ossimDoqqTileSource.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2000 ImageLinks Inc.
3 //
4 // License: LGPL
5 //
6 // See LICENSE.txt file in the top level directory for more details.
7 //
8 // Author: Garrett Potts
9 //
10 //*******************************************************************
11 // $Id: ossimDoqqTileSource.cpp 21631 2012-09-06 18:10:55Z dburken $
20
22  "ossimDoqqTileSource",
24
26  :theHeaderInformation(0)
27 {
28 }
29
31 {
33 }
34
36 {
37  bool result = false;
38
39  theHeaderInformation = new ossimDoqq(filename);
41  {
43
44  return result;
45  }
46  else
47  {
48  // Set the Acquisition Date
50  theAcqDate += "-";
52  theAcqDate += "-";
54
55  vector<ossimFilename> f;
56  f.push_back(filename);
57  ossimGeneralRasterInfo genRasterInfo(f,
59  OSSIM_BIP,
65  0);
66
67  result = ossimGeneralRasterTileSource::open(genRasterInfo);
68  }
69
70  return result;
71 }
72
73 //**************************************************************************************************
76 //**************************************************************************************************
78 {
79  if (theGeometry.valid()) return theGeometry;
80
82  {
83  ossimKeywordlist kwl;
84  const char* prefix = 0; // legacy
85
88
89  if(proj == ossimString("UTM") || proj == ossimString("1"))
90  {
91  kwl.add(prefix,
93  "ossimUtmProjection",
94  true);
95  kwl.add(prefix,
98  true);
99  }
100  else
101  {
103  }
104
105  if(datum == ossimString("NAR") || datum == ossimString("4"))
106  {
107  kwl.add(prefix,
109  "NAR-C", // North American Conus 1983
110  true);
111  }
112  else if(datum == ossimString("NAS") || datum == ossimString("1"))
113  {
114  kwl.add(prefix,
116  "NAS-C", // North American Conus 1927
117  true);
118  }
119  else if(datum == ossimString("2"))
120  {
121  kwl.add(prefix,
123  "WGD", // WGS 72
124  true);
125  }
126  else if(datum == ossimString("3"))
127  {
128  kwl.add(prefix,
130  "WGE", // WGS 84
131  true);
132  }
133  else
134  {
136  }
137
138  kwl.add(prefix,
141  true);
142
143  kwl.add(prefix,
146  true);
147  kwl.add(prefix,
149 // theHeaderInformation->theUE + (theHeaderInformation->theGsd/2.0),
151  true);
152
153  kwl.add(prefix,
155 // theHeaderInformation->theUN - (theHeaderInformation->theGsd/2.0),
157  true);
158
159  // Capture this for next time.
161  theGeometry->loadState(kwl, prefix);
162
163  // Set image things the geometry object should know about.
165
166  return theGeometry;
167  }
169 }
170
172 {
173  if(name == "acquisition_date")
174  {
176  {
177  std::stringstream out;
178  out << std::setw(4) << std::setfill(' ') << theHeaderInformation->theAcqYear.c_str()
179  << std::setw(2) << setfill('0') << theHeaderInformation->theAcqMonth.c_str()
180  << std::setw(2) << setfill('0') << theHeaderInformation->theAcqDay.c_str();
181  return new ossimStringProperty("acquisition_date", out.str());
182  }
183  return 0;
184  }
185  else if(name == "file_type")
186  {
187  return new ossimStringProperty("file_type", "DOQQ");
188  }
189  return ossimImageHandler::getProperty(name);
190 }
191
192 void ossimDoqqTileSource::getPropertyNames(std::vector<ossimString>& propertyNames)const
193 {
195  propertyNames.push_back("acquisition_date");
196  propertyNames.push_back("file_type");
197
198 }
199
201  const char* prefix)
202 {
203  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
204  if(!ossimImageHandler::loadState(kwl, prefix))
205  {
206  return false;
207  }
208
209  if(lookup)
210  {
213  {
215  return false;
216  }
217  else
218  {
219  ossimFilename filename(lookup);
220  vector<ossimFilename> f;
221  f.push_back(filename);
222  ossimGeneralRasterInfo genRasterInfo(f,
223  OSSIM_UCHAR,
224  OSSIM_BIP,
230  0);
231  return open(genRasterInfo);
232  }
233  }
234  else
235  {
236  return false;
237  }
238
239  return true;
240 }
241
243 {
244  return ossimString("doqq");
245 }
246
248 {
249  return ossimString("doqq handler");
250 }
251
253 {
255 }
256
258 {
259  return theAcqDate;
260 }
ossimRefPtr< ossimImageGeometry > theGeometry
virtual bool open()
Pure virtual open.
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
ossim_float64 theEasting
Definition: ossimDoqq.h:111
std::basic_stringstream< char > stringstream
Class for char mixed input and output memory streams.
Definition: ossimIosFwd.h:38
static const char * DATUM_KW
bool valid() const
Definition: ossimRefPtr.h:75
Attempts to initialize a transform and a projection given the KWL.
Gets a property for matching name.
double y
Definition: ossimDpt.h:165
ossim_int32 theUtmZone
Definition: ossimDoqq.h:99
ossimString theDatum
Definition: ossimDoqq.h:88
ossimDpt theGsd
Definition: ossimDoqq.h:117
static const char * METERS_PER_PIXEL_Y_KW
static const char * TYPE_KW
static const char * TIE_POINT_NORTHING_KW
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
ossim_int32 theLine
Definition: ossimDoqq.h:100
ossimString getLongName() const
static const char * ZONE_KW
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
static const char * TIE_POINT_EASTING_KW
ossimString theProjection
Definition: ossimDoqq.h:87
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
ossimString getShortName() const
ossim_int32 theHeaderSize
Definition: ossimDoqq.h:118
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
Gets a list of property names available.
ossim_float64 theNorthing
Definition: ossimDoqq.h:112
ossimRefPtr< ossimDoqq > theHeaderInformation
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
ossim_int32 theSample
Definition: ossimDoqq.h:101
ossimString acqdate() const
double x
Definition: ossimDpt.h:164
const char * c_str() const
Definition: ossimString.h:396
ossimString theAcqMonth
Definition: ossimDoqq.h:105
ossimString theAcqYear
Definition: ossimDoqq.h:104
static const char * FILENAME_KW
static const char * METERS_PER_PIXEL_X_KW
ossim_int32 theRgb
Definition: ossimDoqq.h:102
RTTI_DEF1(ossimDoqqTileSource, "ossimDoqqTileSource", ossimGeneralRasterTileSource)
8 bit unsigned iteger
ossim_int32 errorStatus() const
Definition: ossimDoqq.h:121
ossimString theAcqDay
Definition: ossimDoqq.h:106
