Protected Member Functions | List of all members
ossimJpeg12NitfReader Class Reference
ossimJpeg12NitfReader class for reading NITF images with 12 bit jpeg compressed blocks using libjpeg-turbo library compiled specifically with "--with-12bit" compiler option. More...
#include <ossimJpeg12NitfReader.h>
Inheritance diagram for ossimJpeg12NitfReader:
ossimNitfTileSource ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
virtual bool canUncompress (const ossimNitfImageHeader *hdr) const
virtual bool uncompressJpegBlock (ossim_uint32 x, ossim_uint32 y)
Uncompresses a jpeg block using the jpeg-6b library. More...
bool loadJpeg12QuantizationTables (jpeg12_decompress_struct &cinfo) const
 Loads one of the default tables based on COMRAT value. More...
bool loadJpeg12HuffmanTables (jpeg12_decompress_struct &cinfo) const
 Loads default huffman tables. More...
- Protected Member Functions inherited from ossimNitfTileSource
virtual ~ossimNitfTileSource ()
void setBoundingRectangle (const ossimIrect &imageRect)
 ossimNitfTileSource (const ossimNitfTileSource &obj)
 Copy constructor, disallow... More...
ossimNitfTileSourceoperator= (const ossimNitfTileSource &rhs)
 Operator=, disallow... More...
bool loadTile (const ossimIrect &clipRect)
 Returns true on success, false on error. More...
ossim_uint32 getBlockNumber (const ossimIpt &block_origin) const
void destroy ()
 Deletes all memory allocated by this object. More...
virtual bool parseFile ()
 Parses "theImageFile" and initializes all nitf headers. More...
virtual bool allocate ()
 Allocates everything for current entry. More...
virtual bool allocateBuffers ()
 Allocates buffers for current entry. More...
virtual void initializeScalarType ()
 Initializes the data member "theScalarType" from the current entry. More...
virtual void initializeSwapBytesFlag ()
 Initializes the data member "theSwapBytesFlag" from the current entry. More...
virtual void initializeReadMode ()
 Initializes the data member "theReadMode" from the current entry. More...
void initializeBandCount ()
 Initializes the data member "theNumberOfBands" from the current entry. More...
bool initializeBlockSize ()
 Initializes the data member "theBlockSize" from the current entry. More...
virtual bool initializeImageRect ()
 Initializes the data members "theImageRect" and "theBlockRect" from the current entry. More...
void initializeCacheSize ()
 Initializes the data member "theCacheSize". More...
virtual void initializeCacheTileInterLeaveType ()
 Initializes the data member "theCacheTileInterLeaveType". More...
void initializeCacheTile ()
 Initializes the cache tile size(width and height). More...
virtual void initializeCompressedBuf ()
 Initializes the data member theCompressedBuf. More...
virtual void initializeOutputTile ()
 Initializes the output tile size(width and height). More...
void initializeLut ()
 Initializes "theLut" if applicable. More...
bool loadBlockFromCache (ossim_uint32 x, ossim_uint32 y, const ossimIrect &clipRect)
 Loads a block of data to theCacheTile. More...
virtual bool loadBlock (ossim_uint32 x, ossim_uint32 y)
bool getPosition (std::streamoff &position, ossim_uint32 x, ossim_uint32 y, ossim_uint32 band) const
ossim_uint32 getNumberOfBlocks () const
std::streampos getBandOffset () const
std::streampos getBlockOffset () const
void explodePackedBits (ossimRefPtr< ossimImageData > packedBuffer) const
void convertTransparentToNull (ossimRefPtr< ossimImageData > tile) const
ossim_uint32 getPartialReadSize (const ossimIpt &blockOrigin) const
bool isVqCompressed (const ossimString &compressionCode) const
void vqUncompressC4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source)
 Uncompresses Vector Quantization unmasked image data. More...
void vqUncompressM4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source)
 Uncompresses Vector Quantization masked image data. More...
void lutUncompress (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source)
virtual bool scanForJpegBlockOffsets ()
 scans the file storing in offsets in "theNitfBlockOffset" and block sizes in "theNitfBlockSize". More...
bool loadJpegQuantizationTables (jpeg_decompress_struct &cinfo) const
bool loadJpegHuffmanTables (jpeg_decompress_struct &cinfo) const
virtual void completeOpen ()
virtual ~ossimReferenced ()
Additional Inherited Members
- Public Types inherited from ossimNitfTileSource
enum  ReadMode {
  READ_MODE_UNKNOWN = 0, READ_BIB_BLOCK = 1, READ_BIP_BLOCK = 2, READ_BIR_BLOCK = 3,
  READ_BSQ_BLOCK = 4, READ_BIB = 5, READ_BIP = 6, READ_BIR = 7,
  READ_JPEG_BLOCK = 8
- Public Member Functions inherited from ossimNitfTileSource
virtual bool open ()
 Returns true if the image_file can be opened and is a valid nitf file. More...
bool open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString)
 This open takes a stream and stores/captures the shared pointer on success. More...
virtual void close ()
 Closes file and destroys all memory allocated. More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const
 Returns the number of lines in the image. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const
 Returns the number of samples in the image. More...
 Returns the output pixel type of the tile source. More...
 Returns the width of the output tile. More...
 Returns the height of the output tile. More...
virtual bool isOpen () const
ossim_uint32 getNumberOfEntries () const
ossimString getSecurityClassification () const
bool getCacheEnabledFlag () const
void setCacheEnabledFlag (bool flag)
const ossimNitfFileHeadergetFileHeader () const
const ossimNitfImageHeadergetCurrentImageHeader () const
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
- Protected Attributes inherited from ossimNitfTileSource
ossimRefPtr< ossimImageDatatheCacheTile
ossimRefPtr< ossimNitfFiletheNitfFile
std::vector< ossimRefPtr< ossimNitfImageHeader > > theNitfImageHeader
ReadMode theReadMode
ossimScalarType theScalarType
bool theSwapBytesFlag
ossim_uint32 theNumberOfInputBands
ossim_uint32 theNumberOfOutputBands
ossim_uint32 theBlockSizeInBytes
ossim_uint32 theReadBlockSizeInBytes
ossim_uint32 theNumberOfImages
ossim_uint32 theCurrentEntry
ossimIrect theImageRect
std::shared_ptr< ossim::istreamtheFileStr
std::vector< ossim_uint32theSelectorBandList
std::vector< ossim_uint32theOutputBandList
ossimIpt theCacheSize
ossimInterleaveType theCacheTileInterLeaveType
bool theCacheEnabledFlag
std::vector< ossim_uint32theEntryList
ossimAppFixedTileCache::ossimAppFixedCacheId theCacheId
bool thePackedBitsFlag
ossimIrect theBlockImageRect
std::vector< ossim_uint8theCompressedBuf
std::vector< std::streamoff > theNitfBlockOffset
std::vector< ossim_uint32theNitfBlockSize
bool m_jpegOffsetsDirty
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 33 of file ossimJpeg12NitfReader.h.
Member Function Documentation
◆ canUncompress()
bool ossimJpeg12NitfReader::canUncompress ( const ossimNitfImageHeader hdr) const
protectedvirtual
Parameters
hdrPointer to image header.
Returns
true if reader can uncompress nitf.
Reimplemented from ossimNitfTileSource.
Definition at line 62 of file ossimJpeg12NitfReader.cpp.
References ossimNitfTileSource::canUncompress(), ossimNitfImageHeader::getBitsPerPixelPerBand(), and ossimNitfImageHeader::getCompressionCode().
63 {
64  bool result = false;
65  if (hdr)
66  {
67  // C3 = jpeg. We only do 12 bit jpeg.
68  if ( (hdr->getCompressionCode() == "C3") && (hdr->getBitsPerPixelPerBand() == 12) )
69  {
70  result = true;
71  }
72  else
73  {
75  }
76  }
77  return result;
78 }
virtual bool canUncompress(const ossimNitfImageHeader *hdr) const
virtual ossimString getCompressionCode() const =0
virtual ossim_int32 getBitsPerPixelPerBand() const =0
◆ loadJpeg12HuffmanTables()
bool ossimJpeg12NitfReader::loadJpeg12HuffmanTables ( jpeg12_decompress_struct &  cinfo) const
protected
Returns
true success, false on error.
Definition at line 333 of file ossimJpeg12NitfReader.cpp.
334 {
335  if ( (cinfo.ac_huff_tbl_ptrs[0] != NULL) &&
336  (cinfo.dc_huff_tbl_ptrs[0] != NULL) )
337  {
338  return false;
339  }
340
341  cinfo.ac_huff_tbl_ptrs[0] = jpeg12_alloc_huff_table((j12_common_ptr)&cinfo);
342  cinfo.dc_huff_tbl_ptrs[0] = jpeg12_alloc_huff_table((j12_common_ptr)&cinfo);
343
344  ossim_int32 i;
345  JHUFF_TBL* huff_ptr;
346
347  // Copy the ac tables.
348  huff_ptr = cinfo.ac_huff_tbl_ptrs[0]; /* huff_ptr is JHUFF_TBL* */
349  for (i = 0; i < 16; ++i)
350  {
351  // huff_ptr->bits is array of 17 bits[0] is unused; hence, the i+1
352  huff_ptr->bits[i+1] = AC_BITS[i];
353  }
354
355  for (i = 0; i < 256; ++i)
356  {
357  huff_ptr->huffval[i] = AC_HUFFVAL[i];
358  }
359
360  // Copy the dc tables.
361  huff_ptr = cinfo.dc_huff_tbl_ptrs[0]; /* huff_ptr is JHUFF_TBL* */
362  for (i = 0; i < 16; ++i)
363  {
364  // huff_ptr->bits is array of 17 bits[0] is unused; hence, the i+1
365  huff_ptr->bits[i+1] = DC_BITS[i];
366  }
367
368  for (i = 0; i < 256; i++)
369  {
370  /* symbols[] is the list of Huffman symbols, in code-length order */
371  huff_ptr->huffval[i] = DC_HUFFVAL[i];
372  }
373  return true;
374 }
int ossim_int32
◆ loadJpeg12QuantizationTables()
bool ossimJpeg12NitfReader::loadJpeg12QuantizationTables ( jpeg12_decompress_struct &  cinfo) const
protected
Returns
true if comrat had valid table value(1-5) and table was loaded, false if COMRAT value did not contain a valid value. Will also return false if there is already a table loaded.
Note
COMRAT is nitf compression rate code field:
  • "00.2" == default compression table 2
  • "00.5" == default compression table 5 and so on.
Definition at line 290 of file ossimJpeg12NitfReader.cpp.
References ossimNitfImageHeader::getCompressionRateCode(), ossimNitfTileSource::getCurrentImageHeader(), ossimNotify(), ossimNotifyLevel_WARN, ossimString::push_back(), ossimString::size(), and ossimString::toInt32().
292 {
294  if (!hdr)
295  {
296  return false;
297  }
298
299  ossimString comrat = hdr->getCompressionRateCode();
300  ossim_uint32 tableIndex = 0;
301  if (comrat.size() >= 4)
302  {
303  // COMRAT string like: "00.2" = use table 2. (between 1 and 5).
304  ossimString s;
305  s.push_back(comrat[static_cast<std::string::size_type>(3)]);
306  ossim_int32 comTbl = s.toInt32();
307  if ( (comTbl > 0) && (comTbl < 6) )
308  {
309  tableIndex = comTbl-1;
310  }
311  else
312  {
314  << "ossimJpeg12NitrReader::loadJpegQuantizationTables WARNING\n"
315  << "\nNo quantization tables specified!"
316  << endl;
317  return false;
318  }
319  }
320
321  cinfo.quant_tbl_ptrs[0] = jpeg12_alloc_quant_table((j12_common_ptr) &cinfo);
322
323  JQUANT_TBL* quant_ptr = cinfo.quant_tbl_ptrs[0]; // quant_ptr is JQUANT_TBL*
324
325  for (ossim_int32 i = 0; i < 64; ++i)
326  {
327  /* Qtable[] is desired quantization table, in natural array order */
328  quant_ptr->quantval[i] = QTABLE_ARRAY[tableIndex][i];
329  }
330  return true;
331 }
virtual ossimString getCompressionRateCode() const =0
ossim_int32 toInt32() const
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
std::string::size_type size() const
Definition: ossimString.h:405
unsigned int ossim_uint32
const ossimNitfImageHeader * getCurrentImageHeader() const
int ossim_int32
◆ uncompressJpegBlock()
bool ossimJpeg12NitfReader::uncompressJpegBlock ( ossim_uint32  x,
ossim_uint32  y
protectedvirtual
Parameters
xsample location in image space.
yline location in image space.
Returns
Definition at line 80 of file ossimJpeg12NitfReader.cpp.
References ossimNitfTileSource::getBlockNumber(), x, and y.
81 {
82  ossim_uint32 blockNumber = getBlockNumber( ossimIpt(x,y) );
83
84  if (traceDebug())
85  {
87  << "ossimJpeg12NitrReader::uncompressJpegBlock DEBUG:"
88  << "\nblockNumber: " << blockNumber
89  << std::endl;
90  }
91
92  //---
93  // Logic to hold off on scanning for offsets until a block is actually needed
94  // to speed up loads for things like ossim-info that don't actually read
95  // pixel data.
96  //---
97  if ( m_jpegOffsetsDirty )
98  {
100  {
101  m_jpegOffsetsDirty = false;
102  }
103  else
104  {
106  << "ossimJpeg12NitrReader::uncompressJpegBlock scan for offsets error!"
107  << "\nReturning error..." << endl;
109  return false;
110  }
111  }
112
113  if (traceDebug())
114  {
116  << "\noffset to block: " << theNitfBlockOffset[blockNumber]
117  << "\nblock size: " << theNitfBlockSize[blockNumber]
118  << std::endl;
119  }
120
121  // Seek to the block.
122  theFileStr->seekg(theNitfBlockOffset[blockNumber], ios::beg);
123
124  // Read the block into memory.
125  std::vector<ossim_uint8> compressedBuf(theNitfBlockSize[blockNumber]);
126  if (!theFileStr->read((char*)&(compressedBuf.front()),
127  theNitfBlockSize[blockNumber]))
128  {
129  theFileStr->clear();
131  << "ossimJpeg12NitrReader::uncompressJpegBlock Read Error!"
132  << "\nReturning error..." << endl;
133  return false;
134  }
135
136  jpeg12_decompress_struct cinfo;
137
138  ossimJpegErrorMgr12 jerr;
139
140  cinfo.err = jpeg12_std_error(&jerr.pub);
141
142  jerr.pub.error_exit = ossimJpegErrorExit12;
143
144  /* Establish the setjmp return context for my_error_exit to use. */
145  if (setjmp(jerr.setjmp_buffer))
146  {
147  jpeg12_destroy_decompress(&cinfo);
148
149  return false;
150  }
151
152  jpeg12_CreateDecompress(&cinfo, JPEG12_LIB_VERSION, sizeof(cinfo));
153
154  //---
155  // Step 2: specify data source. In this case we will uncompress from
156  // memory so we will use "ossimJpegMemorySrc" in place of " jpeg_stdio_src".
157  //---
158  ossimJpegMemorySrc12( &cinfo,
159  &(compressedBuf.front()),
160  static_cast<size_t>(theReadBlockSizeInBytes) );
161
162  /* Step 3: read file parameters with jpeg_read_header() */
163
164  jpeg12_read_header(&cinfo, TRUE);
165
166
167  // Check for Quantization tables.
168  if (cinfo.quant_tbl_ptrs[0] == NULL)
169  {
170  // This will load table specified in COMRAT field.
171  if (loadJpeg12QuantizationTables(cinfo) == false)
172  {
173  jpeg12_destroy_decompress(&cinfo);
174  return false;
175  }
176  }
177
178  // Check for huffman tables.
179  if (cinfo.ac_huff_tbl_ptrs[0] == NULL)
180  {
181  // This will load default huffman tables into .
182  if (loadJpeg12HuffmanTables(cinfo) == false)
183  {
184  jpeg12_destroy_decompress(&cinfo);
185  return false;
186  }
187  }
188
189  /* Step 4: set parameters for decompression */
190
191  /* In this example, we don't need to change any of the defaults set by
192  * jpeg_read_header(), so we do nothing here.
193  */
194
195  /* Step 5: Start decompressor */
196
197  jpeg12_start_decompress(&cinfo);
198
199  const ossim_uint32 SAMPLES = cinfo.output_width;
200
201  //---
202  // Note: Some nitf will be tagged with a given number of lines but the last
203  // jpeg block may go beyond that to a complete block. So it you clamp to
204  // last line of the nitf you will get a libjpeg error:
205  //
206  // "Application transferred too few scanlines"
207  //
208  // So here we will always read the full jpeg block even if it is beyond the
209  // last line of the nitf.
210  //---
211  const ossim_uint32 LINES_TO_READ =
212  min(static_cast<ossim_uint32>(theCacheSize.y), cinfo.output_height);
213
214  /* JSAMPLEs per row in output buffer */
215  const ossim_uint32 ROW_STRIDE = SAMPLES * cinfo.output_components;
216
217 #if 0 /* Please leave for debug. drb */
218  static bool TRACED = false;
219  if ( !TRACED )
220  {
221  cout << "theCacheTile:\n" << *(theCacheTile.get())
222  << "\nSAMPLES: " << SAMPLES
223  << "\nLINES_TO_READ: " << LINES_TO_READ
224  << "\nROW_STRIDE: " << ROW_STRIDE
225  << "\nJPEG12_BITS_IN_JSAMPLE: " << JPEG12_BITS_IN_JSAMPLE
226  << "\nsizeof jsamp: " << sizeof(JSAMPLE)
227  << "\ndata_precision: " << cinfo.data_precision
228  << "\ntotal_iMCU_rows: " << cinfo.total_iMCU_rows
229  << endl;
230
231  TRACED = true;
232  }
233 #endif
234
235  if ( (SAMPLES < theCacheTile->getWidth() ) ||
236  (LINES_TO_READ < theCacheTile->getHeight()) )
237  {
239  }
240
241  if ( (SAMPLES > theCacheTile->getWidth()) ||
242  (LINES_TO_READ > theCacheTile->getHeight()) )
243  {
244  jpeg12_finish_decompress(&cinfo);
245  jpeg12_destroy_decompress(&cinfo);
246
247  return false;
248  }
249
250  // Get pointers to the cache tile buffers.
251  std::vector<ossim_uint16*> destinationBuffer(theNumberOfInputBands);
252  ossim_uint32 band = 0;
253  for (band = 0; band < theNumberOfInputBands; ++band)
254  {
255  destinationBuffer[band] = theCacheTile->getUshortBuf(band);
256  }
257
258  std::vector<ossim_uint16> lineBuffer(ROW_STRIDE);
259  // std::vector<ossim_uint8> lineBuffer(ROW_STRIDE);
260  JSAMPROW jbuf[1];
261  jbuf[0] = (JSAMPROW) &(lineBuffer.front());
262
263  while (cinfo.output_scanline < LINES_TO_READ)
264  {
265  // Read a line from the jpeg file.
266  jpeg12_read_scanlines(&cinfo, jbuf, 1);
267
268  ossim_uint32 index = 0;
269  for (ossim_uint32 sample = 0; sample < SAMPLES; ++sample)
270  {
271  for (band = 0; band < theNumberOfInputBands; ++band)
272  {
273  destinationBuffer[band][sample] = lineBuffer[index];
274  ++index;
275  }
276  }
277
278  for (band = 0; band < theNumberOfInputBands; ++band)
279  {
280  destinationBuffer[band] += theCacheSize.x;
281  }
282  }
283
284  jpeg12_finish_decompress(&cinfo);
285  jpeg12_destroy_decompress(&cinfo);
286
287  return true;
288 }
ossim_uint32 x
virtual const ossim_uint16 * getUshortBuf() const
ossim_uint32 y
std::shared_ptr< ossim::istream > theFileStr
void ossimJpegErrorExit12(jpeg12_common_struct *cinfo)
std::vector< ossim_uint32 > theNitfBlockSize
bool loadJpeg12HuffmanTables(jpeg12_decompress_struct &cinfo) const
static const ossimErrorCode OSSIM_ERROR
void ossimJpegMemorySrc12(j12_decompress_ptr cinfo, const ossim_uint8 *buffer, std::size_t bufsize)
ossimRefPtr< ossimImageData > theCacheTile
virtual void makeBlank()
ossim_int32 y
Definition: ossimIpt.h:142
virtual bool scanForJpegBlockOffsets()
ossim_uint32 getBlockNumber(const ossimIpt &block_origin) const
ossim_int32 x
Definition: ossimIpt.h:141
bool loadJpeg12QuantizationTables(jpeg12_decompress_struct &cinfo) const
#define min(a, b)
Definition: auxiliary.h:75
