ossimRLevelFilter Class Reference
#include <ossimRLevelFilter.h>
Inheritance diagram for ossimRLevelFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimRLevelFilter ()
 default constructor More...
ossimRefPtr< ossimImageGeometrygetImageGeometry ()
 Returns a pointer reference to the active image geometry at this filter. More...
virtual void setCurrentRLevel (ossim_uint32 rlevel)
virtual ossim_uint32 getCurrentRLevel () const
virtual bool getOverrideGeometryFlag () const
virtual void setOverrideGeometryFlag (bool override)
 Returns the bounding rectangle. More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual void initialize ()
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimRLevelFilter ()
 virtual destructor. More...
void getSummedDecimation (ossimDpt &result) const
void updateGeometry ()
 If this object is maintaining an ossimImageGeometry, this method needs to be called after a scale change so that the geometry's projection is modified accordingly. More...
virtual ~ossimReferenced ()
Protected Attributes
ossim_uint32 theCurrentRLevel
bool theOverrideGeometryFlag
ossimRefPtr< ossimImageGeometrym_ScaledGeometry
 The input image geometry, altered by the scale. More...
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
This filter is used to adjust the RLevel. If you would like to continually change between RLevels or Reslolutions then you can use this filter to do so. You can also specify whether or not the rLevel passed in from the getTile request is added to this classes current Rlevel. This is so if you concatenate multiple filters that reduce the RLevels then it will keep reducing. For example if I have 2 filters that both go to RLevel 1 then it actually will go to 2 since there are 2 decimations happening. This can be turned off by specifying the Rlevel not to be additive.
Definition at line 27 of file ossimRLevelFilter.h.
◆ ossimRLevelFilter()
ossimRLevelFilter::ossimRLevelFilter ( )
default constructor
Definition at line 27 of file ossimRLevelFilter.cpp.
31 {
32 }
ossimImageSourceFilter(ossimObject *owner=NULL)
◆ ~ossimRLevelFilter()
ossimRLevelFilter::~ossimRLevelFilter ( )
protectedvirtual
virtual destructor.
Definition at line 35 of file ossimRLevelFilter.cpp.
36 {
37 }
Member Function Documentation
◆ getBoundingRect()
ossimIrect ossimRLevelFilter::getBoundingRect ( ossim_uint32  resLevel = 0) const
virtual
Parameters
resLevelThis argument is only passed onto the input connection if this filter is disabled.
See also
disableSource().
To get the bounding rectangle of an rlevel when source is enabled do: myRLevelFilter->setCurrentRLevel(level); myRLevelFilter->getBoundingRect();
Returns
Rectangle of the current rlevel if enabled; else, the rectangle of the input connection for resLevel.
Definition at line 168 of file ossimRLevelFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimSource::isSourceEnabled(), ossimIrect::makeNan(), theCurrentRLevel, and ossimImageSourceFilter::theInputConnection.
169 {
170  ossimIrect rect;
171  rect.makeNan();
172  if(!theInputConnection) return rect;
173
174  if (isSourceEnabled())
175  {
177  }
178  return theInputConnection->getBoundingRect(resLevel);
179 }
This will return the bounding rect of the source.
void makeNan()
Definition: ossimIrect.h:329
◆ getCurrentRLevel()
ossim_uint32 ossimRLevelFilter::getCurrentRLevel ( ) const
virtual
Definition at line 72 of file ossimRLevelFilter.cpp.
References theCurrentRLevel.
Referenced by getImageGeometry(), and getSummedDecimation().
73 {
74  return theCurrentRLevel;
75 }
◆ getDecimationFactor()
void ossimRLevelFilter::getDecimationFactor ( ossim_uint32  resLevel,
ossimDpt result
) const
virtual
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 40 of file ossimRLevelFilter.cpp.
References ossimImageSource::getDecimationFactor(), ossimDpt::makeNan(), and ossimImageSourceFilter::theInputConnection.
Referenced by getSummedDecimation(), and updateGeometry().
42 {
44  {
45  result.makeNan();
46  }
47
49  result);
50 }
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
void makeNan()
Definition: ossimDpt.h:65
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimRLevelFilter::getImageGeometry ( )
virtual
The input source geometry is modified, so we need to maintain our own geometry object as a data member.
Definition at line 81 of file ossimRLevelFilter.cpp.
References getCurrentRLevel(), ossimSource::getEnableFlag(), ossimImageSource::getImageGeometry(), m_ScaledGeometry, ossimImageSourceFilter::theInputConnection, updateGeometry(), and ossimRefPtr< T >::valid().
82 {
83  // Have we already defined our own geometry? Return it if so:
85
87
88  ossim_uint32 rlevel = getCurrentRLevel();
90
91  // If no scaling is happening, just return the input image geometry:
92  if ((!inputGeom) || (rlevel == 0) || (getEnableFlag() == false))
93  return inputGeom;
94
95  // Need to create a copy of the input geom and modify it as our own, then pass that:
96  m_ScaledGeometry = new ossimImageGeometry(*inputGeom);
98
99  // Return our version of the image geometry:
100  return m_ScaledGeometry;
101 }
ossimRefPtr< ossimImageGeometry > m_ScaledGeometry
bool valid() const
Definition: ossimRefPtr.h:75
void updateGeometry()
If this object is maintaining an ossimImageGeometry, this method needs to be called after a scale cha...
virtual bool getEnableFlag() const
Definition: ossimSource.cpp:94
unsigned int ossim_uint32
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
virtual ossim_uint32 getCurrentRLevel() const
◆ getOverrideGeometryFlag()
bool ossimRLevelFilter::getOverrideGeometryFlag ( ) const
virtual
Get/set of the data member "theOverrideGeometryFlag". If set this will override the "getImageGeometry" method and adjust the getMetersPerPixel or the getDecimalDegreesPerPixel. Default behavior is to not override method.
Definition at line 53 of file ossimRLevelFilter.cpp.
References theOverrideGeometryFlag.
54 {
56 }
◆ getSummedDecimation()
void ossimRLevelFilter::getSummedDecimation ( ossimDpt result) const
protected
Initializes result with the sum of decimations from rlevel one to theCurrentRLevel.
Definition at line 128 of file ossimRLevelFilter.cpp.
References getCurrentRLevel(), getDecimationFactor(), ossimDpt::hasNans(), ossimDpt::makeNan(), ossimNotify(), ossimNotifyLevel_WARN, ossimDpt::x, and ossimDpt::y.
129 {
130  // Start with fresh values.
131  result.x = 0.0;
132  result.y = 0.0;
133
134  ossim_uint32 rlevel = getCurrentRLevel();
135
136  if (rlevel == 0)
137  {
138  return; // no decimation.
139  }
140
141  // Sum the decimations from rlevel one to the current rlevel.
142  for (ossim_uint32 i = 1; i <= rlevel; ++i)
143  {
144  ossimDpt dpt;
145  getDecimationFactor(i, dpt);
146  if (dpt.hasNans())
147  {
149  << "ossimRLevelFilter::getSummedDecimation WARNING:"
150  << "\nNans returned from getDecimationFactor!"
151  << std::endl;
152  result.makeNan();
153  return;
154  }
155  result.x += dpt.x;
156  result.y += dpt.y;
157  }
158
159  if (traceDebug())
160  {
162  << "ossimRLevelFilter::getSummedDecimation result: " << result
163  << std::endl;
164  }
165 }
double y
Definition: ossimDpt.h:165
bool hasNans() const
Definition: ossimDpt.h:67
double x
Definition: ossimDpt.h:164
void makeNan()
◆ getTile()
ossimRefPtr< ossimImageData > ossimRLevelFilter::getTile ( const ossimIrect rect,
virtual
Returns
Definition at line 182 of file ossimRLevelFilter.cpp.
References ossimImageSource::getTile(), ossimSource::isSourceEnabled(), theCurrentRLevel, and ossimImageSourceFilter::theInputConnection.
185 {
186  if(!theInputConnection)
187  {
188  return 0;
189  }
190
191  if(!isSourceEnabled())
192  {
193  return theInputConnection->getTile(tileRect, resLevel);
194  }
195
196  // Ignoring resLevel as we're in charge of it here!
197  return theInputConnection->getTile(tileRect, theCurrentRLevel);
198 }
◆ loadState()
bool ossimRLevelFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 201 of file ossimRLevelFilter.cpp.
References ossimKeywordlist::find().
203 {
204  const char* current = kwl.find(prefix, CURRENT_RLEVEL_KW);
205  const char* override = kwl.find(prefix, OVERRIDE_GEOMETRY_KW);
206
207  if(current)
208  theCurrentRLevel = ossimString(current).toULong();
209
210  if(override)
212
213  return ossimImageSourceFilter::loadState(kwl, prefix);
214
215  // An existing image geometry object here will need to be updated:
216  updateGeometry();
217 }
bool toBool() const
String to numeric methods.
unsigned long toULong() const
◆ saveState()
bool ossimRLevelFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 220 of file ossimRLevelFilter.cpp.
References ossimKeywordlist::add().
222 {
223  kwl.add(prefix,
224  CURRENT_RLEVEL_KW,
226  true);
227
228  kwl.add(prefix,
229  OVERRIDE_GEOMETRY_KW,
231  true);
232
233  return ossimImageSourceFilter::saveState(kwl, prefix);
234 }
◆ setCurrentRLevel()
void ossimRLevelFilter::setCurrentRLevel ( ossim_uint32  rlevel)
virtual
Definition at line 65 of file ossimRLevelFilter.cpp.
References theCurrentRLevel, and updateGeometry().
66 {
67  theCurrentRLevel = rlevel;
69 }
◆ setOverrideGeometryFlag()
void ossimRLevelFilter::setOverrideGeometryFlag ( bool  override)
virtual
Definition at line 59 of file ossimRLevelFilter.cpp.
60 {
61  theOverrideGeometryFlag = override;
62 }
◆ updateGeometry()
void ossimRLevelFilter::updateGeometry ( )
protected
Definition at line 107 of file ossimRLevelFilter.cpp.
References ossimMapProjection::applyScale(), getDecimationFactor(), ossimImageGeometry::getProjection(), m_ScaledGeometry, PTR_CAST, theCurrentRLevel, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by getImageGeometry(), and setCurrentRLevel().
108 {
109  if (m_ScaledGeometry.valid())
110  {
111  // Modify the image geometry's projection with the scale factor before returning geom:
114  if(mapProj)
115  {
116  ossimDpt decimation;
118  decimation.x = 1.0/decimation.x;
119  decimation.y = 1.0/decimation.y;
120
121  // This will adjust both the scale and the tie point to account for decimation.
122  mapProj->applyScale(decimation, true); // recenter tie point flag
123  }
124  }
125 }
bool valid() const
double y
virtual void applyScale(const ossimDpt &scale, bool recenterTiePoint)
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: the...
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
double x
Member Data Documentation
◆ m_ScaledGeometry
ossimRefPtr<ossimImageGeometry> ossimRLevelFilter::m_ScaledGeometry
protected
Definition at line 94 of file ossimRLevelFilter.h.
Referenced by getImageGeometry(), and updateGeometry().
◆ theCurrentRLevel
ossim_uint32 ossimRLevelFilter::theCurrentRLevel
protected
◆ theOverrideGeometryFlag
bool ossimRLevelFilter::theOverrideGeometryFlag
protected
Definition at line 93 of file ossimRLevelFilter.h.
Referenced by getOverrideGeometryFlag(), and setOverrideGeometryFlag().
