#include <ossimCassiniProjection.h>
ossimCassiniProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimCassiniProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, const double falseEasting, const double falseNorthing) | |
~ossimCassiniProjection () | |
virtual ossimObject * | dup () const |
virtual ossimDpt | forward (const ossimGpt &worldPoint) const |
All map projections will convert the world coordinate to an easting northing (Meters). More... | |
virtual ossimGpt | inverse (const ossimDpt &projectedPoint) const |
Will take a point in meters and convert it to ground. More... | |
virtual void | update () |
void | setFalseEasting (double falseEasting) |
void | setFalseNorthing (double falseNorthing) |
void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
double | getFalseEasting () const |
double | getFalseNorthing () const |
void | setDefaults () |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
ossimMapProjection (const ossimMapProjection &src) | |
virtual ossimGpt | origin () const |
virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
virtual double | getStandardParallel1 () const |
Derived classes should implement as needed. More... | |
virtual double | getStandardParallel2 () const |
virtual void | setPcsCode (ossim_uint32 pcsCode) |
virtual ossim_uint32 | getPcsCode () const |
Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
virtual ossimString | getProjectionName () const |
Returns the projection name. More... | |
virtual double | getA () const |
ACCESS METHODS: More... | |
virtual double | getB () const |
virtual double | getF () const |
virtual ossimDpt | getMetersPerPixel () const |
virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
virtual const ossimDpt & | getUlEastingNorthing () const |
virtual const ossimGpt & | getUlGpt () const |
virtual const ossimDatum * | getDatum () const |
const ossimEllipsoid & | getEllipsoid () const |
const ossimGpt & | getOrigin () const |
virtual bool | isGeographic () const |
virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
SET METHODS: More... | |
virtual void | setAB (double a, double b) |
virtual void | setDatum (const ossimDatum *datum) |
Sets theDatum to datum. More... | |
virtual void | setOrigin (const ossimGpt &origin) |
Sets theOrigin to origin. More... | |
virtual void | setMetersPerPixel (const ossimDpt &gsd) |
virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
virtual void | setUlTiePoints (const ossimGpt &gpt) |
virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
virtual void | setUlGpt (const ossimGpt &ulGpt) |
virtual void | assign (const ossimProjection &aProjection) |
virtual std::ostream & | print (std::ostream &out) const |
Prints data members to stream. More... | |
virtual bool | operator== (const ossimProjection &projection) const |
Compares this to arg projection and returns TRUE if the same. More... | |
virtual void | computeDegreesPerPixel () |
Computes the approximate resolution in degrees/pixel. More... | |
virtual void | computeMetersPerPixel () |
This will go from the ground point and give you an approximate meters per pixel. More... | |
void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
void | setMatrixScale (const ossimDpt &scale) |
void | setMatrixRotation (double rotation) |
void | setMatrixTranslation (const ossimDpt &translation) |
void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
Utility method to snap the tie point to some multiple. More... | |
void | snapTiePointToOrigin () |
void | setElevationLookupFlag (bool flag) |
bool | getElevationLookupFlag () const |
ossimUnitType | getModelTransformUnitType () const |
void | setModelTransformUnitType (ossimUnitType unit) |
bool | hasModelTransform () const |
virtual bool | isAffectedByElevation () const |
Implementation of pure virtual ossimProjection::isAffectedByElevation method. More... | |
void | setProjectionUnits (ossimUnitType units) |
ossimUnitType | getProjectionUnits () const |
OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimProjection () | |
virtual | ~ossimProjection () |
virtual void | getRoundTripError (const ossimDpt &imagePoint, ossimDpt &errorResult) const |
virtual void | getRoundTripError (const ossimGpt &groundPoint, ossimDpt &errorResult) const |
virtual void | getGroundClipPoints (ossimGeoPolygon &gpts) const |
virtual bool | operator!= (const ossimProjection &projection) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
Private Member Functions | |
long | Set_Cassini_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing) |
void | Get_Cassini_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *False_Easting, double *False_Northing) const |
long | Convert_Geodetic_To_Cassini (double Latitude, double Longitude, double *Easting, double *Northing) const |
long | Convert_Cassini_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
double | Cass_a |
double | Cass_f |
double | es2 |
double | es4 |
double | es6 |
double | M0 |
double | c0 |
double | c1 |
double | c2 |
double | c3 |
double | One_Minus_es2 |
double | a0 |
double | a1 |
double | a2 |
double | a3 |
double | Cass_Origin_Lat |
double | Cass_Origin_Long |
double | Cass_False_Northing |
double | Cass_False_Easting |
double | Cass_Min_Easting |
double | Cass_Max_Easting |
double | Cass_Min_Northing |
double | Cass_Max_Northing |
virtual | ~ossimMapProjection () |
void | updateFromTransform () |
virtual | ~ossimReferenced () |
ossimEllipsoid | theEllipsoid |
This method verifies that the projection parameters match the current pcs code. More... | |
ossimGpt | theOrigin |
const ossimDatum * | theDatum |
This is only set if we want to have built in datum shifting. More... | |
ossimDpt | theMetersPerPixel |
Holds the number of meters per pixel. More... | |
ossimDpt | theDegreesPerPixel |
Hold the decimal degrees per pixel. More... | |
ossimGpt | theUlGpt |
Hold tie point in decimal degrees. More... | |
ossimDpt | theUlEastingNorthing |
Hold tie point as easting northing. More... | |
ossimDpt | theFalseEastingNorthing |
Hold the false easting northing. More... | |
ossim_uint32 | thePcsCode |
Projection Coordinate System(PCS) code. More... | |
bool | theElevationLookupFlag |
ossimMatrix4x4 | theModelTransform |
ossimMatrix4x4 | theInverseModelTransform |
ossimUnitType | theModelTransformUnitType |
ossimUnitType | theProjectionUnits |
Linear units of the projection as indicated in the projection's specification: More... | |
ossimErrorCode | theErrorStatus |
Definition at line 18 of file ossimCassiniProjection.h.
ossimCassiniProjection::ossimCassiniProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid() , |
const ossimGpt & | origin = ossimGpt() |
Definition at line 52 of file ossimCassiniProjection.cpp.
References setDefaults(), and update().
ossimCassiniProjection::ossimCassiniProjection | ( | const ossimEllipsoid & | ellipsoid, |
const ossimGpt & | origin, | ||
const double | falseEasting, | ||
const double | falseNorthing | ||
Definition at line 60 of file ossimCassiniProjection.cpp.
References Cass_False_Easting, Cass_False_Northing, Cass_Max_Easting, Cass_Max_Northing, Cass_Min_Easting, Cass_Min_Northing, and update().
inline |
Definition at line 27 of file ossimCassiniProjection.h.
private |
The function Convert_Cassini_To_Geodetic converts Cassini projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Cassini projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise CASS_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 415 of file ossimCassiniProjection.cpp.
References a0, a1, a2, a3, c0, Cass_a, CASS_COEFF_TIMES_SIN, Cass_False_Easting, Cass_False_Northing, CASS_LON_WARNING, CASS_NO_ERROR, Cass_Origin_Long, CASS_RD, FLOAT_EQ, M0, M_PI, One_Minus_es2, and PI_OVER_2.
Referenced by inverse().
private |
The function Convert_Geodetic_To_Cassini converts geodetic (latitude and longitude) coordinates to Cassini projection easting, and northing coordinates, according to the current ellipsoid and Cassini projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise CASS_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 335 of file ossimCassiniProjection.cpp.
References c0, c1, c2, c3, Cass_a, CASS_COEFF_TIMES_SIN, Cass_False_Easting, Cass_False_Northing, CASS_LON_WARNING, CASS_M, CASS_NO_ERROR, Cass_Origin_Long, CASS_RD, es2, M0, M_PI, One_Minus_es2, and TWO_PI.
Referenced by forward(), and Set_Cassini_Parameters().
inlinevirtual |
Implements ossimProjection.
Definition at line 28 of file ossimCassiniProjection.h.
Definition at line 136 of file ossimCassiniProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Cassini(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
private |
The function Get_Cassini_Parameters returns the current ellipsoid parameters, and Cassini projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude in radians at which the (output) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 301 of file ossimCassiniProjection.cpp.
References Cass_a, Cass_f, Cass_False_Easting, Cass_False_Northing, Cass_Origin_Lat, and Cass_Origin_Long.
inlinevirtual |
Definition at line 52 of file ossimCassiniProjection.h.
inlinevirtual |
Definition at line 53 of file ossimCassiniProjection.h.
Definition at line 123 of file ossimCassiniProjection.cpp.
References Convert_Cassini_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 163 of file ossimCassiniProjection.cpp.
References Cass_False_Easting, Cass_False_Northing, ossimKeywordlist::find(), ossimMapProjection::loadState(), setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 158 of file ossimCassiniProjection.cpp.
References ossimMapProjection::saveState().
private |
The function Set_Cassini_Parameters receives the ellipsoid parameters and Cassini projcetion parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise CASS_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Origin_Latitude : Latitude in radians at which the (input) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 190 of file ossimCassiniProjection.cpp.
References a0, a1, a2, a3, c0, c1, c2, c3, Cass_a, CASS_COEFF_TIMES_SIN, Cass_f, Cass_False_Easting, Cass_False_Northing, CASS_M, Cass_Max_Easting, Cass_Max_Northing, Cass_Min_Easting, Cass_Min_Northing, CASS_NO_ERROR, Cass_Origin_Lat, Cass_Origin_Long, Convert_Geodetic_To_Cassini(), es2, es4, es6, M0, M_PI, One_Minus_es2, THIRTY_ONE, and x.
Referenced by update().
void ossimCassiniProjection::setDefaults | ( | ) |
Initialize all pramters to default and calls update for pre-computations.
Definition at line 112 of file ossimCassiniProjection.cpp.
References Cass_False_Easting, Cass_False_Northing, Cass_Max_Easting, Cass_Max_Northing, Cass_Min_Easting, and Cass_Min_Northing.
Referenced by loadState(), and ossimCassiniProjection().
void ossimCassiniProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 92 of file ossimCassiniProjection.cpp.
References Cass_False_Easting, and update().
void ossimCassiniProjection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 104 of file ossimCassiniProjection.cpp.
References Cass_False_Easting, Cass_False_Northing, and update().
void ossimCassiniProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 98 of file ossimCassiniProjection.cpp.
References Cass_False_Northing, and update().
Definition at line 76 of file ossimCassiniProjection.cpp.
References Cass_False_Easting, Cass_False_Northing, ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latr(), ossimGpt::lonr(), Set_Cassini_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimCassiniProjection(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprivate |
Definition at line 90 of file ossimCassiniProjection.h.
Referenced by Convert_Cassini_To_Geodetic(), and Set_Cassini_Parameters().
mutableprivate |
Definition at line 91 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 92 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 93 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 85 of file ossimCassiniProjection.h.
Referenced by Convert_Cassini_To_Geodetic(), Convert_Geodetic_To_Cassini(), and Set_Cassini_Parameters().
mutableprivate |
Definition at line 86 of file ossimCassiniProjection.h.
Referenced by Convert_Geodetic_To_Cassini(), and Set_Cassini_Parameters().
mutableprivate |
Definition at line 87 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 88 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 79 of file ossimCassiniProjection.h.
Referenced by Convert_Cassini_To_Geodetic(), Convert_Geodetic_To_Cassini(), Get_Cassini_Parameters(), and Set_Cassini_Parameters().
mutableprivate |
Definition at line 80 of file ossimCassiniProjection.h.
Referenced by Get_Cassini_Parameters(), and Set_Cassini_Parameters().
mutableprivate |
Definition at line 99 of file ossimCassiniProjection.h.
Referenced by Convert_Cassini_To_Geodetic(), Convert_Geodetic_To_Cassini(), Get_Cassini_Parameters(), loadState(), ossimCassiniProjection(), Set_Cassini_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprivate |
Definition at line 98 of file ossimCassiniProjection.h.
Referenced by Convert_Cassini_To_Geodetic(), Convert_Geodetic_To_Cassini(), Get_Cassini_Parameters(), loadState(), ossimCassiniProjection(), Set_Cassini_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprivate |
Definition at line 104 of file ossimCassiniProjection.h.
Referenced by ossimCassiniProjection(), Set_Cassini_Parameters(), and setDefaults().
mutableprivate |
Definition at line 106 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 103 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 105 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 96 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 97 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 81 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 82 of file ossimCassiniProjection.h.
Referenced by Set_Cassini_Parameters().
mutableprivate |
Definition at line 83 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 84 of file ossimCassiniProjection.h.
mutableprivate |
Definition at line 89 of file ossimCassiniProjection.h.
