Public Member Functions | Protected Member Functions | Private Attributes | List of all members
ossimVectorRenderer Class Referenceabstract
#include <ossimVectorRenderer.h>
Inheritance diagram for ossimVectorRenderer:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimVectorRenderer ()
 ossimVectorRenderer (ossimImageSource *inputSource, ossimImageViewTransform *transform=NULL)
virtual ossimImageDatarenderVectorData () const =0
 Renders the vector data to a data object. More...
virtual vector< ossimDpt3dgetObject (ossim_uint32 index) const =0
 Returns vector of ossimDpt3d points representing the data object at the index passed in. More...
virtual void setImageViewTransform (ossimImageViewTransform *transform)
 Sets the ImageViewTransform to be used for converting vector data. More...
virtual void setAreaOfInterest (const ossimDrect &aoi)
 Sets the area of interest. More...
virtual ossimDrect getAreaOfInterest () const
 Returns the current area of interest as an ossimDrect. More...
virtual ossimDrect getBoundingRect (long resLevel=0) const
 Returns the full bounding rectangle of current vector data loaded. More...
virtual ossim_int32 getNumberOfAoiObjects () const
 Returns the number of vector objects in the area of interest. More...
virtual ossim_int32 getNumberOfObjects () const
 Returns the total number of vector objects in the full bounding rectangle. More...
virtual void initialize ()
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
virtual ~ossimVectorRenderer ()
virtual void setBoundingRect (ossimDrect &rect)
 Sets the bounding rectangle of current vector data loaded. More...
virtual void setNumberOfAoiObjects (ossim_int32 number_of_objects)
 Sets the number of vector objects in the area of interest. More...
virtual void setNumberOfObjects (ossim_int32 number_of_objects)
 Sets the number of vector objects in the full bounding rectangle. More...
virtual ~ossimReferenced ()
Private Attributes
ossimImageViewTransformtheImageViewTransform
ossimDrect theBoundingRect
ossimDrect theAreaOfInterest
ossim_int32 theNumberOfAoiObjects
ossim_int32 theNumberOfObjects
Additional Inherited Members
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Detailed Description
Definition at line 24 of file ossimVectorRenderer.h.
◆ ossimVectorRenderer() [1/2]
ossimVectorRenderer::ossimVectorRenderer ( )
Definition at line 29 of file ossimVectorRenderer.cpp.
30  :
37 {
38 }
ossimImageSourceFilter(ossimObject *owner=NULL)
ossimImageViewTransform * theImageViewTransform
◆ ossimVectorRenderer() [2/2]
ossimVectorRenderer::ossimVectorRenderer ( ossimImageSource inputSource,
ossimImageViewTransform transform = NULL
Definition at line 40 of file ossimVectorRenderer.cpp.
42  : ossimImageSourceFilter(inputSource),
43  theImageViewTransform(transform),
48 {
49
50 }
◆ ~ossimVectorRenderer()
ossimVectorRenderer::~ossimVectorRenderer ( )
protectedvirtual
Definition at line 53 of file ossimVectorRenderer.cpp.
References theImageViewTransform.
54 {
56  {
57  delete theImageViewTransform;
58  theImageViewTransform = NULL;
59  }
60 }
Member Function Documentation
◆ getAreaOfInterest()
ossimDrect ossimVectorRenderer::getAreaOfInterest ( ) const
virtual
Definition at line 101 of file ossimVectorRenderer.cpp.
References theAreaOfInterest.
102 {
103  return theAreaOfInterest;
104 }
◆ getBoundingRect()
ossimDrect ossimVectorRenderer::getBoundingRect ( long  resLevel = 0) const
virtual
Definition at line 106 of file ossimVectorRenderer.cpp.
References theBoundingRect.
107 {
108  return theBoundingRect;
109 }
◆ getNumberOfAoiObjects()
ossim_int32 ossimVectorRenderer::getNumberOfAoiObjects ( ) const
virtual
Definition at line 111 of file ossimVectorRenderer.cpp.
References theNumberOfAoiObjects.
112 {
113  return theNumberOfAoiObjects;
114 }
◆ getNumberOfObjects()
ossim_int32 ossimVectorRenderer::getNumberOfObjects ( ) const
virtual
Definition at line 116 of file ossimVectorRenderer.cpp.
References theNumberOfObjects.
117 {
118  return theNumberOfObjects;
119 }
◆ getObject()
virtual vector<ossimDpt3d> ossimVectorRenderer::getObject ( ossim_uint32  index) const
pure virtual
Implementors should set an error and return an empty vector if the index is out of range.
◆ loadState()
bool ossimVectorRenderer::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 68 of file ossimVectorRenderer.cpp.
References ossimString::c_str(), ossimImageViewTransformFactory::instance(), ossimImageSource::loadState(), and theImageViewTransform.
70 {
71  ossimString newPrefix = prefix + ossimString("image_view_trans.");
72
74  {
75  delete theImageViewTransform;
76  theImageViewTransform = NULL;
77  }
78
81  createTransform(kwl, newPrefix.c_str());
82
83  return ossimImageSource::loadState(kwl, prefix);
84 }
static ossimImageViewTransformFactory * instance()
const char * c_str() const
Definition: ossimString.h:396
◆ renderVectorData()
virtual ossimImageData* ossimVectorRenderer::renderVectorData ( ) const
pure virtual
The area which is imaged is the area of interest. The scale is determined by the output view projection of the ImageViewTransform.
◆ saveState()
bool ossimVectorRenderer::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 62 of file ossimVectorRenderer.cpp.
64 {
65  return false;
66 }
◆ setAreaOfInterest()
void ossimVectorRenderer::setAreaOfInterest ( const ossimDrect aoi)
virtual
This will be used by the renderVectorData.
Definition at line 96 of file ossimVectorRenderer.cpp.
97 {
98  theAreaOfInterest = aoi;
99 }
◆ setBoundingRect()
void ossimVectorRenderer::setBoundingRect ( ossimDrect rect)
protectedvirtual
Definition at line 121 of file ossimVectorRenderer.cpp.
122 {
123  theBoundingRect = rect;
124 }
◆ setImageViewTransform()
void ossimVectorRenderer::setImageViewTransform ( ossimImageViewTransform transform)
virtual
Definition at line 87 of file ossimVectorRenderer.cpp.
88 {
90  {
91  delete theImageViewTransform;
92  }
93  theImageViewTransform = transform;
94 }
◆ setNumberOfAoiObjects()
void ossimVectorRenderer::setNumberOfAoiObjects ( ossim_int32  number_of_objects)
protectedvirtual
Definition at line 126 of file ossimVectorRenderer.cpp.
127 {
128  theNumberOfAoiObjects = number_of_objects;
129 }
◆ setNumberOfObjects()
void ossimVectorRenderer::setNumberOfObjects ( ossim_int32  number_of_objects)
protectedvirtual
Definition at line 131 of file ossimVectorRenderer.cpp.
132 {
133  theNumberOfObjects = number_of_objects;
134 }
Member Data Documentation
◆ theAreaOfInterest
ossimDrect ossimVectorRenderer::theAreaOfInterest
private
Definition at line 112 of file ossimVectorRenderer.h.
Referenced by getAreaOfInterest(), and setAreaOfInterest().
◆ theBoundingRect
ossimDrect ossimVectorRenderer::theBoundingRect
private
Definition at line 111 of file ossimVectorRenderer.h.
Referenced by getBoundingRect(), and setBoundingRect().
◆ theImageViewTransform
ossimImageViewTransform* ossimVectorRenderer::theImageViewTransform
private
Definition at line 110 of file ossimVectorRenderer.h.
Referenced by loadState(), setImageViewTransform(), and ~ossimVectorRenderer().
◆ theNumberOfAoiObjects
ossim_int32 ossimVectorRenderer::theNumberOfAoiObjects
private
Definition at line 113 of file ossimVectorRenderer.h.
Referenced by getNumberOfAoiObjects(), and setNumberOfAoiObjects().
◆ theNumberOfObjects
ossim_int32 ossimVectorRenderer::theNumberOfObjects
private
Definition at line 114 of file ossimVectorRenderer.h.
Referenced by getNumberOfObjects(), and setNumberOfObjects().
