Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimMeanMedianFilter Class Reference
#include <ossimMeanMedianFilter.h>
Inheritance diagram for ossimMeanMedianFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Types
enum  ossimMeanMedianFilterType {
  OSSIM_MEDIAN = 0, OSSIM_MEDIAN_FILL_NULLS = 1, OSSIM_MEDIAN_NULL_CENTER_ONLY = 2, OSSIM_MEAN = 3,
  OSSIM_MEAN_FILL_NULLS = 4, OSSIM_MEAN_NULL_CENTER_ONLY = 5
 ossimMeanMedianFilter (ossimObject *owner=NULL)
virtual ~ossimMeanMedianFilter ()
virtual void initialize ()
void setWindowSize (ossim_uint32 windowSize)
ossim_uint32 getWindowSize () const
void setAutoGrowRectFlag (bool flag)
bool getAutoGrowRectFlag () const
void setFilterType (ossimMeanMedianFilterType type)
void setFilterType (const ossimString &type)
ossimString getFilterTypeString () const
void getFilterTypeList (std::vector< ossimString > &list) const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
void applyFilter (ossimRefPtr< ossimImageData > &input)
template<class T >
void applyMean (T dummyVariable, ossimRefPtr< ossimImageData > &inputData)
template<class T >
void applyMeanNullCenterOnly (T dummyVariable, ossimRefPtr< ossimImageData > &inputData)
template<class T >
void applyMedian (T dummyVariable, ossimRefPtr< ossimImageData > &inputData)
template<class T >
void applyMedianNullCenterOnly (T dummyVariable, ossimRefPtr< ossimImageData > &inputData)
virtual ~ossimReferenced ()
ossimMeanMedianFilterType theFilterType
ossim_uint32 theWindowSize
bool theEnableFillNullFlag
 Used by applyMean and applyMedian for "fill null" modes. More...
bool theAutoGrowRectFlag
 If true rectangle is expanded by half filter in each direction if the theFilterType fills nulls. More...
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Detailed Description
class ossimMeanMedianFilter
Allows you to change between a median or mean filter. You can also specify a window size which the median or mean is computed and the center pixel is replaced.
Definition at line 25 of file ossimMeanMedianFilter.h.
◆ ossimMeanMedianFilterType
Enumerator
OSSIM_MEDIAN
Applies filter to any non-null center pixel.
Applies filter to all pixels including null center pixels.
Applies filter to only null center pixels.
OSSIM_MEAN
Definition at line 29 of file ossimMeanMedianFilter.h.
30  {
32  OSSIM_MEDIAN = 0,
33
36
39
41  OSSIM_MEAN = 3,
42
43  /* Applies filter to all pixels including null center pixels. */
45
48  };
◆ ossimMeanMedianFilter()
ossimMeanMedianFilter::ossimMeanMedianFilter ( ossimObject owner = NULL)
Definition at line 33 of file ossimMeanMedianFilter.cpp.
References ossimConnectableObject::setDescription().
34  :ossimImageSourceFilter(owner),
35  theTile(0),
37  theWindowSize(3),
38  theEnableFillNullFlag(false),
39  theAutoGrowRectFlag(false)
40 {
41  setDescription(ossimString("Mean Median Filter"));
42 }
virtual void setDescription(const ossimString &description)
ossimImageSourceFilter(ossimObject *owner=NULL)
If true rectangle is expanded by half filter in each direction if the theFilterType fills nulls...
◆ ~ossimMeanMedianFilter()
ossimMeanMedianFilter::~ossimMeanMedianFilter ( )
virtual
Definition at line 44 of file ossimMeanMedianFilter.cpp.
45 {
46 }
Member Function Documentation
◆ applyFilter()
void ossimMeanMedianFilter::applyFilter ( ossimRefPtr< ossimImageData > &  input)
protected
Definition at line 108 of file ossimMeanMedianFilter.cpp.
References applyMean(), applyMeanNullCenterOnly(), applyMedian(), applyMedianNullCenterOnly(), ossimRectilinearDataObject::getScalarType(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_MEAN, OSSIM_MEAN_FILL_NULLS, OSSIM_MEAN_NULL_CENTER_ONLY, OSSIM_MEDIAN, OSSIM_MEDIAN_FILL_NULLS, OSSIM_MEDIAN_NULL_CENTER_ONLY, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_WARN, and theFilterType.
Referenced by getTile().
109 {
110  switch(input->getScalarType())
111  {
112  case OSSIM_UINT8:
113  {
114  switch (theFilterType)
115  {
116  case OSSIM_MEDIAN:
118  applyMedian(ossim_uint8(0), input);
119  break;
120
123  break;
124
125  case OSSIM_MEAN:
127  applyMean(ossim_uint8(0), input);
128  break;
129
132
133  default:
134  break;
135  }
136  break;
137  }
138  case OSSIM_USHORT11:
139  case OSSIM_USHORT12:
140  case OSSIM_USHORT13:
141  case OSSIM_USHORT14:
142  case OSSIM_USHORT15:
143  case OSSIM_UINT16:
144  {
145  switch (theFilterType)
146  {
147  case OSSIM_MEDIAN:
149  applyMedian(ossim_uint16(0), input);
150  break;
151
154  break;
155
156  case OSSIM_MEAN:
158  applyMean(ossim_uint16(0), input);
159  break;
160
163  break;
164
165  default:
166  break;
167  }
168  break;
169  }
170  case OSSIM_SINT16:
171  {
172  switch (theFilterType)
173  {
174  case OSSIM_MEDIAN:
176  applyMedian(ossim_sint16(0), input);
177  break;
178
181  break;
182
183  case OSSIM_MEAN:
185  applyMean(ossim_sint16(0), input);
186  break;
187
190  break;
191
192  default:
193  break;
194  }
195  break;
196  }
197  case OSSIM_UINT32:
198  {
199  switch (theFilterType)
200  {
201  case OSSIM_MEDIAN:
203  applyMedian(ossim_uint32(0), input);
204  break;
205
208  break;
209
210  case OSSIM_MEAN:
212  applyMean(ossim_uint32(0), input);
213  break;
214
217  break;
218
219  default:
220  break;
221  }
222  }
223  case OSSIM_FLOAT32:
225  {
226  switch (theFilterType)
227  {
228  case OSSIM_MEDIAN:
230  applyMedian(ossim_float32(0.0), input);
231  break;
232
235  break;
236
237  case OSSIM_MEAN:
239  applyMean(ossim_float32(0.0), input);
240  break;
241
244  break;
245
246  default:
247  break;
248  }
249  break;
250  }
251  case OSSIM_FLOAT64:
253  {
254  switch (theFilterType)
255  {
256  case OSSIM_MEDIAN:
258  applyMedian(ossim_float64(0.0), input);
259  break;
260
263  break;
264
265  case OSSIM_MEAN:
267  applyMean(ossim_float64(0.0), input);
268  break;
269
272  break;
273
274  default:
275  break;
276  }
277  break;
278  }
279  default:
280  {
282  << "ossimMeanMedianFilter::applyFilter WARNING:\n"
283  << "Unhandled scalar type!" << endl;
284  }
285  }
286 }
64 bit floating point
16 bit unsigned integer
float ossim_float32
16 bit signed integer
void applyMedian(T dummyVariable, ossimRefPtr< ossimImageData > &inputData)
32 bit floating point
unsigned short ossim_uint16
32 bit unsigned integer
double ossim_float64
void applyMedianNullCenterOnly(T dummyVariable, ossimRefPtr< ossimImageData > &inputData)
signed short ossim_sint16
void applyMean(T dummyVariable, ossimRefPtr< ossimImageData > &inputData)
unsigned int ossim_uint32
void applyMeanNullCenterOnly(T dummyVariable, ossimRefPtr< ossimImageData > &inputData)
8 bit unsigned integer
unsigned char ossim_uint8
◆ applyMean()
template<class T >
void ossimMeanMedianFilter::applyMean ( dummyVariable,
ossimRefPtr< ossimImageData > &  inputData
protected
Definition at line 289 of file ossimMeanMedianFilter.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossim::min(), OSSIM_FULL, status, theEnableFillNullFlag, theTile, theWindowSize, x, and y.
Referenced by applyFilter().
291 {
292  ossim_uint32 halfWindow = (theWindowSize >> 1);
293  ossim_uint32 bandIdx = 0;
294  ossim_uint32 x = 0;
295  ossim_uint32 y = 0;
296  ossim_uint32 kernelX = 0;
297  ossim_uint32 kernelY = 0;
298  ossim_uint32 kernelIdx = 0;
299  ossim_uint32 iw = inputData->getWidth();
300  ossim_uint32 ow = theTile->getWidth();
302  ossim_uint32 numberOfBands = ossim::min(theTile->getNumberOfBands(),
303  inputData->getNumberOfBands());
305  std::vector<double> values(theWindowSize*theWindowSize);
306
307  if(status == OSSIM_FULL)
308  {
309  for(bandIdx = 0; bandIdx < numberOfBands; ++bandIdx)
310  {
311  T* inputBuf = (T*)inputData->getBuf(bandIdx);
312  T* outputBuf = (T*)theTile->getBuf(bandIdx);
313
314  if(inputBuf&&outputBuf)
315  {
316  for(y = 0; y < oh; ++y)
317  {
318  for(x = 0; x < ow; ++x)
319  {
320  kernelIdx = 0;
321  for(kernelY = 0; kernelY < theWindowSize; ++kernelY)
322  {
323  for(kernelX = 0; kernelX < theWindowSize;++kernelX)
324  {
325  values[kernelIdx] = *(inputBuf+kernelX + kernelY*iw);
326  ++kernelIdx;
327  }
328  }
329
330
331  if(values.size() > 0)
332  {
333  double sum = std::accumulate(values.begin(),
334  values.end(),
335  0.0);
336  double average = sum/(double)values.size();
337  (*outputBuf) = (T)average;
338  }
339  ++inputBuf;
340  ++outputBuf;
341  }
342
343  inputBuf+=(halfWindow<<1);
344  }
345  }
346  }
347  }
348  else
349  {
350  for(bandIdx = 0; bandIdx < numberOfBands; ++bandIdx)
351  {
352  T* inputBuf = (T*)inputData->getBuf(bandIdx);
353  T* outputBuf = (T*)theTile->getBuf(bandIdx);
354  T np = (T)inputData->getNullPix(bandIdx);
355  if(inputBuf&&outputBuf)
356  {
357  for(y = 0; y < oh; ++y)
358  {
359  for(x = 0; x < ow; ++x)
360  {
361  values.clear();
362  for(kernelY = 0; kernelY < theWindowSize; ++kernelY)
363  {
364  for(kernelX = 0; kernelX < theWindowSize;++kernelX)
365  {
366  T tempValue = *(inputBuf+kernelX + kernelY*iw);
367
368  if(tempValue != np)
369  {
370  values.push_back((double)tempValue);
371  }
372  }
373  }
374
375
376  if(values.size() > 0)
377  {
378  double accumulate = std::accumulate(values.begin(),
379  values.end(),
380  0.0);
381  double average = accumulate/(double)values.size();
382  if(*(inputBuf+halfWindow + halfWindow*iw) == np)
383  {
385  {
386  (*outputBuf) = (T)average;
387  }
388  else
389  {
390  (*outputBuf) = np;
391  }
392  }
393  else
394  {
395  (*outputBuf) = (T)average;
396  }
397  }
398  else
399  {
400  *outputBuf = np;
401  }
402  ++inputBuf;
403  ++outputBuf;
404  }
405
406  inputBuf+=(halfWindow<<1);
407  }
408  }
409  }
410  }
411 }
ossim_uint32 x
ossim_uint32 y
virtual const ossim_float64 * getNullPix() const
T min(T a, T b)
Definition: ossimCommon.h:203
return status
ossimDataObjectStatus
Definitions for data object status.
◆ applyMeanNullCenterOnly()
template<class T >
void ossimMeanMedianFilter::applyMeanNullCenterOnly ( dummyVariable,
protected
Definition at line 413 of file ossimMeanMedianFilter.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimImageData::loadTile(), ossim::min(), OSSIM_FULL, status, theTile, theWindowSize, x, and y.
416 {
417  ossim_uint32 halfWindow = (theWindowSize >> 1);
418  ossim_uint32 bandIdx = 0;
419  ossim_uint32 x = 0;
420  ossim_uint32 y = 0;
421  ossim_uint32 kernelX = 0;
422  ossim_uint32 kernelY = 0;
423  ossim_uint32 iw = inputData->getWidth();
424  ossim_uint32 ow = theTile->getWidth();
426  ossim_uint32 numberOfBands = ossim::min(theTile->getNumberOfBands(),
427  inputData->getNumberOfBands());
429  std::vector<double> values;
430
431  if(status == OSSIM_FULL)
432  {
433  // Nothing to do just copy the tile.
434  theTile->loadTile(inputData.get());
435  }
436  else
437  {
438  // Partial tile with nulls in it.
439  for(bandIdx = 0; bandIdx < numberOfBands; ++bandIdx)
440  {
441  T* inputBuf = (T*)inputData->getBuf(bandIdx);
442  T* outputBuf = (T*)theTile->getBuf(bandIdx);
443  if (!inputBuf || !outputBuf)
444  {
445  return; // Shouldn't happen...
446  }
447
448  const T NP = (T)inputData->getNullPix(bandIdx);
449
450  for(y = 0; y < oh; ++y)
451  {
452  for(x = 0; x < ow; ++x)
453  {
454  // Get the center input pixel.
455  const T CP = *(inputBuf+halfWindow + halfWindow*iw);
456  if (CP == NP)
457  {
458  values.clear();
459  for(kernelY = 0; kernelY < theWindowSize; ++kernelY)
460  {
461  for(kernelX = 0; kernelX < theWindowSize;++kernelX)
462  {
463  T tempValue = *(inputBuf+kernelX + kernelY*iw);
464
465  if(tempValue != NP)
466  {
467  values.push_back((double)tempValue);
468  }
469  }
470  }
471
472  if(values.size() > 0)
473  {
474  double accumulate = std::accumulate(values.begin(),
475  values.end(),
476  0.0);
477  double average = accumulate/(double)values.size();
478  (*outputBuf) = (T)average;
479  }
480  else
481  {
482  (*outputBuf) = NP;
483  }
484
485  }
486  else // Center pixel (CP) not null.
487  {
488  (*outputBuf) = CP;
489  }
490
491  // Move over...
492  ++inputBuf;
493  ++outputBuf;
494
495  } // End of loop in x direction.
496
497  // Move down...
498  inputBuf+=(halfWindow<<1);
499
500  } // End of loop in y direction.
501
502  } // End of band loop.
503
504  } // End of else "partial tile" block.
505 }
ossim_uint32 x
ossim_uint32 y
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
T min(T a, T b)
return status
◆ applyMedian()
template<class T >
void ossimMeanMedianFilter::applyMedian ( dummyVariable,
protected
Definition at line 508 of file ossimMeanMedianFilter.cpp.
510 {
511  ossim_uint32 halfWindow = (theWindowSize >> 1);
512  ossim_uint32 bandIdx = 0;
513  ossim_uint32 x = 0;
514  ossim_uint32 y = 0;
515  ossim_uint32 kernelX = 0;
516  ossim_uint32 kernelY = 0;
517  ossim_uint32 kernelIdx = 0;
518  ossim_uint32 iw = inputData->getWidth();
519  ossim_uint32 ow = theTile->getWidth();
521  ossim_uint32 numberOfBands = ossim::min(theTile->getNumberOfBands(),
522  inputData->getNumberOfBands());
524  std::vector<T> values(theWindowSize*theWindowSize);
525
526  if(status == OSSIM_FULL)
527  {
528  for(bandIdx = 0; bandIdx < numberOfBands; ++bandIdx)
529  {
530  T* inputBuf = (T*)inputData->getBuf(bandIdx);
531  T* outputBuf = (T*)theTile->getBuf(bandIdx);
532
533  if(inputBuf&&outputBuf)
534  {
535  for(y = 0; y < oh; ++y)
536  {
537  for(x = 0; x < ow; ++x)
538  {
539  kernelIdx = 0;
540  for(kernelY = 0; kernelY < theWindowSize; ++kernelY)
541  {
542  for(kernelX = 0; kernelX < theWindowSize;++kernelX)
543  {
544  values[kernelIdx] = *(inputBuf+kernelX + kernelY*iw);
545  ++kernelIdx;
546  }
547  }
548
549  std::sort(values.begin(),
550  values.end());
551
552  if(values.size() > 0)
553  {
554  (*outputBuf) = values[values.size()>>1];
555  }
556  ++inputBuf;
557  ++outputBuf;
558  }
559
560  inputBuf+=(halfWindow<<1);
561  }
562  }
563  }
564  }
565  else
566  {
567  for(bandIdx = 0; bandIdx < numberOfBands; ++bandIdx)
568  {
569  T* inputBuf = (T*)inputData->getBuf(bandIdx);
570  T* outputBuf = (T*)theTile->getBuf(bandIdx);
571  T np = (T)inputData->getNullPix(bandIdx);
572  if(inputBuf&&outputBuf)
573  {
574  for(y = 0; y < oh; ++y)
575  {
576  for(x = 0; x < ow; ++x)
577  {
578  values.clear();
579  for(kernelY = 0; kernelY < theWindowSize; ++kernelY)
580  {
581  for(kernelX = 0; kernelX < theWindowSize;++kernelX)
582  {
583  T tempValue = *(inputBuf+kernelX + kernelY*iw);
584
585  if(tempValue != np)
586  {
587  values.push_back(tempValue);
588  }
589  }
590  }
591
592  std::sort(values.begin(),
593  values.end());
594
595  if(values.size() > 0)
596  {
597  if(*(inputBuf+halfWindow + halfWindow*iw) == np)
598  {
600  {
601  (*outputBuf) = values[values.size()>>1];
602  }
603  else
604  {
605  (*outputBuf) = np;
606  }
607  }
608  else
609  {
610  (*outputBuf) = values[values.size()>>1];
611  }
612  }
613  else
614  {
615  *outputBuf = np;
616  }
617  ++inputBuf;
618  ++outputBuf;
619  }
620
621  inputBuf+=(halfWindow<<1);
622  }
623  }
624  }
625  }
626 }
ossim_uint32 x
ossim_uint32 y
T min(T a, T b)
return status
◆ applyMedianNullCenterOnly()
template<class T >
void ossimMeanMedianFilter::applyMedianNullCenterOnly ( dummyVariable,
protected
Definition at line 628 of file ossimMeanMedianFilter.cpp.
631 {
632  ossim_uint32 halfWindow = (theWindowSize >> 1);
633  ossim_uint32 bandIdx = 0;
634  ossim_uint32 x = 0;
635  ossim_uint32 y = 0;
636  ossim_uint32 kernelX = 0;
637  ossim_uint32 kernelY = 0;
638  ossim_uint32 iw = inputData->getWidth();
639  ossim_uint32 ow = theTile->getWidth();
641  ossim_uint32 numberOfBands = ossim::min(theTile->getNumberOfBands(),
642  inputData->getNumberOfBands());
644  std::vector<T> values;
645
646  if(status == OSSIM_FULL)
647  {
648  // Nothing to do just copy the tile.
649  theTile->loadTile(inputData.get());
650  }
651  else
652  {
653  // Partial tile with nulls in it.
654  for(bandIdx = 0; bandIdx < numberOfBands; ++bandIdx)
655  {
656  T* inputBuf = (T*)inputData->getBuf(bandIdx);
657  T* outputBuf = (T*)theTile->getBuf(bandIdx);
658  if (!inputBuf || !outputBuf)
659  {
660  return; // Shouldn't happen...
661  }
662
663  const T NP = (T)inputData->getNullPix(bandIdx);
664
665  for(y = 0; y < oh; ++y)
666  {
667  for(x = 0; x < ow; ++x)
668  {
669  // Get the center input pixel.
670  const T CP = *(inputBuf+halfWindow + halfWindow*iw);
671  if (CP == NP)
672  {
673  values.clear();
674  for(kernelY = 0; kernelY < theWindowSize; ++kernelY)
675  {
676  for(kernelX = 0; kernelX < theWindowSize;++kernelX)
677  {
678  T tempValue = *(inputBuf+kernelX + kernelY*iw);
679
680  if(tempValue != NP)
681  {
682  values.push_back(tempValue);
683  }
684  }
685  }
686
687  std::sort(values.begin(),
688  values.end());
689
690  if(values.size() > 0)
691  {
692  (*outputBuf) = values[values.size()>>1];
693  }
694  else
695  {
696  (*outputBuf) = NP;
697  }
698  }
699  else // Center pixel (CP) not null.
700  {
701  (*outputBuf) = CP;
702  }
703
704  // Move over...
705  ++inputBuf;
706  ++outputBuf;
707
708  } // End of loop in x direction.
709
710  // Move down...
711  inputBuf+=(halfWindow<<1);
712
713  } // End of loop in y direction.
714
715  } // End of band loop.
716
717  } // End of else "partial tile" block.
718 }
ossim_uint32 x
ossim_uint32 y
T min(T a, T b)
return status
◆ getAutoGrowRectFlag()
bool ossimMeanMedianFilter::getAutoGrowRectFlag ( ) const
Definition at line 879 of file ossimMeanMedianFilter.cpp.
References theAutoGrowRectFlag.
880 {
881  return theAutoGrowRectFlag;
882 }
◆ getBoundingRect()
ossimIrect ossimMeanMedianFilter::getBoundingRect ( ossim_uint32  resLevel = 0) const
virtual
Returns
Returns the bounding rectangle which is the input bounding rectangle with any expansion (from autogrow) added in.
Definition at line 904 of file ossimMeanMedianFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimIrect::hasNans(), ossimIrect::lr(), OSSIM_MEAN_FILL_NULLS, OSSIM_MEAN_NULL_CENTER_ONLY, OSSIM_MEDIAN_FILL_NULLS, OSSIM_MEDIAN_NULL_CENTER_ONLY, ossimIrect::set_lr(), ossimIrect::set_ul(), theAutoGrowRectFlag, theFilterType, theWindowSize, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
905 {
906  // Get the input rectangle.
908  if (!theAutoGrowRectFlag || rect.hasNans())
909  {
910  return rect; // Not in autogrow mode or no input connection yet...
911  }
912
917  {
918  ossimIpt pt = rect.ul();
919  const ossim_int32 HW = (theWindowSize >> 1); // half window size.
920
921  // Adjust the upper left.
922  pt.x = pt.x-HW;
923  pt.y = pt.y-HW;
924  rect.set_ul(pt);
925
926  // Adjust the lower right.
927  pt = rect.lr();
928  pt.x = pt.x+HW;
929  pt.y = pt.y+HW;
930  rect.set_lr(pt);
931  }
932
933  return rect;
934 }
This will return the bounding rect of the source.
const ossimIpt & ul() const
Definition: ossimIrect.h:274
void set_ul(const ossimIpt &pt)
Definition: ossimIrect.h:589
const ossimIpt & lr() const
Definition: ossimIrect.h:276
void set_lr(const ossimIpt &pt)
Definition: ossimIrect.h:623
ossim_int32 y
Definition: ossimIpt.h:142
bool hasNans() const
Definition: ossimIrect.h:337
ossim_int32 x
Definition: ossimIpt.h:141
int ossim_int32
◆ getFilterTypeList()
void ossimMeanMedianFilter::getFilterTypeList ( std::vector< ossimString > &  list) const
Definition at line 891 of file ossimMeanMedianFilter.cpp.
References OSSIM_MEAN_NULL_CENTER_ONLY.
Referenced by getFilterTypeString(), and setFilterType().
893 {
894  list.resize(OSSIM_MEAN_NULL_CENTER_ONLY+1);
895
896  list[0] = ossimString("median");
897  list[1] = ossimString("median_fill_nulls");
898  list[2] = ossimString("median_null_center_only");
899  list[3] = ossimString("mean");
900  list[4] = ossimString("mean_fill_nulls");
901  list[5] = ossimString("mean_null_center_only");
902 }
◆ getFilterTypeString()
ossimString ossimMeanMedianFilter::getFilterTypeString ( ) const
Definition at line 884 of file ossimMeanMedianFilter.cpp.
References getFilterTypeList(), and theFilterType.
885 {
886  std::vector<ossimString> list;
887  getFilterTypeList(list);
888  return list[theFilterType];
889 }
void getFilterTypeList(std::vector< ossimString > &list) const
◆ getProperty()
ossimRefPtr< ossimProperty > ossimMeanMedianFilter::getProperty ( const ossimString name) const
virtual
Definition at line 750 of file ossimMeanMedianFilter.cpp.
751 {
752  if (name == WINDOW_SIZE_KW)
753  {
754  ossimProperty* prop =
755  new ossimNumericProperty(WINDOW_SIZE_KW,
757  3,
758  25);
759  prop->setCacheRefreshBit();
760
761  return prop;
762  }
763  else if (name == FILTER_TYPE_KW)
764  {
765  std::vector<ossimString> constraintList;
766  getFilterTypeList(constraintList);
768  ossimProperty* prop = new ossimStringProperty(FILTER_TYPE_KW,
769  value,
770  false,
771  constraintList);
772  prop->setCacheRefreshBit();
773
774  return prop;
775  }
776  else if (name == AUTO_GROW_KW)
777  {
779  AUTO_GROW_KW, getAutoGrowRectFlag());
780  p->setFullRefreshBit();
781  return p;
782  }
784 }
Numeric to string methods.
void setFullRefreshBit()
ossimString getFilterTypeString() const
void setCacheRefreshBit()
◆ getPropertyNames()
void ossimMeanMedianFilter::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Definition at line 786 of file ossimMeanMedianFilter.cpp.
788 {
789  propertyNames.push_back(WINDOW_SIZE_KW);
790  propertyNames.push_back(FILTER_TYPE_KW);
791  propertyNames.push_back(AUTO_GROW_KW);
792
794 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimMeanMedianFilter::getTile ( const ossimIrect rect,
virtual
Returns
Definition at line 48 of file ossimMeanMedianFilter.cpp.
References applyFilter(), ossimImageData::dup(), ossimImageSource::getTile(), getWindowSize(), ossimSource::isSourceEnabled(), ossimIrect::lr(), ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangle(), ossimImageData::setImageRectangleAndBands(), theEnableFillNullFlag, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
50 {
51  if(!isSourceEnabled())
52  {
53  return ossimImageSourceFilter::getTile(rect, resLevel);
54  }
55
56  ossim_uint32 halfSize = getWindowSize()>>1;
57
58  ossimIrect requestRect(rect.ul().x - halfSize,
59  rect.ul().y - halfSize,
60  rect.lr().x + halfSize,
61  rect.lr().y + halfSize);
62
63  ossimRefPtr<ossimImageData> inputData =
64  ossimImageSourceFilter::getTile(requestRect, resLevel);
65  if(!inputData.valid() || !inputData->getBuf())
66  {
67  return inputData;
68  }
69
70  if(!theTile.valid())
71  {
72  theTile = (ossimImageData*)inputData->dup();
74  }
75  else
76  {
77  theTile->setImageRectangleAndBands(rect, inputData->getNumberOfBands());
78  }
79
80  applyFilter(inputData);
81
82  theTile->setDataObjectStatus(inputData->getDataObjectStatus());
84  {
85  theTile->validate();
86  }
87
88  return theTile;
89 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimObject * dup() const
ossim_uint32 getWindowSize() const
virtual void setImageRectangleAndBands(const ossimIrect &rect, ossim_uint32 numberOfBands)
ossim_int32 y
virtual void setDataObjectStatus(ossimDataObjectStatus status) const
Full list found in ossimConstants.h.
ossim_int32 x
void applyFilter(ossimRefPtr< ossimImageData > &input)
◆ getWindowSize()
ossim_uint32 ossimMeanMedianFilter::getWindowSize ( ) const
Definition at line 96 of file ossimMeanMedianFilter.cpp.
References theWindowSize.
97 {
98  return theWindowSize;
99 }
◆ initialize()
void ossimMeanMedianFilter::initialize ( )
virtual
Definition at line 101 of file ossimMeanMedianFilter.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
102 {
104
105  theTile = NULL;
106 }
◆ loadState()
bool ossimMeanMedianFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 815 of file ossimMeanMedianFilter.cpp.
References ossimKeywordlist::find().
817 {
818  const char* lookup = NULL;
819
820  lookup = kwl.find(prefix, WINDOW_SIZE_KW.c_str());
821  if(lookup)
822  {
823  theWindowSize = ossimString(lookup).toUInt32();
824  }
825
826  lookup = kwl.find(prefix, FILTER_TYPE_KW.c_str());
827  if(lookup)
828  {
829  ossimString type = lookup;
830  setFilterType(type);
831  }
832
833  lookup = kwl.find(prefix, AUTO_GROW_KW.c_str());
834  if(lookup)
835  {
836  ossimString flag = lookup;
837  setAutoGrowRectFlag(flag.toBool());
838  }
839
840  return ossimImageSourceFilter::loadState(kwl, prefix);
841 }
ossim_uint32 toUInt32() const
bool toBool() const
String to numeric methods.
void setFilterType(ossimMeanMedianFilterType type)
const char * c_str() const
Definition: ossimString.h:396
◆ saveState()
bool ossimMeanMedianFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 796 of file ossimMeanMedianFilter.cpp.
References ossimKeywordlist::add().
798 {
799  kwl.add(prefix,
800  WINDOW_SIZE_KW.c_str(),
802  true);
803  kwl.add(prefix,
804  FILTER_TYPE_KW.c_str(),
806  true);
807  kwl.add(prefix,
808  AUTO_GROW_KW.c_str(),
809  (theAutoGrowRectFlag?"true":"false"),
810  true);
811
812  return ossimImageSourceFilter::saveState(kwl, prefix);
813 }
◆ setAutoGrowRectFlag()
void ossimMeanMedianFilter::setAutoGrowRectFlag ( bool  flag)
Parameters
flagSet "theAutoGrowRectFlag". This only affects filter types that set nulls. Will have a growing affect on the edges.
Definition at line 874 of file ossimMeanMedianFilter.cpp.
875 {
876  theAutoGrowRectFlag = flag;
877 }
◆ setFilterType() [1/2]
void ossimMeanMedianFilter::setFilterType ( ossimMeanMedianFilterType  type)
Definition at line 842 of file ossimMeanMedianFilter.cpp.
References theFilterType.
843 {
844  theFilterType = type;
845 }
◆ setFilterType() [2/2]
void ossimMeanMedianFilter::setFilterType ( const ossimString type)
Definition at line 847 of file ossimMeanMedianFilter.cpp.
References ossimString::downcase(), getFilterTypeList(), OSSIM_MEAN_FILL_NULLS, OSSIM_MEDIAN_FILL_NULLS, theEnableFillNullFlag, and theFilterType.
848 {
849  ossimString s = type;
850  s.downcase();
851
852  std::vector<ossimString> list;
853  getFilterTypeList(list);
854
855  for (ossim_uint32 i = 0; i < list.size(); ++i)
856  {
857  if (s == list[i])
858  {
859  theFilterType = static_cast<ossimMeanMedianFilterType>(i);
860  }
861  }
862
865  {
866  theEnableFillNullFlag = true;
867  }
868  else
869  {
870  theEnableFillNullFlag = false;
871  }
872 }
◆ setProperty()
void ossimMeanMedianFilter::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Definition at line 720 of file ossimMeanMedianFilter.cpp.
References ossimRefPtr< T >::valid().
721 {
722  if(!property.valid())
723  {
724  return;
725  }
726
727  ossimString name = property->getName();
728
729  if (name == WINDOW_SIZE_KW)
730  {
731  theWindowSize = property->valueToString().toUInt32();
732  }
733  else if (name == FILTER_TYPE_KW)
734  {
735  ossimString value = property->valueToString();
736  setFilterType(value);
737  }
738  else if (name == AUTO_GROW_KW)
739  {
740  ossimString value;
741  property->valueToString(value);
742  setAutoGrowRectFlag(value.toBool());
743  }
744  else
745  {
747  }
748 }
bool valid() const
bool toBool() const
◆ setWindowSize()
void ossimMeanMedianFilter::setWindowSize ( ossim_uint32  windowSize)
Definition at line 91 of file ossimMeanMedianFilter.cpp.
92 {
93  theWindowSize = windowSize;
94 }
Member Data Documentation
◆ theAutoGrowRectFlag
bool ossimMeanMedianFilter::theAutoGrowRectFlag
protected
Definition at line 109 of file ossimMeanMedianFilter.h.
Referenced by getAutoGrowRectFlag(), getBoundingRect(), and setAutoGrowRectFlag().
◆ theEnableFillNullFlag
bool ossimMeanMedianFilter::theEnableFillNullFlag
protected
Definition at line 103 of file ossimMeanMedianFilter.h.
Referenced by applyMean(), applyMedian(), getTile(), and setFilterType().
◆ theFilterType
ossimMeanMedianFilterType ossimMeanMedianFilter::theFilterType
protected
◆ theTile
ossimRefPtr<ossimImageData> ossimMeanMedianFilter::theTile
protected
◆ theWindowSize
ossim_uint32 ossimMeanMedianFilter::theWindowSize
protected
