ossimImageGaussianFilter Class Reference
class for symmetric Gaussian filtering implemented as two separable horizontal/vertical gaussian filters More...
#include <ossimImageGaussianFilter.h>
Inheritance diagram for ossimImageGaussianFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimImageGaussianFilter ()
 own methods More...
ossim_float64 getGaussStd () const
void setGaussStd (const ossim_float64 &v)
bool isStrictNoData () const
void setStrictNoData (bool aStrict)
virtual void initialize ()
 inherited methods More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimImageGaussianFilter ()
void initializeProcesses ()
 protected methods More...
void updateKernels ()
virtual ~ossimReferenced ()
Protected Attributes
ossim_float64 theGaussStd
 parameters More...
bool theStrictNoData
ossimRefPtr< ossimConvolutionFilter1DtheHF
 subprocesses More...
ossimRefPtr< ossimConvolutionFilter1DtheVF
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
PROPERTIES: -GaussStd is the standard deviation of the gaussian (filter widths are equal to 2*floor(2.5*GaussStd+0.5)+1) -strictNoData selects the behaviour for NODATA pixels true : any NODATA pixels in the convolution will Nullify the center pixel false : center pixel will be NODATA only if it was NODATA before other NODATA pixels are processed as zero in the convolution calculation
Definition at line 26 of file ossimImageGaussianFilter.h.
◆ ossimImageGaussianFilter()
ossimImageGaussianFilter::ossimImageGaussianFilter ( )
own methods
Definition at line 23 of file ossimImageGaussianFilter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), ossimConvolutionFilter1D::setIsHorizontal(), ossimConvolutionFilter1D::setStrictNoData(), theHF, theStrictNoData, theVF, and updateKernels().
25  theGaussStd(0.5),
26  theStrictNoData(true)
27 {
28  // ingredients:
29  // 2x ConvolutionFilter1D
32
33  theHF->setIsHorizontal(true);
34  theVF->setIsHorizontal(false);
35  updateKernels();
36
39
40  //tie them up
42 }
ossimImageSourceFilter(ossimObject *owner=NULL)
virtual void setStrictNoData(bool aStrict)
parameters
class for vertical or horizontal convolution
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
virtual void setIsHorizontal(bool aIsHz)
ossimRefPtr< ossimConvolutionFilter1D > theHF
subprocesses
ossimRefPtr< ossimConvolutionFilter1D > theVF
◆ ~ossimImageGaussianFilter()
ossimImageGaussianFilter::~ossimImageGaussianFilter ( )
protectedvirtual
Definition at line 44 of file ossimImageGaussianFilter.cpp.
References ossimConnectableObject::disconnect(), theHF, theVF, and ossimRefPtr< T >::valid().
45 {
46  if(theHF.valid())
47  {
48  theHF->disconnect();
49  theHF = 0;
50  }
51  if(theVF.valid())
52  {
53  theVF->disconnect();
54  theVF = 0;
55  }
56 }
virtual void disconnect(ossimConnectableObject *object=0)
Will disconnect the object passed in.
bool valid() const
Definition: ossimRefPtr.h:75
subprocesses
Member Function Documentation
◆ connectInputEvent()
void ossimImageGaussianFilter::connectInputEvent ( ossimConnectionEvent event)
virtual
Definition at line 181 of file ossimImageGaussianFilter.cpp.
References ossimImageSourceFilter::connectInputEvent(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectMyInput(), ossimConnectableObject::getInput(), initializeProcesses(), and theHF.
182 {
184  if(getInput())
185  {
188  }
189  else
190  {
191  theHF->disconnectMyInput(0, false, false);
193  }
194 }
virtual ossimRefPtr< ossimConnectableObject > disconnectMyInput(ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true)
Will disconnect the object at the given input index and generate a connection event.
virtual void connectInputEvent(ossimConnectionEvent &event)
void initializeProcesses()
protected methods
subprocesses
◆ disconnectInputEvent()
void ossimImageGaussianFilter::disconnectInputEvent ( ossimConnectionEvent event)
virtual
Definition at line 197 of file ossimImageGaussianFilter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimImageSourceFilter::disconnectInputEvent(), ossimConnectableObject::disconnectMyInput(), ossimConnectableObject::getInput(), initializeProcesses(), and theHF.
198 {
200  if(getInput())
201  {
204  }
205  else
206  {
207  theHF->disconnectMyInput(0, false, false);
209  }
210 }
virtual void disconnectInputEvent(ossimConnectionEvent &event)
protected methods
subprocesses
◆ getGaussStd()
ossim_float64 ossimImageGaussianFilter::getGaussStd ( ) const
inline
Definition at line 34 of file ossimImageGaussianFilter.h.
Referenced by updateKernels().
34 { return theGaussStd; }
parameters
◆ getProperty()
ossimRefPtr< ossimProperty > ossimImageGaussianFilter::getProperty ( const ossimString name) const
virtual
Definition at line 81 of file ossimImageGaussianFilter.cpp.
82 {
83  if (name == PROPERTYNAME_GAUSSSTD) {
85  property->setCacheRefreshBit();
86  return property;
87  } else if (name == PROPERTYNAME_STRICTNODATA) {
89  property->setCacheRefreshBit();
90  return property;
91  }
93 }
ossim_float64 getGaussStd() const
Numeric to string methods.
◆ getPropertyNames()
void ossimImageGaussianFilter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 95 of file ossimImageGaussianFilter.cpp.
References ossimImageSourceFilter::getPropertyNames().
96 {
98  propertyNames.push_back(PROPERTYNAME_GAUSSSTD);
99  propertyNames.push_back(PROPERTYNAME_STRICTNODATA);
100 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimImageGaussianFilter::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 159 of file ossimImageGaussianFilter.cpp.
References ossimImageSource::getTile(), ossimConvolutionFilter1D::getTile(), ossimSource::isSourceEnabled(), ossimImageSourceFilter::theInputConnection, and theVF.
Referenced by ossimSFIMFusion::getTile(), and ossimLocalCorrelationFusion::getTile().
160 {
161  if(isSourceEnabled())
162  {
163  return theVF->getTile(tileRect, resLevel);
164  }
166  {
167  return theInputConnection->getTile(tileRect, resLevel);
168  }
169
170  return 0;
171 }
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
◆ initialize()
void ossimImageGaussianFilter::initialize ( )
virtual
◆ initializeProcesses()
void ossimImageGaussianFilter::initializeProcesses ( )
protected
protected methods
Definition at line 174 of file ossimImageGaussianFilter.cpp.
References ossimConvolutionFilter1D::initialize(), theHF, and theVF.
Referenced by connectInputEvent(), disconnectInputEvent(), and initialize().
175 {
176  theHF->initialize();
177  theVF->initialize();
178 }
subprocesses
◆ isStrictNoData()
bool ossimImageGaussianFilter::isStrictNoData ( ) const
inline
Definition at line 37 of file ossimImageGaussianFilter.h.
◆ loadState()
bool ossimImageGaussianFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 118 of file ossimImageGaussianFilter.cpp.
References ossimKeywordlist::find().
120 {
121  const char* gs = kwl.find(prefix, PROPERTYNAME_GAUSSSTD);
122  if(gs)
123  {
124  setGaussStd(ossimString(gs).toDouble());
125  } else {
126  cerr<<"ossimImageGaussianFilter : warning no "<< PROPERTYNAME_GAUSSSTD<<" in loadState"<<endl;
127  }
128  const char* sn = kwl.find(prefix, PROPERTYNAME_STRICTNODATA);
129  if(sn)
130  {
131  setStrictNoData(ossimString(sn).toBool());
132  } else {
133  cerr<<"ossimConvolutionFilter1D : warning no "<<PROPERTYNAME_STRICTNODATA<<" in state"<<endl;
134  }
135  return ossimImageSourceFilter::loadState(kwl, prefix);
136 }
void setGaussStd(const ossim_float64 &v)
◆ saveState()
bool ossimImageGaussianFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 102 of file ossimImageGaussianFilter.cpp.
References ossimKeywordlist::add().
104 {
105  kwl.add(prefix,
106  PROPERTYNAME_GAUSSSTD,
107  theGaussStd,
108  true);
109  kwl.add(prefix,
110  PROPERTYNAME_STRICTNODATA,
111  isStrictNoData()?"true":"false", //use string instead of boolean
112  true);
113
114  return ossimImageSourceFilter::saveState(kwl, prefix);
115 }
parameters
◆ setGaussStd()
void ossimImageGaussianFilter::setGaussStd ( const ossim_float64 v)
◆ setProperty()
void ossimImageGaussianFilter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 58 of file ossimImageGaussianFilter.cpp.
References ossimProperty::getName().
59 {
60  if(!property) return;
61
62  if (property->getName() == PROPERTYNAME_GAUSSSTD) {
64  property.get());
65  if(sProperty)
66  {
67  setGaussStd(sProperty->asFloat64());
68  }
69  } else if (property->getName() == PROPERTYNAME_STRICTNODATA) {
71  property.get());
72  if(booleanProperty)
73  {
74  setStrictNoData(booleanProperty->getBoolean());
75  }
76  } else {
78  }
79 }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
virtual ossim_float64 asFloat64() const
const ossimString & getName() const
◆ setStrictNoData()
void ossimImageGaussianFilter::setStrictNoData ( bool  aStrict)
Definition at line 144 of file ossimImageGaussianFilter.cpp.
References ossimConvolutionFilter1D::setStrictNoData(), theHF, theStrictNoData, and theVF.
145 {
146  theStrictNoData = aStrict;
147  theHF->setStrictNoData(aStrict);
148  theVF->setStrictNoData(aStrict);
149 }
subprocesses
◆ updateKernels()
void ossimImageGaussianFilter::updateKernels ( )
protected
Definition at line 212 of file ossimImageGaussianFilter.cpp.
References getGaussStd(), ossimConvolutionFilter1D::setCenterOffset(), ossimConvolutionFilter1D::setKernel(), theHF, and theVF.
Referenced by ossimImageGaussianFilter(), and setGaussStd().
213 {
214  //update kernels based on GaussStd value :2.5 sigma on each side
215  // symetric kernel
216  static const ossim_float64 sigmaN = 2.5;
217  ossim_float64 sig22 = getGaussStd()*getGaussStd()*2.0;
218
219  ossim_uint32 halfw = (ossim_uint32)(std::floor(getGaussStd() * sigmaN + 0.5));
220  ossim_uint32 supsize = 2*halfw + 1;
221
222  //fill with sym. gaussian (unnormalized)
223  vector<ossim_float64> newk(supsize);
224  ossim_float64 sum=1.0;
225  ossim_float64 v;
226  newk[halfw] = 1.0;
227  for(ossim_int32 i=(ossim_int32)halfw; i>0 ;--i) //reverse for summing
228  {
229  newk[halfw + i] = newk[halfw - i] = v = std::exp(-i*i/sig22);
230  sum += 2.0 * v;
231  }
232
233  //normalize
234  ossim_float64 invsum=1.0/sum;
235  for(ossim_uint32 i=0; i<supsize ;++i)
236  {
237  newk[i] *= invsum;
238  }
239
240  //send to 1d conv filters
241  theHF->setKernel(newk);
242  theVF->setKernel(newk);
243  theHF->setCenterOffset(halfw);
244  theVF->setCenterOffset(halfw);
245 }
virtual void setKernel(const std::vector< ossim_float64 > &aKernel)
double ossim_float64
unsigned int ossim_uint32
subprocesses
virtual void setCenterOffset(ossim_int32 aCenterOffset)
int ossim_int32
Member Data Documentation
◆ theGaussStd
ossim_float64 ossimImageGaussianFilter::theGaussStd
protected
parameters
Definition at line 68 of file ossimImageGaussianFilter.h.
Referenced by setGaussStd().
◆ theHF
ossimRefPtr<ossimConvolutionFilter1D> ossimImageGaussianFilter::theHF
protected
◆ theStrictNoData
bool ossimImageGaussianFilter::theStrictNoData
protected
Definition at line 69 of file ossimImageGaussianFilter.h.
Referenced by ossimImageGaussianFilter(), and setStrictNoData().
◆ theVF
ossimRefPtr<ossimConvolutionFilter1D> ossimImageGaussianFilter::theVF
protected
