ossimOgrGdalTileSource.h
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: Garrett Potts
8 //
9 // Description:
10 //
11 // Contains class definition for the class "ossimOgrGdalTileSource".
12 // ossimOgrGdalTileSource is derived from ImageHandler which is derived from
13 // TileSource.
14 //
15 //*******************************************************************
16 // $Id: ossimOgrGdalTileSource.h 19733 2011-06-06 23:35:25Z dburken $
17
18 #ifndef ossimOgrGdalTileSource_HEADER
19 #define ossimOgrGdalTileSource_HEADER 1
20
21 #include <vector>
22 #include <list>
23 #include <map>
24
29 #include <ossim/base/ossimIrect.h>
31
33 class ossimProjection;
34 class ossimMapProjection;
39
41  public ossimImageHandler,
42  public ossimViewInterface,
44 {
45 public:
47  virtual ~ossimOgrGdalTileSource();
48
49  virtual void close();
50
59  virtual bool open();
60
66  virtual ossimRefPtr<ossimImageData> getTile(const ossimIrect& tileRect,
67  ossim_uint32 resLevel=0);
68
73  virtual ossim_uint32 getNumberOfInputBands() const;
74
80  virtual ossim_uint32 getNumberOfOutputBands() const;
81
86  virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level = 0) const;
87
92  virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level = 0) const;
93
101
106  virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level = 0) const;
107
112  virtual bool saveState(ossimKeywordlist& kwl,
113  const char* prefix=0)const;
114
119  virtual bool loadState(const ossimKeywordlist& kwl,
120  const char* prefix=0);
121
125
129  virtual ossimScalarType getOutputScalarType() const;
130
134  virtual ossim_uint32 getTileWidth() const;
135
139  virtual ossim_uint32 getTileHeight() const;
140
147  virtual ossim_uint32 getImageTileWidth() const;
148
155  virtual ossim_uint32 getImageTileHeight() const;
156
157  virtual bool isOpen()const;
158
159  virtual double getNullPixelValue(ossim_uint32 band=0)const;
160
161  virtual double getMinPixelValue(ossim_uint32 band=0)const;
162
163  virtual double getMaxPixelValue(ossim_uint32 band=0)const;
164
165  virtual ossimObject* getView();
166
167  virtual const ossimObject* getView()const;
168
187  virtual bool setView(ossimObject* baseObject);
188
189  virtual void setProperty(ossimRefPtr<ossimProperty> property);
190  virtual ossimRefPtr<ossimProperty> getProperty(const ossimString& name)const;
191  virtual void getPropertyNames(std::vector<ossimString>& propertyNames)const;
192
193  virtual std::multimap<long, ossimAnnotationObject*> getFeatureTable();
194
195  virtual void setQuery(const ossimString& query);
196
198
199  virtual bool setCurrentEntry(ossim_uint32 entryIdx);
200
201 private:
203 TYPE_DATA
204 };
205
206 #endif
virtual bool open()=0
Pure virtual open.
ossimRefPtr< ossimGdalOgrVectorAnnotation > theAnnotationSource
virtual void setQuery(const ossimString &query)=0
Pure virtual setQuery method.
ossimUnitType
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
Returns the default processing tile height.
Class derived from ossimImageModel, this adds an image projection for lineSampleToWorld and worldToLi...
Returns the default processing tile width.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool isOpen() const =0
Retuns the min pixel value.
double ossim_float64
#define TYPE_DATA
Definition: ossimRtti.h:339
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
#define OSSIM_PLUGINS_DLL
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
ossimScalarType
virtual ossim_uint32 getImageTileWidth() const =0
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual bool setView(ossimObject *baseObject)=0
virtual std::multimap< long, ossimAnnotationObject * > getFeatureTable()=0
Pure virtual getFeatureTable method.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
virtual ossimObject * getView()=0
virtual ossim_uint32 getNumberOfInputBands() const =0
float distance(double lat1, double lon1, double lat2, double lon2, int units)
virtual void setGeometryBuffer(ossim_float64 distance, ossimUnitType type)=0
Pure virtual setGeometryBuffer method.
