19 static const char* CURRENT_RLEVEL_KW =
"current_rlevel";
20 static const char* OVERRIDE_GEOMETRY_KW =
"override_geometry";
22 static ossimTrace traceDebug(
"ossimRLevelFilter:debug");
30 theOverrideGeometryFlag(false)
92 if ((!inputGeom) || (rlevel == 0) || (
getEnableFlag() ==
false))
118 decimation.
x = 1.0/decimation.
x;
119 decimation.
y = 1.0/decimation.
y;
149 <<
"ossimRLevelFilter::getSummedDecimation WARNING:" 150 <<
"\nNans returned from getDecimationFactor!" 162 <<
"ossimRLevelFilter::getSummedDecimation result: " << result
204 const char* current = kwl.
find(prefix, CURRENT_RLEVEL_KW);
205 const char*
override = kwl.
find(prefix, OVERRIDE_GEOMETRY_KW);
221 const char* prefix)
const 229 OVERRIDE_GEOMETRY_KW,
ossimRLevelFilter()
default constructor
This will return the bounding rect of the source.
void getSummedDecimation(ossimDpt &result) const
ossimRefPtr< ossimImageGeometry > m_ScaledGeometry
The input image geometry, altered by the scale.
ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns a pointer reference to the active image geometry at this filter.
virtual void setCurrentRLevel(ossim_uint32 rlevel)
virtual bool getOverrideGeometryFlag() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
void updateGeometry()
If this object is maintaining an ossimImageGeometry, this method needs to be called after a scale cha...
virtual void applyScale(const ossimDpt &scale, bool recenterTiePoint)
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: the...
virtual bool getEnableFlag() const
ossim_uint32 theCurrentRLevel
bool theOverrideGeometryFlag
bool toBool() const
String to numeric methods.
unsigned int ossim_uint32
virtual ~ossimRLevelFilter()
virtual destructor.
RTTI_DEF1(ossimRLevelFilter, "ossimRLevelFilter", ossimImageSourceFilter)
unsigned long toULong() const
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
Will return the decimation factor for the given resolution level.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
virtual void setOverrideGeometryFlag(bool override)
Returns the bounding rectangle.
virtual ossim_uint32 getCurrentRLevel() const
