188 result.
x = 1.0 / (1<<resLevel);
195 decimations.push_back(
ossimDpt(1.0,1.0));
235 type = kwl.
find(geomPrefix,
"type");
This will return the bounding rect of the source.
virtual bool canConnectMyInputTo(ossim_int32 myInputIndex, const ossimConnectableObject *object) const
required to be overriden by derived classes
virtual const ossim_float64 * getMaxPix() const
void setRect(ossim_uint32 ulx, ossim_uint32 uly, ossim_uint32 width, ossim_uint32 height)
Attempts to initialize a transform and a projection given the KWL.
ossim_uint32 height() const
void setImage(ossimRefPtr< ossimImageData > image)
ossimRefPtr< ossimImageData > m_image
ossimRefPtr< ossimImageGeometry > m_geometry
virtual void initialize()
Initialize the data buffer.
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
loadState is here so one can construct a memory source as a blank tile.
ossimIrect m_boundingRect
virtual ossimIrect getImageRectangle() const
ossim_uint32 width() const
virtual ossim_uint32 getNumberOfInputBands() const
virtual ossim_uint32 getNumberOfDecimationLevels() const
Will return the number of resolution levels.
RTTI_DEF1(ossimMemoryImageSource, "ossimMemoryImageSource", ossimImageSource)
virtual const ossim_float64 * getMinPix() const
ossimRefPtr< ossimImageData > m_result
virtual void makeBlank()
save state is not implemented for this source and only passes to the base.
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
Will return the decimation factor for the given resolution level.
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
Saves the transform (if any) and projection (if any) states to the KWL.
virtual void getDecimationFactors(std::vector< ossimDpt > &decimations) const
Will return an array of all decimations for each resolution level.
