Classes | Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimPointCloudImageHandler Class Reference
Class used for rendering point cloud data into a raster tile. More...
#include <ossimPointCloudImageHandler.h>
Inheritance diagram for ossimPointCloudImageHandler:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Classes
class  PcrBucket
Public Types
enum  Components {
  INTENSITY =0, HIGHEST, LOWEST, RETURNS,
  RGB, NUM_COMPONENTS
 ossimPointCloudImageHandler ()
virtual ~ossimPointCloudImageHandler ()
virtual bool open ()
 open method. More...
virtual bool isOpen () const
 is open method. More...
virtual void close ()
 Close method. More...
ossimRefPtr< ossimImageDatagetTile (const ossimIrect &rect, ossim_uint32 resLevel=0) override
 Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More...
bool getTile (ossimImageData *result, ossim_uint32 resLevel=0) override
 Method to get a tile. More...
ossim_uint32 getNumberOfInputBands () const override
 Gets bands. More...
ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const override
 Gets lines. More...
ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const override
 Gets samples. More...
ossim_uint32 getImageTileWidth () const override
 Gets tile width. More...
ossim_uint32 getImageTileHeight () const override
 Gets tile height. More...
ossim_uint32 getTileWidth () const override
ossim_uint32 getTileHeight () const override
ossimScalarType getOutputScalarType () const override
void getEntryList (std::vector< ossim_uint32 > &entryList) const override
 Gets entry list. More...
void getEntryNames (std::vector< ossimString > &entryNames) const override
ossim_uint32 getCurrentEntry () const override
bool setCurrentEntry (ossim_uint32 entryIdx) override
ossimString getShortName () const override
ossimString getLongName () const override
ossimRefPtr< ossimImageGeometrygetImageGeometry () override
double getMinPixelValue (ossim_uint32 band) const override
double getMaxPixelValue (ossim_uint32 band) const override
double getNullPixelValue (ossim_uint32 band) const override
ossim_uint32 getNumberOfDecimationLevels () const override
bool saveState (ossimKeywordlist &kwl, const char *prefix) const override
bool loadState (const ossimKeywordlist &kwl, const char *prefix) override
void getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering, ossim_uint32 resLevel) const override
void setProperty (ossimRefPtr< ossimProperty > property) override
 The reader properties are: – the GSD ("meters_per_pixel") which overrides computed nominal GSD – the GSD factor ("gsd_factor") scales the computed nominal GSD, defaults to 1.0. More...
ossimRefPtr< ossimPropertygetProperty (const ossimString &name) const override
bool setPointCloudHandler (ossimPointCloudHandler *pch)
 Permits backdoor for setting the input point cloud handler object. More...
void getGSD (ossimDpt &gsd, ossim_uint32 resLevel) const
 Get the GSD for resLevel. More...
void setGSD (const ossim_float64 &gsd)
 Sets m_gsd data member and projection if projection is set. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
void initTile ()
void addSample (std::map< ossim_int32, PcrBucket *> &accumulator, ossim_int32 index, const ossimPointRecord *sample)
void normalize (std::map< ossim_int32, PcrBucket *> &accumulator)
ossim_uint32 componentToFieldCode () const
virtual void completeOpen ()
virtual ~ossimReferenced ()
ossimRefPtr< ossimPointCloudHandlerm_pch
ossim_float32 m_maxPixel
ossim_float32 m_minPixel
ossimDpt m_gsd
ossim_float64 m_gsdFactor
std::mutex m_mutex
Components m_activeComponent
std::vector< ossimStringm_componentNames
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
It is derived from ossimImageHandler so that it can be included in the available file formats for reading as maintained by the ossimImageHandlerRegistry. This base class implementation exposes the data elements represented by the base-class ossimPointCloudSource and the individual point base-class ossimPointCloudRecord, namely, intensity, RGB color, elevation, and number of returns.
For sensor systems providing additional renderable data items, a derived class will be required to expose those components.
Definition at line 35 of file ossimPointCloudImageHandler.h.
◆ Components
◆ ossimPointCloudImageHandler()
ossimPointCloudImageHandler::ossimPointCloudImageHandler ( )
Definition at line 81 of file ossimPointCloudImageHandler.cpp.
References m_componentNames, m_gsd, and ossimDpt::makeNan().
83  m_maxPixel(1.0),
84  m_minPixel(0.0),
85  m_gsd(),
86  m_gsdFactor (1.0),
87  m_tile(0),
88  m_mutex(),
90 {
91  //---
92  // Nan out as can be set in several places, i.e. setProperty,
93  // loadState and initProjection.
94  //---
95  m_gsd.makeNan();
96
97  m_componentNames.emplace_back(INTENSITY_KW);
98  m_componentNames.emplace_back(HIGHEST_KW);
99  m_componentNames.emplace_back(LOWEST_KW);
100  m_componentNames.emplace_back(RETURNS_KW);
101  m_componentNames.emplace_back(RGB_KW);
102 }
ossimRefPtr< ossimImageData > m_tile
std::vector< ossimString > m_componentNames
ossimImageHandler()
Constructor (default):
void makeNan()
Definition: ossimDpt.h:65
◆ ~ossimPointCloudImageHandler()
ossimPointCloudImageHandler::~ossimPointCloudImageHandler ( )
virtual
Definition at line 104 of file ossimPointCloudImageHandler.cpp.
References close().
105 {
106  close();
107 }
virtual void close()
Close method.
Member Function Documentation
◆ addSample()
void ossimPointCloudImageHandler::addSample ( std::map< ossim_int32, PcrBucket *> &  accumulator,
ossim_int32  index,
const ossimPointRecord sample
protected
Definition at line 354 of file ossimPointCloudImageHandler.cpp.
References ossimPointRecord::Blue, ossimPointRecord::getField(), ossimPointRecord::getPosition(), ossimPointRecord::Green, ossimGpt::hgt, HIGHEST, ossimPointRecord::Intensity, INTENSITY, LOWEST, m_activeComponent, ossimPointCloudImageHandler::PcrBucket::m_bucket, ossimPointRecord::NumberOfReturns, ossimPointRecord::Red, RETURNS, and RGB.
Referenced by getTile().
357 {
358  if (sample == 0)
359  return;
360
361  //cout << "sample: "<<*sample<<endl;//TODO: REMOVE DEBUG
362
363  // Search map for exisiting point in that location:
364  auto iter = accumulator.find(index);
365  if (iter == accumulator.end())
366  {
367  // First hit. Initialize location with current sample:
369  {
370  accumulator[index] = new PcrBucket(sample->getField(ossimPointRecord::Intensity));
371  }
372  else if (m_activeComponent == RGB)
373  {
374  ossim_float32 color[3];
375  color[0] = sample->getField(ossimPointRecord::Red);
376  color[1] = sample->getField(ossimPointRecord::Green);
377  color[2] = sample->getField(ossimPointRecord::Blue);
378  accumulator[index] = new PcrBucket(color, 3);
379  }
380  else if ((m_activeComponent == LOWEST) || (m_activeComponent == HIGHEST))
381  accumulator[index] = new PcrBucket(sample->getPosition().hgt);
382  else if (m_activeComponent == RETURNS)
383  accumulator[index] = new PcrBucket(sample->getField(ossimPointRecord::NumberOfReturns));
384  }
385  else
386  {
387  // Not the first hit at this location, accumulate:
388  // First hit. Initialize location with current sample:
390  {
391  iter->second->m_bucket[0] += sample->getField(ossimPointRecord::Intensity);
392  }
393  else if (m_activeComponent == RGB)
394  {
395  iter->second->m_bucket[0] += sample->getField(ossimPointRecord::Red);
396  iter->second->m_bucket[1] += sample->getField(ossimPointRecord::Green);
397  iter->second->m_bucket[2] += sample->getField(ossimPointRecord::Blue);
398  }
399  else if ((m_activeComponent == HIGHEST) &&
400  (sample->getPosition().hgt > iter->second->m_bucket[0]))
401  iter->second->m_bucket[0] = sample->getPosition().hgt;
402  else if ((m_activeComponent == LOWEST) &&
403  (sample->getPosition().hgt < iter->second->m_bucket[0]))
404  iter->second->m_bucket[0] = sample->getPosition().hgt;
405  else if (m_activeComponent == RETURNS)
406  iter->second->m_bucket[0] += sample->getField(ossimPointRecord::NumberOfReturns);
407
408  iter->second->m_numSamples++;
409  }
410 }
float ossim_float32
ossim_float32 getField(FIELD_CODES fc) const
Return the float value of the requested field.
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
const ossimGpt & getPosition() const
Returns the 3D position vector in the dataset&#39;s coodinate reference system (available from the ossimP...
◆ close()
void ossimPointCloudImageHandler::close ( )
virtual
Close method.
Definition at line 145 of file ossimPointCloudImageHandler.cpp.
References ossimPointCloudHandler::close(), ossimImageHandler::close(), isOpen(), m_pch, and m_tile.
Referenced by open(), setPointCloudHandler(), and ~ossimPointCloudImageHandler().
146 {
147  if (isOpen())
148  {
149  m_pch->close();
150  m_tile = 0;
152  }
153 }
ossimRefPtr< ossimPointCloudHandler > m_pch
virtual bool isOpen() const
is open method.
virtual void close()=0
Closes the point cloud file(s).
◆ componentToFieldCode()
ossim_uint32 ossimPointCloudImageHandler::componentToFieldCode ( ) const
protected
◆ getCurrentEntry()
ossim_uint32 ossimPointCloudImageHandler::getCurrentEntry ( ) const
overridevirtual
Returns
The current entry number.
Definition at line 522 of file ossimPointCloudImageHandler.cpp.
References m_activeComponent.
523 {
525 }
unsigned int ossim_uint32
◆ getEntryList()
void ossimPointCloudImageHandler::getEntryList ( std::vector< ossim_uint32 > &  entryList) const
overridevirtual
Gets entry list.
This list reflects the data component entry list provided by the derived point-cloud handler. This base class understands the basic (LIDAR-biased) entries: "Intensity", "RGB", "Elevation", and "Return". If a sensor provides other components, then a derived image handler will be needed to rasterize that data channel as well.
Parameters
entryListThis is the list to initialize with entry indexes.
Definition at line 508 of file ossimPointCloudImageHandler.cpp.
References m_componentNames.
509 {
510  entryList.clear();
511  for (ossim_uint32 i = 0; i < m_componentNames.size(); i++)
512  {
513  entryList.emplace_back(i);
514  }
515 }
◆ getEntryNames()
void ossimPointCloudImageHandler::getEntryNames ( std::vector< ossimString > &  entryNames) const
overridevirtual
Parameters
getEntryNamesList to initialize with strings associated with entries.
Note
This implementation calls getEntryList and converts entries in the list to strings. Derived classes that support multiple entries with associated strings should re-implement.
Definition at line 517 of file ossimPointCloudImageHandler.cpp.
518 {
519  entryNames = m_componentNames;
520 }
◆ getGSD()
void ossimPointCloudImageHandler::getGSD ( ossimDpt gsd,
) const
Definition at line 616 of file ossimPointCloudImageHandler.cpp.
References m_gsd, ossimDpt::x, and ossimDpt::y.
Referenced by getTile(), and writeRaster().
617 {
618  // std::pow(2.0, 0) returns 1.
619  ossim_float64 d = std::pow(2.0, static_cast<double>(resLevel));
620  gsd.x = m_gsd.x * d;
621  gsd.y = m_gsd.y * d;
622 }
double y
Definition: ossimDpt.h:165
double ossim_float64
double x
Definition: ossimDpt.h:164
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimPointCloudImageHandler::getImageGeometry ( )
overridevirtual
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 155 of file ossimPointCloudImageHandler.cpp.
References ossimEpsgProjectionFactory::createProjection(), ossimPointCloudHandler::getBounds(), ossimImageHandler::getExternalImageGeometry(), ossimPointCloudSource::getNumPoints(), ossimDpt::hasNans(), ossimGrect::heightMeters(), ossimEpsgProjectionFactory::instance(), isOpen(), m_gsd, m_gsdFactor, m_pch, ossimDpt::makeNan(), setGSD(), ossimMapProjection::setOrigin(), ossimImageGeometry::setProjection(), ossimMapProjection::setUlTiePoints(), ossimImageHandler::theGeometry, ossimGrect::ul(), ossimRefPtr< T >::valid(), and ossimGrect::widthMeters().
Referenced by ossimPointCloudTool::loadPC(), open(), and setPointCloudHandler().
156 {
157  if (!isOpen())
158  return 0;
159
160  if (theGeometry.valid())
161  return theGeometry;
162
163  // Check for external geom (i.e., a *.geom file)
165  if (theGeometry.valid())
166  return theGeometry;
167
169  ossimString epsgCode ("EPSG:4326");
170  ossimMapProjection* proj = dynamic_cast<ossimMapProjection*>( // NOLINT
172  if (!proj)
173  return 0;
174  theGeometry->setProjection(proj);
175
176  // Need to establish image bounds and optimal GSD given ground rect. Use this switch to also
177  // initialize the UL tiepoint of image projection:
178  ossimGrect bounds;
179  m_pch->getBounds(bounds);
180  proj->setOrigin(bounds.ul());
181  proj->setUlTiePoints(bounds.ul());
182
183  // The GSD depends on the point density on the ground. count all final returns and
184  // assume they are evenly distributed over the bounding ground rect. Note that this can have
185  // up to a sqrt(2)X error if the collection was taken in a cardinal-diagonal direction.
186  // Also use this point loop to latch the ground quad vertices vertices.
187  ossim_uint32 numPulses = m_pch->getNumPoints(); // count of final returns
188  if (numPulses == 0)
189  {
190  // Not yet determined. Set GSD to NAN and expect it will be set later:
191  m_gsd.makeNan();
192  }
193  else if (m_gsd.hasNans())
194  {
195  ossimDpt delta (bounds.widthMeters(), bounds.heightMeters());
196  ossim_float64 gsd = sqrt(delta.x * delta.y / numPulses) * m_gsdFactor;
197  setGSD(gsd); // also recomputes the image size
198  }
199
200  return theGeometry;
201 }
ossimRefPtr< ossimImageGeometry > theGeometry
virtual ossim_uint32 getNumPoints() const =0
Returns the total number of points in the dataset (not just the block returned in getPoints) ...
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool valid() const
Definition: ossimRefPtr.h:75
virtual void setOrigin(const ossimGpt &origin)
Sets theOrigin to origin.
virtual void getBounds(ossimGrect &bounds) const
is open method.
ossim_float64 widthMeters() const
Returns the width of a rectangle in meters using the center lat for scaling EW direction.
Definition: ossimGrect.cpp:292
void setGSD(const ossim_float64 &gsd)
const ossimGpt & ul() const
Definition: ossimGrect.h:252
bool hasNans() const
Definition: ossimDpt.h:67
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
STUB. Not implemented.
ossim_float64 heightMeters() const
Returns the height of a rectangle in meters.
Definition: ossimGrect.cpp:286
virtual void setUlTiePoints(const ossimGpt &gpt)
static ossimEpsgProjectionFactory * instance()
Implements singleton pattern.
void makeNan()
◆ getImageTileHeight()
ossim_uint32 ossimPointCloudImageHandler::getImageTileHeight ( ) const
overridevirtual
Gets tile height.
Satisfies ossimImageHandler::getImageTileHeight pure virtual.
Returns
The tile width of the image or 0 if the image is not tiled. Note: this is not the same as the ossimImageSource::getTileWidth which returns the output tile width which can be different than the internal image tile width on disk.
Implements ossimImageHandler.
Definition at line 484 of file ossimPointCloudImageHandler.cpp.
References getTileHeight().
485 {
486  return getTileHeight();
487 }
ossim_uint32 getTileHeight() const override
◆ getImageTileWidth()
ossim_uint32 ossimPointCloudImageHandler::getImageTileWidth ( ) const
overridevirtual
Gets tile width.
Satisfies ossimImageHandler::getImageTileWidth pure virtual.
Returns
Definition at line 479 of file ossimPointCloudImageHandler.cpp.
References getTileWidth().
480 {
481  return getTileWidth();
482 }
ossim_uint32 getTileWidth() const override
◆ getLongName()
ossimString ossimPointCloudImageHandler::getLongName ( ) const
overridevirtual
Returns
"ossim point cloud to image renderer"
Definition at line 565 of file ossimPointCloudImageHandler.cpp.
566 {
567  return ossimString("ossim point cloud to image renderer");
568 }
◆ getMaxPixelValue()
double ossimPointCloudImageHandler::getMaxPixelValue ( ossim_uint32  band) const
overridevirtual
Returns
Min pixel value.
Definition at line 575 of file ossimPointCloudImageHandler.cpp.
References m_maxPixel.
Referenced by initTile().
576 {
577  return m_maxPixel;
578 }
◆ getMinPixelValue()
double ossimPointCloudImageHandler::getMinPixelValue ( ossim_uint32  band) const
overridevirtual
Returns
Min pixel value.
Definition at line 570 of file ossimPointCloudImageHandler.cpp.
References m_minPixel.
571 {
572  return m_minPixel;
573 }
◆ getNullPixelValue()
double ossimPointCloudImageHandler::getNullPixelValue ( ossim_uint32  band) const
overridevirtual
Returns
Min pixel value.
Definition at line 580 of file ossimPointCloudImageHandler.cpp.
References OSSIM_DEFAULT_NULL_PIX_FLOAT.
581 {
583 }
#define OSSIM_DEFAULT_NULL_PIX_FLOAT
◆ getNumberOfDecimationLevels()
ossim_uint32 ossimPointCloudImageHandler::getNumberOfDecimationLevels ( ) const
overridevirtual
Returns
The total number of decimation levels.
Definition at line 585 of file ossimPointCloudImageHandler.cpp.
References getNumberOfLines(), and getNumberOfSamples().
586 {
587  // Can support any number of rlevels.
588  ossim_uint32 result = 1;
589  const ossim_uint32 STOP_DIMENSION = 16;
590  ossim_uint32 largestImageDimension =
592  while (largestImageDimension > STOP_DIMENSION)
593  {
594  largestImageDimension /= 2;
595  ++result;
596  }
597  return result;
598 }
ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const override
Gets samples.
ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const override
Gets lines.
◆ getNumberOfInputBands()
ossim_uint32 ossimPointCloudImageHandler::getNumberOfInputBands ( ) const
overridevirtual
Gets bands.
Satisfies ossimImageSource::getNumberOfInputBands pure virtual. Number of bands.
Implements ossimImageSource.
Definition at line 436 of file ossimPointCloudImageHandler.cpp.
References HIGHEST, INTENSITY, LOWEST, m_activeComponent, m_pch, RETURNS, RGB, and ossimRefPtr< T >::valid().
437 {
438  ossim_uint32 numBands = 0;
439  if (m_pch.valid())
440  {
442  numBands = 1;
443  else if (m_activeComponent == RGB)
444  numBands = 3;
445  else if ((m_activeComponent == LOWEST) || (m_activeComponent == HIGHEST))
446  numBands = 1;
447  else if (m_activeComponent == RETURNS)
448  numBands = 1;
449  }
450  return numBands;
451 }
bool valid() const
◆ getNumberOfLines()
ossim_uint32 ossimPointCloudImageHandler::getNumberOfLines ( ossim_uint32  resLevel = 0) const
overridevirtual
Gets lines.
Satisfies ossimImageHandler::getNumberOfLines pure virtual.
Parameters
resLevelReduced resolution level to return lines of. Default = 0
Returns
The number of lines for specified reduced resolution level.
Definition at line 453 of file ossimPointCloudImageHandler.cpp.
References ossimImageGeometry::getImageSize(), isOpen(), ossimIpt::line, ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
Referenced by getNumberOfDecimationLevels().
454 {
455  ossim_uint32 result = 0;
456  if (isOpen() && theGeometry.valid())
457  {
458  ossimIpt image_size(theGeometry->getImageSize());
459  result = image_size.line;
460  if (resLevel)
461  result = (result >> resLevel);
462  }
463  return result;
464 }
const ossimIpt & getImageSize() const
bool valid() const
is open method.
ossim_int32 line
Definition: ossimIpt.h:142
◆ getNumberOfSamples()
ossim_uint32 ossimPointCloudImageHandler::getNumberOfSamples ( ossim_uint32  resLevel = 0) const
overridevirtual
Gets samples.
Satisfies ossimImageHandler::getNumberOfSamples
Parameters
resLevelReduced resolution level to return samples of. Default = 0
Returns
The number of samples for specified reduced resolution level.
Definition at line 466 of file ossimPointCloudImageHandler.cpp.
References ossimImageGeometry::getImageSize(), isOpen(), ossimIpt::samp, ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
467 {
468  ossim_uint32 result = 0;
469  if (isOpen() && theGeometry.valid())
470  {
471  ossimIpt image_size(theGeometry->getImageSize());
472  result = image_size.samp;
473  if (resLevel)
474  result = (result >> resLevel);
475  }
476  return result;
477 }
bool valid() const
is open method.
ossim_int32 samp
Definition: ossimIpt.h:141
◆ getOutputScalarType()
ossimScalarType ossimPointCloudImageHandler::getOutputScalarType ( ) const
overridevirtual
Returns
The output pixel type of the tile source.
Definition at line 503 of file ossimPointCloudImageHandler.cpp.
References OSSIM_FLOAT32.
504 {
505  return OSSIM_FLOAT32;
506 }
32 bit floating point
◆ getProperty()
ossimRefPtr< ossimProperty > ossimPointCloudImageHandler::getProperty ( const ossimString name) const
overridevirtual
Definition at line 784 of file ossimPointCloudImageHandler.cpp.
References m_gsd, ossimKeywordNames::METERS_PER_PIXEL_KW, ossimString::toString(), and ossimDpt::x.
785 {
788  {
790  prop = new ossimStringProperty(name, value);
791  }
792  else if ( name == GSD_FACTOR_KW )
793  {
795  }
796  else if ( name == ossimKeywordNames::ENTRY_KW )
797  {
799  }
800  else if ( name == COMPONENT_KW )
801  {
803  }
804  else
805  {
806  prop = ossimImageHandler::getProperty(name);
807  }
808  return prop;
809 }
Numeric to string methods.
static const char * ENTRY_KW
static const char * METERS_PER_PIXEL_KW
double x
◆ getShortName()
ossimString ossimPointCloudImageHandler::getShortName ( ) const
overridevirtual
Returns
"point-cloud"
Definition at line 560 of file ossimPointCloudImageHandler.cpp.
561 {
562  return ossimString("Point Cloud Image Handler");
563 }
◆ getTile() [1/2]
ossimRefPtr< ossimImageData > ossimPointCloudImageHandler::getTile ( const ossimIrect rect,
overridevirtual
Satisfies pure virtual from TileSource class.
Definition at line 203 of file ossimPointCloudImageHandler.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), initTile(), m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Referenced by ossimPointCloudUtilityFilter::getTile().
205 {
206  if (!m_tile.valid())
207  initTile();
208
209  // Image rectangle must be set prior to calling getTile.
210  m_tile->setImageRectangle(tile_rect);
211  if (!getTile(m_tile.get(), resLevel))
212  {
214  m_tile->makeBlank();
215  }
216
217  return m_tile;
218 }
bool valid() const
ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0) override
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
virtual void makeBlank()
◆ getTile() [2/2]
bool ossimPointCloudImageHandler::getTile ( ossimImageData result,
overridevirtual
Parameters
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands()
Returns
true on success false on error. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 220 of file ossimPointCloudImageHandler.cpp.
References addSample(), ossimIrect::area(), ossimPointBlock::clear(), componentToFieldCode(), ossimPointCloudHandler::DEFAULT_BLOCK_SIZE, ossimPointCloudHandler::getBlock(), ossimDataObject::getDataObjectStatus(), ossimImageData::getFloatBuf(), getGSD(), ossimImageData::getImageRectangle(), ossimPointCloudHandler::getNextFileBlock(), ossimImageData::getNumberOfBands(), getNumberOfInputBands(), ossimPointCloudSource::getNumPoints(), ossimRectilinearDataObject::getScalarType(), ossimDpt::hasNans(), ossimIrect::height(), ossimIrect::lr(), m_gsd, m_pch, ossimImageData::makeBlank(), normalize(), OSSIM_DEFAULT_NULL_PIX_FLOAT, OSSIM_FLOAT32, OSSIM_NULL, ossimNotify(), ossimNotifyLevel_FATAL, ossimGrect::pointWithin(), ossimPointCloudHandler::rewind(), ossimImageGeometry::rnToWorld(), ossimPointBlock::setFieldCode(), ossimImageData::setNullPix(), ossimPointBlock::size(), ossimImageHandler::theGeometry, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimImageGeometry::worldToRn(), ossimIpt::x, ossimDpt::x, x, ossimIpt::y, ossimDpt::y, and y.
221 {
222  // check for all systems go and valid args:
223  if (!m_pch.valid() || !result || (result->getScalarType() != OSSIM_FLOAT32)
224  || (result->getDataObjectStatus() == OSSIM_NULL) || m_gsd.hasNans())
225  {
226  return false;
227  }
228
229  // Overviews achieved with GSD setting. This may be too slow.
230  ossimDpt gsd (m_gsd);
231  if (resLevel > 0)
232  getGSD(gsd, resLevel);
233
234  // Establish the ground and image rects for this tile:
235  const ossimIrect img_tile_rect = result->getImageRectangle();
236  const ossimIpt tile_offset (img_tile_rect.ul());
237  const ossim_uint32 tile_width = img_tile_rect.width();
238  const ossim_uint32 tile_height = img_tile_rect.height();
239  const ossim_uint32 tile_size = img_tile_rect.area();
240
241  ossimGpt gnd_ul, gnd_lr;
242  ossimDpt dpt_ul (img_tile_rect.ul().x - 0.5, img_tile_rect.ul().y - 0.5);
243  ossimDpt dpt_lr (img_tile_rect.lr().x + 0.5, img_tile_rect.lr().y + 0.5);
244  theGeometry->rnToWorld(dpt_ul, resLevel, gnd_ul);
245  theGeometry->rnToWorld(dpt_lr, resLevel, gnd_lr);
246  const ossimGrect gnd_rect (gnd_ul, gnd_lr);
247
248  // Create array of buckets to store accumulated point data.
249  ossim_uint32 numBands = result->getNumberOfBands();
250  if (numBands > getNumberOfInputBands())
251  {
252  // This should never happen;
254  << "ossimPointCloudImageHandler::getTile() ERROR: \n"
255  << "More bands were requested than was available from the point cloud source. Returning "
256  << "blank tile." << endl;
257  result->makeBlank();
258  return false;
259  }
260  std::map<ossim_int32, PcrBucket*> accumulator;
261
262  // initialize a point block with desired fields as requested in the reader properties
263  ossimPointBlock pointBlock (this);
264  pointBlock.setFieldCode(componentToFieldCode());
265  m_pch->rewind();
266
267  ossimDpt ipt;
268  ossimGpt pos;
269
270 #define USE_GETBLOCK
271 #ifdef USE_GETBLOCK
272  m_pch->getBlock(gnd_rect, pointBlock);
273  for (ossim_uint32 id=0; id<pointBlock.size(); ++id)
274  {
275  pos = pointBlock[id]->getPosition();
276  theGeometry->worldToRn(pos, resLevel, ipt);
277  ipt.x = ossim::round<double,double>(ipt.x) - tile_offset.x;
278  ipt.y = ossim::round<double,double>(ipt.y) - tile_offset.y;
279
280  ossim_int32 bucketIndex = ipt.y*tile_width + ipt.x;
281  if ((bucketIndex >= 0) && (bucketIndex < (ossim_int32)tile_size))
282  addSample(accumulator, bucketIndex, pointBlock[id]);
283  }
284
285 #else // using getFileBlock
286  ossim_uint32 numPoints = m_pch->getNumPoints();
289
290  // Loop to read all point blocks:
291  do
292  {
293  pointBlock.clear();
294  m_pch->getNextFileBlock(pointBlock, numPoints);
295  //m_pch->normalizeBlock(pointBlock);
296
297  for (ossim_uint32 id=0; id<pointBlock.size(); ++id)
298  {
299  // Check that each point in read block is inside the ROI before accumulating it:
300  pos = pointBlock[id]->getPosition();
301  if (gnd_rect.pointWithin(pos))
302  {
303  theGeometry->worldToRn(pos, resLevel, ipt);
304  ipt.x = ossim::round<double,double>(ipt.x) - tile_offset.x;
305  ipt.y = ossim::round<double,double>(ipt.y) - tile_offset.y;
306
307  ossim_int32 bucketIndex = ipt.y*tile_width + ipt.x;
308  if ((bucketIndex >= 0) && (bucketIndex < (ossim_int32)tile_size))
309  addSample(accumulator, bucketIndex, pointBlock[id]);
310  }
311  }
312  } while (pointBlock.size() == numPoints);
313 #endif
314
315  // Finished accumulating, need to normalize and fill the tile.
316  // We must always blank out the tile as we may not have a point for every pixel.
317  normalize(accumulator);
318  auto buf = new ossim_float32*[numBands];
319  std::map<ossim_int32, PcrBucket*>::iterator accum_iter;
321  result->setNullPix(null_pixel);
322  for (ossim_uint32 band = 0; band < numBands; band++)
323  {
324  ossim_uint32 index = 0;
325  buf[band] = result->getFloatBuf(band);
326  for (ossim_uint32 y = 0; y < tile_height; y++)
327  {
328  for (ossim_uint32 x = 0; x < tile_width; x++)
329  {
330  accum_iter = accumulator.find(index);
331  if (accum_iter != accumulator.end())
332  buf[band][index] = accum_iter->second->m_bucket[band];
333  else
334  buf[band][index] = null_pixel;
335  ++index;
336  }
337  }
338  }
339
340  delete [] buf;
341  buf = 0;
342
343  auto pcr_iter = accumulator.begin();
344  while (pcr_iter != accumulator.end())
345  {
346  delete pcr_iter->second;
347  pcr_iter++;
348  }
349
350  result->validate();
351  return true;
352 }
ossim_uint32 x
ossim_uint32 y
bool valid() const
float ossim_float32
double y
ossim_uint32 height() const
Definition: ossimIrect.h:487
const ossimIpt & ul() const
Definition: ossimIrect.h:274
void getGSD(ossimDpt &gsd, ossim_uint32 resLevel) const
virtual void setNullPix(ossim_float64 null_pix)
ossim_uint32 getNumberOfInputBands() const override
Gets bands.
static ossim_uint32 DEFAULT_BLOCK_SIZE
void addSample(std::map< ossim_int32, PcrBucket *> &accumulator, ossim_int32 index, const ossimPointRecord *sample)
virtual ossimIrect getImageRectangle() const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
void rnToWorld(const ossimDpt &rnPt, ossim_uint32 resolutionLevel, ossimGpt &wpt) const
rnToWorld is a utility method that takes a rn resolution image point and maps it to the world point...
void worldToRn(const ossimGpt &wpt, ossim_uint32 resolutionLevel, ossimDpt &rnPt) const
worldToRn is a utility method that takes a world point allows one to transform all the way back to an...
ossim_uint32 width() const
Definition: ossimIrect.h:500
virtual const ossim_float32 * getFloatBuf() const
virtual void getBlock(const ossimGrect &bounds, ossimPointBlock &block) const
Fetches the block of points inside the block bounds.
virtual void rewind() const
ossim_int32 y
ossim_uint32 area() const
Definition: ossimIrect.h:396
double x
ossim_int32 x
void normalize(std::map< ossim_int32, PcrBucket *> &accumulator)
virtual void getNextFileBlock(ossimPointBlock &block, ossim_uint32 maxNumPoints=0xFFFFFFFF) const
int ossim_int32
◆ getTileHeight()
ossim_uint32 ossimPointCloudImageHandler::getTileHeight ( ) const
overridevirtual
Returns
The height of the output tile.
Definition at line 496 of file ossimPointCloudImageHandler.cpp.
References ossim::defaultTileSize(), and ossimIpt::y.
Referenced by getImageTileHeight(), and initTile().
497 {
498  ossimIpt ipt;
500  return ipt.y;
501 }
OSSIM_DLL void defaultTileSize(ossimIpt &tileSize)
ossim_int32 y
◆ getTileWidth()
ossim_uint32 ossimPointCloudImageHandler::getTileWidth ( ) const
overridevirtual
Returns
The width of the output tile.
Definition at line 489 of file ossimPointCloudImageHandler.cpp.
References ossim::defaultTileSize(), and ossimIpt::x.
Referenced by getImageTileWidth(), and initTile().
490 {
491  ossimIpt ipt;
493  return ipt.x;
494 }
ossim_int32 x
◆ getValidImageVertices()
void ossimPointCloudImageHandler::getValidImageVertices ( std::vector< ossimIpt > &  validVertices,
) const
overridevirtual
ordering specifies how the vertices should be arranged.
valid image vertices is basically the tightly fit convex hull of the image. Usually an image has NULL values and are internally not upright rectangular. This can cause problems some spatial filters.
The default implementation is to return the bounding rect.
Definition at line 703 of file ossimPointCloudImageHandler.cpp.
References ossimPointCloudHandler::getBounds(), ossimGrect::ll(), ossimGrect::lr(), m_pch, OSSIM_COUNTERCLOCKWISE_ORDER, ossimImageHandler::theGeometry, ossimGrect::ul(), ossimGrect::ur(), ossimRefPtr< T >::valid(), and ossimImageGeometry::worldToLocal().
706 {
707  validVertices.clear();
708  if (!m_pch.valid())
709  return;
710  int divisor = 1;
711  if (resLevel)
712  divisor = resLevel<<1;
713
714  // Transform the world coords for the four vertices into image vertices:
715  ossimDpt r0Pt;
716  ossimGrect bounds;
717  m_pch->getBounds(bounds);
718  theGeometry->worldToLocal(bounds.ul(), r0Pt);
719  validVertices.emplace_back(r0Pt);
720  theGeometry->worldToLocal(bounds.ur(), r0Pt);
721  validVertices.emplace_back(r0Pt);
722  theGeometry->worldToLocal(bounds.lr(), r0Pt);
723  validVertices.emplace_back(r0Pt);
724  theGeometry->worldToLocal(bounds.ll(), r0Pt);
725  validVertices.emplace_back(r0Pt);
726
727  if (ordering == OSSIM_COUNTERCLOCKWISE_ORDER)
728  {
729  for (int i=3; i>=0; i--)
730  validVertices.emplace_back(validVertices[i]/divisor);
731  validVertices.erase(validVertices.begin(), validVertices.begin()+4);
732  }
733 }
bool valid() const
ossimGpt ur() const
Definition: ossimGrect.h:257
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
const ossimGpt & lr() const
Definition: ossimGrect.h:269
ossimGpt ll() const
Definition: ossimGrect.h:263
◆ initTile()
void ossimPointCloudImageHandler::initTile ( )
protected
Definition at line 600 of file ossimPointCloudImageHandler.cpp.
References getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), ossimImageSource::getNumberOfOutputBands(), getOutputScalarType(), getTileHeight(), getTileWidth(), ossimImageData::initialize(), m_tile, ossimImageData::setMaxPix(), ossimImageData::setMinPix(), and ossimImageData::setNullPix().
601 {
602  const ossim_uint32 BANDS = getNumberOfOutputBands();
603
605
606  for (ossim_uint32 band = 0; band < BANDS; ++band)
607  {
608  m_tile->setMinPix(getMinPixelValue(band), band);
609  m_tile->setMaxPix(getMaxPixelValue(band), band);
610  m_tile->setNullPix(getNullPixelValue(band), band);
611  }
612
613  m_tile->initialize();
614 }
ossimScalarType getOutputScalarType() const override
double getNullPixelValue(ossim_uint32 band) const override
virtual void initialize()
Initialize the data buffer.
double getMaxPixelValue(ossim_uint32 band) const override
double getMinPixelValue(ossim_uint32 band) const override
virtual void setMaxPix(ossim_float64 max_pix)
virtual void setMinPix(ossim_float64 min_pix)
◆ isOpen()
virtual bool ossimPointCloudImageHandler::isOpen ( ) const
inlinevirtual
is open method.
Satisfies ossimImageHandler::isOpen pure virtual.
Returns
true if open, false if not.
Definition at line 59 of file ossimPointCloudImageHandler.h.
Referenced by close(), getImageGeometry(), getNumberOfLines(), and getNumberOfSamples().
59 { return m_pch.valid(); }
bool valid() const
◆ loadState()
bool ossimPointCloudImageHandler::loadState ( const ossimKeywordlist kwl,
const char *  prefix
overridevirtual
Definition at line 669 of file ossimPointCloudImageHandler.cpp.
References ossimImageHandler::theDecimationFactors.
670 {
671  static const char MODULE[] = "ossimPointCloudImageHandler::loadState()";
672  theDecimationFactors.clear();
673  if(traceDebug())
674  ossimNotify(ossimNotifyLevel_DEBUG)<< MODULE << " DEBUG: entered ..."<< std::endl;
675
676  ossimImageHandler::loadState(kwl, prefix);
678  {
680  << "WARNING: error detected in keyword list! State not load." << std::endl;
681  return false;
682  }
683
685  ossimString value = kwl.find(prefix, ossimKeywordNames::ENTRY_KW);
686  if (!value.empty())
687  {
688  ossim_uint32 i = value.toUInt32();
689  if (i < NUM_COMPONENTS)
691  }
692
693  value = kwl.find(prefix, ossimKeywordNames::METERS_PER_PIXEL_KW);
694  if (!value.empty())
695  setGSD(value.toDouble());
696
697  // The rest of the state is established by opening the file:
698  bool good_open = open();
699
700  return good_open;
701 }
std::vector< ossimDpt > theDecimationFactors
static const ossimErrorCode OSSIM_ERROR
ossim_uint32 toUInt32() const
double toDouble() const
virtual ossimErrorCode getErrorStatus() const
bool empty() const
Definition: ossimString.h:411
◆ normalize()
void ossimPointCloudImageHandler::normalize ( std::map< ossim_int32, PcrBucket *> &  accumulator)
protected
Definition at line 412 of file ossimPointCloudImageHandler.cpp.
References HIGHEST, LOWEST, m_activeComponent, RETURNS, and RGB.
413 {
414  // highest and lowest elevations latch extremes, no mean is computed but needs to be normalized
417  return;
418
419  int numBands = 1;
420  if (m_activeComponent == RGB)
421  numBands = 3;
422
423  auto iter = accumulator.begin();
424  ossim_float32 avg;
425  while (iter != accumulator.end())
426  {
427  for (int i=0; i<numBands; i++)
428  {
429  avg = iter->second->m_bucket[i] / iter->second->m_numSamples;
430  iter->second->m_bucket[i] = avg;
431  }
432  iter++;
433  }
434 }
float ossim_float32
◆ open()
bool ossimPointCloudImageHandler::open ( )
virtual
open method.
Satisfies ossimImageHandler::open pure virtual.
Returns
Note
This method relies on the data member ossimImageData::theImageFile being set. Callers should do a "setFilename" prior to calling this method or use the ossimImageHandler::open that takes a file name and an entry index.
Definition at line 109 of file ossimPointCloudImageHandler.cpp.
References close(), ossimImageHandler::completeOpen(), getImageGeometry(), ossimPointCloudHandlerRegistry::instance(), m_activeComponent, m_pch, ossimPointCloudHandlerRegistry::open(), setCurrentEntry(), ossimImageHandler::theImageFile, and ossimRefPtr< T >::valid().
110 {
111  close();
112
113  // Need to utilize the Point Cloud handler registry to open the PC file:
115  if (!m_pch.valid())
116  return false;
117
120
121  // Needed here after open to make sure that min/max pixels are set for active component/entry
123
124  return true;
125 }
bool valid() const
virtual ossimPointCloudHandler * open(const ossimFilename &fileName) const
ossimRefPtr< ossimImageGeometry > getImageGeometry() override
bool setCurrentEntry(ossim_uint32 entryIdx) override
static ossimPointCloudHandlerRegistry * instance()
virtual void completeOpen()
Will complete the opening process.
Close method.
◆ saveState()
bool ossimPointCloudImageHandler::saveState ( ossimKeywordlist kwl,
const char *  prefix
) const
overridevirtual
Definition at line 651 of file ossimPointCloudImageHandler.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::ENTRY_KW, ossimErrorStatusInterface::getErrorStatus(), m_activeComponent, m_gsd, ossimKeywordNames::METERS_PER_PIXEL_KW, ossimErrorCodes::OSSIM_ERROR, ossimNotify(), ossimNotifyLevel_WARN, ossimImageHandler::saveState(), and ossimDpt::x.
652 {
653  static const char MODULE[] = "ossimPointCloudImageHandler::saveState()";
654
655  ossimImageHandler::saveState(kwl, prefix);
657  {
659  << " ERROR detected in keyword list! State not saved." << std::endl;
660  return false;
661  }
662
663  kwl.add(prefix, ossimKeywordNames::ENTRY_KW, (int) m_activeComponent, true);
665
666  return true;
667 }
double x
◆ setCurrentEntry()
bool ossimPointCloudImageHandler::setCurrentEntry ( ossim_uint32  entryIdx)
overridevirtual
Parameters
entryIdxEntry number to select.
Returns
true if it was able to set the current entry and false otherwise.
Definition at line 527 of file ossimPointCloudImageHandler.cpp.
References ossimPointRecord::getField(), ossimPointCloudHandler::getMaxPoint(), ossimPointCloudHandler::getMinPoint(), ossimPointRecord::getPosition(), ossimGpt::hgt, HIGHEST, ossimPointRecord::Intensity, INTENSITY, LOWEST, m_activeComponent, m_maxPixel, m_minPixel, m_pch, NUM_COMPONENTS, ossimPointRecord::NumberOfReturns, ossimPointRecord::Red, RETURNS, RGB, and ossimRefPtr< T >::valid().
Referenced by ossimPointCloudUtilityFilter::getTile(), open(), setPointCloudHandler(), and writeRaster().
528 {
529  if (entryIdx >= NUM_COMPONENTS)
530  return false;
531
532  m_activeComponent = (Components) entryIdx;
533  if (m_pch.valid() && m_pch->getMinPoint() && m_pch->getMaxPoint())
534  {
536  {
539  }
540  else if (m_activeComponent == RGB)
541  {
544  }
545  else if ((m_activeComponent == LOWEST) || (m_activeComponent == HIGHEST))
546  {
549  }
550  else if (m_activeComponent == RETURNS)
551  {
552  m_minPixel = 0;
554  }
555  }
556
557  return true;
558 }
bool valid() const
ossim_float64 hgt
virtual const ossimPointRecord * getMaxPoint() const
virtual const ossimPointRecord * getMinPoint() const
Assigns the two points with fields representing the extremes of the dataset.
◆ setGSD()
void ossimPointCloudImageHandler::setGSD ( const ossim_float64 gsd)
Definition at line 624 of file ossimPointCloudImageHandler.cpp.
References ossimPointCloudHandler::getBounds(), ossimImageGeometry::getProjection(), ossim::isnan(), ossimGrect::lr(), m_gsd, m_gsdFactor, m_pch, ossimImageGeometry::setImageSize(), ossimMapProjection::setMetersPerPixel(), ossimImageHandler::theGeometry, ossimGrect::ul(), ossimRefPtr< T >::valid(), ossimImageGeometry::worldToLocal(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by getImageGeometry(), and setProperty().
625 {
626  if (ossim::isnan(gsd) || (gsd<=0.0) || !theGeometry.valid())
627  return;
628
629  m_gsd = ossimDpt(gsd, gsd);
630  m_gsdFactor = 1.0; // resets after GSD adjusted
631
633  if (!proj)
634  return;
635
636  proj->setMetersPerPixel(m_gsd);
637
638  ossimGrect bounds;
639  m_pch->getBounds(bounds);
640
641  ossimDpt ipt_ul, ipt_lr;
642  theGeometry->worldToLocal(bounds.ul(), ipt_ul);
643  theGeometry->worldToLocal(bounds.lr(), ipt_lr);
644  ossimIpt image_size;
645  image_size.x = ossim::round<ossim_int32,double>(ipt_lr.x - ipt_ul.x) + 1;
646  image_size.y = ossim::round<ossim_int32,double>(ipt_lr.y - ipt_ul.y) + 1;
647
648  theGeometry->setImageSize(image_size);
649 }
bool valid() const
double y
void setImageSize(const ossimIpt &size)
virtual void setMetersPerPixel(const ossimDpt &gsd)
ossim_int32 y
double x
ossim_int32 x
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ setPointCloudHandler()
bool ossimPointCloudImageHandler::setPointCloudHandler ( ossimPointCloudHandler pch)
Useful for debug
Definition at line 127 of file ossimPointCloudImageHandler.cpp.
References close(), ossimImageHandler::completeOpen(), getImageGeometry(), m_activeComponent, m_pch, setCurrentEntry(), and ossimRefPtr< T >::valid().
Referenced by ossimDemTool::doOMG(), ossimPointCloudTool::loadPC(), and writeRaster().
128 {
129  close();
130
131  // Need to utilize the Point Cloud handler registry to open the PC file:
132  m_pch = pch;
133  if (!m_pch.valid())
134  return false;
135
138
139  // Needed here after open to make sure that min/max pixels are set for active component/entry
141
142  return true;
143 }
bool valid() const
Close method.
◆ setProperty()
void ossimPointCloudImageHandler::setProperty ( ossimRefPtr< ossimProperty property)
overridevirtual
– the active component as entry number ("entry") with possible values [0 - 4] corresponding to "component" property (listed below) – the active component ("component") as string with possible values "intensity", "highest", "lowest", "returns", or "rgb", respectively (case insensitive)
Definition at line 735 of file ossimPointCloudImageHandler.cpp.
References ossimString::empty(), ossimProperty::getName(), ossim::isnan(), ossimKeywordNames::METERS_PER_PIXEL_KW, setGSD(), ossimString::toFloat64(), and ossimRefPtr< T >::valid().
Referenced by writeRaster().
736 {
737  if (!property.valid())
738  return;
739
740  ossimString s;
741  property->valueToString(s);
742  if (s.empty())
743  return;
744
745  // The user should select either explicit GSD or relative GSD factor, never both:
746  if ( property->getName() == ossimKeywordNames::METERS_PER_PIXEL_KW )
747  {
748  ossim_float64 gsd = s.toFloat64();
749  if (!ossim::isnan(gsd))
750  setGSD(gsd);
751  }
752  else if ( property->getName() == GSD_FACTOR_KW )
753  {
754  m_gsdFactor = s.toDouble();
756  {
757  if (!m_gsd.hasNans())
759  }
760  else
761  m_gsdFactor = 1.0;
762  }
763  else if ( property->getName() == ossimKeywordNames::ENTRY_KW )
764  {
766  }
767  else if ( property->getName() == COMPONENT_KW )
768  {
769  for (int i=0; i<NUM_COMPONENTS; i++)
770  {
771  if (s.upcase() == m_componentNames[i])
772  {
774  break;
775  }
776  }
777  }
778  else
779  {
781  }
782 }
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
bool valid() const
ossim_float64 toFloat64() const
double x
bool empty() const
const ossimString & getName() const
Member Data Documentation
◆ m_activeComponent
Components ossimPointCloudImageHandler::m_activeComponent
protected
◆ m_componentNames
std::vector<ossimString> ossimPointCloudImageHandler::m_componentNames
protected
◆ m_gsd
ossimDpt ossimPointCloudImageHandler::m_gsd
protected
◆ m_gsdFactor
ossim_float64 ossimPointCloudImageHandler::m_gsdFactor
protected
Definition at line 248 of file ossimPointCloudImageHandler.h.
Referenced by getImageGeometry(), and setGSD().
◆ m_maxPixel
ossim_float32 ossimPointCloudImageHandler::m_maxPixel
protected
Definition at line 245 of file ossimPointCloudImageHandler.h.
Referenced by getMaxPixelValue(), and setCurrentEntry().
◆ m_minPixel
ossim_float32 ossimPointCloudImageHandler::m_minPixel
protected
Definition at line 246 of file ossimPointCloudImageHandler.h.
Referenced by getMinPixelValue(), and setCurrentEntry().
◆ m_mutex
std::mutex ossimPointCloudImageHandler::m_mutex
protected
Definition at line 250 of file ossimPointCloudImageHandler.h.
◆ m_pch
ossimRefPtr<ossimPointCloudHandler> ossimPointCloudImageHandler::m_pch
protected
◆ m_tile
ossimRefPtr<ossimImageData> ossimPointCloudImageHandler::m_tile
protected
Definition at line 249 of file ossimPointCloudImageHandler.h.
Referenced by close(), getTile(), and initTile().
