ossimDilationFilter Class Reference
#include <ossimDilationFilter.h>
Inheritance diagram for ossimDilationFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimDilationFilter (ossimObject *owner=NULL)
virtual void initialize ()
void setWindowSize (ossim_uint32 windowSize)
 Size of resampling kernel width & height. More...
ossim_uint32 getWindowSize () const
void setRecursiveFlag (bool flag=true)
 Set if getTile is to be called recursively until all pixels have been assigned non-null. More...
bool getRecursiveFlag () const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimDilationFilter ()
template<class T >
void doDilation (T scalarType, ossimRefPtr< ossimImageData > &inputData)
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimImageDatatheTempTile
ossim_uint32 theWindowSize
Used for recursion when recursive fill enabled
More...
bool theRecursiveFlag
ossimPolygon theValidImagePoly
bool theNullFoundFlag
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
class ossimDilationFilter
Allows you to change between a median or mean filter. You can also specify a window size which the median or mean is computed and the center pixel is replaced.
Definition at line 23 of file ossimDilationFilter.h.
◆ ossimDilationFilter()
ossimDilationFilter::ossimDilationFilter ( ossimObject owner = NULL)
Definition at line 29 of file ossimDilationFilter.cpp.
References ossimConnectableObject::setDescription().
30  :ossimImageSourceFilter(owner),
31  theTile(0),
32  theTempTile(0),
33  theWindowSize(15),
34  theRecursiveFlag(false),
35  theNullFoundFlag(false)
36 {
37  setDescription(ossimString("Dilation Filter"));
38 }
virtual void setDescription(const ossimString &description)
ossimImageSourceFilter(ossimObject *owner=NULL)
ossimRefPtr< ossimImageData > theTempTile
◆ ~ossimDilationFilter()
ossimDilationFilter::~ossimDilationFilter ( )
protectedvirtual
Definition at line 40 of file ossimDilationFilter.cpp.
41 {
42 }
Member Function Documentation
◆ doDilation()
template<class T >
void ossimDilationFilter::doDilation ( scalarType,
ossimRefPtr< ossimImageData > &  inputData
protected
Definition at line 126 of file ossimDilationFilter.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getImageRectangle(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimPolygon::isPointWithin(), ossimImageData::loadTile(), ossim::min(), OSSIM_EMPTY, OSSIM_FULL, status, theNullFoundFlag, theRecursiveFlag, theTempTile, theTile, theValidImagePoly, theWindowSize, ossimIrect::ul(), ossimImageData::validate(), x, and y.
Referenced by getTile().
127 {
129
130  if ((status == OSSIM_FULL) || (status == OSSIM_EMPTY))
131  {
132  // Nothing to do just copy the tile.
133  theTile->loadTile(inputData.get());
134  return;
135  }
136
137  ossim_int32 halfWindow = (ossim_int32)(theWindowSize >> 1);
138  ossim_int32 x, y, kernelX, kernelY;
139  ossim_int32 iw = (ossim_int32)inputData->getWidth();
140  ossim_int32 ih = (ossim_int32)inputData->getHeight();
143  ossim_uint32 numBands = ossim::min(theTile->getNumberOfBands(), inputData->getNumberOfBands());
144
145  // It may be that the input rect is the same size as the output (i.e., the tile bounds aren't
146  // expanded in the input's request to permit full kernels for output edge pixels:
147  ossim_uint32 i_offset = 0;
148  ossim_int32 delta = (ossim_int32)((iw - ow) >> 1);
149  ossim_int32 xi, yi;
150  if (delta > 0)
151  i_offset = (ossim_uint32) halfWindow*(iw + 1);
152
153  ossimIpt tile_ul (theTile->getImageRectangle().ul());
154  vector<double> values;
155  for(ossim_uint32 bandIdx = 0; bandIdx < numBands; ++bandIdx)
156  {
157  T* inputBuf = (T*)inputData->getBuf(bandIdx);
158  T* outputBuf = (T*)theTile->getBuf(bandIdx);
159  if (!inputBuf || !outputBuf)
160  {
161  return; // Shouldn't happen...
162  }
163
164  const T NP = (T)inputData->getNullPix(bandIdx);
165
166  for(y = 0; y < oh; ++y)
167  {
168  for(x = 0; x < ow; ++x)
169  {
170  // Get the center input pixel. Only process those points inside the valid image
171  // (to avoid dilation beyond valid image)
172  const T CP = *(inputBuf+i_offset);
173  ossimDpt ipt (tile_ul.x+x, tile_ul.y+y);
174  if ((CP == NP) && theValidImagePoly.isPointWithin(ipt))
175  {
176  theNullFoundFlag = true; // Needed for recursion
177  values.clear();
178  for(kernelY = -halfWindow; kernelY <= halfWindow; ++kernelY)
179  {
180  yi = y + kernelY + delta;
181  if ((yi < 0) || (y > ih))
182  continue;
183
184  for(kernelX = -halfWindow; kernelX <= halfWindow; ++kernelX)
185  {
186  xi = x + kernelX + delta;
187  if ((xi < 0) || (x > iw))
188  continue;
189
190  T tempValue = *(inputBuf+kernelX+delta + (kernelY+delta)*iw);
191  if(tempValue != NP)
192  values.push_back((double)tempValue);
193  }
194  }
195
196  if(values.size() > 0)
197  {
198  double accum = accumulate(values.begin(), values.end(), 0.0);
199  double average = accum/(double)values.size();
200  (*outputBuf) = (T)average;
201  }
202  else
203  {
204  (*outputBuf) = NP;
205  }
206
207  }
208  else // Center pixel (CP) not null.
209  {
210  (*outputBuf) = CP;
211  }
212
213  // Move over...
214  ++inputBuf;
215  ++outputBuf;
216
217  } // End of loop in x direction.
218
219  // Move down...
220  inputBuf += iw - ow;
221
222  } // End of loop in y direction.
223
224  } // End of band loop.
225
226  theTile->validate();
227
228  // Set up recursion for "dilation fill mode", we'll keep calling this getTile until all pixels
229  // are filled with non-null values:
230  if (theRecursiveFlag)
231  {
232  //cout << "Percent Full: "<<theTile->percentFull()<<endl; //###
233  //theTile->write("filtered.ras"); //###
234
236  if (theNullFoundFlag)
237  {
238  theNullFoundFlag = false; // assume will fill, set true in next recursion if null found
240  doDilation(scalarType, theTempTile);
241  }
242  }
243 }
ossim_uint32 x
ossim_uint32 y
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
virtual ossimIrect getImageRectangle() const
T min(T a, T b)
Definition: ossimCommon.h:203
return status
bool isPointWithin(const ossimDpt &point) const
void doDilation(T scalarType, ossimRefPtr< ossimImageData > &inputData)
ossimDataObjectStatus
Definitions for data object status.
int ossim_int32
◆ getProperty()
ossimRefPtr< ossimProperty > ossimDilationFilter::getProperty ( const ossimString name) const
virtual
Definition at line 268 of file ossimDilationFilter.cpp.
269 {
271  if (name == WINDOW_SIZE_KW)
272  {
273  prop = new ossimNumericProperty(WINDOW_SIZE_KW, ossimString::toString(theWindowSize), 3, 25);
274  prop->setCacheRefreshBit();
275  return prop;
276  }
277  else if (name == RECURSIVE_DILATION_KW)
278  {
279  prop = new ossimBooleanProperty(RECURSIVE_DILATION_KW, getRecursiveFlag());
280  prop->setFullRefreshBit();
281  return prop;
282  }
284 }
Numeric to string methods.
void setFullRefreshBit()
bool getRecursiveFlag() const
void setCacheRefreshBit()
◆ getPropertyNames()
void ossimDilationFilter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 286 of file ossimDilationFilter.cpp.
287 {
288  propertyNames.push_back(WINDOW_SIZE_KW);
289  propertyNames.push_back(RECURSIVE_DILATION_KW);
291 }
◆ getRecursiveFlag()
bool ossimDilationFilter::getRecursiveFlag ( ) const
inline
Definition at line 41 of file ossimDilationFilter.h.
◆ getTile()
ossimRefPtr< ossimImageData > ossimDilationFilter::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 50 of file ossimDilationFilter.cpp.
References doDilation(), ossimImageData::dup(), ossimImageData::getBuf(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageSource::getValidImageVertices(), getWindowSize(), ossimSource::isSourceEnabled(), ossimIrect::lr(), OSSIM_CLOCKWISE_ORDER, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimImageData::setImageRectangleAndBands(), theNullFoundFlag, theRecursiveFlag, theTile, theValidImagePoly, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
52 {
53  if(!isSourceEnabled())
54  return ossimImageSourceFilter::getTile(rect, resLevel);
55
57  if (theRecursiveFlag)
58  inputData = ossimImageSourceFilter::getTile(rect, resLevel);
59  else
60  {
61  ossim_uint32 halfSize = getWindowSize()>>1;
62  ossimIrect requestRect(rect.ul().x - halfSize,
63  rect.ul().y - halfSize,
64  rect.lr().x + halfSize,
65  rect.lr().y + halfSize);
66
67  inputData = ossimImageSourceFilter::getTile(requestRect, resLevel);
68  }
69
70  if(!inputData.valid() || !inputData->getBuf())
71  return inputData;
72
73  vector<ossimIpt> viv;
76
77  if(!theTile.valid())
78  {
79  theTile = (ossimImageData*)inputData->dup();
81  }
82  else
83  {
85  }
86
87  theNullFoundFlag = false;
88  switch(inputData->getScalarType())
89  {
90  case OSSIM_UINT8:
91  doDilation(ossim_uint8(0), inputData);
92  break;
93  case OSSIM_USHORT11:
94  case OSSIM_USHORT12:
95  case OSSIM_USHORT13:
96  case OSSIM_USHORT14:
97  case OSSIM_USHORT15:
98  case OSSIM_UINT16:
99  doDilation(ossim_uint16(0), inputData);
100  break;
101  case OSSIM_SINT16:
102  doDilation(ossim_sint16(0), inputData);
103  break;
104  case OSSIM_UINT32:
105  doDilation(ossim_uint32(0), inputData);
106  break;
107  case OSSIM_FLOAT32:
109  doDilation(ossim_float32(0), inputData);
110  break;
111  case OSSIM_FLOAT64:
113  doDilation(ossim_float64(0), inputData);
114  break;
115  default:
116  {
118  << "ossimDilationFilter::applyFilter WARNING:\n"
119  << "Unhandled scalar type!" << endl;
120  }
121  }
122  return theTile;
123 }
64 bit floating point
16 bit unsigned integer
bool valid() const
Definition: ossimRefPtr.h:75
float ossim_float32
16 bit signed integer
32 bit floating point
unsigned short ossim_uint16
32 bit unsigned integer
virtual ossimObject * dup() const
double ossim_float64
signed short ossim_sint16
virtual void setImageRectangleAndBands(const ossimIrect &rect, ossim_uint32 numberOfBands)
virtual void getValidImageVertices(std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const
ordering specifies how the vertices should be arranged.
const ossimIpt & lr() const
Definition: ossimIrect.h:276
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
8 bit unsigned integer
ossim_uint32 getWindowSize() const
unsigned char ossim_uint8
◆ getWindowSize()
ossim_uint32 ossimDilationFilter::getWindowSize ( ) const
inline
Definition at line 34 of file ossimDilationFilter.h.
34 { return theWindowSize; }
◆ initialize()
void ossimDilationFilter::initialize ( )
virtual
Definition at line 44 of file ossimDilationFilter.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
45 {
47  theTile = NULL;
48 }
◆ loadState()
bool ossimDilationFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 300 of file ossimDilationFilter.cpp.
References ossimKeywordlist::find().
301 {
302  const char* lookup = kwl.find(prefix, WINDOW_SIZE_KW.c_str());
303  if (lookup)
304  theWindowSize = ossimString(lookup).toUInt32();
305
306  lookup = kwl.find(prefix, RECURSIVE_DILATION_KW.c_str());
307  if (lookup)
308  setRecursiveFlag(ossimString(lookup).toBool());
309
310  return ossimImageSourceFilter::loadState(kwl, prefix);
311 }
ossim_uint32 toUInt32() const
void setRecursiveFlag(bool flag=true)
const char * c_str() const
Definition: ossimString.h:396
◆ saveState()
bool ossimDilationFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 293 of file ossimDilationFilter.cpp.
References ossimKeywordlist::add().
294 {
295  kwl.add(prefix, WINDOW_SIZE_KW.c_str(), theWindowSize, true);
296  kwl.add(prefix, RECURSIVE_DILATION_KW.c_str(), (theRecursiveFlag?"true":"false"), true);
297  return ossimImageSourceFilter::saveState(kwl, prefix);
298 }
◆ setProperty()
void ossimDilationFilter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 245 of file ossimDilationFilter.cpp.
References ossimRefPtr< T >::valid().
246 {
247  if (!property.valid())
248  return;
249
250  ossimString name = property->getName();
251
252  if (name == WINDOW_SIZE_KW)
253  {
254  theWindowSize = property->valueToString().toUInt32();
255  }
256  else if (name == RECURSIVE_DILATION_KW)
257  {
258  ossimString value;
259  property->valueToString(value);
260  setRecursiveFlag(value.toBool());
261  }
262  else
263  {
265  }
266 }
bool valid() const
bool toBool() const
String to numeric methods.
◆ setRecursiveFlag()
void ossimDilationFilter::setRecursiveFlag ( bool  flag = true)
inline
This is only valid for "fill null" modes.
Definition at line 40 of file ossimDilationFilter.h.
◆ setWindowSize()
void ossimDilationFilter::setWindowSize ( ossim_uint32  windowSize)
inline
Definition at line 33 of file ossimDilationFilter.h.
33 { theWindowSize = windowSize; }
Member Data Documentation
◆ theNullFoundFlag
bool ossimDilationFilter::theNullFoundFlag
protected
Definition at line 67 of file ossimDilationFilter.h.
Referenced by doDilation(), and getTile().
◆ theRecursiveFlag
bool ossimDilationFilter::theRecursiveFlag
protected
Definition at line 65 of file ossimDilationFilter.h.
◆ theTempTile
ossimRefPtr<ossimImageData> ossimDilationFilter::theTempTile
protected
Definition at line 63 of file ossimDilationFilter.h.
Referenced by doDilation().
◆ theTile
ossimRefPtr<ossimImageData> ossimDilationFilter::theTile
protected
Definition at line 62 of file ossimDilationFilter.h.
Referenced by doDilation(), getTile(), and initialize().
◆ theValidImagePoly
ossimPolygon ossimDilationFilter::theValidImagePoly
protected
Definition at line 66 of file ossimDilationFilter.h.
◆ theWindowSize
ossim_uint32 ossimDilationFilter::theWindowSize
protected
Definition at line 64 of file ossimDilationFilter.h.
