#include <ossimVanDerGrintenProjection.h>
ossimVanDerGrintenProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimVanDerGrintenProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, const double falseEasting, const double falseNorthing) | |
~ossimVanDerGrintenProjection () | |
virtual ossimObject * | dup () const |
virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
Will take a point in meters and convert it to ground. More... | |
virtual ossimDpt | forward (const ossimGpt &latLon) const |
All map projections will convert the world coordinate to an easting northing (Meters). More... | |
virtual void | update () |
void | setFalseEasting (double falseEasting) |
void | setFalseNorthing (double falseNorthing) |
void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
void | setDefaults () |
void | setCentralMeridian (double centralMeridian) |
double | getFalseEasting () const |
double | getFalseNorthing () const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual bool | operator== (const ossimProjection &projection) const |
Returns TRUE if principal parameters are within epsilon tolerance. More... | |
ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimMapProjection (const ossimMapProjection &src) | |
virtual ossimGpt | origin () const |
virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
virtual double | getStandardParallel1 () const |
Derived classes should implement as needed. More... | |
virtual double | getStandardParallel2 () const |
virtual void | setPcsCode (ossim_uint32 pcsCode) |
virtual ossim_uint32 | getPcsCode () const |
Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
virtual ossimString | getProjectionName () const |
Returns the projection name. More... | |
virtual double | getA () const |
ACCESS METHODS: More... | |
virtual double | getB () const |
virtual double | getF () const |
virtual ossimDpt | getMetersPerPixel () const |
virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
virtual const ossimDpt & | getUlEastingNorthing () const |
virtual const ossimGpt & | getUlGpt () const |
virtual const ossimDatum * | getDatum () const |
const ossimEllipsoid & | getEllipsoid () const |
const ossimGpt & | getOrigin () const |
virtual bool | isGeographic () const |
virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
SET METHODS: More... | |
virtual void | setAB (double a, double b) |
virtual void | setDatum (const ossimDatum *datum) |
Sets theDatum to datum. More... | |
virtual void | setOrigin (const ossimGpt &origin) |
Sets theOrigin to origin. More... | |
virtual void | setMetersPerPixel (const ossimDpt &gsd) |
virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
virtual void | setUlTiePoints (const ossimGpt &gpt) |
virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
virtual void | setUlGpt (const ossimGpt &ulGpt) |
virtual void | assign (const ossimProjection &aProjection) |
virtual std::ostream & | print (std::ostream &out) const |
Prints data members to stream. More... | |
virtual void | computeDegreesPerPixel () |
Computes the approximate resolution in degrees/pixel. More... | |
virtual void | computeMetersPerPixel () |
This will go from the ground point and give you an approximate meters per pixel. More... | |
void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
void | setMatrixScale (const ossimDpt &scale) |
void | setMatrixRotation (double rotation) |
void | setMatrixTranslation (const ossimDpt &translation) |
void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
Utility method to snap the tie point to some multiple. More... | |
void | snapTiePointToOrigin () |
void | setElevationLookupFlag (bool flag) |
bool | getElevationLookupFlag () const |
ossimUnitType | getModelTransformUnitType () const |
void | setModelTransformUnitType (ossimUnitType unit) |
bool | hasModelTransform () const |
virtual bool | isAffectedByElevation () const |
Implementation of pure virtual ossimProjection::isAffectedByElevation method. More... | |
void | setProjectionUnits (ossimUnitType units) |
ossimUnitType | getProjectionUnits () const |
OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimProjection () | |
virtual | ~ossimProjection () |
virtual void | getRoundTripError (const ossimDpt &imagePoint, ossimDpt &errorResult) const |
virtual void | getRoundTripError (const ossimGpt &groundPoint, ossimDpt &errorResult) const |
virtual void | getGroundClipPoints (ossimGeoPolygon &gpts) const |
virtual bool | operator!= (const ossimProjection &projection) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
long | Set_Van_der_Grinten_Parameters (double a, double f, double Central_Meridian, double False_Easting, double False_Northing) |
void | Get_Van_der_Grinten_Parameters (double *a, double *f, double *Central_Meridian, double *False_Easting, double *False_Northing) const |
long | Convert_Geodetic_To_Van_der_Grinten (double Latitude, double Longitude, double *Easting, double *Northing) const |
long | Convert_Van_der_Grinten_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
virtual | ~ossimMapProjection () |
void | updateFromTransform () |
virtual | ~ossimReferenced () |
Protected Attributes | |
double | Grin_a |
double | Grin_f |
double | es2 |
double | es4 |
double | es6 |
double | Ra |
double | PI_Ra |
double | Grin_Origin_Long |
double | Grin_False_Easting |
double | Grin_False_Northing |
ossimEllipsoid | theEllipsoid |
This method verifies that the projection parameters match the current pcs code. More... | |
ossimGpt | theOrigin |
const ossimDatum * | theDatum |
This is only set if we want to have built in datum shifting. More... | |
ossimDpt | theMetersPerPixel |
Holds the number of meters per pixel. More... | |
ossimDpt | theDegreesPerPixel |
Hold the decimal degrees per pixel. More... | |
ossimGpt | theUlGpt |
Hold tie point in decimal degrees. More... | |
ossimDpt | theUlEastingNorthing |
Hold tie point as easting northing. More... | |
ossimDpt | theFalseEastingNorthing |
Hold the false easting northing. More... | |
ossim_uint32 | thePcsCode |
Projection Coordinate System(PCS) code. More... | |
bool | theElevationLookupFlag |
ossimMatrix4x4 | theModelTransform |
ossimMatrix4x4 | theInverseModelTransform |
ossimUnitType | theModelTransformUnitType |
ossimUnitType | theProjectionUnits |
Linear units of the projection as indicated in the projection's specification: More... | |
ossimErrorCode | theErrorStatus |
Definition at line 17 of file ossimVanDerGrintenProjection.h.
ossimVanDerGrintenProjection::ossimVanDerGrintenProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid() , |
const ossimGpt & | origin = ossimGpt() |
Definition at line 54 of file ossimVanDerGrintenProjection.cpp.
References setDefaults(), and update().
ossimVanDerGrintenProjection::ossimVanDerGrintenProjection | ( | const ossimEllipsoid & | ellipsoid, |
const ossimGpt & | origin, | ||
const double | falseEasting, | ||
const double | falseNorthing | ||
Definition at line 62 of file ossimVanDerGrintenProjection.cpp.
References Grin_False_Easting, Grin_False_Northing, and update().
inline |
Definition at line 26 of file ossimVanDerGrintenProjection.h.
protected |
The function Convert_Geodetic_To_Van_der_Grinten converts geodetic (latitude and longitude) coordinates to Van Der Grinten projection easting, and northing coordinates, according to the current ellipsoid and Van Der Grinten projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise GRIN_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 278 of file ossimVanDerGrintenProjection.cpp.
References FLOAT_EQ, Grin_False_Easting, Grin_False_Northing, GRIN_NO_ERROR, Grin_Origin_Long, M_PI, MAX_LAT, PI_Ra, Ra, and TWO_OVER_PI.
Referenced by forward().
protected |
The function Convert_Van_der_Grinten_To_Geodetic converts Van Der Grinten projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Van Der Grinten projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise GRIN_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 387 of file ossimVanDerGrintenProjection.cpp.
References Grin_False_Easting, Grin_False_Northing, GRIN_NO_ERROR, Grin_Origin_Long, M_PI, MAX_LAT, ONE_THIRD, PI_OVER_3, and PI_Ra.
Referenced by inverse().
inlinevirtual |
Implements ossimProjection.
Definition at line 27 of file ossimVanDerGrintenProjection.h.
Definition at line 136 of file ossimVanDerGrintenProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Van_der_Grinten(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
protected |
The function Get_Van_der_Grinten_Parameters returns the current ellipsoid parameters, and Van Der Grinten projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 247 of file ossimVanDerGrintenProjection.cpp.
References Grin_a, Grin_f, Grin_False_Easting, Grin_False_Northing, and Grin_Origin_Long.
inlinevirtual |
Definition at line 60 of file ossimVanDerGrintenProjection.h.
inlinevirtual |
Definition at line 61 of file ossimVanDerGrintenProjection.h.
Definition at line 123 of file ossimVanDerGrintenProjection.cpp.
References Convert_Van_der_Grinten_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 162 of file ossimVanDerGrintenProjection.cpp.
References ossimKeywordlist::find(), Grin_False_Easting, Grin_False_Northing, ossimMapProjection::loadState(), setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 513 of file ossimVanDerGrintenProjection.cpp.
References ossim::almostEqual(), and Grin_Origin_Long.
Definition at line 157 of file ossimVanDerGrintenProjection.cpp.
References ossimMapProjection::saveState().
protected |
The function Set_Van_der_Grinten_Parameters receives the ellipsoid parameters and Van Der Grinten projcetion parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise GRIN_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 188 of file ossimVanDerGrintenProjection.cpp.
References es2, es4, es6, Grin_a, Grin_f, Grin_False_Easting, Grin_False_Northing, GRIN_NO_ERROR, Grin_Origin_Long, M_PI, PI_Ra, and Ra.
Referenced by update().
void ossimVanDerGrintenProjection::setCentralMeridian | ( | double | centralMeridian | ) |
Definition at line 108 of file ossimVanDerGrintenProjection.cpp.
References Grin_Origin_Long, and update().
void ossimVanDerGrintenProjection::setDefaults | ( | ) |
Definition at line 102 of file ossimVanDerGrintenProjection.cpp.
References Grin_False_Easting, and Grin_False_Northing.
Referenced by loadState(), and ossimVanDerGrintenProjection().
void ossimVanDerGrintenProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 88 of file ossimVanDerGrintenProjection.cpp.
References Grin_False_Easting, and update().
void ossimVanDerGrintenProjection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 114 of file ossimVanDerGrintenProjection.cpp.
void ossimVanDerGrintenProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 95 of file ossimVanDerGrintenProjection.cpp.
References Grin_False_Northing, and update().
Definition at line 74 of file ossimVanDerGrintenProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), Grin_False_Easting, Grin_False_Northing, ossimGpt::lonr(), Set_Van_der_Grinten_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimVanDerGrintenProjection(), setCentralMeridian(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprotected |
Definition at line 87 of file ossimVanDerGrintenProjection.h.
Referenced by Set_Van_der_Grinten_Parameters().
mutableprotected |
Definition at line 88 of file ossimVanDerGrintenProjection.h.
mutableprotected |
Definition at line 89 of file ossimVanDerGrintenProjection.h.
mutableprotected |
Definition at line 85 of file ossimVanDerGrintenProjection.h.
Referenced by Get_Van_der_Grinten_Parameters(), and Set_Van_der_Grinten_Parameters().
mutableprotected |
Definition at line 86 of file ossimVanDerGrintenProjection.h.
mutableprotected |
Definition at line 94 of file ossimVanDerGrintenProjection.h.
Referenced by Convert_Geodetic_To_Van_der_Grinten(), Convert_Van_der_Grinten_To_Geodetic(), Get_Van_der_Grinten_Parameters(), loadState(), ossimVanDerGrintenProjection(), Set_Van_der_Grinten_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprotected |
Definition at line 95 of file ossimVanDerGrintenProjection.h.
Referenced by Convert_Geodetic_To_Van_der_Grinten(), Convert_Van_der_Grinten_To_Geodetic(), Get_Van_der_Grinten_Parameters(), loadState(), ossimVanDerGrintenProjection(), Set_Van_der_Grinten_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprotected |
Definition at line 93 of file ossimVanDerGrintenProjection.h.
Referenced by Convert_Geodetic_To_Van_der_Grinten(), Convert_Van_der_Grinten_To_Geodetic(), Get_Van_der_Grinten_Parameters(), operator==(), Set_Van_der_Grinten_Parameters(), and setCentralMeridian().
mutableprotected |
Definition at line 91 of file ossimVanDerGrintenProjection.h.
Referenced by Convert_Geodetic_To_Van_der_Grinten(), Convert_Van_der_Grinten_To_Geodetic(), and Set_Van_der_Grinten_Parameters().
mutableprotected |
Definition at line 90 of file ossimVanDerGrintenProjection.h.
Referenced by Convert_Geodetic_To_Van_der_Grinten(), and Set_Van_der_Grinten_Parameters().
