ossimDespeckleFilter Class Reference
#include <ossimDespeckleFilter.h>
Inheritance diagram for ossimDespeckleFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimDespeckleFilter ()
 ossimDespeckleFilter (ossimImageSource *inputSource, ossim_uint32 filter_radius=1)
virtual void setRadius (ossim_uint32 radius)
virtual bool saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const
ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual void initialize ()
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimDespeckleFilter ()
template<class T >
void despeckle (T dummyVariable, ossimRefPtr< ossimImageData > inputTile)
void allocate ()
virtual ~ossimReferenced ()
Protected Attributes
ossim_int32 theFilterRadius
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
Definition at line 16 of file ossimDespeckleFilter.h.
◆ ossimDespeckleFilter() [1/2]
ossimDespeckleFilter::ossimDespeckleFilter ( )
Definition at line 23 of file ossimDespeckleFilter.cpp.
25  theTile(NULL),
27 {
28 }
ossimImageSourceFilter(ossimObject *owner=NULL)
◆ ossimDespeckleFilter() [2/2]
ossimDespeckleFilter::ossimDespeckleFilter ( ossimImageSource inputSource,
ossim_uint32  filter_radius = 1
Definition at line 30 of file ossimDespeckleFilter.cpp.
References initialize().
31  : ossimImageSourceFilter(inputSource),
32  theTile(NULL),
33  theFilterRadius(filter_radius)
34 {
35  initialize();
36 }
◆ ~ossimDespeckleFilter()
ossimDespeckleFilter::~ossimDespeckleFilter ( )
protectedvirtual
Definition at line 38 of file ossimDespeckleFilter.cpp.
References theTile.
39 {
40  theTile = 0;
41 }
Member Function Documentation
◆ allocate()
void ossimDespeckleFilter::allocate ( )
protected
Definition at line 190 of file ossimDespeckleFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
Referenced by getTile().
191 {
193  {
195  theTile->initialize();
196  }
197 }
virtual void initialize()
Initialize the data buffer.
◆ despeckle()
template<class T >
void ossimDespeckleFilter::despeckle ( dummyVariable,
ossimRefPtr< ossimImageData inputTile
protected
Definition at line 122 of file ossimDespeckleFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), if(), ossimIrect::lr(), theFilterRadius, theTile, ossimIrect::ul(), x, and y.
123 {
124  ossimIpt inUL (inputTile->getImageRectangle().ul());
125  ossimIpt inLR (inputTile->getImageRectangle().lr());
126  ossimIpt outUL (theTile->getImageRectangle().ul());
127  ossimIpt outLR (theTile->getImageRectangle().lr());
128  long inWidth = inputTile->getWidth();
129  long outWidth = theTile->getWidth();
130  long num_bands = theTile->getNumberOfBands();
131
132  // Loop over all bands first:
133  for(long b = 0; b < num_bands; ++b)
134  {
135  const T* inbuf = (const T*) inputTile->getBuf(b);
136  T* outBuf = (T*) theTile->getBuf(b);
137  T null_pixel = (T) inputTile->getNullPix(b);
138
139  for (long y=outUL.y; y<=outLR.y; y++)
140  {
141  for (long x=outUL.x; x<=outLR.x; x++)
142  {
143  bool found_valid = false;
144  long idx = (y - inUL.y)*inWidth + x - inUL.x; // index to input buffer
145  long odx = (y-outUL.y)*outWidth + x - outUL.x;// index to output buffer
146
147  T pixel = inbuf[idx];
148  if (pixel != null_pixel)
149  {
150  // Inside loop over input "kernel" pixels centered at x, y:
151  for (long iy=-theFilterRadius; (iy<=theFilterRadius) && !found_valid; iy++)
152  {
153  // Compute row number in image space and skip this row if outside input tile:
154  long row = y + iy;
155  if ((row < inUL.y) || (row > inLR.y))
156  continue;
157
158  for (long ix=-theFilterRadius; (ix<=theFilterRadius) && !found_valid; ix++)
159  {
160  // Compute column number in image space and skip this col if outside input tile:
161  long col = x + ix;
162  if ((col < inUL.x) || (col > inLR.x))
163  continue;
164
165  // Compute offset into input buffer for the neighbor pixel. If we aren't at the
166  // kernel center, consider if valid neighbor was found:
167  idx = (row - inUL.y)*inWidth + col - inUL.x;
168  if ( ((iy != 0) || (ix != 0)) && (inbuf[idx] != null_pixel) )
169  found_valid = true;
170  }
171  }
172  }
173
174  // Finished scanning neighborhood. Save output to tile buffer:
175  if (found_valid)
176  outBuf[odx] = pixel;
177  else
178  outBuf[odx] = null_pixel;
179  }
180  }
181  }
182 }
ossim_uint32 x
ossim_uint32 y
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual const ossim_float64 * getNullPix() const
virtual ossimIrect getImageRectangle() const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
if(yy_init)
◆ getProperty()
ossimRefPtr< ossimProperty > ossimDespeckleFilter::getProperty ( const ossimString name) const
virtual
Definition at line 224 of file ossimDespeckleFilter.cpp.
References ossimImageSourceFilter::getProperty(), ossimProperty::setCacheRefreshBit(), theFilterRadius, and ossimString::toString().
225 {
226  if(name == "Filter Radius")
227  {
229  prop->setCacheRefreshBit();
230  return prop;
231  }
233 }
Numeric to string methods.
void setCacheRefreshBit()
◆ getPropertyNames()
void ossimDespeckleFilter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 235 of file ossimDespeckleFilter.cpp.
References ossimImageSourceFilter::getPropertyNames().
236 {
238  propertyNames.push_back("Filter Radius");
239 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimDespeckleFilter::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 44 of file ossimDespeckleFilter.cpp.
References allocate(), despeckle(), ossimImageData::getHeight(), ossimImageSource::getTile(), ossimImageData::getWidth(), ossimIrect::height(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), ossimImageData::loadTile(), ossimIrect::lr(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_EMPTY, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimImageData::setHeight(), ossimImageData::setOrigin(), ossimImageData::setWidth(), status, theFilterRadius, ossimImageSourceFilter::theInputConnection, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
45 {
46  if (!theInputConnection)
47  return NULL;
48
49  if (!isSourceEnabled())
50  return theInputConnection->getTile(tileRect, resLevel);
51
52  if (!theTile.valid())
53  {
54  allocate();
55  if (!theTile.valid()) // Throw exception???
56  return theInputConnection->getTile(tileRect, resLevel);
57  }
58
59  // Fetch input tile with kernel margins:
60  ossimIrect requestRect(tileRect.ul().x - theFilterRadius,
61  tileRect.ul().y - theFilterRadius,
62  tileRect.lr().x + theFilterRadius,
63  tileRect.lr().y + theFilterRadius);
64  ossimRefPtr<ossimImageData> inputTile = theInputConnection->getTile(requestRect, resLevel);
65  if (!inputTile.valid())
66  return NULL;
67
68  ossim_uint32 w = tileRect.width();
69  ossim_uint32 h = tileRect.height();
72  theTile->setWidth(w);
73  theTile->setHeight(h);
74  if((w*h)!=(tw*th))
76
77  theTile->makeBlank();
78  theTile->setOrigin(tileRect.ul());
79
80  ossimDataObjectStatus status = inputTile->getDataObjectStatus();
81  if ((status == OSSIM_NULL) || (status == OSSIM_EMPTY))
82  return inputTile;
83
84  switch(inputTile->getScalarType())
85  {
86  case OSSIM_UCHAR:
87  despeckle(static_cast<ossim_uint8>(0), inputTile);
88  break;
89
90  case OSSIM_USHORT16:
91  case OSSIM_USHORT11:
92  case OSSIM_USHORT12:
93  case OSSIM_USHORT13:
94  case OSSIM_USHORT14:
95  case OSSIM_USHORT15:
96  despeckle(static_cast<ossim_uint16>(0), inputTile);
97  break;
98
99  case OSSIM_SSHORT16:
100  despeckle(static_cast<ossim_sint16>(0), inputTile);
101  break;
102
103  case OSSIM_FLOAT:
105  despeckle(static_cast<float>(0), inputTile);
106  break;
107
108  case OSSIM_DOUBLE:
110  despeckle(static_cast<double>(0), inputTile);
111  break;
112
113  default:
114  theTile->loadTile(inputTile.get());
115  }
116
117  theTile->validate();
118  return theTile;
119 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual void setHeight(ossim_uint32 height)
unsigned int ossim_uint32
virtual void setWidth(ossim_uint32 width)
virtual void setOrigin(const ossimIpt &origin)
return status
virtual void makeBlank()
void despeckle(T dummyVariable, ossimRefPtr< ossimImageData > inputTile)
Definitions for data object status.
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
8 bit unsigned iteger
◆ initialize()
void ossimDespeckleFilter::initialize ( )
virtual
Definition at line 184 of file ossimDespeckleFilter.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
Referenced by ossimDespeckleFilter().
185 {
187  theTile = NULL;
188 }
◆ loadState()
bool ossimDespeckleFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = NULL
virtual
Definition at line 206 of file ossimDespeckleFilter.cpp.
References ossimKeywordlist::find().
207 {
208  const char* lookup = kwl.find(prefix, FILTER_RADIUS_KW);
209  if (lookup)
210  theFilterRadius = ossimString(lookup).toInt32();
211
212  return ossimImageSourceFilter::loadState(kwl, prefix);
213 }
ossim_int32 toInt32() const
◆ saveState()
bool ossimDespeckleFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 199 of file ossimDespeckleFilter.cpp.
References ossimKeywordlist::add().
200 {
201  kwl.add(prefix, FILTER_RADIUS_KW, theFilterRadius, true);
202  return ossimImageSourceFilter::saveState(kwl, prefix);
203 }
◆ setProperty()
void ossimDespeckleFilter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 215 of file ossimDespeckleFilter.cpp.
References ossimImageSourceFilter::setProperty(), and theFilterRadius.
216 {
217  ossimString name = property->getName();
218  if(name == "Filter Radius")
219  theFilterRadius = property->valueToString().toInt32();
220  else
222 }
◆ setRadius()
virtual void ossimDespeckleFilter::setRadius ( ossim_uint32  radius)
inlinevirtual
Definition at line 22 of file ossimDespeckleFilter.h.
References theFilterRadius.
22 { theFilterRadius = (ossim_int32) radius; }
int ossim_int32
Member Data Documentation
◆ theFilterRadius
ossim_int32 ossimDespeckleFilter::theFilterRadius
protected
Definition at line 43 of file ossimDespeckleFilter.h.
Referenced by despeckle(), getProperty(), getTile(), setProperty(), and setRadius().
◆ theTile
ossimRefPtr<ossimImageData> ossimDespeckleFilter::theTile
protected
