#include <ossimOgrGdalTileSource.h>
ossimOgrGdalTileSource () | |
virtual | ~ossimOgrGdalTileSource () |
virtual void | close () |
Deletes the overview and clears the valid image vertices. More... | |
virtual bool | open () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual ossim_uint32 | getNumberOfInputBands () const |
virtual ossim_uint32 | getNumberOfOutputBands () const |
virtual ossim_uint32 | getNumberOfLines (ossim_uint32 reduced_res_level=0) const |
virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 reduced_res_level=0) const |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual ossimRefPtr< ossimImageGeometry > | getInternalImageGeometry () const |
Returns the image geometry object associated with this tile source or NULL if non defined. More... | |
virtual ossimScalarType | getOutputScalarType () const |
virtual ossim_uint32 | getTileWidth () const |
virtual ossim_uint32 | getTileHeight () const |
virtual ossim_uint32 | getImageTileWidth () const |
virtual ossim_uint32 | getImageTileHeight () const |
virtual bool | isOpen () const |
Derived classes must implement this method to be concrete. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Retuns the min pixel value. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual ossimObject * | getView () |
virtual const ossimObject * | getView () const |
virtual bool | setView (ossimObject *baseObject) |
Sets the output view. More... | |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual std::multimap< long, ossimAnnotationObject * > | getFeatureTable () |
Pure virtual getFeatureTable method. More... | |
virtual void | setQuery (const ossimString &query) |
Pure virtual setQuery method. More... | |
virtual void | setGeometryBuffer (ossim_float64 distance, ossimUnitType type) |
Pure virtual setGeometryBuffer method. More... | |
virtual bool | setCurrentEntry (ossim_uint32 entryIdx) |
ossimImageHandler () | |
Constructor (default): More... | |
virtual | ~ossimImageHandler () |
Destructor: Derived classes should implement. More... | |
virtual void | initialize () |
initialize Does nothing in this class. More... | |
virtual bool | openOverview () |
Searches for an overview. More... | |
virtual bool | openOverview (const ossimFilename &overview_file) |
Calls closeOverview(), then attempts to open the overview_file. More... | |
virtual void | closeOverview () |
If theOverview is initialized it will be deleted and set to NULL. More... | |
virtual const ossimImageHandler * | getOverview () const |
virtual bool | hasOverviews () const |
virtual ossimFilename | createDefaultOverviewFilename () const |
virtual ossimFilename | createDefaultGeometryFilename () const |
virtual ossimFilename | createDefaultMetadataFilename () const |
virtual ossimFilename | createDefaultHistogramFilename () const |
virtual ossimFilename | createDefaultValidVerticesFilename () const |
virtual bool | writeValidImageVertices (const std::vector< ossimIpt > &vertices, const ossimFilename &file=ossimFilename("")) |
Outputs vertices to file and updates the internal vertex array variable "theValidImageVertices". More... | |
virtual bool | openValidVertices (const ossimFilename &vertices_file) |
Opens the valid image vertices file and sets theValidImageVerticesFile variable. More... | |
virtual bool | openValidVertices () |
Creates vertices file name based on image, then tries to open. More... | |
virtual bool | open (const ossimFilename &imageFile, ossim_uint32 entryIndex) |
Opens the image file. More... | |
virtual bool | open (const ossimFilename &imageFile) |
virtual bool | open (std::shared_ptr< ossim::ImageHandlerState > state) |
virtual bool | buildHistogram (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
Build a histogram for image file. More... | |
virtual bool | buildAllHistograms (int numberOfRLevels=0, ossimHistogramMode mode=OSSIM_HISTO_MODE_NORMAL) |
Build a histograms for all image entries. More... | |
virtual bool | buildOverview (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build over file for theImageFile. More... | |
virtual bool | buildAllOverviews (ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build over file for all image entries. More... | |
virtual bool | buildOverview (const ossimFilename &filename, ossimImageHandlerOverviewCompressionType compressionType=OSSIM_OVERVIEW_COMPRESSION_NONE, ossim_uint32 quality=75, ossimFilterResampler::ossimFilterResamplerType resampleType=ossimFilterResampler::ossimFilterResampler_BOX, bool includeFullResFlag=false) |
Will build an over file for filename. More... | |
ossimRefPtr< ossimMultiResLevelHistogram > | getImageHistogram () const |
Fetches the current entry image's histogram. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
virtual void | setImageGeometry (ossimImageGeometry *geom) |
Sets the image geometry object. More... | |
virtual void | saveImageGeometry () const |
Saves the image geometry to a file that will be made based on the image file name. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
Returns zero-based bounding rectangle of the image. More... | |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
virtual void | getDecimationFactors (vector< ossimDpt > &decimations) const |
This returns all decimation for all levels. More... | |
virtual ossim_uint32 | getNumberOfReducedResSets () const |
This method is obsolete. More... | |
virtual void | setFilename (const ossimFilename &filename) |
Sets the filename. More... | |
virtual const ossimFilename & | getFilename () const |
Returns the filename. More... | |
virtual bool | isValidRLevel (ossim_uint32 resLevel) const |
Determines if the passed in reslution level is valid. More... | |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
Connection rule. More... | |
virtual void | getValidImageVertices (vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual bool | isBandSelector () const |
Indicates whether or not the image handler can control output band selection via the setOutputBandList method. More... | |
virtual bool | setOutputBandList (const std::vector< ossim_uint32 > &band_list) |
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled. More... | |
virtual bool | setOutputToInputBandList () |
If the image handler "isBandSeletor()" then the band selection of the output are set to input or identity. More... | |
virtual bool | isIdentityBandList (const std::vector< ossim_uint32 > &bandList) const |
Convenience method to see if band list is identity. More... | |
virtual bool | isImageTiled () const |
Indicates whether or not the image is tiled internally. More... | |
virtual bool | hasMetaData () const |
virtual ossimRefPtr< ossimNBandLutDataObject > | getLut () const |
virtual bool | hasLut () const |
virtual void | loadMetaData () |
There is an external file with an omd extension. More... | |
virtual void | setMinPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set min pixel value. More... | |
virtual void | setMaxPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set max pixel value. More... | |
virtual void | setNullPixelValue (ossim_uint32 band, const ossim_float64 &pix) |
convenience method to set null pixel value. More... | |
virtual ossim_uint32 | getCurrentEntry () const |
virtual ossim_uint32 | getNumberOfEntries () const |
virtual void | getEntryName (ossim_uint32 entryIdx, std::string &name) const |
Get the name of entry as a string. More... | |
virtual void | getEntryList (std::vector< ossim_uint32 > &entryList) const |
virtual void | getEntryNames (std::vector< ossimString > &entryNames) const |
bool | useEntryIndex () const |
Convenience method to determine if entry index should be used for support files, e.g. More... | |
ossimFilename | getOverviewFile () const |
ossimFilename | getFilenameWithThisExtension (const ossimString &ext, bool set_e0_prefix=false) const |
Returns the image file with extension set using supplentary directory for dirname if set. More... | |
void | getFilenameWithThisExt (const ossimString &ext, ossimFilename &f) const |
ossim_uint32 | getStartingResLevel () const |
void | setStartingResLevel (ossim_uint32 level) |
bool | getOpenOverviewFlag () const |
void | setOpenOverviewFlag (bool flag) |
Sets theOpenOverviewFlag. More... | |
virtual void | setSupplementaryDirectory (const ossimFilename &dir) |
Sets the supplementary directory. More... | |
virtual const ossimFilename & | getSupplementaryDirectory () const |
Returns the supplementary directory. More... | |
const ossimString & | getImageID () const |
Fetches the image ID. More... | |
void | setImageID (const ossimString &id) |
Sets the image ID in case it is externally generated. More... | |
ossimPixelType | getPixelType () const |
Returns the raster pixel alignment type. More... | |
virtual bool | getRgbBandList (std::vector< ossim_uint32 > &bandList) const |
Convenience method to get the zero based rgb output band list. More... | |
template<class T > | |
std::shared_ptr< T > | getStateAs () |
std::shared_ptr< const T > | getStateAs () const |
std::shared_ptr< ossim::ImageHandlerState > | getState () |
std::shared_ptr< const ossim::ImageHandlerState > | getState () const |
void | setState (std::shared_ptr< ossim::ImageHandlerState > state) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
Initializes bandList. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimViewInterface () | |
ossimViewInterface (ossimObject *base) | |
virtual | ~ossimViewInterface () |
virtual void | refreshView () |
ossimObject * | getBaseObject () |
Private Attributes | |
ossimRefPtr< ossimGdalOgrVectorAnnotation > | theAnnotationSource |
enum | ossimImageHandlerOverviewCompressionType { OSSIM_OVERVIEW_COMPRESSION_NONE = 0, OSSIM_OVERVIEW_COMPRESSION_JPEG, OSSIM_OVERVIEW_COMPRESSION_LZW, OSSIM_OVERVIEW_COMPRESSION_DEFLATE, OSSIM_OVERVIEW_COMPRESSION_PACKBITS } |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
virtual ossimRefPtr< ossimImageGeometry > | getExternalImageGeometry () const |
virtual bool | getOverviewTile (ossim_uint32 resLevel, ossimImageData *result) |
Method to get an overview tile. More... | |
bool | initVertices (const char *file) |
Opens file and attempts to initialize the valid image vertices. More... | |
virtual void | completeOpen () |
Will complete the opening process. More... | |
void | initImageParameters (ossimImageGeometry *geom) const |
Convenience method to set things needed in the image geometry from the image handler. More... | |
virtual void | establishDecimationFactors () |
Virtual method determines the decimation factors at each resolution level. More... | |
virtual bool | setOutputBandList (const std::vector< ossim_uint32 > &inBandList, std::vector< ossim_uint32 > &outBandList) |
Convenience method to set output band list. More... | |
void | getFilenameWithNoExtension (ossimFilename &f) const |
Get filename with no extension, using supplentary directory for dirname if set. More... | |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
ossimFilename | theImageFile |
ossimFilename | theOverviewFile |
ossimFilename | theSupplementaryDirectory |
ossimRefPtr< ossimImageHandler > | theOverview |
vector< ossimIpt > | theValidImageVertices |
ossimImageMetaData | theMetaData |
ossimRefPtr< ossimImageGeometry > | theGeometry |
ossimRefPtr< ossimNBandLutDataObject > | theLut |
std::vector< ossimDpt > | theDecimationFactors |
ossimString | theImageID |
ossim_uint32 | theStartingResLevel |
theStartingResLevel If set to something other than zero(default) this is indicative that the reader is an overview. More... | |
bool | theOpenOverviewFlag |
If true opening of overviews will be attempted. More... | |
ossimPixelType | thePixelType |
std::shared_ptr< ossim::ImageHandlerState > | m_state |
bool | theEnableFlag |
bool | theInitializedFlag |
ossimId | theId |
ossimString | theDescription |
ossimObject * | theOwner |
bool | theInputListIsFixedFlag |
Indicates whether the theInputObjectList is fixed. More... | |
bool | theOutputListIsFixedFlag |
Indicates whether the theOutputObjectList is fixed. More... | |
ConnectableObjectList | theInputObjectList |
Holds a list of input objects. More... | |
ConnectableObjectList | theOutputObjectList |
Holds a list of output objects. More... | |
std::list< ossimListener * > | theListenerList |
bool | theEnabledFlag |
std::list< ossimListener * > | theDelayedAdd |
std::list< ossimListener * > | theDelayedRemove |
bool | theFireEventFlag |
ossimErrorCode | theErrorStatus |
ossimObject * | theObject |
Definition at line 40 of file ossimOgrGdalTileSource.h.
ossimOgrGdalTileSource::ossimOgrGdalTileSource | ( | ) |
Definition at line 25 of file ossimOgrGdalTileSource.cpp.
References OSSIM_PIXEL_IS_AREA, theAnnotationSource, ossimViewInterface::theObject, and ossimImageHandler::thePixelType.
Definition at line 39 of file ossimOgrGdalTileSource.cpp.
References close(), and ossimViewInterface::theObject.
Definition at line 106 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::close(), and theAnnotationSource.
Referenced by ~ossimOgrGdalTileSource().
Implements ossimEsriShapeFileInterface.
Definition at line 237 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getFeatureTable(), theAnnotationSource, and ossimRefPtr< T >::valid().
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. Note that rrds 0 is the highest resolution rrds.
Definition at line 156 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getBoundingRect(), and theAnnotationSource.
Returns the tile width of the image or 0 if the image is not tiled. Note: this is not the same as the ossimImageSource::getTileWidth which returns the output tile width which can be different than the internal image tile width on disk.
Implements ossimImageHandler.
Definition at line 94 of file ossimOgrGdalTileSource.cpp.
Definition at line 89 of file ossimOgrGdalTileSource.cpp.
The geometry contains full-to-local image transform as well as projection (image-to-world)
Definition at line 99 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getImageGeometry(), theAnnotationSource, and ossimImageHandler::theGeometry.
Definition at line 191 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getMaxPixelValue(), and theAnnotationSource.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 186 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getMinPixelValue(), and theAnnotationSource.
Definition at line 181 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getNullPixelValue(), and theAnnotationSource.
Returns the number of reduced resolution data sets (rrds).
Note: Shape files should never have reduced res sets so this method is returns "8" to avoid the question of "Do you want to build res sets".
Definition at line 151 of file ossimOgrGdalTileSource.cpp.
Returns the number of bands in the image. Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 117 of file ossimOgrGdalTileSource.cpp.
References ossimAnnotationSource::getNumberOfOutputBands(), and theAnnotationSource.
Definition at line 127 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getBoundingRect(), ossimIrect::hasNans(), ossimIrect::height(), theAnnotationSource, ossimIrect::ul(), and ossimIpt::x.
Returns the number of bands in a tile returned from this TileSource. Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 122 of file ossimOgrGdalTileSource.cpp.
Returns the number of bands available from an image. Satisfies pure virtual from ImageHandler class.
Definition at line 139 of file ossimOgrGdalTileSource.cpp.
Definition at line 161 of file ossimOgrGdalTileSource.cpp.
References ossimAnnotationSource::getOutputScalarType(), and theAnnotationSource.
Definition at line 219 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getProperty(), theAnnotationSource, and ossimRefPtr< T >::valid().
Definition at line 229 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getPropertyNames(), theAnnotationSource, and ossimRefPtr< T >::valid().
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. Satisfies pure virtual from TileSource class.
Definition at line 111 of file ossimOgrGdalTileSource.cpp.
References ossimAnnotationSource::getTile(), and theAnnotationSource.
Returns the height of the output tile.
Definition at line 171 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getTileHeight(), and theAnnotationSource.
Returns the width of the output tile.
Definition at line 166 of file ossimOgrGdalTileSource.cpp.
References ossimImageSource::getTileWidth(), and theAnnotationSource.
Implements ossimViewInterface.
Definition at line 196 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::getView(), and theAnnotationSource.
Definition at line 201 of file ossimOgrGdalTileSource.cpp.
Definition at line 176 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::isOpen(), and theAnnotationSource.
Definition at line 70 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::loadState(), ossimImageHandler::loadState(), open(), OSSIM_PIXEL_IS_AREA, theAnnotationSource, ossimImageHandler::thePixelType, and ossimRefPtr< T >::valid().
Definition at line 49 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::open(), theAnnotationSource, and ossimImageHandler::theImageFile.
Referenced by loadState().
Definition at line 57 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::saveState(), ossimImageHandler::saveState(), theAnnotationSource, and ossimRefPtr< T >::valid().
entryIdx | Entry number to select. |
Definition at line 262 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::setCurrentEntry(), theAnnotationSource, and ossimRefPtr< T >::valid().
Definition at line 254 of file ossimOgrGdalTileSource.cpp.
References distance(), ossimGdalOgrVectorAnnotation::setGeometryBuffer(), theAnnotationSource, and ossimRefPtr< T >::valid().
Definition at line 211 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::setProperty(), theAnnotationSource, and ossimRefPtr< T >::valid().
Definition at line 246 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::setQuery(), theAnnotationSource, and ossimRefPtr< T >::valid().
This will transform the shape file points to the view passed in.
baseObject | This can be a ossimProjection or an ossimImageProjectionModel. If ossimImageProjectionModel this will transform world points to line sample; then, convert any line sample to the correct target rrds point. The target rrds is set via ossimImageModel::setTargetRrds. |
ownsItFlag | If true the memory will be handled for baseObject by the underlying code. |
Definition at line 206 of file ossimOgrGdalTileSource.cpp.
References ossimGdalOgrVectorAnnotation::setView(), and theAnnotationSource.
private |
Definition at line 202 of file ossimOgrGdalTileSource.h.
Referenced by close(), getFeatureTable(), getImageRectangle(), getInternalImageGeometry(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfOutputBands(), getNumberOfSamples(), getOutputScalarType(), getProperty(), getPropertyNames(), getTile(), getTileHeight(), getTileWidth(), getView(), isOpen(), loadState(), open(), ossimOgrGdalTileSource(), saveState(), setCurrentEntry(), setGeometryBuffer(), setProperty(), setQuery(), and setView().
