ossimChipProcTool Class Referenceabstract
#include <ossimChipProcTool.h>
Inheritance diagram for ossimChipProcTool:
ossimTool ossimProcessInterface ossimListenerManager ossimObject ossim::JsonInterface ossimReferenced ossimBandMergeTool ossimHdf5Tool ossimHillshadeTool ossimHlzTool ossimOrthoTool ossimPotraceTool ossimRegTool ossimShorelineTool ossimSlopeTool ossimSubImageTool ossimViewshedTool
Public Member Functions
 ossimChipProcTool ()
 default constructor More...
virtual ~ossimChipProcTool ()
 virtual destructor More...
virtual void setUsage (ossimArgumentParser &ap)
 Initializes the aurgument parser with expected parameters and options. More...
virtual void clear ()
 Disconnects and clears the dem and image layers. More...
virtual bool initialize (ossimArgumentParser &ap)
 Initial method to be ran prior to execute. More...
virtual void initialize (const ossimKeywordlist &kwl)
 This method is responsible for completely setting up the full processing chain according to the specifications given in the kwl passed in. More...
virtual bool execute ()
 Performs the actual product write. More...
virtual void abort ()
virtual bool isChipProcessor () const
 Overrides base class implementation to indicate this class supports getChip() calls. More...
virtual ossimRefPtr< ossimImageDatagetChip (const ossimIrect &img_rect)
 The meat and potatos of this class. More...
virtual ossimRefPtr< ossimImageDatagetChip (const ossimGrect &gnd_rect)
ossimRefPtr< ossimImageDatagetChip (const ossimDrect &map_bounding_rect, const ossimDpt &gsd)
ossimRefPtr< ossimImageDatagetChip ()
 Get chip method that assumes pre-initialized state. More...
const ossimFilenamegetProductFilename () const
- Public Member Functions inherited from ossimTool
 ossimTool ()
virtual ~ossimTool ()
virtual void loadJSON (const Json::Value &json_request)
 Reads processing params from JSON object provided. More...
virtual void saveJSON (Json::Value &json) const
 Fetch product as JSON object when applicable Always returns true since using exception on error. More...
virtual const std::string & getResponse () const
 Fetch product as string (typically JSON) when applicable, otherwise passes back empty string. More...
virtual void getKwlTemplate (ossimKeywordlist &kwl)
 Assigns a template keywordlist to string for initializing derived classes. More...
void getAPI (std::string &out) const
 Outputs a JSON representation of the Utility's API. More...
std::string getAPI () const
void getBuildDate (std::string &s) const
 Gets build date. More...
void getRevision (std::string &s) const
 Gets revision. More...
void getVersion (std::string &s) const
 Gets version. More...
void setOutputStream (std::ostream *os)
 Redirects any console output to the supplied stream for logging or JNI application. More...
bool helpRequested () const
 Returns true when the initialization detects a "--help" option, so caller can avoid subsequent execute() call. More...
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
- Public Member Functions inherited from ossim::JsonInterface
 JsonInterface ()
virtual ~JsonInterface ()
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ossimListenerManager ()
Protected Member Functions
void processRemainingArgs (ossimArgumentParser &ap)
 Intended to be called after derived class has picked off its own options from the parser, and arguments remain (such as input and output filenames). More...
virtual void initProcessingChain ()=0
 Derived classes initialize their custom chains here. More...
virtual void finalizeChain ()
 Called after initProcessingChain() to append common items to the processing chain. More...
virtual void loadImageFiles ()
 Creates chains for image entries associated with specified keyword. More...
virtual void loadDemFiles ()
 Loads all DEM files specified in master KWL into the elev manager's database. More...
ossimRefPtr< ossimSingleImageChaincreateInputChain (const ossimFilename &image_file, ossim_uint32 entry_index=0)
 Creates the ossimSingleImageChain from image filename and populates the chain with resampler and product output projection on view-side of resampler's IVT. More...
void createOutputProjection ()
 Creates the output or view projection. More...
ossimRefPtr< ossimMapProjectionnewIdentityProjection ()
 Sets the single image chain for identity operations view to a ossimImageViewAffineTransform. More...
ossimRefPtr< ossimMapProjectionnewUtmProjection ()
 Convenience method to get a utm projection. More...
virtual void initializeProjectionGsd ()
 Initializes the projection gsd. More...
virtual void initializeAOI ()
 Initializes m_aoiViewRect with the output area of interest as specified in master KWL. More...
bool getProjectionOrigin (ossimGpt &gpt)
 Reads the KWL for origin latitude and central meridian. More...
ossimRefPtr< ossimImageFileWriternewWriter ()
 Creates a new writer. More...
void propagateGeometryToChains ()
 Loops through all chains and sets the output projection. More...
ossimRefPtr< ossimImageSourcecombineLayers (std::vector< ossimRefPtr< ossimSingleImageChain > > &layers) const
 When multiple input sources are present, this method instantiates a combiner and adds inputs. More...
void computeAdjustedViewFromGrect ()
 Initializes m_aoiViewRect given m_aoiGroundRect. More...
void setAoiToInputs ()
 Assigns the AOI to be the bounding rect of the union of all inputs. More...
void getBandList (ossim_uint32 image_idx, std::vector< ossim_uint32 > &bandList) const
 Gets the band list if BANDS keyword is set. More...
void setReaderProps (ossimImageHandler *ih) const
 Passes reader properties to single image handler if any. More...
 ossimChipProcTool (const ossimChipProcTool &obj)
 Hidden from use copy constructor. More...
const ossimChipProcTooloperator= (const ossimChipProcTool &)
 Hidden from use assignment operator. More...
ossimRefPtr< ossimGeoPolygoncreateClipPolygon () const
void findCenterGpt (ossimGpt &gpt)
 Tries to determine the AOI center point based on KWL entries, else returns NaNs in gpt. More...
ossimRefPtr< ossimImageSourcemosaicDemSources ()
 Some utilities need to work on DEMs as images. More...
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimImageGeometrym_geom
ossimIrect m_aoiViewRect
ossimGrect m_aoiGroundRect
std::vector< ossimRefPtr< ossimSingleImageChain > > m_imgLayers
std::vector< ossimFilenamem_demSources
ossimRefPtr< ossimImageFileWriterm_writer
ossimRefPtr< ossimImageChainm_procChain
ossimRefPtr< ossimRectangleCutFilterm_cutRectFilter
bool m_projIsIdentity
ossimDpt m_gsd
bool m_geoScaled
ossimFilename m_productFilename
ossimScalarType m_productScalarType
bool m_needCutRect
- Protected Attributes inherited from ossimTool
ossimKeywordlist m_kwl
std::ostream * m_consoleStream
bool m_helpRequested
std::string m_response
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theEnabledFlag
bool theFireEventFlag
Additional Inherited Members
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
Detailed Description
Definition at line 42 of file ossimChipProcTool.h.
◆ ossimChipProcTool() [1/2]
ossimChipProcTool::ossimChipProcTool ( )
default constructor
Definition at line 69 of file ossimChipProcTool.cpp.
References m_geom, m_gsd, ossimTool::m_kwl, m_procChain, ossimDpt::makeNan(), and ossimKeywordlist::setExpandEnvVarsFlag().
70 : m_projIsIdentity(false),
71  m_geoScaled(false),
73  m_needCutRect(false)
74 {
76  m_gsd.makeNan();
79 }
ossimRefPtr< ossimImageGeometry > m_geom
Definition: ossimTool.h:148
ossimRefPtr< ossimImageChain > m_procChain
void setExpandEnvVarsFlag(bool flag)
void makeNan()
Definition: ossimDpt.h:65
◆ ~ossimChipProcTool()
ossimChipProcTool::~ossimChipProcTool ( )
virtual
virtual destructor
Definition at line 81 of file ossimChipProcTool.cpp.
References clear().
82 {
83  clear();
84 }
virtual void clear()
◆ ossimChipProcTool() [2/2]
ossimChipProcTool::ossimChipProcTool ( const ossimChipProcTool obj)
protected
Definition at line 62 of file ossimChipProcTool.cpp.
Member Function Documentation
◆ abort()
void ossimChipProcTool::abort ( )
virtual
Reimplemented from ossimProcessInterface.
Definition at line 444 of file ossimChipProcTool.cpp.
References ossimProcessInterface::abort(), m_writer, and ossimRefPtr< T >::valid().
445 {
446  if(m_writer.valid())
447  {
448  m_writer->abort();
449  }
450 }
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimImageFileWriter > m_writer
◆ clear()
void ossimChipProcTool::clear ( )
virtual
Reimplemented from ossimTool.
Reimplemented in ossimViewshedTool.
Definition at line 86 of file ossimChipProcTool.cpp.
References m_geom, m_gsd, m_imgLayers, m_needCutRect, m_procChain, m_writer, and ossimDpt::makeNan().
Referenced by ossimViewshedTool::clear(), ~ossimChipProcTool(), and ossimHillshadeTool::~ossimHillshadeTool().
87 {
88  m_gsd.makeNan();
89
90  m_procChain = 0;
91  m_imgLayers.clear();
92  m_writer = 0;
93  m_geom = 0;
94  m_needCutRect = false;
95 }
void makeNan()
◆ combineLayers()
ossimRefPtr< ossimImageSource > ossimChipProcTool::combineLayers ( std::vector< ossimRefPtr< ossimSingleImageChain > > &  layers) const
protected
Returns
Reference to the combiner.
Definition at line 1429 of file ossimChipProcTool.cpp.
References ossimConnectableObject::connectMyInputTo(), and ossimRefPtr< T >::get().
Referenced by ossimHillshadeTool::initProcessingChain(), ossimSlopeTool::initProcessingChain(), ossimHdf5Tool::initProcessingChain(), ossimHlzTool::initProcessingChain(), and ossimViewshedTool::initProcessingChain().
1430 {
1431  ossimRefPtr<ossimImageSource> combiner = 0;
1432  ossim_uint32 layerCount = (ossim_uint32) layers.size();
1433  if ( layerCount == 1 )
1434  {
1435  combiner = layers[0].get();
1436  }
1437  else if (layerCount > 1)
1438  {
1439  combiner = new ossimImageMosaic;
1440  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx = layers.begin();
1441  while ( chainIdx != layers.end() )
1442  {
1443  combiner->connectMyInputTo( (*chainIdx).get() );
1444  ++chainIdx;
1445  }
1446  }
1447  return combiner;
1448 }
An image mosaic is a simple combiner that will just do a simple mosaic.
unsigned int ossim_uint32
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
◆ computeAdjustedViewFromGrect()
void ossimChipProcTool::computeAdjustedViewFromGrect ( )
protected
Definition at line 1265 of file ossimChipProcTool.cpp.
References ossimImageChain::getBoundingRect(), ossimImageGeometry::getDegreesPerPixel(), ossimGrect::hasNans(), ossimIrect::hasNans(), ossimGpt::lat, ossimGpt::lon, ossimGrect::lr(), m_aoiGroundRect, m_aoiViewRect, m_geom, m_procChain, ossimIrect::makeNan(), ossimGrect::ul(), ossimImageGeometry::worldToLocal(), ossimDpt::x, and ossimDpt::y.
Referenced by getChip().
1266 {
1267  // Nan rect for starters.
1269  if (m_aoiGroundRect.hasNans())
1270  return;
1271
1272  // Assume cut box is edge to edge or "Pixel Is Area". Our
1273  // AOI(area of interest) uses center of pixel or "Pixel Is Point"
1274  // so get the degrees per pixel and shift AOI to center.
1275  ossimDpt halfDpp;
1276  m_geom->getDegreesPerPixel( halfDpp );
1277  halfDpp = halfDpp/2.0;
1278
1279  ossimGpt gpt(0.0, 0.0, 0.0);
1280  ossimDpt ulPt;
1281  ossimDpt lrPt;
1282
1283  // Upper left:
1284  gpt.lat = m_aoiGroundRect.ul().lat - halfDpp.y;
1285  gpt.lon = m_aoiGroundRect.ul().lon + halfDpp.x;
1286  m_geom->worldToLocal(gpt, ulPt);
1287
1288  // Lower right:
1289  gpt.lat = m_aoiGroundRect.lr().lat + halfDpp.y;
1290  gpt.lon = m_aoiGroundRect.lr().lon - halfDpp.x;
1291  m_geom->worldToLocal(gpt, lrPt);
1292
1293  m_aoiViewRect = ossimIrect( ossimIpt(ulPt), ossimIpt(lrPt) );
1294
1295  // If no user defined rect set to scene bounding rect.
1296  if ( m_aoiViewRect.hasNans() )
1298 }
double y
Definition: ossimDpt.h:165
ossimDpt getDegreesPerPixel() const
Returns the resolution of this image in degrees/pixel.
bool hasNans() const
Definition: ossimGrect.h:298
double lat
ossim_float64 lon
Definition: ossimGpt.h:266
const ossimGpt & ul() const
Definition: ossimGrect.h:252
Will pass this call to the head of the list.
void makeNan()
Definition: ossimIrect.h:329
double x
Definition: ossimDpt.h:164
Definition: ossimIrect.h:337
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
ossim_float64 lat
Definition: ossimGpt.h:265
const ossimGpt & lr() const
Definition: ossimGrect.h:269
◆ createClipPolygon()
ossimRefPtr<ossimGeoPolygon> ossimChipProcTool::createClipPolygon ( ) const
protected
◆ createInputChain()
ossimRefPtr< ossimSingleImageChain > ossimChipProcTool::createInputChain ( const ossimFilename image_file,
ossim_uint32  entry_index = 0
protected
Parameters
fileFile to open.
entryIndexEntry to open.
Returns
Ref pointer to ossimSingleImageChain.
Note
Throws ossimException on error.
Definition at line 597 of file ossimChipProcTool.cpp.
References ossimImageChain::add(), ossimSingleImageChain::addCache(), ossimSingleImageChain::addResampler(), ossimKeywordlist::findKey(), ossimRefPtr< T >::get(), ossimSingleImageChain::getImageHandler(), ossimImageChain::getOutputScalarType(), ossimTool::m_kwl, m_procChain, m_productScalarType, ossimSingleImageChain::open(), OSSIM_SCALAR_UNKNOWN, ossimImageHandler::setCurrentEntry(), ossimScalarRemapper::setOutputScalarType(), and setReaderProps().
Referenced by loadImageFiles(), ossimHlzTool::MaskSource::MaskSource(), and mosaicDemSources().
598 {
599  // Init chain with handler:
601  if (!chain->open(fname))
602  {
603  ostringstream errMsg;
604  errMsg<<"ERROR: ossimChipProcUtil ["<<__LINE__<<"] Could not open <"<<fname<<">"<<ends;
605  throw ossimException(errMsg.str());
606  }
607
608  // Set any reader props:
609  ossimImageHandler* handler = chain->getImageHandler().get();
610  setReaderProps( handler );
611  if (!handler->setCurrentEntry( entry_index ))
612  {
613  std::ostringstream errMsg;
614  errMsg << " ERROR: ossimChipProcUtil ["<<__LINE__<<"] Entry " << entry_index << " out of range!" << std::endl;
615  throw ossimException( errMsg.str() );
616  }
617
618  // Set up the remapper:
621  {
624  chain->add(remapper.get());
625  }
626
627  // Set up the renderer with cache:
628  chain->addResampler();
629  chain->addCache();
630
631  // Add geo polygon cutter if specifried:
632  ossimString param = m_kwl.findKey(CLIP_POLY_LAT_LON_KW);
633  if (!param.empty())
634  {
635  std::vector<ossimGpt> points;
636  ossim::toVector(points, param);
637  if(points.size() >= 3)
638  {
639  ossimGeoPolygon polygon(points);
640  chain->addGeoPolyCutterPolygon(polygon);
641  }
642  }
643
644  chain->initialize();
645  return chain;
646 }
void setReaderProps(ossimImageHandler *ih) const
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
ossimRefPtr< const ossimImageHandler > getImageHandler() const
void addResampler()
Adds a resampler (a.k.a.
virtual void initialize()
Single image chain class.
This call is passed to the head of the list.
virtual void setOutputScalarType(ossimScalarType scalarType)
Sets the output scalar type.
OSSIM_DLL void toVector(std::vector< ossimDpt > &result, const ossimString &stringOfPoints)
Will take a string list separated by spaces and convert to a vector of ossimDpts. ...
virtual bool add(ossimConnectableObject *source)
Will return true or false if an image source was added to the chain.
ossimRefPtr< ossimCacheTileSource > addCache()
Adds a new cache to the current end of the chain.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
bool open(const ossimFilename &file, bool openOverview=true)
open method that takes an image file.
bool empty() const
Definition: ossimString.h:411
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
void addGeoPolyCutterPolygon(const vector< ossimGpt > &polygon)
◆ createOutputProjection()
void ossimChipProcTool::createOutputProjection ( )
protected
Note
All chains must be constructed prior to calling this.
Definition at line 688 of file ossimChipProcTool.cpp.
References ossimKeywordlist::findKey(), ossimTool::m_kwl, and ossimKeywordNames::PROJECTION_KW.
689 {
690  static const char* MODULE = "ossimChipProcUtil::createOutputProjection()";
691
693  ossimString srs = m_kwl.findKey( SRS_KW );
694  if ( op.size() && srs.size() )
695  {
697  << MODULE << " WARNING:"
698  << "\nBoth " << SRS_KW << " and " << ossimKeywordNames::PROJECTION_KW
699  << " keywords are set!"
700  << "\nsrs: " << srs
701  << "\noutput_projection: " << op
702  << "\nTaking " << srs << " over " << op << "\n";
703  }
704
706  m_geoScaled = false;
707  op.downcase();
708
709  if (op.contains("epsg"))
710  srs = op;
711
712  if ( (op == "geo") || (srs.contains("4326")))
713  proj = new ossimEquDistCylProjection();
714
715  else if (srs.size())
716  {
718  ossimProjectionFactoryRegistry::instance()->createProjection(srs));
719  if (!proj.valid())
720  throw ossimException("ossimChipProcUtil::createOutputProjection() -- Bad EPSG code passed.");
721  }
722  else if (op == "geo-scaled")
723  {
724  m_geoScaled = true; // used later when reference latitude is known
725  proj = new ossimEquDistCylProjection();
726  }
727  else if ( ( op == "input" ) || (op == "identity") || (op == "none") )
728  proj = newIdentityProjection();
729
730  else if ( (op == "utm") || (op == "ossimutmprojection") )
731  proj = newUtmProjection();
732
733  else
734  {
735  m_geoScaled = true; // used later when reference latitude is known
736  proj = new ossimEquDistCylProjection();
737  }
738
739  // Create our ossimImageGeometry with projection (no transform).
740  proj->setElevationLookupFlag(true);
741  m_geom->setProjection(proj.get());
742
743  // Set the scale and AOI.
745  initializeAOI(); // also sets the tie point to AOI UL and geoscaling to origin.
746
747  // Setup the view in all the chains.
749 }
static const char * PROJECTION_KW
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool valid() const
bool contains(char aChar) const
Definition: ossimString.h:58
virtual void initializeProjectionGsd()
ossimRefPtr< ossimMapProjection > newUtmProjection()
std::string::size_type size() const
Definition: ossimString.h:405
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
static ossimProjectionFactoryRegistry * instance()
virtual void initializeAOI()
Initializes m_aoiViewRect with the output area of interest as specified in master KWL...
ossimRefPtr< ossimMapProjection > newIdentityProjection()
void setElevationLookupFlag(bool flag)
void propagateGeometryToChains()
◆ execute()
bool ossimChipProcTool::execute ( )
virtual
Note
Implements ossimProcessInterface.
Reimplemented in ossimSubImageTool, ossimViewshedTool, ossimHdf5Tool, ossimShorelineTool, ossimHlzTool, ossimPotraceTool, ossimBandMergeTool, and ossimRegTool.
Definition at line 394 of file ossimChipProcTool.cpp.
References ossimImageFileWriter::addListener(), ossimConnectableObject::connectMyInputTo(), ossimImageFileWriter::execute(), ossimRefPtr< T >::get(), ossimErrorStatusInterface::getErrorStatus(), ossimImageGeometry::getImageSize(), ossimIpt::hasNans(), ossimProcessInterface::isAborted(), m_aoiViewRect, m_geom, ossimTool::m_helpRequested, m_procChain, m_productFilename, m_writer, newWriter(), ossimErrorCodes::OSSIM_OK, ossimNotify(), ossimNotifyLevel_INFO, ossimImageFileWriter::removeListener(), ossimImageFileWriter::setAreaOfInterest(), and ossimRefPtr< T >::valid().
Referenced by ossimShorelineTool::doThreshold(), ossimBandMergeTool::execute(), ossimHlzTool::execute(), ossimShorelineTool::execute(), ossimHdf5Tool::execute(), ossimViewshedTool::execute(), and ossimSubImageTool::execute().
395 {
396  if (m_helpRequested)
397  return true;
398
399  ostringstream xmsg;
400
401  if ( !m_procChain.valid() )
402  {
403  xmsg << "ossimChipProcUtil:"<<__LINE__<<"Null pointer encountered for m_procChain!";
404  throw ossimException(xmsg.str());
405  }
406
407  if (m_geom->getImageSize().hasNans())
408  {
409  xmsg << "ossimChipProcUtil:"<<__LINE__<<"Image size is NaN!";
410  throw ossimException(xmsg.str());
411  }
412
413  // Set up the writer.
414  m_writer = newWriter();
415
416  // Connect the writer to the processing chain.
418
419  // Set the area of interest. NOTE: This must be called after the writer->connectMyInputTo as
420  // ossimImageFileWriter::initialize incorrectly resets AOI back to the bounding rect.
422
424  throw ossimException( "Unable to initialize writer for execution" );
425
426  // Add a listener to get percent complete.
427  ossimStdOutProgress prog(0, true);
428  m_writer->addListener(&prog);
429
430  // Write the file:
431  m_writer->execute();
432  m_writer->removeListener(&prog);
433  if(m_writer->isAborted())
434  {
435  xmsg << "ossimChipProcUtil:"<<__LINE__<<"Writer Process aborted!";
436  throw ossimException(xmsg.str());
437  }
438
439  ossimNotify(ossimNotifyLevel_INFO)<<"Wrote product image to <"<<m_productFilename<<">"<<endl;
440
441  return true;
442 }
const ossimIpt & getImageSize() const
Definition: ossimTool.h:150
static const ossimErrorCode OSSIM_OK
bool valid() const
virtual bool addListener(ossimListener *listener)
Overrides base "addListener" this will capture the pointer and then call the base class "addListener"...
ossimRefPtr< ossimImageFileWriter > newWriter()
virtual ossimErrorCode getErrorStatus() const
virtual void setAreaOfInterest(const ossimIrect &inputRect)
Definition: ossimIpt.h:58
virtual bool removeListener(ossimListener *listener)
Overrides base "removeListener".
virtual bool execute()
Calls: writeFile() writeMetaDataFiles()
◆ finalizeChain()
void ossimChipProcTool::finalizeChain ( )
protectedvirtual
Sets up the AOI box cutter filter and related stuff and initializes area of interest(aoi). The filter is appended to the current m_procChain. Derived class should override if not applicable to its processing chain.
Reimplemented in ossimPotraceTool, and ossimRegTool.
Definition at line 354 of file ossimChipProcTool.cpp.
References ossimKeywordlist::findKey(), and ossimTool::m_kwl.
Referenced by ossimSubImageTool::initialize().
355 {
356  ostringstream errMsg;
357
358  // See if an LUT is requested:
359  ossimFilename lutFile = m_kwl.findKey( LUT_FILE_KW );
360  if (!lutFile.empty())
361  {
362  if ( !lutFile.exists() )
363  {
364  errMsg<<"ERROR ossimChipProcUtil ["<<__LINE__<<"] Color table <"<<lutFile
365  <<"> does not exists: "<<ends;
366  throw ossimException(errMsg.str());
367  }
369  lut->setLut(lutFile);
370  m_procChain->add(lut.get());
371  }
372
373  if (m_needCutRect)
374  {
375  // Add a cut filter. This will:
376  // 1) Null out/clip any data pulled in.
377  // 2) Speed up by not propagating get tile request outside the cut or "aoi"
378  // to the left hand side(input).
383  }
384
385  // Set the image size here. Note must be set after combineLayers. This is needed for
386  // the ossimImageGeometry::worldToLocal call for a geographic projection to handle wrapping
387  // accross the date line.
389
390  // Reset the source bounding rect if it changed.
392 }
void setRectangle(const ossimIrect &rect)
void setImageSize(const ossimIpt &size)
ossimIpt size() const
Definition: ossimIrect.h:510
void setCutType(ossimRectangleCutType cutType)
bool exists() const
void setLut(const ossimFilename &file)
Set lookup table(lut) method.
bool empty() const
ossimRefPtr< ossimRectangleCutFilter > m_cutRectFilter
◆ findCenterGpt()
void ossimChipProcTool::findCenterGpt ( ossimGpt gpt)
protected
Needed for bootstrapping the GSD computation when information in KWL is sparse
Definition at line 1166 of file ossimChipProcTool.cpp.
References ossimKeywordlist::findKey(), ossimGpt::hgt, and ossimTool::m_kwl.
1167 {
1168  gpt.hgt = 0.0;
1169  ossimString lookup = m_kwl.findKey( AOI_GEO_CENTER_KW );
1170  if (lookup.size())
1171  {
1172  lookup.trim();
1173  vector<ossimString> substrings = lookup.split(", ");
1174  if (substrings.size() != 2)
1175  {
1176  ostringstream errMsg;
1177  errMsg << "ossimChipProcUtil ["<<__LINE__<<"] Incorrect number of values specified for "
1178  "aoi_geo_center!";
1179  throw( ossimException(errMsg.str()) );
1180  }
1181  gpt.lat = substrings[0].toDouble();
1182  gpt.lon = substrings[1].toDouble();
1183  return;
1184  }
1185
1186  lookup = m_kwl.findKey(AOI_GEO_RECT_KW);
1187  if (lookup.size())
1188  {
1189  lookup.trim();
1190  vector<ossimString> substrings = lookup.split(", ");
1191  if (substrings.size() != 4)
1192  {
1193  ostringstream errMsg;
1194  errMsg << "ossimChipProcUtil ["<<__LINE__<<"] Incorrect number of values specified for "
1195  "aoi_geo_rect!";
1196  throw( ossimException(errMsg.str()) );
1197  }
1198  ossim_float64 minLatF = substrings[0].toDouble();
1199  ossim_float64 minLonF = substrings[1].toDouble();
1200  ossim_float64 maxLatF = substrings[2].toDouble();
1201  ossim_float64 maxLonF = substrings[3].toDouble();
1202  gpt.lat = 0.5*(minLatF + maxLatF);
1203  gpt.lon = 0.5*(minLonF + maxLonF);
1204  return;
1205  }
1206  gpt.makeNan();
1207 }
void makeNan()
Definition: ossimGpt.h:130
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
double ossim_float64
ossim_float64 lon
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
ossim_float64 lat
◆ getBandList()
void ossimChipProcTool::getBandList ( ossim_uint32  image_idx,
std::vector< ossim_uint32 > &  bandList
) const
protected
NOTE: BANDS keyword values are ONE based. bandList values are ZERO based.
Parameters
inputimage index for which the band selection applies
bandListList initialized by this.
Definition at line 1351 of file ossimChipProcTool.cpp.
References ossimKeywordNames::BANDS_KW, ossimString::empty(), ossimKeywordlist::find(), ossimKeywordlist::findKey(), ossimKeywordNames::IMAGE_FILE_KW, ossimTool::m_kwl, ossimString::size(), and ossimString::split().
Referenced by loadImageFiles().
1353 {
1354  bandList.clear();
1355  ostringstream key;
1356  key << ossimKeywordNames::IMAGE_FILE_KW << image_idx << "." << ossimKeywordNames::BANDS_KW;
1357  ossimString os = m_kwl.findKey(key.str());
1358  if (os.empty())
1359  {
1360  // Look for possible global bands selection:
1362  }
1363
1364  if ( os.size() )
1365  {
1366  std::vector<ossimString> band_list(0);
1367  os.split( band_list, ossimString(", "), false );
1368  if ( band_list.size() )
1369  {
1370  std::vector<ossimString>::const_iterator i = band_list.begin();
1371  while ( i != band_list.end() )
1372  {
1373  ossim_uint32 band = (*i).toUInt32();
1374  if ( band ) // One based so we need to subtract.
1375  {
1376  bandList.push_back( band - 1 );
1377  }
1378  ++i;
1379  }
1380  }
1381  }
1382 } // End: ossimChipProcUtil::getBandList
static const char * BANDS_KW
bool empty() const
static const char * IMAGE_FILE_KW
◆ getChip() [1/4]
ossimRefPtr< ossimImageData > ossimChipProcTool::getChip ( const ossimIrect img_rect)
virtual
Performs an execute on specified rect.
Reimplemented in ossimViewshedTool, ossimShorelineTool, and ossimHlzTool.
Definition at line 493 of file ossimChipProcTool.cpp.
References ossimImageChain::add(), ossimRefPtr< T >::get(), ossimImageChain::getTile(), m_aoiViewRect, m_cutRectFilter, m_geom, m_procChain, ossimRectangleCutFilter::OSSIM_RECTANGLE_NULL_OUTSIDE, ossimRectangleCutFilter::setCutType(), ossimImageGeometry::setImageSize(), ossimRectangleCutFilter::setRectangle(), ossimIrect::size(), and ossimRefPtr< T >::valid().
494 {
496  if(!m_procChain.valid())
497  return chip;
498
499  m_aoiViewRect = bounding_irect;
501
502  // There should not be a chipper filter in the chain for getImage() calls since the chipping
503  // is implied by the requested rect to getTile(), but if present, make sure it covers
504  // the requested AOI to avoid masking out the tile.
505  if (!m_cutRectFilter.valid())
506  {
510  }
512  return m_procChain->getTile( m_aoiViewRect, 0 );
513 }
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
Within the image chain will pass the head of the list.
bool valid() const
◆ getChip() [2/4]
ossimRefPtr< ossimImageData > ossimChipProcTool::getChip ( const ossimGrect gnd_rect)
virtual
Definition at line 475 of file ossimChipProcTool.cpp.
References computeAdjustedViewFromGrect(), getChip(), ossimGrect::hasNans(), m_aoiGroundRect, m_aoiViewRect, m_geom, ossimNotify(), ossimNotifyLevel_INFO, and ossimRefPtr< T >::valid().
476 {
478  if (!m_geom.valid())
479  return chip;
480
481  // Set the new cut rectangle. Note that a NaN rect passed in implies the full AOI:
482  if (!geo_bounding_grect.hasNans())
483  {
484  ossimNotify(ossimNotifyLevel_INFO) <<"\nossimChipProcUtil::getChip(grect) -- NaN rect "
485  "provided. Using full AOI."<<endl;
486  m_aoiGroundRect = geo_bounding_grect;
488  }
489
490  return getChip(m_aoiViewRect);
491 }
ossimRefPtr< ossimImageData > getChip()
void computeAdjustedViewFromGrect()
bool valid() const
◆ getChip() [3/4]
ossimRefPtr< ossimImageData > ossimChipProcTool::getChip ( const ossimDrect map_bounding_rect,
const ossimDpt gsd
Definition at line 452 of file ossimChipProcTool.cpp.
References ossimImageGeometry::getAsMapProjection(), getChip(), ossimMapProjection::inverse(), ossimDrect::lr(), m_aoiGroundRect, m_aoiViewRect, m_geom, ossimImageGeometry::setImageSize(), ossimMapProjection::setMetersPerPixel(), ossimIrect::size(), ossimDrect::ul(), ossimRefPtr< T >::valid(), and ossimImageGeometry::worldToLocal().
454 {
455  ostringstream xmsg;
456  if (!m_geom.valid())
457  return 0;
458
460  if (proj == 0)
461  return 0;
462
463  proj->setMetersPerPixel(gsd);
464  ossimGpt ulGpt = proj->inverse(map_bounding_rect.ul());
465  ossimGpt lrGpt = proj->inverse(map_bounding_rect.lr());
466  m_aoiGroundRect = ossimGrect(ulGpt, lrGpt);
467  ossimDrect view_rect;
468  m_geom->worldToLocal(m_aoiGroundRect, view_rect);
469  m_aoiViewRect = view_rect;
471
472  return getChip(m_aoiViewRect);
473 }
bool valid() const
const ossimMapProjection * getAsMapProjection() const
const ossimDpt & ul() const
Definition: ossimDrect.h:339
virtual ossimGpt inverse(const ossimDpt &projectedPoint) const =0
virtual void setMetersPerPixel(const ossimDpt &gsd)
const ossimDpt & lr() const
Definition: ossimDrect.h:341
◆ getChip() [4/4]
ossimRefPtr< ossimImageData > ossimChipProcTool::getChip ( )
Returns
ossimImageData object. This can be null/not-valid if not initialized.
Definition at line 515 of file ossimChipProcTool.cpp.
References ossimImageChain::getTile(), m_aoiViewRect, m_procChain, and ossimRefPtr< T >::valid().
Referenced by ossimHlzTool::execute(), and getChip().
516 {
518  if(m_procChain.valid())
519  {
520  chip = m_procChain->getTile( m_aoiViewRect, 0 );
521  }
522  return chip;
523 }
bool valid() const
◆ getManager()
ossimListenerManager * ossimChipProcTool::getManager ( )
virtual
Definition at line 525 of file ossimChipProcTool.cpp.
526 {
527  return this;
528 };
◆ getObject() [1/2]
ossimObject * ossimChipProcTool::getObject ( )
virtual
Definition at line 530 of file ossimChipProcTool.cpp.
531 {
532  return this;
533 }
◆ getObject() [2/2]
const ossimObject * ossimChipProcTool::getObject ( ) const
virtual
Definition at line 535 of file ossimChipProcTool.cpp.
536 {
537  return this;
538 }
◆ getProductFilename()
const ossimFilename& ossimChipProcTool::getProductFilename ( ) const
inline
Definition at line 108 of file ossimChipProcTool.h.
Referenced by ossimToolServer::runCommand().
108 { return m_productFilename; }
◆ getProjectionOrigin()
bool ossimChipProcTool::getProjectionOrigin ( ossimGpt gpt)
protected
Parameters
gptPoint to initialize. Set to 0 unless lat or lon specified in KWL
Returns
false if no items found in KWL.
Note
Definition at line 1135 of file ossimChipProcTool.cpp.
References ossimKeywordNames::CENTRAL_MERIDIAN_KW, ossimKeywordlist::find(), ossimGpt::lat, ossimGpt::lon, m_geoScaled, ossimTool::m_kwl, ossimKeywordNames::ORIGIN_LATITUDE_KW, ossimString::size(), and ossimString::toFloat64().
Referenced by newUtmProjection().
1136 {
1137  gpt = ossimGpt(0,0,0);
1138  bool found_spec = false;
1140  if ( lookup.size() )
1141  {
1142  gpt.lat = lookup.toFloat64();
1143  if ( (gpt.lat < -90) || (gpt.lat > 90.0) )
1144  {
1145  std::string errMsg = "origin latitude range error! Valid range: -90 to 90";
1146  throw ossimException(errMsg);
1147  }
1148  m_geoScaled = true;
1149  found_spec = true;
1150  }
1151
1153  if ( lookup.size() )
1154  {
1155  gpt.lon = lookup.toFloat64();
1156  if ( (gpt.lon < -180.0) || (gpt.lon > 180.0) )
1157  {
1158  std::string errMsg = "central meridian range error! Valid range: -180 to 180";
1159  throw ossimException(errMsg);
1160  }
1161  found_spec = true;
1162  }
1163  return found_spec;
1164 }
static const char * CENTRAL_MERIDIAN_KW
ossim_float64 lon
ossim_float64 toFloat64() const
static const char * ORIGIN_LATITUDE_KW
ossim_float64 lat
◆ initialize() [1/2]
bool ossimChipProcTool::initialize ( ossimArgumentParser ap)
virtual
Intended for command-line app usage.
Parameters
apArg parser to initialize from.
Returns
FALSE if –help option requested or no params provided, so that derived classes can
Note
A throw with an error message of "usage" is used to get out when a usage is printed.
Reimplemented in ossimShorelineTool, ossimHdf5Tool, ossimHillshadeTool, ossimSubImageTool, ossimHlzTool, ossimViewshedTool, ossimOrthoTool, ossimSlopeTool, ossimPotraceTool, ossimBandMergeTool, and ossimRegTool.
Definition at line 97 of file ossimChipProcTool.cpp.
References ossimKeywordlist::addFile(), ossimKeywordlist::addPair(), ossimTool::initialize(), ossimTool::m_helpRequested, ossimTool::m_kwl, ossimNotify(), ossimNotifyLevel_NOTICE, ossimArgumentParser::read(), and ossimArgumentParser::writeErrorMessages().
Referenced by ossimBandMergeTool::initialize(), ossimRegTool::initialize(), ossimSlopeTool::initialize(), ossimOrthoTool::initialize(), ossimHlzTool::initialize(), ossimViewshedTool::initialize(), ossimHillshadeTool::initialize(), ossimHdf5Tool::initialize(), ossimShorelineTool::initialize(), and processRemainingArgs().
98 {
99  if (!ossimTool::initialize(ap))
100  return false;
101  if (m_helpRequested)
102  return true;
103
104  std::string tempString1;
105  ossimArgumentParser::ossimParameter stringParam1(tempString1);
106  std::string tempString2;
107  ossimArgumentParser::ossimParameter stringParam2(tempString2);
108  std::string tempString3;
109  ossimArgumentParser::ossimParameter stringParam3(tempString3);
110  std::string tempString4;
111  ossimArgumentParser::ossimParameter stringParam4(tempString4);
112  double tempDouble1;
113  ossimArgumentParser::ossimParameter doubleParam1(tempDouble1);
114  double tempDouble2;
115  ossimArgumentParser::ossimParameter doubleParam2(tempDouble2);
116  vector<ossimString> paramList;
117
118  ossim_uint32 readerPropIdx = 0;
119  ossim_uint32 writerPropIdx = 0;
120  ostringstream keys;
121
122  if ( ap.read("--load-options", stringParam1))
123  {
124  if (!m_kwl.addFile(tempString1.c_str()))
125  {
127  throw ossimException("Must supply an output file.");
128  }
129  }
130
131  if ( ap.read("--aoi-geo-bbox", stringParam1, stringParam2, stringParam3, stringParam4))
132  {
133  ostringstream ostr;
134  ostr<<tempString1<<" "<<tempString2<<" "<<tempString3<<" "<<tempString4<<ends;
135  m_kwl.addPair( AOI_GEO_RECT_KW, ostr.str() );
136  }
137
138  if ( ap.read("--aoi-geo-center", stringParam1, stringParam2))
139  {
140  ostringstream ostr;
141  ostr<<tempString1<<" "<<tempString2<<ends;
142  m_kwl.addPair( AOI_GEO_CENTER_KW, ostr.str() );
143  }
144
145  if ( ap.read("--aoi-map-bbox", stringParam1, stringParam2, stringParam3, stringParam4))
146  {
147  ostringstream ostr;
148  ostr<<tempString1<<" "<<tempString2<<" "<<tempString3<<" "<<tempString4<<ends;
149  m_kwl.addPair( AOI_MAP_RECT_KW, ostr.str() );
150  }
151
152  if ( ap.read("--aoi-size-meters", stringParam1, stringParam2))
153  {
154  ostringstream ostr;
155  ostr<<tempString1<<" "<<tempString2<<ends;
156  m_kwl.addPair( AOI_SIZE_METERS_KW, ostr.str() );
157  }
158
159  if ( ap.read("--aoi-size-pixels", stringParam1, stringParam2))
160  {
161  ostringstream ostr;
162  ostr<<tempString1<<" "<<tempString2<<ends;
163  m_kwl.addPair( AOI_SIZE_PIXELS_KW, ostr.str() );
164  }
165
166  if (ap.read("-b", stringParam1) || ap.read("--bands", stringParam1))
167  m_kwl.addPair( std::string(ossimKeywordNames::BANDS_KW), tempString1 );
168
169  if( ap.read("--central-meridian", stringParam1) )
170  m_kwl.addPair( std::string(ossimKeywordNames::CENTRAL_MERIDIAN_KW), tempString1 );
171
172  if( ap.read("--color-table", stringParam1) || ap.read("--lut", stringParam1) )
173  m_kwl.addPair( LUT_FILE_KW, tempString1 );
174
175  if ( ap.read("-e", stringParam1) || ap.read("--entry", stringParam1) )
176  m_kwl.addPair( std::string(ossimKeywordNames::ENTRY_KW), tempString1 );
177
178  if (ap.read("--dem", paramList))
179  {
180  ostringstream value;
181  for(ossim_uint32 idx=0; idx<paramList.size(); ++idx)
182  {
183  ostringstream key;
185  m_kwl.addPair(key.str(), paramList[idx] );
186  }
187  }
188
189  if( ap.read("--gsd", stringParam1) )
190  m_kwl.addPair( GSD_KW, tempString1 );
191
192  if ( ap.read("--hemisphere", stringParam1) )
193  m_kwl.addPair( std::string(ossimKeywordNames::HEMISPHERE_KW), tempString1 );
194
195  vector<ossimString> imageFnames;
196  if (ap.read("--image", imageFnames) || ap.read("-i", imageFnames))
197  {
198  if (imageFnames.size() == 1)
199  m_kwl.add(ossimKeywordNames::IMAGE_FILE_KW, imageFnames[0].chars() );
200  else for(ossim_uint32 idx=0; idx<imageFnames.size(); ++idx)
201  {
202  ostringstream key;
204  m_kwl.addPair(key.str(), imageFnames[idx] );
205  }
206  }
207
208  if( ap.read("--origin-latitude", stringParam1) )
209  m_kwl.addPair( std::string(ossimKeywordNames::ORIGIN_LATITUDE_KW), tempString1 );
210
211  if(ap.read("--output-file", stringParam1) || ap.read("-o", stringParam1))
213
214  if(ap.read("--output-radiometry", stringParam1))
215  m_kwl.addPair( OUTPUT_RADIOMETRY_KW, tempString1 );
216
217  if( ap.read("--projection", stringParam1) )
218  m_kwl.addPair( std::string(ossimKeywordNames::PROJECTION_KW), tempString1 );
219
220  while (ap.read("--reader-prop", stringParam1))
221  {
222  ostringstream key;
223  key << READER_PROPERTY_KW << readerPropIdx;
224  m_kwl.addPair(key.str(), tempString1 );
225  ++readerPropIdx;
226  }
227
228  if ( ap.read("--snap-tie-to-origin") )
229  m_kwl.addPair( SNAP_TIE_TO_ORIGIN_KW, TRUE_KW);
230
231  if( ap.read("--srs", stringParam1) )
232  {
233  ossimString os = tempString1;
234  if ( os.contains("EPSG:") )
235  os.gsub( ossimString("EPSG:"), ossimString("") );
236  m_kwl.addPair( SRS_KW, os.string() );
237  }
238
239  if( ap.read("--tile-size", stringParam1) )
240  m_kwl.addPair( TILE_SIZE_KW, tempString1 );
241
242  if( ap.read("-w", stringParam1) || ap.read("--writer", stringParam1) )
243  m_kwl.addPair( WRITER_KW, tempString1);
244
245  while (ap.read("--writer-prop", stringParam1))
246  {
247  ostringstream key;
248  key << WRITER_PROPERTY_KW << writerPropIdx;
249  m_kwl.addPair(key.str(), tempString1 );
250  ++writerPropIdx;
251  }
252
253  if( ap.read("--zone", stringParam1) )
254  m_kwl.addPair( std::string(ossimKeywordNames::ZONE_KW), tempString1);
255
256  return true;
257 }
static const char * OUTPUT_FILE_KW
bool addFile(const char *file)
bool read(const std::string &str)
search for an occurance of a string in the argument list, on sucess remove that occurance from the li...
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
static const char * ZONE_KW
virtual bool initialize(ossimArgumentParser &ap)
Initializes from command line arguments.
Definition: ossimTool.cpp:58
static const char * ENTRY_KW
static const char * HEMISPHERE_KW
ossimString & gsub(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false)
Substitutes searchKey string with replacementValue and returns a reference to *this.
static const char * ELEVATION_SOURCE_KW
void writeErrorMessages(std::ostream &output, ossimErrorSeverity sevrity=OSSIM_BENIGN)
write out error messages at an above specified .
const std::string & string() const
Definition: ossimString.h:414
◆ initialize() [2/2]
void ossimChipProcTool::initialize ( const ossimKeywordlist kwl)
virtual
If the utility is run from a command line, the initialize(ossimArgumentParser) will assign the member master KWL and pass it to this method. Web service calls will fill a KWL and pass it.
This base class implementation should be called by the derived class implementation (assuming the derived class needs to pull some parameters out of the KWL before the chains are set up.
This method will instantiate the output projection and define the output bounding rect and product size in pixels. The processing chain (stored in m_procChain) will be completely initialized and ready for calls to getTile(). Then either getChip() or execute() can be called depending on usage to fetch product.
Note
Reimplemented in ossimHdf5Tool, ossimSubImageTool, ossimShorelineTool, ossimOrthoTool, ossimSlopeTool, ossimViewshedTool, ossimHlzTool, ossimPotraceTool, ossimBandMergeTool, and ossimRegTool.
Definition at line 321 of file ossimChipProcTool.cpp.
References ossimKeywordlist::addList(), ossimKeywordlist::clear(), ossimKeywordlist::findKey(), ossimScalarTypeLut::instance(), ossimTool::m_helpRequested, ossimTool::m_kwl, and m_productScalarType.
322 {
323  m_helpRequested = false;
324
325  // Don't copy KWL if member KWL passed in:
326  if (&kwl != &m_kwl)
327  {
328  // Start with clean options keyword list.
329  m_kwl.clear();
330  m_kwl.addList( kwl, true );
331  }
332
333  // Assign some members from KWL:
335  getScalarTypeFromString( m_kwl.findKey( OUTPUT_RADIOMETRY_KW ) );
336
338
339  // Create chains for input sources.
340  loadImageFiles();
341
342  // Load any specified DEMs:
343  loadDemFiles();
344
345  // Initialize projection and propagate to chains.
347
348  // Pass control to derived class so it can add its specific processing to the chain(s). This
349  // should return an initialized m_procChain.
351  finalizeChain();
352 }
virtual void initProcessingChain()=0
virtual void loadDemFiles()
Loads all DEM files specified in master KWL into the elev manager&#39;s database.
void addList(const ossimKeywordlist &src, bool overwrite=true)
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
virtual void finalizeChain()
void createOutputProjection()
virtual void loadImageFiles()
◆ initializeAOI()
void ossimChipProcTool::initializeAOI ( )
protectedvirtual
Initialization will either come from user defined cut options or the source bounding rect with user options taking precidence.
Note
Definition at line 931 of file ossimChipProcTool.cpp.
References ossimKeywordlist::hasKey(), m_aoiGroundRect, m_aoiViewRect, ossimTool::m_kwl, ossimGrect::makeNan(), and ossimIrect::makeNan().
Referenced by ossimViewshedTool::initializeAOI().
932 {
933  // Nan rect for starters.
936  ossimString lookup;
937
938  // Image size:
939  ossimIpt imageSize(0,0);
940  if (m_kwl.hasKey(AOI_SIZE_PIXELS_KW))
941  {
942  lookup = m_kwl.findKey( AOI_SIZE_PIXELS_KW );
943  lookup.trim();
944  imageSize.x = lookup.before(" ").toUInt32();
945  imageSize.y = lookup.after(" ").toUInt32();
946  }
947
948  // The AOI rect can be specified in different ways:
949  if ( m_kwl.hasKey( AOI_GEO_CENTER_KW.c_str() ) )
950  {
951  // A center point was given:
952  ossimGpt centerGpt;
953  findCenterGpt(centerGpt);
954
955  // A center point spec can be accompanied by a width/height (in meters or pixels):
956  ossimDpt sizeMeters;
957  sizeMeters.makeNan();
958  if (m_kwl.hasKey(AOI_SIZE_METERS_KW))
959  {
960  lookup = m_kwl.findKey( AOI_SIZE_METERS_KW );
961  lookup.trim();
962  sizeMeters.x = lookup.before(" ").toDouble();
963  sizeMeters.y = lookup.after(" ").toDouble();
964  }
965  else if (m_kwl.hasKey(AOI_SIZE_PIXELS_KW))
966  {
967  if ( (imageSize.x > 0)&& (imageSize.y > 0 ) )
968  {
969  sizeMeters.x = imageSize.x*m_gsd.x;
970  sizeMeters.y = imageSize.y*m_gsd.y;
971  }
972  }
973  if (!sizeMeters.hasNans())
974  {
975  ossimDpt metersPerDegree (centerGpt.metersPerDegree());
976  double dlat = sizeMeters.y/metersPerDegree.y/2.0;
977  double dlon = sizeMeters.x/metersPerDegree.x/2.0;
978  ossimGpt ulgpt (centerGpt.lat + dlat, centerGpt.lon - dlon);
979  ossimGpt lrgpt (centerGpt.lat - dlat, centerGpt.lon + dlon);
980  m_aoiGroundRect = ossimGrect(ulgpt, lrgpt);
981  sizeMeters.x = imageSize.x*m_gsd.x;
982  sizeMeters.y = imageSize.y*m_gsd.y;
983  }
984  if (!sizeMeters.hasNans())
985  {
986  ossimDpt metersPerDegree (centerGpt.metersPerDegree());
987  double dlat = sizeMeters.y/metersPerDegree.y/2.0;
988  double dlon = sizeMeters.x/metersPerDegree.x/2.0;
989  ossimGpt ulgpt (centerGpt.lat + dlat, centerGpt.lon - dlon);
990  ossimGpt lrgpt (centerGpt.lat - dlat, centerGpt.lon + dlon);
991  m_aoiGroundRect = ossimGrect(ulgpt, lrgpt);
992  m_needCutRect = true;
993  }
994  }
995
996  else if ( m_kwl.hasKey( AOI_GEO_RECT_KW ) )
997  {
998  ossimString lookup = m_kwl.findKey(AOI_GEO_RECT_KW);
999  lookup.trim();
1000  vector<ossimString> substrings = lookup.split(" ");
1001  if (substrings.size() != 4)
1002  {
1003  ostringstream errMsg;
1004  errMsg << "ossimChipProcUtil ["<<__LINE__<<"] Incorrect number of values specified for "
1005  "aoi_geo_rect!";
1006  throw( ossimException(errMsg.str()) );
1007  }
1008  ossim_float64 minLatF = substrings[0].toFloat64();
1009  ossim_float64 minLonF = substrings[1].toFloat64();
1010  ossim_float64 maxLatF = substrings[2].toFloat64();
1011  ossim_float64 maxLonF = substrings[3].toFloat64();
1012
1013  // Check for swap so we don't get a negative height.
1014  // Note no swap check for longitude as box could cross date line.
1015  if ( minLatF > maxLatF )
1016  {
1017  ossim_float64 tmpF = minLatF;
1018  minLatF = maxLatF;
1019  maxLatF = tmpF;
1020  }
1021
1022  // Assume cut box is edge to edge or "Pixel Is Area". Our
1023  // AOI(area of interest) uses center of pixel or "Pixel Is Point"
1024  // so get the degrees per pixel and shift AOI to center.
1025  ossimGpt ulgpt (maxLatF, minLonF);
1026  ossimGpt lrgpt (minLatF , maxLonF);
1027  m_aoiGroundRect = ossimGrect(ulgpt, lrgpt);
1028  m_needCutRect = true;
1029
1030  if ( (imageSize.x > 0) && (imageSize.y > 0) )
1031  {
1033  dynamic_cast<ossimMapProjection*>(m_geom->getProjection());
1034  if (mapProj.valid())
1035  {
1036  ossimDpt gsd;
1037  gsd.x = std::fabs( maxLonF - minLonF ) / imageSize.x;
1038  gsd.y = std::fabs( maxLatF - minLatF ) / imageSize.y;
1039  mapProj->setDecimalDegreesPerPixel(gsd);
1040  }
1041  }
1042  }
1043
1044  else if ( m_kwl.hasKey( AOI_MAP_RECT_KW ) )
1045  {
1047  dynamic_cast<ossimMapProjection*>(m_geom->getProjection());
1048  if (mapProj.valid())
1049  {
1050  ossimString lookup = m_kwl.findKey(AOI_MAP_RECT_KW);
1051  lookup.trim();
1052  vector<ossimString> substrings = lookup.split(", ", true);
1053  if (substrings.size() != 4)
1054  {
1055  ostringstream errMsg;
1056  errMsg << "ossimChipProcUtil ["<<__LINE__<<"] Incorrect number of values specified for "
1057  "aoi_geo_rect!";
1058  throw( ossimException(errMsg.str()) );
1059  }
1060  ossim_float64 minX = substrings[0].toFloat64();
1061  ossim_float64 minY = substrings[1].toFloat64();
1062  ossim_float64 maxX = substrings[2].toFloat64();
1063  ossim_float64 maxY = substrings[3].toFloat64();
1064
1065  // Check for swap so we don't get a negative height.
1066  // Note no swap check for longitude as box could cross date line.
1067  if ( minX > maxX )
1068  {
1069  ossim_float64 tmpF = minX;
1070  minX = maxX;
1071  maxX = tmpF;
1072  }
1073  if ( minY > maxY )
1074  {
1075  ossim_float64 tmpF = minY;
1076  minY = maxY;
1077  maxY = tmpF;
1078  }
1079
1080  ossimDpt ulMap (minX, maxY);
1081  ossimDpt lrMap (maxX , minY);
1082  ossimGpt ulGeo = mapProj->inverse(ulMap);
1083  ossimGpt lrGeo = mapProj->inverse(lrMap);
1084  m_aoiGroundRect = ossimGrect(ulGeo, lrGeo);
1085  m_needCutRect = true;
1086
1087  if ( (imageSize.x > 0) && (imageSize.y > 0) )
1088  {
1090  dynamic_cast<ossimMapProjection*>(m_geom->getProjection());
1091  if (mapProj.valid())
1092  {
1093  ossimDpt gsd;
1094  gsd.x = std::fabs( maxX - minX ) / imageSize.x;
1095  gsd.y = std::fabs( maxY - minY ) / imageSize.y;
1096  mapProj->setMetersPerPixel(gsd);
1097  }
1098  }
1099  }
1100  }
1101
1102  // If no user defined rect set to scene bounding rect.
1103  if ( m_aoiGroundRect.hasNans() )
1104  setAoiToInputs();
1105
1106  // If AOI established, we can set projection TP and origin if applicable:
1108  dynamic_cast<ossimMapProjection*>(m_geom->getProjection());
1109  if (!m_aoiGroundRect.hasNans() && mapProj.valid())
1110  {
1111  // Geo-scaled projection needs to know the reference latitude:
1112  if (m_geoScaled)
1113  {
1114  // The origin may have ben explicitely specified,or just use midpoint of AOI:
1115  ossimGpt origin;
1116  if (!getProjectionOrigin(origin))
1117  origin = m_aoiGroundRect.midPoint();
1118  mapProj->setOrigin(origin);
1120  }
1121
1122  // Set the tie-point of the projection to the AOI's UL.
1123  // Adjust it to be on an even pixel distance from projection origin if desired:
1124  mapProj->setUlTiePoints(m_aoiGroundRect.ul());
1125  bool snapToTP = false;
1126  m_kwl.getBoolKeywordValue(snapToTP, SNAP_TIE_TO_ORIGIN_KW.c_str());
1127  if ( snapToTP )
1128  mapProj->snapTiePointToOrigin();
1129
1130  // Re-establish the AOI view rect based on updated projection:
1132  }
1133 }
ossimString before(const ossimString &str, std::string::size_type pos=0) const
METHOD: before(str, pos) Returns string beginning at pos and ending one before the token str If strin...
bool valid() const
void makeNan()
Definition: ossimGrect.h:284
double y
virtual void setOrigin(const ossimGpt &origin)
Sets theOrigin to origin.
bool hasKey(const std::string &key) const
Checks for key in map.
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
ossim_uint32 toUInt32() const
ossim_float64 lon
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
double toDouble() const
bool getBoolKeywordValue(bool &rtn_val, const char *keyword, const char *prefix=0) const
[OLK, Aug/2008] Sets the boolean <rtn_val> depending on value associated with keyword for values = (y...
Definition: ossimDpt.h:67
ossimGpt midPoint() const
Definition: ossimGrect.h:178
bool getProjectionOrigin(ossimGpt &gpt)
void findCenterGpt(ossimGpt &gpt)
Tries to determine the AOI center point based on KWL entries, else returns NaNs in gpt...
void makeNan()
double x
virtual void setUlTiePoints(const ossimGpt &gpt)
ossimDpt metersPerDegree() const
Definition: ossimGpt.cpp:498
ossim_float64 lat
ossimString after(const ossimString &str, std::string::size_type pos=0) const
METHOD: after(str, pos) Returns string immediately after the token str.
void setAoiToInputs()
void makeNan()
◆ initializeProjectionGsd()
void ossimChipProcTool::initializeProjectionGsd ( )
protectedvirtual
This loops through all chains to find the minimum gsd.
Note
Definition at line 856 of file ossimChipProcTool.cpp.
References ossimKeywordlist::findKey(), ossimImageGeometry::getProjection(), m_geom, and ossimTool::m_kwl.
Referenced by ossimViewshedTool::initializeProjectionGsd().
857 {
858  // The GSD computation may be a chicken-and-egg problem. Need to try different methods depending
859  // on information available in KWL including specified input images and DEMs.
860
862  dynamic_cast<ossimMapProjection*>(m_geom->getProjection());
863
864  ossimString lookup = m_kwl.findKey( GSD_KW );
865  if ( lookup.size() )
866  m_gsd.y = m_gsd.x = lookup.toFloat64();
867
868  if (m_gsd.hasNans() && m_projIsIdentity && m_geom.valid())
870
871  if (m_gsd.hasNans())
872  {
873  // No GSD specified, use minimum among all input images:
874  ossimGpt chainTiePoint;
875  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx = m_imgLayers.begin();
876  while ( chainIdx != m_imgLayers.end() )
877  {
878  ossimRefPtr<ossimImageGeometry> geom = (*chainIdx)->getImageGeometry();
879  if (geom.valid())
880  {
881  ossimDpt gsd;
882  geom->getMetersPerPixel(gsd);
883  gsd.y = gsd.x = gsd.mean();
884  if (m_gsd.hasNans() || ( m_gsd.x > gsd.x))
885  m_gsd = gsd;
886  }
887  ++chainIdx;
888  }
889  }
890
891  if (m_gsd.hasNans())
892  {
893  // Still no GSD established, try using minimum among all input DEMs (the operation possibly
894  // involves DEMs as inputs):
895  std::vector<ossimFilename>::iterator demFile = m_demSources.begin();
896  while ( demFile != m_demSources.end() )
897  {
898  ossimImageGeometry geom;
899  if (geom.open(*demFile))
900  {
901  ossimDpt gsd;
902  geom.getMetersPerPixel(gsd);
903  gsd.y = gsd.x = gsd.mean();
904  if (m_gsd.hasNans() || ( m_gsd.x > gsd.x))
905  m_gsd = gsd;
906  }
907  ++demFile;
908  }
909  }
910
911  if (m_gsd.hasNans())
912  {
913  // Still no GSD specified. As a last resort, use the elevation database nominal GSD at center
914  // as output GSD. This is valid since most operations without input images depend on DEM data.
915  // Requires that the center point be given in input spec:
916  ossimGpt centerGpt;
917  findCenterGpt(centerGpt);
918  if (!centerGpt.hasNans())
919  {
922  if (m_gsd.x == 0) // getMeanSpacing unfortunately return 0 for unknown GSD
923  m_gsd.makeNan();
924  }
925  }
926
927  if (!m_gsd.hasNans())
928  mapProj->setMetersPerPixel(m_gsd);
929 }
virtual double getMeanSpacingMeters() const
Returns the mean post spacing (in meters) for the highest resolution DEM in the list or NaN if no DEM...
double mean() const
Returns the average of x and y.
Definition: ossimDpt.h:159
bool valid() const
double y
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
bool open(const ossimFilename &image)
Shortcut way of getting to an image&#39;s geometry when access to pixels is not needed.
std::vector< ossimFilename > m_demSources
virtual double getHeightAboveEllipsoid(const ossimGpt &gpt)
Definition: ossimGpt.h:135
double x
void makeNan()
◆ initProcessingChain()
virtual void ossimChipProcTool::initProcessingChain ( )
protectedpure virtual
◆ isChipProcessor()
virtual bool ossimChipProcTool::isChipProcessor ( ) const
inlinevirtual
Can be done with dunamic cast and pointer test, but not sure how that is supported in SWIG (OLK 11/2015).
Definition at line 90 of file ossimChipProcTool.h.
90 { return true; }
◆ loadDemFiles()
void ossimChipProcTool::loadDemFiles ( )
protectedvirtual
Definition at line 648 of file ossimChipProcTool.cpp.
References ossimKeywordNames::ELEVATION_SOURCE_KW, ossimString::empty(), ossimKeywordlist::findKey(), ossimElevManager::instance(), ossimFilename::isReadable(), ossimElevManager::loadElevationPath(), m_demSources, ossimTool::m_kwl, and ossimKeywordlist::numberOf().
649 {
651  if (numDems == 0)
652  return;
653
654  cout<<m_kwl<<endl;//TODO:REMOVE
655  ossim_uint32 count = numDems;
656  for (ossim_uint32 i=0; count > 0; ++i)
657  {
658  ossimFilename f;
659  if (numDems == 1)
660  {
661  ostringstream key;
662  key << ossimKeywordNames::ELEVATION_SOURCE_KW; // Try non-indexed first
663  f = m_kwl.findKey( key.str() );
664  }
665  if (f.empty())
666  {
667  ostringstream key;
669  cout<<key.str()<<endl;//TODO:REMOVE
670  f = m_kwl.findKey( key.str() );
671  }
672  if ( f.empty() )
673  continue;
674
675  if (!f.isReadable())
676  {
677  ostringstream errMsg;
678  errMsg << "ossimChipProcUtil ["<<__LINE__<<"] Could not open DEM file: <" << f << ">";
679  throw ossimException(errMsg.str());
680  }
681
682  m_demSources.push_back(f);
684  --count;
685  }
686 }
ossim_uint32 numberOf(const char *str) const
bool loadElevationPath(const ossimFilename &path, bool set_as_first=false)
Adds a new elevation file (or multiple files if path is a directory) to the collection.
bool isReadable() const
bool empty() const
◆ loadImageFiles()
void ossimChipProcTool::loadImageFiles ( )
protectedvirtual
This is usually the input image sources but could also be used for reading list of color sources.
Note
Reimplemented in ossimHdf5Tool.
Definition at line 540 of file ossimChipProcTool.cpp.
References createInputChain(), ossimString::empty(), ossimKeywordNames::ENTRY_KW, ossimKeywordlist::find(), ossimKeywordlist::findKey(), getBandList(), ossimKeywordNames::IMAGE_FILE_KW, m_imgLayers, ossimTool::m_kwl, ossimKeywordlist::numberOf(), ossimSingleImageChain::setBandSelection(), ossimString::toUInt32(), and ossimRefPtr< T >::valid().
541 {
543  ossim_uint32 count = numImages;
544  ossim_uint32 entryIndex = 0;
545
546  // Returns 0 if no entry found. This is default anyway.
547  ossim_uint32 globalEntryValue = ossimString(m_kwl.find(ossimKeywordNames::ENTRY_KW)).toUInt32();
548
549  for (ossim_uint32 i=0; count > 0; ++i)
550  {
551  ossimFilename f;
552  if (numImages == 1)
553  {
554  ostringstream key;
555  key << ossimKeywordNames::IMAGE_FILE_KW; // Try non-indexed first
556  f = m_kwl.findKey( key.str() );
557  }
558  if (f.empty())
559  {
560  ostringstream key;
562  f = m_kwl.findKey( key.str() );
563  }
564  if ( f.empty() )
565  continue;
566
567  // Look for the entry key, e.g. image_source0.entry: 10
568  ostringstream entryKey;
570  ossimString os = m_kwl.findKey(entryKey.str());
571  if (!os.empty())
572  entryIndex = os.toUInt32();
573  else
574  entryIndex = globalEntryValue;
575
576  // Add it:
578  if (!ic.valid())
579  {
580  ostringstream errMsg;
581  errMsg<<"ERROR: ossimChipProcUtil ["<<__LINE__<<"] Could not open <"<<f<<">"<<ends;
582  throw ossimException(errMsg.str());
583  }
584
585  // Need a band selector?
586  std::vector<ossim_uint32> bandList(0);
587  getBandList(i, bandList );
588  if ( bandList.size() )
589  ic->setBandSelection( bandList );
590
591  m_imgLayers.push_back(ic);
592  --count;
593  }
594 }
void getBandList(ossim_uint32 image_idx, std::vector< ossim_uint32 > &bandList) const
bool valid() const
void setBandSelection(const std::vector< ossim_uint32 > &bandList)
method to set band selector.
bool empty() const
ossimRefPtr< ossimSingleImageChain > createInputChain(const ossimFilename &image_file, ossim_uint32 entry_index=0)
Creates the ossimSingleImageChain from image filename and populates the chain with resampler and prod...
◆ mosaicDemSources()
ossimRefPtr< ossimImageSource > ossimChipProcTool::mosaicDemSources ( )
protected
This method determines which DEMs cover the AOI and creates an image mosaic with the DEMS serving as pixel sources. Throws exceptions.
Definition at line 1384 of file ossimChipProcTool.cpp.
References createInputChain(), ossimRefPtr< T >::get(), ossimElevManager::getCellsForBounds(), ossimSingleImageChain::getImageHandler(), ossimSingleImageChain::getImageRenderer(), ossimElevManager::instance(), m_aoiGroundRect, m_demSources, m_geom, and ossimRefPtr< T >::valid().
Referenced by ossimHillshadeTool::initProcessingChain(), and ossimHlzTool::initProcessingChain().
1385 {
1386  ostringstream xmsg;
1387  ossimRefPtr<ossimImageSource> demMosaic = 0;
1388
1389  if (m_demSources.empty())
1390  {
1391  // Establish connection to DEM posts directly as raster "images" versus using the OSSIM elev
1392  // manager that performs interpolation of DEM posts for arbitrary locations. These elev images
1393  // feed into a combiner in order to have a common tap for elev pixels:
1396  }
1397
1398  // Open a raster image for each elevation source being considered:
1400  vector<ossimFilename>::iterator fname_iter = m_demSources.begin();
1401  while (fname_iter != m_demSources.end())
1402  {
1404  if (!chain.valid() || !chain->getImageRenderer().valid() )
1405  {
1406  xmsg<<"ossimChipProcUtil:"<<__LINE__<<" Cannot open DEM file at <"<<*fname_iter<<">";
1407  throw(xmsg.str());
1408  }
1409
1410  // Set up the input chain with proper renderer IVT:
1412  (chain->getImageHandler()->getImageGeometry().get(), m_geom.get());
1413  chain->getImageRenderer()->setImageViewTransform(ivt.get());
1414  ossimRefPtr<ossimConnectableObject> connectable = chain.get();
1415  elevChains.push_back(connectable);
1416  ++fname_iter;
1417  }
1418
1419  if (elevChains.size() == 1)
1420  demMosaic = (ossimImageSource*) elevChains[0].get();
1421  else
1422  demMosaic = new ossimImageMosaic(elevChains);
1423
1424  return demMosaic;
1425 }
bool valid() const
void getCellsForBounds(const std::string &connectionString, const ossim_float64 &minLat, const ossim_float64 &minLon, const ossim_float64 &maxLat, const ossim_float64 &maxLon, std::vector< ossimFilename > &cells, ossim_uint32 maxNumberOfCells=0)
Gets a list of elevation cells needed to cover bounding box.
std::vector< ossimRefPtr< ossimConnectableObject > > ConnectableObjectList
ossimRefPtr< const ossimImageRenderer > getImageRenderer() const
◆ newIdentityProjection()
ossimRefPtr< ossimMapProjection > ossimChipProcTool::newIdentityProjection ( )
protected
This will have a rotation if up is up is selected. Also set m_outputProjection to the input's for area of interest.
Definition at line 751 of file ossimChipProcTool.cpp.
References ossimProjection::dup(), ossimRefPtr< T >::get(), ossimUtmProjection::getHemisphere(), ossimImageHandler::getImageGeometry(), ossimSingleImageChain::getImageHandler(), ossimImageGeometry::getProjection(), ossimUtmProjection::getZone(), m_demSources, m_imgLayers, m_projIsIdentity, ossimImageGeometry::open(), ossimUtmProjection::setHemisphere(), ossimUtmProjection::setZone(), and ossimRefPtr< T >::valid().
752 {
754  ossimProjection* input_proj = 0;
755  ossimRefPtr<ossimMapProjection> output_proj = 0;
756  ossimRefPtr<ossimImageRenderer> resampler = 0;
757
758  if ( m_imgLayers.size() )
759  {
760  sic = m_imgLayers[0];
761  if (sic.valid())
762  {
764  if (ih.valid())
765  {
767  if (geom.valid())
768  {
769  input_proj = geom->getProjection();
770
771  // Check if input is UTM, need to copy zone and hemisphere if so:
772  ossimUtmProjection* input_utm = dynamic_cast<ossimUtmProjection*>(input_proj);
773  if ( input_utm )
774  {
776  output_utm->setZone(input_utm->getZone());
777  output_utm->setHemisphere(input_utm->getHemisphere());
778  output_proj = output_utm.get();
779  }
780  else
781  {
782  input_proj = dynamic_cast<ossimMapProjection*>( geom->getProjection() );
783  if (input_proj)
784  {
785  output_proj = (ossimMapProjection*) input_proj->dup();
786  m_projIsIdentity = true;
787  }
788  }
789  }
790  }
791  }
792  }
793
794  // try input dem "image" if specified:
795  if (!output_proj.valid() && (m_demSources.size()))
796  {
797  ossimImageGeometry geom;
798  if (geom.open(m_demSources[0]))
799  {
800  input_proj = dynamic_cast<ossimMapProjection*>(geom.getProjection());
801  if (input_proj)
802  {
803  output_proj = (ossimMapProjection*) input_proj->dup();
804  m_projIsIdentity = true;
805  }
806  }
807  }
808
809  return output_proj;
810 }
virtual ossimObject * dup() const =0
bool valid() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
void setZone(const ossimGpt &ground)
ossim_int32 getZone() const
void setHemisphere(const ossimGpt &ground)
◆ newUtmProjection()
ossimRefPtr< ossimMapProjection > ossimChipProcTool::newUtmProjection ( )
protected
Returns
new ossimUtmProjection.
Definition at line 812 of file ossimChipProcTool.cpp.
References ossimKeywordlist::findKey(), ossimRefPtr< T >::get(), getProjectionOrigin(), ossimKeywordNames::HEMISPHERE_KW, ossimTool::m_kwl, ossimUtmProjection::setHemisphere(), ossimUtmProjection::setZone(), ossimString::size(), ossimString::string(), ossimString::toUInt32(), ossimString::upcase(), and ossimKeywordNames::ZONE_KW.
813 {
814  // Make projection:
816
817  // Set the zone from keyword option:
818  bool setZone = false;
819  ossim_int32 zone = 0;
820  std::string value = m_kwl.findKey( std::string( ossimKeywordNames::ZONE_KW ) );
821  if ( value.size() )
822  zone = ossimString(value).toUInt32();
823  if ( (zone > 0 ) && ( zone < 61 ) )
824  {
825  utm->setZone( zone );
826  setZone = true;
827  }
828
829  // Set the hemisphere from keyword option:
830  bool setHemisphere = false;
832  if ( h.size() )
833  {
834  h.upcase();
835  if ( ( h == "N" ) || ( h == "NORTH" ) || ( h == "S" ) || ( h == "SOUTH" ) )
836  {
837  utm->setHemisphere( h.string()[0] );
838  setHemisphere = true;
839  }
840  }
841
842  if ( !setZone || !setHemisphere )
843  {
844  // Check for user set "central_meridian" and "origin_latitude":
845  ossimGpt origin;
846  getProjectionOrigin(origin);
847  if ( !setZone )
848  utm->setZone(origin);
849  if ( !setHemisphere )
850  utm->setHemisphere(origin);
851  }
852
853  return ossimRefPtr<ossimMapProjection>(utm.get());
854 }
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
int ossim_int32
◆ newWriter()
ossimRefPtr< ossimImageFileWriter > ossimChipProcTool::newWriter ( )
protected
This will use the writer option (-w or –writer), if present; else, it will be derived from the output file extention. This will also set any writer properties passed in.
Returns
new ossimImageFileWriter.
Note
Definition at line 1450 of file ossimChipProcTool.cpp.
Referenced by execute().
1451 {
1453
1454  ossimString lookup = m_kwl.findKey( WRITER_KW );
1455  if ( lookup.size() )
1456  {
1458  if ( !writer.valid() )
1459  {
1460  ostringstream errMsg;
1461  errMsg << "ossimChipProcUtil ["<<__LINE__<<"] ERROR creating writer for <"<<lookup<<">"
1462  <<ends;
1463  throw ossimException(errMsg.str());
1464  }
1465  }
1466  else // Create from output file extension.
1467  {
1469  createWriterFromExtension( m_productFilename.ext() );
1470
1471  if ( !writer.valid() )
1472  {
1473  ostringstream errMsg;
1474  errMsg << "ossimChipProcUtil ["<<__LINE__<<"] ERROR creating writer from extension <"
1475  <<m_productFilename.ext()<<">"<<ends;
1476  throw ossimException(errMsg.str());
1477  }
1478  }
1479
1480  // Set the output name.
1481  writer->setFilename( m_productFilename );
1482
1483  // Add any writer props.
1484  ossim_uint32 count = m_kwl.numberOf( WRITER_PROPERTY_KW.c_str() );
1485  for (ossim_uint32 i = 0; i < count; ++i)
1486  {
1487  ossimString key = WRITER_PROPERTY_KW;
1488  key += ossimString::toString(i);
1489  lookup = m_kwl.findKey( key.string() );
1490  if ( lookup.size() )
1491  {
1492  std::vector<ossimString> splitArray;
1493  lookup.split(splitArray, "=");
1494  if(splitArray.size() == 2)
1495  {
1497  new ossimStringProperty(splitArray[0], splitArray[1]);
1498
1499  writer->setProperty( prop );
1500  }
1501  }
1502  }
1503
1504  // Output tile size:
1505  lookup = m_kwl.findKey( TILE_SIZE_KW );
1506  if ( lookup.size() )
1507  {
1508  ossimIpt tileSize;
1509  tileSize.x = lookup.toInt32();
1510  if ( (tileSize.x % 16) == 0 )
1511  {
1512  tileSize.y = tileSize.x;
1513  writer->setTileSize( tileSize );
1514  }
1515  }
1516
1517  return writer;
1518 }
bool valid() const
static ossimImageWriterFactoryRegistry * instance()
Numeric to string methods.
virtual void setTileSize(const ossimIpt &tileSize)
Sets the output image tiling size if supported by the writer.
ossimKeywordlist m_kwl
ossim_int32 toInt32() const
ossimFilename m_productFilename
virtual void setFilename(const ossimFilename &file)
ossim_int32 y
Definition: ossimIpt.h:142
ossimImageFileWriter * createWriter(const ossimFilename &filename) const
ossimString ext() const
ossim_int32 x
Definition: ossimIpt.h:141
◆ operator=()
const ossimChipProcTool& ossimChipProcTool::operator= ( const ossimChipProcTool )
inlineprotected
Hidden from use assignment operator.
Definition at line 207 of file ossimChipProcTool.h.
207 { return *this; }
◆ processRemainingArgs()
void ossimChipProcTool::processRemainingArgs ( ossimArgumentParser ap)
protected
Intended to be called after derived class has picked off its own options from the parser, and arguments remain (such as input and output filenames).
Note
Definition at line 259 of file ossimChipProcTool.cpp.
References ossimKeywordlist::add(), ossimArgumentParser::argc(), ossimString::chars(), ossimArgumentParser::errors(), ossimKeywordlist::find(), ossimTool::getClassName(), ossimKeywordNames::IMAGE_FILE_KW, initialize(), ossimTool::m_kwl, ossimNotify(), ossimNotifyLevel_NOTICE, ossimKeywordNames::OUTPUT_FILE_KW, ossimArgumentParser::read(), ossimArgumentParser::reportRemainingOptionsAsUnrecognized(), ossimFilename::setExtension(), ossimKeywordlist::write(), and ossimArgumentParser::writeErrorMessages().
Referenced by ossimSlopeTool::initialize(), and ossimSubImageTool::initialize().
260 {
261  // ossim_uint32 inputIdx = 0;
262
263  bool dumpKwl = false;
264  if ( ap.read("--dump-options") )
265  dumpKwl = true;
266
267  if ( ap.argc() >= 2 )
268  {
269  // Output file is last arg:
271  }
272  else
273  {
275  {
277  throw ossimException("Must supply an output file.");
278  }
279  }
280
281  if ( ap.argc() > 2 ) // User passed inputs in front of output file.
282  {
283  int pos = 1; // ap.argv[0] is application name.
284  int idx = 0;
285  while ( pos < (ap.argc()-1) )
286  {
287  ostringstream key;
289  m_kwl.add( key.str().c_str(), ap[pos] );
290
291  ++pos; // Go to next arg...
292
293  } // End: while ( pos < (ap.argc()-1) )
294
295  } // End: if ( ap.argc() > 2 )
296
297  // End of arg parsing.
299  if ( ap.errors() )
300  {
302  throw ossimException("Unknown option...");
303  }
304
305  if (dumpKwl)
306  {
308  f.setExtension("kwl");
309  if (!m_kwl.write(f.chars()))
310  {
311  ostringstream xmsg;
312  xmsg<<"ossimChipProcUtil:"<<__LINE__<<" Error encountered writing options file to <"<<f<<">";
313  throw ossimException(xmsg.str());
314  }
315  ossimNotify(ossimNotifyLevel_NOTICE)<<"\nWrote options file to <"<<f<<">"<<endl;
316  }
317
318  initialize(m_kwl);
319 }
Initial method to be ran prior to execute.
virtual ossimString getClassName() const
Definition: ossimTool.cpp:36
Definition: ossimTool.h:148
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
void reportRemainingOptionsAsUnrecognized(ossimErrorSeverity severity=OSSIM_BENIGN)
for each remaining option report it as an unrecongnized.
bool errors(ossimErrorSeverity severity=OSSIM_BENIGN) const
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
int & argc()
return the argument count.
◆ propagateGeometryToChains()
void ossimChipProcTool::propagateGeometryToChains ( )
protected
Loops through all chains and sets the output projection.
Note
Definition at line 1300 of file ossimChipProcTool.cpp.
References ossimRefPtr< T >::get(), m_geom, m_imgLayers, ossimConnectableObject::propagateEventToOutputs(), ossimImageRenderer::setView(), and ossimRefPtr< T >::valid().
1301 {
1302  // we need to make sure the outputs are refreshed so they can reset themselves
1303  // Needed when we are doing interactive update to the GSD and clip window
1305  ossimEventVisitor eventVisitor(refreshEvent.get());
1306  ossimViewInterfaceVisitor viewVisitor(m_geom.get());
1307
1308  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chainIdx = m_imgLayers.begin();
1309  while ( chainIdx != m_imgLayers.end() )
1310  {
1311  viewVisitor.reset();
1312  eventVisitor.reset();
1313  (*chainIdx)->accept(viewVisitor);
1314  (*chainIdx)->accept(eventVisitor);
1315  ossimRefPtr<ossimImageRenderer> resampler = (*chainIdx)->getImageRenderer();
1316  if (resampler.valid())
1317  {
1318  resampler->setView( m_geom.get() );
1319  resampler->propagateEventToOutputs(*refreshEvent);
1320  }
1321  ++chainIdx;
1322  }
1323 }
ossimRefPtr< ossimImageGeometry > m_geom
bool valid() const
Definition: ossimRefPtr.h:75
virtual void propagateEventToOutputs(ossimEvent &event)
Visitor to update view and then propagate property event to outputs.
Definition: ossimVisitor.h:179
std::vector< ossimRefPtr< ossimSingleImageChain > > m_imgLayers
virtual bool setView(ossimObject *baseObject)
◆ setAoiToInputs()
void ossimChipProcTool::setAoiToInputs ( )
protected
Assigns the AOI to be the bounding rect of the union of all inputs.
Definition at line 1209 of file ossimChipProcTool.cpp.
References ossimGrect::clipToRect(), ossimGrect::expandToInclude(), ossimImageGeometry::getBoundingGroundRect(), ossimGrect::hasNans(), m_aoiGroundRect, m_demSources, m_imgLayers, ossimGrect::makeNan(), ossimImageGeometry::open(), ossimNotify(), ossimNotifyLevel_WARN, and ossimRefPtr< T >::valid().
1210 {
1212  ossimGrect bbox_i;
1214
1215  // Assign the AOI to be the bounding rect of the union of all inputs. Start with image inputs:
1216  std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator chain = m_imgLayers.begin();
1217  while (chain != m_imgLayers.end())
1218  {
1219  geom = (*chain)->getImageGeometry();
1220  if (geom.valid())
1221  {
1222  geom->getBoundingGroundRect(bbox_i);
1223  if (!bbox_i.hasNans())
1224  {
1225  if (m_aoiGroundRect.hasNans())
1226  m_aoiGroundRect = bbox_i;
1227  else
1229  }
1230  }
1231  ++chain;
1232  }
1233
1234  // Now determine DEM inputs coverage:
1235  ossimGrect bbox_dems;
1236  bbox_dems.makeNan();
1237  std::vector<ossimFilename>::iterator dem_file = m_demSources.begin();
1238  while (dem_file != m_demSources.end())
1239  {
1241  if (!geom->open(*dem_file))
1242  {
1244  << "ossimHLZUtil::initialize ERR: Cannot open DEM file <" << *dem_file << "> "
1245  "as image handler. Ignoring entry for bounding box computation.\n" << std::endl;
1246  }
1247  geom->getBoundingGroundRect(bbox_i);
1248  if (!bbox_i.hasNans())
1249  {
1250  if (bbox_dems.hasNans())
1251  bbox_dems = bbox_i;
1252  else
1253  bbox_dems.expandToInclude(bbox_i);
1254  }
1255  ++dem_file;
1256  }
1257
1258  // Finally compute the AOI as the intersection of the image and DEM inputs:
1259  if (m_aoiGroundRect.hasNans())
1260  m_aoiGroundRect = bbox_dems;
1261  else if (!bbox_dems.hasNans())
1263 }
void getBoundingGroundRect(ossimGrect &bounding_grect) const
ossimGrect m_aoiGroundRect
bool valid() const
void makeNan()
bool hasNans() const
Definition: ossimGrect.h:298
void expandToInclude(const ossimGpt &gpt)
Expands existing rect to accommodate argument point.
Definition: ossimGrect.cpp:299
ossimGrect clipToRect(const ossimGrect &rect) const
Definition: ossimGrect.h:190
◆ setReaderProps()
void ossimChipProcTool::setReaderProps ( ossimImageHandler ih) const
protected
Passes reader properties to single image handler if any.
Parameters
ihImage handler to set properties on.
Definition at line 1325 of file ossimChipProcTool.cpp.
References ossimTool::m_kwl, and ossimKeywordlist::numberOf().
Referenced by createInputChain().
1326 {
1327  if ( ih )
1328  {
1329  ossim_uint32 count = m_kwl.numberOf( READER_PROPERTY_KW.c_str() );
1330  for (ossim_uint32 i = 0; i < count; ++i)
1331  {
1332  ossimString key = READER_PROPERTY_KW;
1333  key += ossimString::toString(i);
1334  ossimString value = m_kwl.findKey( key.string() );
1335  if ( value.size() )
1336  {
1337  std::vector<ossimString> splitArray;
1338  value.split(splitArray, "=");
1339  if(splitArray.size() == 2)
1340  {
1342  new ossimStringProperty(splitArray[0], splitArray[1]);
1343
1344  ih->setProperty( prop );
1345  }
1346  }
1347  }
1348  }
1349 }
unsigned int ossim_uint32
◆ setUsage()
void ossimChipProcTool::setUsage ( ossimArgumentParser ap)
virtual
Initializes the aurgument parser with expected parameters and options.
It does not output anything. To see the usage, the caller will need to do something like:
ap.getApplicationUsage()->write(<ostream>);
This base class has some common arguments to add. The derived class should call this implementation in addition to setting its own arguments.
Reimplemented from ossimTool.
Reimplemented in ossimShorelineTool, ossimHillshadeTool, ossimHlzTool, ossimHdf5Tool, ossimViewshedTool, ossimSubImageTool, ossimOrthoTool, ossimSlopeTool, ossimPotraceTool, ossimBandMergeTool, and ossimRegTool.
Definition at line 1520 of file ossimChipProcTool.cpp.
References ossimApplicationUsage::addCommandLineOption(), ossimInit::addOptions(), ossimArgumentParser::getApplicationName(), ossimArgumentParser::getApplicationUsage(), ossimInit::instance(), and ossimTool::setUsage().
Referenced by ossimBandMergeTool::setUsage(), ossimOrthoTool::setUsage(), ossimSlopeTool::setUsage(), ossimViewshedTool::setUsage(), ossimHdf5Tool::setUsage(), ossimHlzTool::setUsage(), ossimHillshadeTool::setUsage(), and ossimShorelineTool::setUsage().
1521 {
1522  // Add global usage options.
1524
1525  // Set app name.
1526  std::string appName = ap.getApplicationName();
1528
1529  // Base class has some:
1530  ossimTool::setUsage(ap);
1531
1532  // Add options.
1533  au->addCommandLineOption("--aoi-geo-bbox", "<min-lat> <min-lon> <max-lat> <max-lon>\nSpecify a comma-separated list for the lower-left and upper-right corners of the scene rect in decimal degrees.");
1534  au->addCommandLineOption("--aoi-geo-center", "<lat> <lon>\nCenter of AOI in decimal degrees.");
1535  au->addCommandLineOption("--aoi-map-bbox", "<min-x> <min-y> <max-x> <max-y>\nSpecify a space-separated list for the upper-left and lower-right corners of the scene rect in decimal degrees.");
1536  au->addCommandLineOption("--aoi-map-center", "<x> <y>\nCenter of AOI in map coordinates.");
1537  au->addCommandLineOption("--aoi-size-pixels", "<dx> <dy>,\nSize of AOI in output product pixels.");
1538  au->addCommandLineOption("--aoi-size-meters", "<dx> <dy>,\nSize of AOI in meters.");
1539  au->addCommandLineOption( "-b or --bands <n,n...>", "Use the specified bands in given order: e.g. \"3,2,1\" will select bands 3, 2 and 1 of the input image.\nNote: it is 1 based" );
1540  au->addCommandLineOption("--central-meridian","<lon>\nNote if set this will be used for the central meridian of the projection. This can be used to lock the utm zone.");
1541  au->addCommandLineOption("--color-table | --lut","<color-table.kwl>\nKeyword list containing color table for color-relief option.");
1542  au->addCommandLineOption("--deg-per-pixel","<dpp_xy> | <dpp_x> <dpp_y>\nSpecifies an override for degrees per pixel. Takes either a single value applied equally to x and y directions, or two values applied correspondingly to x then y. This option takes precedence over the \"--meters\" option.");
1543  au->addCommandLineOption("--dem", "<file1>[,<file2>...]\n Input DEM file(s) (comma-separated) to process.");
1544  au->addCommandLineOption("--dump-options","The current state of the utility (after the entire command line is parsed) is written to the file $PWD/<utility>.kwl, where <utility> is the name of the operation being performed. See \"--load-options\".");
1545  au->addCommandLineOption("-e or --entry", "<entry> For multi image handlers which entry do you wish to extract. For list of entries use: \"ossim-info -i <your_image>\" ");
1546  au->addCommandLineOption("--gsd", "<meters>\nSpecifies an override for the meters per pixel");
1547  au->addCommandLineOption("-h or --help", "Display this help and exit.");
1548  au->addCommandLineOption("--hemisphere", "<hemisphere>\nSpecify a projection hemisphere if supported. E.g. UTM projection. This will lock the hemisphere even if input scene center is the other hemisphere. Valid values for UTM are \"N\" and \"S\"");
1549  au->addCommandLineOption("--image | -i", "<file1>[, <file2>...] Input image file(s) (comma-separated) to process.");
1550  au->addCommandLineOption("--load-options","[<filename>]\nThe contents of <filename> (keyword-value pairs) are loaded as command options. The command-line options take precedence. See \"--load-options\" and \"--write-template\" options.");
1551  au->addCommandLineOption("--output-file | -o","<filename>\nThe product output file name. The format is dictated by the extension.");
1552  au->addCommandLineOption("--origin-latitude","<latidude_in_decimal_degrees>\nNote if set this will be used for the origin latitude of the projection. Setting this to something other than 0.0 with a geographic projection creates a scaled geographic projection.");
1553  au->addCommandLineOption("--output-radiometry", "<R>\nSpecifies the desired product's pixel radiometry type. Possible values for <R> are: U8, U11, U16, S16, F32. Note this overrides the deprecated option \"scale-to-8-bit\".");
1554  au->addCommandLineOption("--projection", "<output_projection> Valid projections: geo, geo-scaled, input or utm\ngeo = Equidistant Cylindrical, origin latitude = 0.0\ngeo-scaled = Equidistant Cylindrical, origin latitude = image center\ninput Use first images projection. Must be a map projecion.\nutm = Universal Tranverse Mercator\nIf input and multiple sources the projection of the first image will be used.\nIf utm the zone will be set from the scene center of first image.\nNOTE: --srs takes precedence over this option.");
1555  au->addCommandLineOption("--reader-prop", "<string>Adds a property to send to the reader. format is name=value");
1556  au->addCommandLineOption("--scale-to-8-bit", "Scales the output to unsigned eight bits per band. This option has been deprecated by the newer \"--output-radiometry\" option.");
1557  au->addCommandLineOption("--snap-tie-to-origin", "Snaps tie point to projection origin so that (tie-origin)/gsd come out on an even integer boundary.");
1558  au->addCommandLineOption("--srs","<src_code>\nSpecify a spatial reference system(srs) code for the output projection. Example: --srs EPSG:4326");
1559  au->addCommandLineOption("-t or --thumbnail", "<max_dimension>\nSpecify a thumbnail resolution.\nScale will be adjusted so the maximum dimension = argument given.");
1560  au->addCommandLineOption("--tile-size", "<size_in_pixels>\nSets the output tile size if supported by writer. Notes: This sets both dimensions. Must be a multiple of 16, e.g. 1024.");
1561  au->addCommandLineOption("-w or --writer","<writer>\nSpecifies the output writer. Default uses output file extension to determine writer. For valid output writer types use: \"ossim-info --writers\"\n");
1562  au->addCommandLineOption("--writer-prop", "<writer-property>\nPasses a name=value pair to the writer for setting it's property. Any number of these can appear on the line.");
1563  au->addCommandLineOption("--write-template", "<filename>\nWrites a keywrd list template to the filename specified.");
1564  au->addCommandLineOption("--zone", "<zone>\nSpecify a projection zone if supported. E.g. UTM projection. This will lock the zone even if input scene center is in another zone. Valid values for UTM are \"1\" to \"60\"");
1565 }
std::string getApplicationName() const
return the application name, as specified by argv[0]
void addCommandLineOption(const ossimString &option, const ossimString &explanation)
void addOptions(ossimArgumentParser &parser)
Definition: ossimInit.cpp:100
ossimApplicationUsage * getApplicationUsage()
virtual void setUsage(ossimArgumentParser &ap)
Definition: ossimTool.cpp:41
static ossimInit * instance()
Definition: ossimInit.cpp:89
Member Data Documentation
◆ m_aoiGroundRect
ossimGrect ossimChipProcTool::m_aoiGroundRect
protected
◆ m_aoiViewRect
ossimIrect ossimChipProcTool::m_aoiViewRect
protected
◆ m_cutRectFilter
ossimRefPtr<ossimRectangleCutFilter> ossimChipProcTool::m_cutRectFilter
protected
Definition at line 228 of file ossimChipProcTool.h.
Referenced by getChip().
◆ m_demSources
std::vector< ossimFilename > ossimChipProcTool::m_demSources
protected
◆ m_geom
ossimRefPtr<ossimImageGeometry> ossimChipProcTool::m_geom
protected
◆ m_geoScaled
bool ossimChipProcTool::m_geoScaled
protected
◆ m_gsd
ossimDpt ossimChipProcTool::m_gsd
protected
◆ m_imgLayers
std::vector< ossimRefPtr<ossimSingleImageChain> > ossimChipProcTool::m_imgLayers
protected
◆ m_needCutRect
bool ossimChipProcTool::m_needCutRect
protected
Definition at line 234 of file ossimChipProcTool.h.
Referenced by clear(), and ossimSubImageTool::initialize().
◆ m_procChain
ossimRefPtr<ossimImageChain> ossimChipProcTool::m_procChain
protected
◆ m_productFilename
ossimFilename ossimChipProcTool::m_productFilename
protected
◆ m_productScalarType
ossimScalarType ossimChipProcTool::m_productScalarType
protected
◆ m_projIsIdentity
bool ossimChipProcTool::m_projIsIdentity
protected
Definition at line 229 of file ossimChipProcTool.h.
Referenced by newIdentityProjection().
◆ m_writer
ossimRefPtr<ossimImageFileWriter> ossimChipProcTool::m_writer
mutableprotected
Definition at line 226 of file ossimChipProcTool.h.
Referenced by abort(), clear(), and execute().
