
336  return result;
337 }
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
virtual std::vector< ossimGpt > getPoints()
virtual void setQuery(const ossimString &query)=0
Pure virtual setQuery method.
virtual ossimImageHandler * open(const ossimFilename &fileName, bool trySuffixFirst=true, bool openOverview=true) const
open that takes a filename.
virtual bool isGeographic() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
const std::vector< ossimGeoPolygon > & getMultiPolygon() const
double x
bool empty() const
virtual std::multimap< long, ossimAnnotationObject * > getFeatureTable()=0
Pure virtual getFeatureTable method.
static ossimImageHandlerRegistry * instance()
virtual ossimDpt getMetersPerPixel() const
virtual void setGeometryBuffer(ossim_float64 distance, ossimUnitType type)=0
Pure virtual setGeometryBuffer method.
◆ saveState()
bool ossimTilingPoly::saveState ( ossimKeywordlist kwl,
) const
virtual
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 99 of file ossimTilingPoly.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), m_shpFilename, m_useMbr, and ossimTilingRect::saveState().
101 {
102  kwl.add(prefix,
103  "tile_source",
105  true);
106
107  kwl.add(prefix,
108  "paddding_use_mbr",
109  m_useMbr,
110  true);
111
112  return ossimTilingRect::saveState(kwl, prefix);;
113 }
const char * c_str() const
Definition: ossimString.h:396
◆ setRect()
void ossimTilingPoly::setRect ( )
protected
Definition at line 215 of file ossimTilingPoly.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimPolyCutter::getRectangle(), ossimIrect::intersects(), ossimIrect::lr(), m_exteriorCut, m_featureBoundingIntersect, m_useMbr, ossimPolyCutter::setRectangle(), ossimTiling::theImageRect, ossimTiling::thePaddingSizeInPixels, ossimIrect::ul(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by nextFeature().
216  {
218  if (rect.intersects(theImageRect))
219  {
221  if (!rect.completely_within(theImageRect))
222  {
223  ossimIrect clipRect = rect.clipToRect(theImageRect);
224  m_exteriorCut->setRectangle(clipRect);
225  rect = clipRect;
226  }
227  }
228  else
229  {
231  }
232  if (m_useMbr)
233  {
235  {
240  ossimIrect clipRect = newRect.clipToRect(theImageRect);//in case the bounding is larger than input image after adding buffer
241  m_exteriorCut->setRectangle(clipRect);
242  }
243  }
244  }
double y
Definition: ossimDpt.h:165
const ossimIpt & ul() const
Definition: ossimIrect.h:274
Definition: ossimTiling.h:174
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
const ossimIpt & lr() const
Definition: ossimIrect.h:276
ossim_int32 y
Definition: ossimIpt.h:142
double x
ossim_int32 x
Definition: ossimIpt.h:141
void setRectangle(const ossimIrect &rect)
int ossim_int32
◆ useMbr()
bool ossimTilingPoly::useMbr ( ) const
Definition at line 339 of file ossimTilingPoly.cpp.
References m_useMbr.
Referenced by loadState(), and ossimIgen::outputProduct().
340 {
341  //if the use_mbr is set to true, no matter if the padding is set to 0 or greater than 0,
342  //always clip the MBR of each feature
343  return m_useMbr;
344 }
Member Data Documentation
◆ m_bufferDistance
ossim_float64 ossimTilingPoly::m_bufferDistance
protected
Definition at line 84 of file ossimTilingPoly.h.
Referenced by loadState(), and parseShpFile().
◆ m_exteriorCut
ossimRefPtr<ossimGeoPolyCutter> ossimTilingPoly::m_exteriorCut
protected
◆ m_featureBoundingIntersect
bool ossimTilingPoly::m_featureBoundingIntersect
protected
Definition at line 90 of file ossimTilingPoly.h.
Referenced by isFeatureBoundingIntersect(), and setRect().
◆ m_features
std::vector<ossimShpFeature> ossimTilingPoly::m_features
protected
Definition at line 89 of file ossimTilingPoly.h.
Referenced by next(), nextFeature(), parseShpFile(), and ~ossimTilingPoly().
◆ m_interiorCut
ossimRefPtr<ossimGeoPolyCutter> ossimTilingPoly::m_interiorCut
protected
Definition at line 87 of file ossimTilingPoly.h.
Referenced by getInteriorCut(), hasInteriorCut(), nextFeature(), and ~ossimTilingPoly().
◆ m_shpFilename
ossimFilename ossimTilingPoly::m_shpFilename
protected
Definition at line 82 of file ossimTilingPoly.h.
Referenced by loadState(), parseShpFile(), and saveState().
◆ m_useMbr
bool ossimTilingPoly::m_useMbr
protected
Definition at line 83 of file ossimTilingPoly.h.
Referenced by loadState(), parseShpFile(), saveState(), setRect(), and useMbr().
