ossimErosionFilter Class Reference
#include <ossimErosionFilter.h>
Inheritance diagram for ossimErosionFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimErosionFilter (ossimObject *owner=NULL)
virtual void initialize ()
void setWindowSize (ossim_uint32 windowSize)
 Size of resampling kernel width & height. More...
ossim_uint32 getWindowSize () const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimErosionFilter ()
template<class T >
void doErosion (T scalarType, ossimRefPtr< ossimImageData > &inputData)
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimImageDatatheTempTile
ossim_uint32 theWindowSize
Used for recursion when recursive fill enabled
More...
ossimPolygon theValidImagePoly
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
class ossimErosionFilter
Causes null pixels to erode neighboring valid pixels. This is the opposite of dilation. If a null pixel is detected inside the sampling window, the center pixel is set to null.
Definition at line 20 of file ossimErosionFilter.h.
◆ ossimErosionFilter()
ossimErosionFilter::ossimErosionFilter ( ossimObject owner = NULL)
Definition at line 23 of file ossimErosionFilter.cpp.
References ossimConnectableObject::setDescription().
24  :ossimImageSourceFilter(owner),
25  theTile(0),
26  theTempTile(0),
27  theWindowSize(3)
28 {
29  setDescription(ossimString("Dilation Filter"));
30 }
virtual void setDescription(const ossimString &description)
ossimRefPtr< ossimImageData > theTempTile
ossimImageSourceFilter(ossimObject *owner=NULL)
◆ ~ossimErosionFilter()
ossimErosionFilter::~ossimErosionFilter ( )
protectedvirtual
Definition at line 32 of file ossimErosionFilter.cpp.
33 {
34 }
Member Function Documentation
◆ doErosion()
template<class T >
void ossimErosionFilter::doErosion ( scalarType,
ossimRefPtr< ossimImageData > &  inputData
protected
Definition at line 112 of file ossimErosionFilter.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getImageRectangle(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimPolygon::isPointWithin(), ossimImageData::loadTile(), ossim::min(), OSSIM_EMPTY, OSSIM_FULL, status, theTile, theValidImagePoly, theWindowSize, ossimIrect::ul(), ossimImageData::validate(), x, and y.
Referenced by getTile().
113 {
115
116  if ((status == OSSIM_FULL) || (status == OSSIM_EMPTY))
117  {
118  // Nothing to do just copy the tile.
119  theTile->loadTile(inputData.get());
120  return;
121  }
122
123  ossim_int32 halfWindow = (ossim_int32)(theWindowSize >> 1);
124  ossim_int32 x, y, kernelX, kernelY;
125  ossim_int32 iw = (ossim_int32)inputData->getWidth();
126  ossim_int32 ih = (ossim_int32)inputData->getHeight();
129  ossim_uint32 numBands = ossim::min(theTile->getNumberOfBands(), inputData->getNumberOfBands());
130
131  // It may be that the input rect is the same size as the output (i.e., the tile bounds aren't
132  // expanded in the input's request to permit full kernels for output edge pixels:
133  ossim_uint32 i_offset = 0;
134  ossim_int32 delta = (ossim_int32)((iw - ow) >> 1);
135  ossim_int32 xi, yi;
136  if (delta > 0)
137  i_offset = (ossim_uint32) halfWindow*(iw + 1);
138
139  ossimIpt tile_ul (theTile->getImageRectangle().ul());
140  vector<double> values;
141  for(ossim_uint32 bandIdx = 0; bandIdx < numBands; ++bandIdx)
142  {
143  T* inputBuf = (T*)inputData->getBuf(bandIdx);
144  T* outputBuf = (T*)theTile->getBuf(bandIdx);
145  if (!inputBuf || !outputBuf)
146  {
147  return; // Shouldn't happen...
148  }
149
150  const T NP = (T)inputData->getNullPix(bandIdx);
151
152  for(y = 0; y < oh; ++y)
153  {
154  for(x = 0; x < ow; ++x)
155  {
156  bool null_found = true;
157  const T CP = *(inputBuf+i_offset);
158  ossimDpt ipt (tile_ul.x+x, tile_ul.y+y);
159
160  if ((CP != NP) && theValidImagePoly.isPointWithin(ipt))
161  {
162  // Valid pixel found, need to check neighbors for null:
163  null_found = false;
164  values.clear();
165  for(kernelY = -halfWindow; (kernelY<=halfWindow) && !null_found; ++kernelY)
166  {
167  yi = y + kernelY + delta;
168  if ((yi < 0) || (y > ih))
169  continue;
170
171  for(kernelX = -halfWindow; (kernelX<=halfWindow) && !null_found; ++kernelX)
172  {
173  xi = x + kernelX + delta;
174  if ((xi < 0) || (x > iw))
175  continue;
176
177  T neighborPixel = *(inputBuf+kernelX+delta + (kernelY+delta)*iw);
178  if(neighborPixel == NP)
179  {
180  // Found a NULL pixel:
181  (*outputBuf) = NP;
182  null_found = true;
183  }
184  }
185  }
186  }
187
188  if (null_found)
189  (*outputBuf) = NP;
190  else
191  (*outputBuf) = CP;
192
193  // Move over...
194  ++inputBuf;
195  ++outputBuf;
196
197  } // End of loop in x direction.
198
199  // Move down...
200  inputBuf += iw - ow;
201
202  } // End of loop in y direction.
203
204  } // End of band loop.
205
206  theTile->validate();
207
208 }
ossim_uint32 x
ossim_uint32 y
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
virtual ossimIrect getImageRectangle() const
T min(T a, T b)
Definition: ossimCommon.h:203
return status
bool isPointWithin(const ossimDpt &point) const
ossimDataObjectStatus
Definitions for data object status.
int ossim_int32
◆ getProperty()
ossimRefPtr< ossimProperty > ossimErosionFilter::getProperty ( const ossimString name) const
virtual
Definition at line 227 of file ossimErosionFilter.cpp.
228 {
230  if (name == WINDOW_SIZE_KW)
231  {
232  prop = new ossimNumericProperty(WINDOW_SIZE_KW, ossimString::toString(theWindowSize), 3, 25);
233  prop->setCacheRefreshBit();
234  return prop;
235  }
237 }
Numeric to string methods.
void setCacheRefreshBit()
◆ getPropertyNames()
void ossimErosionFilter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 239 of file ossimErosionFilter.cpp.
240 {
241  propertyNames.push_back(WINDOW_SIZE_KW);
243 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimErosionFilter::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 42 of file ossimErosionFilter.cpp.
References doErosion(), ossimImageData::dup(), ossimImageSource::getTile(), ossimImageSource::getValidImageVertices(), getWindowSize(), ossimSource::isSourceEnabled(), ossimIrect::lr(), OSSIM_CLOCKWISE_ORDER, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimImageData::setImageRectangleAndBands(), theTile, theValidImagePoly, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
44 {
45  if(!isSourceEnabled())
46  return ossimImageSourceFilter::getTile(rect, resLevel);
47
49  ossim_uint32 halfSize = getWindowSize()>>1;
50  ossimIrect requestRect(rect.ul().x - halfSize,
51  rect.ul().y - halfSize,
52  rect.lr().x + halfSize,
53  rect.lr().y + halfSize);
54
55  inputData = ossimImageSourceFilter::getTile(requestRect, resLevel);
56
57  if(!inputData.valid() || !inputData->getBuf())
58  return inputData;
59
60  vector<ossimIpt> viv;
63
64  if(!theTile.valid())
65  {
66  theTile = (ossimImageData*)inputData->dup();
68  }
69  else
70  {
71  theTile->setImageRectangleAndBands(rect, inputData->getNumberOfBands());
72  }
73
74  switch(inputData->getScalarType())
75  {
76  case OSSIM_UINT8:
77  doErosion(ossim_uint8(0), inputData);
78  break;
79  case OSSIM_USHORT11:
80  case OSSIM_USHORT12:
81  case OSSIM_USHORT13:
82  case OSSIM_USHORT14:
83  case OSSIM_USHORT15:
84  case OSSIM_UINT16:
85  doErosion(ossim_uint16(0), inputData);
86  break;
87  case OSSIM_SINT16:
88  doErosion(ossim_sint16(0), inputData);
89  break;
90  case OSSIM_UINT32:
91  doErosion(ossim_uint32(0), inputData);
92  break;
93  case OSSIM_FLOAT32:
95  doErosion(ossim_float32(0), inputData);
96  break;
97  case OSSIM_FLOAT64:
99  doErosion(ossim_float64(0), inputData);
100  break;
101  default:
102  {
104  << "ossimErosionFilter::applyFilter WARNING:\n"
105  << "Unhandled scalar type!" << endl;
106  }
107  }
108  return theTile;
109 }
64 bit floating point
16 bit unsigned integer
bool valid() const
Definition: ossimRefPtr.h:75
void doErosion(T scalarType, ossimRefPtr< ossimImageData > &inputData)
float ossim_float32
16 bit signed integer
32 bit floating point
unsigned short ossim_uint16
32 bit unsigned integer
virtual ossimObject * dup() const
double ossim_float64
signed short ossim_sint16
virtual void setImageRectangleAndBands(const ossimIrect &rect, ossim_uint32 numberOfBands)
virtual void getValidImageVertices(std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const
ordering specifies how the vertices should be arranged.
ossim_uint32 getWindowSize() const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
8 bit unsigned integer
unsigned char ossim_uint8
◆ getWindowSize()
ossim_uint32 ossimErosionFilter::getWindowSize ( ) const
inline
Definition at line 31 of file ossimErosionFilter.h.
31 { return theWindowSize; }
◆ initialize()
void ossimErosionFilter::initialize ( )
virtual
Definition at line 36 of file ossimErosionFilter.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
37 {
39  theTile = NULL;
40 }
◆ loadState()
bool ossimErosionFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 251 of file ossimErosionFilter.cpp.
References ossimKeywordlist::find().
252 {
253  const char* lookup = kwl.find(prefix, WINDOW_SIZE_KW.c_str());
254  if (lookup)
255  theWindowSize = ossimString(lookup).toUInt32();
256
257  return ossimImageSourceFilter::loadState(kwl, prefix);
258 }
ossim_uint32 toUInt32() const
const char * c_str() const
Definition: ossimString.h:396
◆ saveState()
bool ossimErosionFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 245 of file ossimErosionFilter.cpp.
References ossimKeywordlist::add().
246 {
247  kwl.add(prefix, WINDOW_SIZE_KW.c_str(), theWindowSize, true);
248  return ossimImageSourceFilter::saveState(kwl, prefix);
249 }
◆ setProperty()
void ossimErosionFilter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 210 of file ossimErosionFilter.cpp.
References ossimRefPtr< T >::valid().
211 {
212  if (!property.valid())
213  return;
214
215  ossimString name = property->getName();
216
217  if (name == WINDOW_SIZE_KW)
218  {
219  theWindowSize = property->valueToString().toUInt32();
220  }
221  else
222  {
224  }
225 }
bool valid() const
◆ setWindowSize()
void ossimErosionFilter::setWindowSize ( ossim_uint32  windowSize)
inline
Definition at line 30 of file ossimErosionFilter.h.
Referenced by ossimShorelineTool::execute().
30 { theWindowSize = windowSize; }
Member Data Documentation
◆ theTempTile
ossimRefPtr<ossimImageData> ossimErosionFilter::theTempTile
protected
Definition at line 53 of file ossimErosionFilter.h.
◆ theTile
ossimRefPtr<ossimImageData> ossimErosionFilter::theTile
protected
Definition at line 52 of file ossimErosionFilter.h.
Referenced by doErosion(), getTile(), and initialize().
◆ theValidImagePoly
ossimPolygon ossimErosionFilter::theValidImagePoly
protected
Definition at line 55 of file ossimErosionFilter.h.
Referenced by doErosion(), and getTile().
◆ theWindowSize
ossim_uint32 ossimErosionFilter::theWindowSize
protected
Definition at line 54 of file ossimErosionFilter.h.
Referenced by doErosion().
