#include <ossimPluginProjectionFactory.h>
virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
takes a filename. More... | |
virtual ossimProjection * | createProjection (const ossimString &name) const |
Take a projection type name. More... | |
virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
Take a keywordlist. More... | |
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimPluginProjectionFactory * | instance () |
ossimPluginProjectionFactory () | |
bool | isTileMap (const ossimFilename &filename) const |
ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
This method takes the filename and tries to find an external ".geom" file. More... | |
virtual | ~ossimReferenced () |
Definition at line 19 of file ossimPluginProjectionFactory.h.
inlineprotected |
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 511 of file ossimPluginProjectionFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 517 of file ossimPluginProjectionFactory.cpp.
takes a filename.
This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful.
Implements ossimProjectionFactoryBase.
Definition at line 57 of file ossimPluginProjectionFactory.cpp.
References ossimFilename::dirCat(), ossimString::downcase(), ossimFilename::exists(), ossimFilename::file(), ossimRefPtr< T >::get(), ossimFormosatDimapSupportData::loadXmlFile(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimFilename::path(), ossimRefPtr< T >::release(), ossimFilename::setExtension(), and ossimRefPtr< T >::valid().
Referenced by createObject().
Definition at line 318 of file ossimPluginProjectionFactory.cpp.
References ossimNotify(), ossimNotifyLevel_DEBUG, and STATIC_TYPE_NAME.
Take a keywordlist.
Definition at line 390 of file ossimPluginProjectionFactory.cpp.
References ossimKeywordlist::find(), ossimProjection::loadState(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimRefPtr< T >::release(), and ossimKeywordNames::TYPE_KW.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 524 of file ossimPluginProjectionFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by ossimplugins::ossimSharedLibraryInitialize().
static |
Definition at line 49 of file ossimPluginProjectionFactory.cpp.
References ossimPluginProjectionFactory().
Referenced by ossimplugins::ossimSharedLibraryFinalize(), and ossimplugins::ossimSharedLibraryInitialize().
protected |
Definition at line 544 of file ossimPluginProjectionFactory.cpp.
References ossimString::beforePos(), ossimString::downcase(), and ossimFilename::ext().
