10 #ifndef ossimPointCloudImageSource_HEADER 11 #define ossimPointCloudImageSource_HEADER 22 class ossimTiffOverviewTileSource;
23 class ossimPoinCloudHandler;
38 enum Components { INTENSITY=0, HIGHEST, LOWEST, RETURNS,
RGB, NUM_COMPONENTS };
59 virtual bool isOpen()
const {
return m_pch.valid(); }
149 void getEntryList(std::vector<ossim_uint32>& entryList)
const override;
151 void getEntryNames(std::vector<ossimString>& entryNames)
const override;
236 void addSample(std::map<ossim_int32, PcrBucket*>& accumulator,
240 void normalize(std::map<ossim_int32, PcrBucket*>& accumulator);
virtual bool open()=0
Pure virtual open.
ossimRefPtr< ossimPointCloudHandler > m_pch
ossimRefPtr< ossimImageData > m_tile
virtual void getEntryNames(std::vector< ossimString > &entryNames) const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
Class used for rendering point cloud data into a raster tile.
std::vector< ossimString > m_componentNames
virtual bool isOpen() const
is open method.
virtual ossimString getShortName() const
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
Retuns the min pixel value.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual ossim_uint32 getImageTileHeight() const =0
unsigned int ossim_uint32
virtual ossimString getLongName() const
virtual void close()
virtual ossim_uint32 getCurrentEntry() const
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
virtual ossim_uint32 getImageTileWidth() const =0
Components m_activeComponent
ossim_float64 m_gsdFactor
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual void getValidImageVertices(vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const
ordering specifies how the vertices should be arranged.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
Base class for all point-cloud file readers.
virtual ossim_uint32 getNumberOfInputBands() const =0
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
