ossimVideoImageHandler Class Referenceabstract
OSSIM Image handler for video frames. More...
#include <ossimVideoImageHandler.h>
Inheritance diagram for ossimVideoImageHandler:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
virtual bool open ()=0
 Pure virtual open. More...
virtual bool isOpen () const =0
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
virtual void initialize ()=0
 Common initialization code for all construction methods. More...
virtual bool setCurrentEntry (ossim_uint32 frame_number)
 Sets the currently active frame number as count from start of video. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const
 Pure virtual, derived classes must implement. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const
 Currently assuming all videos are RGB. More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &rect, ossim_uint32 resLevel=0)=0
ossimRefPtr< ossimVideoHandlergetVideo () const
ossimRefPtr< ossimVideoGeometrygetVideoGeometry () const
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
Protected Member Functions
 ossimVideoImageHandler ()
virtual void completeOpen ()
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimVideoHandlerm_video
ossimRefPtr< ossimVideoGeometrym_videoGeometry
int m_currentFrameNumber
 This is the currently active entry. More...
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Additional Inherited Members
Detailed Description
Notes on video handling in OSSIM:
Definition at line 26 of file ossimVideoImageHandler.h.
◆ ossimVideoImageHandler()
ossimVideoImageHandler::ossimVideoImageHandler ( )
protected
Definition at line 22 of file ossimVideoImageHandler.cpp.
24 {
25 }
Member Function Documentation
◆ close()
void ossimVideoImageHandler::close ( )
virtual
Definition at line 30 of file ossimVideoImageHandler.cpp.
References m_video, and m_videoGeometry.
31 {
32  m_video = 0;
33  m_videoGeometry = 0;
34 }
ossimRefPtr< ossimVideoGeometry > m_videoGeometry
ossimRefPtr< ossimVideoHandler > m_video
◆ getCurrentEntry()
ossim_uint32 ossimVideoImageHandler::getCurrentEntry ( ) const
virtual
Returns
The current entry number.
Note
This implementation returns 0. Derived classes should override if of multiple entry image type.
Definition at line 69 of file ossimVideoImageHandler.cpp.
References m_currentFrameNumber.
70 {
71  if (m_currentFrameNumber < 0 )
72  return 0;
73
74  return m_currentFrameNumber;
75 }
◆ getEntryList()
void ossimVideoImageHandler::getEntryList ( std::vector< ossim_uint32 > &  entryList) const
virtual
Parameters
entryListThis is the list to initialize with entry indexes.
Note
This implementation returns puts one entry "0" in the list.
Definition at line 39 of file ossimVideoImageHandler.cpp.
References getNumberOfEntries().
40 {
41  entryList.clear();
42  ossim_uint32 num_frames = getNumberOfEntries();
43  for (ossim_uint32 i=0; i<num_frames; ++i)
44  entryList.push_back(i);
45 }
unsigned int ossim_uint32
virtual ossim_uint32 getNumberOfEntries() const
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimVideoImageHandler::getImageGeometry ( )
virtual
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 116 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::computeFrameTime(), ossimVideoGeometry::getImageGeometry(), m_currentFrameNumber, m_video, m_videoGeometry, ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
117 {
118  if (theGeometry.valid())
119  return theGeometry;
120
121  // Only full-image res level = 0 presently supported:
122  if (!m_video.valid() || !m_videoGeometry.valid())
123  return NULL;
124
126  return theGeometry;
127 }
ossimRefPtr< ossimImageGeometry > theGeometry
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry(const double &t)=0
Provides an image geometry object for frame at specified time in seconds since start of sequence...
double computeFrameTime(ossim_uint32 frame_count) const
Utility method for computing frame time from frame number.
◆ getImageTileHeight()
virtual ossim_uint32 ossimVideoImageHandler::getImageTileHeight ( ) const
inlinevirtual
Implements ossimImageHandler.
Definition at line 49 of file ossimVideoImageHandler.h.
References ossimImageHandler::getNumberOfLines().
49 { return getNumberOfLines(); }
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const
◆ getImageTileWidth()
virtual ossim_uint32 ossimVideoImageHandler::getImageTileWidth ( ) const
inlinevirtual
Definition at line 48 of file ossimVideoImageHandler.h.
References ossimImageHandler::getNumberOfSamples().
48 { return getNumberOfSamples(); }
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
◆ getNumberOfEntries()
ossim_uint32 ossimVideoImageHandler::getNumberOfEntries ( ) const
virtual
Returns
The number of entries (images) in the image file.
Definition at line 80 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::computeFrameNumber(), ossimVideoHandler::duration(), m_video, and ossimRefPtr< T >::valid().
Referenced by getEntryList().
81 {
82  if (!m_video.valid())
83  return 0;
84
86  return num_frames;
87 }
bool valid() const
int computeFrameNumber(double seconds_from_start) const
Utility method for computing frame number from frame time.
ossim_float64 duration() const
Total length of video in seconds.
◆ getNumberOfInputBands()
virtual ossim_uint32 ossimVideoImageHandler::getNumberOfInputBands ( ) const
inlinevirtual
Implements ossimImageSource.
Definition at line 52 of file ossimVideoImageHandler.h.
52 { return 3; }
◆ getNumberOfLines()
ossim_uint32 ossimVideoImageHandler::getNumberOfLines ( ossim_uint32  resLevel = 0) const
virtual
Parameters
resLevelReduced resolution level to return lines of. Default = 0
Returns
The number of lines for specified reduced resolution level.
Definition at line 92 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::frameSize(), ossimIpt::line, m_video, and ossimRefPtr< T >::valid().
93 {
94  // Only full-image res level = 0 presently supported:
95  if (!m_video.valid() || (resLevel != 0))
96  return 0;
97
98  return m_video->frameSize().line;
99 }
bool valid() const
const ossimIpt & frameSize() const
Nominal size of a frame in pixels.
ossim_int32 line
Definition: ossimIpt.h:142
◆ getNumberOfOutputBands()
virtual ossim_uint32 ossimVideoImageHandler::getNumberOfOutputBands ( ) const
inlinevirtual
Definition at line 53 of file ossimVideoImageHandler.h.
53 { return 3; }
◆ getNumberOfSamples()
ossim_uint32 ossimVideoImageHandler::getNumberOfSamples ( ossim_uint32  resLevel = 0) const
virtual
Parameters
resLevelReduced resolution level to return samples of. Default = 0
Returns
The number of samples for specified reduced resolution level.
Definition at line 104 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::frameSize(), m_video, ossimIpt::samp, and ossimRefPtr< T >::valid().
105 {
106  // Only full-image res level = 0 presently supported:
107  if (!m_video.valid() || (resLevel != 0))
108  return 0;
109
110  return m_video->frameSize().samp;
111 }
bool valid() const
ossim_int32 samp
Definition: ossimIpt.h:141
◆ getOutputScalarType()
virtual ossimScalarType ossimVideoImageHandler::getOutputScalarType ( ) const
inlinevirtual
Definition at line 54 of file ossimVideoImageHandler.h.
References OSSIM_UINT8.
54 { return OSSIM_UINT8; }
8 bit unsigned integer
◆ getTile()
virtual ossimRefPtr<ossimImageData> ossimVideoImageHandler::getTile ( const ossimIrect rect,
pure virtual
Returns
◆ getVideo()
ossimRefPtr<ossimVideoHandler> ossimVideoImageHandler::getVideo ( ) const
inline
Definition at line 63 of file ossimVideoImageHandler.h.
63 { return m_video; }
◆ getVideoGeometry()
ossimRefPtr<ossimVideoGeometry> ossimVideoImageHandler::getVideoGeometry ( ) const
inline
Definition at line 64 of file ossimVideoImageHandler.h.
64 { return m_videoGeometry; }
◆ initialize()
virtual void ossimVideoImageHandler::initialize ( )
pure virtual
◆ isOpen()
virtual bool ossimVideoImageHandler::isOpen ( ) const
pure virtual
Returns
true if open, false if not.
◆ open()
virtual bool ossimVideoImageHandler::open ( )
pure virtual
Pure virtual open.
Derived classes must implement.
Returns
Note
This method relies on the data member ossimImageData::theImageFile being set. Callers should do a "setFilename" prior to calling this method or use the ossimImageHandler::open that takes a file name and an entry index.
◆ setCurrentEntry()
bool ossimVideoImageHandler::setCurrentEntry ( ossim_uint32  frame_number)
virtual
Returns false if frame time is outside of allowable range.
Returns false if frame count is outside of allowable range.
Definition at line 51 of file ossimVideoImageHandler.cpp.
References ossimVideoSource::computeFrameTime(), m_currentFrameNumber, m_video, ossimVideoHandler::seek(), ossimVideoSource::SEEK_ABSOLUTE, and ossimRefPtr< T >::valid().
52 {
53  if (!m_video.valid())
54  return false;
55
56  ossim_float64 frameTime = m_video->computeFrameTime(frame_number);
58  {
59  m_currentFrameNumber = frame_number;
60  return true;
61  }
62
63  return false;
64 }
virtual bool seek(ossim_float64 reference_time_sec, SeekType seekType)=0
Seeks to the frame at time specified, according to the seekType (relative to active frame or absolute...
bool valid() const
double ossim_float64
Member Data Documentation
◆ m_currentFrameNumber
int ossimVideoImageHandler::m_currentFrameNumber
protected
Definition at line 71 of file ossimVideoImageHandler.h.
Referenced by getCurrentEntry(), getImageGeometry(), and setCurrentEntry().
◆ m_tile
ossimRefPtr<ossimImageData> ossimVideoImageHandler::m_tile
protected
Definition at line 72 of file ossimVideoImageHandler.h.
◆ m_video
ossimRefPtr<ossimVideoHandler> ossimVideoImageHandler::m_video
protected
◆ m_videoGeometry
ossimRefPtr<ossimVideoGeometry> ossimVideoImageHandler::m_videoGeometry
protected
Definition at line 70 of file ossimVideoImageHandler.h.
Referenced by close(), and getImageGeometry().
