Public Member Functions | Static Public Member Functions | Static Private Attributes | List of all members
ossimPointCloudImageHandlerFactory Class Reference
#include <ossimPointCloudImageHandlerFactory.h>
Inheritance diagram for ossimPointCloudImageHandlerFactory:
ossimImageHandlerFactoryBase ossimObjectFactory ossimObject ossimReferenced
 ossimPointCloudImageHandlerFactory ()
virtual ~ossimPointCloudImageHandlerFactory ()
virtual ossimImageHandleropen (const ossimFilename &fileName, bool openOverview=true) const
virtual ossimImageHandleropen (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
virtual ossimRefPtr< ossimImageHandleropenOverview (const ossimFilename &file) const
 Open overview that takes a file name. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
virtual void getImageHandlersBySuffix (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &ext) const
virtual void getImageHandlersByMimeType (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &mimeType) const
- Public Member Functions inherited from ossimImageHandlerFactoryBase
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const
 Open method that takes a stream. More...
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::ImageHandlerState > state) const
virtual ossimRefPtr< ossimImageHandleropenOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimPointCloudImageHandlerFactoryinstance ()
static ossimPointCloudImageHandlerFactorym_instance = 0
Additional Inherited Members
- Public Types inherited from ossimImageHandlerFactoryBase
typedef UniqueList< ossimStringUniqueStringList
typedef std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
virtual ~ossimReferenced ()
Detailed Description
Definition at line 13 of file ossimPointCloudImageHandlerFactory.h.
◆ ossimPointCloudImageHandlerFactory()
ossimPointCloudImageHandlerFactory::ossimPointCloudImageHandlerFactory ( )
inline
Definition at line 16 of file ossimPointCloudImageHandlerFactory.h.
Referenced by instance().
16 {}
◆ ~ossimPointCloudImageHandlerFactory()
ossimPointCloudImageHandlerFactory::~ossimPointCloudImageHandlerFactory ( )
virtual
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimPointCloudImageHandlerFactory::createObject ( const ossimString typeName) const
virtual
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 84 of file ossimPointCloudImageHandlerFactory.cpp.
References STATIC_TYPE_NAME.
85 {
87  {
88  return new ossimPointCloudImageHandler();
89  }
90
91  return (ossimObject*)0;
92 }
Class used for rendering point cloud data into a raster tile.
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
◆ createObject() [2/2]
ossimObject * ossimPointCloudImageHandlerFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Creates and object given a keyword list.
Definition at line 123 of file ossimPointCloudImageHandlerFactory.cpp.
References ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), STATIC_TYPE_NAME, and ossimKeywordNames::TYPE_KW.
125 {
126  ossimObject* result = (ossimObject*)0;
127  const char* type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
128
129  if(type)
130  {
131  if (ossimString(type).trim() == STATIC_TYPE_NAME(ossimImageHandler))
132  {
133  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
134
135  if (lookup)
136  {
137  if(traceDebug())
138  {
139  ossimNotify(ossimNotifyLevel_DEBUG) << "BEBUG: filename " << lookup << std::endl;
140  }
141  // Call the open that takes a filename...
142  result = this->open(kwl, prefix);//ossimFilename(lookup));
143  }
144  }
145  else
146  {
147  result = createObject(ossimString(type));
148  if(result)
149  {
150  result->loadState(kwl, prefix);
151  }
152  }
153  }
154  return result;
155 }
static const char * TYPE_KW
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const
This class defines an abstract Handler which all image handlers(loaders) should derive from...
virtual ossimObject * createObject(const ossimString &typeName) const
static const char * FILENAME_KW
◆ getImageHandlersByMimeType()
void ossimPointCloudImageHandlerFactory::getImageHandlersByMimeType ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString mimeType
) const
virtual
Reimplemented from ossimImageHandlerFactoryBase.
Definition at line 109 of file ossimPointCloudImageHandlerFactory.cpp.
References ossimString::begin(), ossimString::end(), and getImageHandlersBySuffix().
110 {
111  ossimString test(mimeType.begin(), mimeType.begin()+6);
112  if(test == "image/")
113  {
114  ossimString mimeTypeTest(mimeType.begin() + 6, mimeType.end());
115  getImageHandlersBySuffix(result, mimeTypeTest);
116  if(mimeTypeTest == "las")
117  {
118  result.push_back(new ossimPointCloudImageHandler);
119  }
120  }
121 }
virtual void getImageHandlersBySuffix(ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &ext) const
std::string::iterator end()
Definition: ossimString.h:423
std::string::iterator begin()
Definition: ossimString.h:420
◆ getImageHandlersBySuffix()
void ossimPointCloudImageHandlerFactory::getImageHandlersBySuffix ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString ext
) const
virtual
Definition at line 100 of file ossimPointCloudImageHandlerFactory.cpp.
Referenced by getImageHandlersByMimeType().
101 {
102  if ((ext == "las") || (ext == "gpkg"))
103  {
104  result.push_back(new ossimPointCloudImageHandler);
105  return;
106  }
107 }
◆ getSupportedExtensions()
void ossimPointCloudImageHandlerFactory::getSupportedExtensions ( ossimImageHandlerFactoryBase::UniqueStringList extensionList) const
virtual
Implements ossimImageHandlerFactoryBase.
Definition at line 94 of file ossimPointCloudImageHandlerFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back().
95 {
96  extensionList.push_back("las");
97  extensionList.push_back("gpkg");
98 }
◆ getTypeNameList()
void ossimPointCloudImageHandlerFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 157 of file ossimPointCloudImageHandlerFactory.cpp.
158 {
159  typeList.push_back(STATIC_TYPE_NAME(ossimPointCloudImageHandler));
160 }
◆ instance()
ossimPointCloudImageHandlerFactory * ossimPointCloudImageHandlerFactory::instance ( )
static
Definition at line 23 of file ossimPointCloudImageHandlerFactory.cpp.
References m_instance, and ossimPointCloudImageHandlerFactory().
24 {
25  if(!m_instance)
26  {
28  }
29
30  return m_instance;
31 }
static ossimPointCloudImageHandlerFactory * m_instance
◆ open() [1/2]
ossimImageHandler * ossimPointCloudImageHandlerFactory::open ( const ossimFilename fileName,
bool  openOverview = true
) const
virtual
Definition at line 33 of file ossimPointCloudImageHandlerFactory.cpp.
References ossimString::downcase(), ossimString::empty(), ossimFilename::exists(), ossimFilename::ext(), ossimFilename::setExtension(), and ossimString::trim().
35 {
36  static const char* M = "ossimPointCloudImageHandlerFactory::open(filename) -- ";
37
38  ossimFilename copyFilename = fileName;
40
41  // Check for empty file.
42  copyFilename.trim();
43  if (copyFilename.empty() || !copyFilename.exists())
44  return 0;
45
46  ossimString ext = copyFilename.ext().downcase();
47  if(ext == "gz")
48  copyFilename = copyFilename.setExtension("");
49
50  if (traceDebug())
51  ossimNotify(ossimNotifyLevel_DEBUG)<<M<< "Trying Point Cloud...\n";
52
53  result = new ossimPointCloudImageHandler();
54  result->setFilename(copyFilename);
55  if (!result->open())
56  result = 0;
58
59  return result.release();
60 }
virtual bool open()=0
Pure virtual open.
void setOpenOverviewFlag(bool flag)
Sets theOpenOverviewFlag.
bool exists() const
virtual void setFilename(const ossimFilename &filename)
Sets the filename.
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
T * release()
Definition: ossimRefPtr.h:93
bool empty() const
Definition: ossimString.h:411
ossimString ext() const
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
◆ open() [2/2]
ossimImageHandler * ossimPointCloudImageHandlerFactory::open ( const ossimKeywordlist kwl,
) const
virtual
Definition at line 62 of file ossimPointCloudImageHandlerFactory.cpp.
64 {
65  static const char* M = "ossimPointCloudImageHandlerFactory::open(kwl,prefix) -- ";
66  if(traceDebug()) ossimNotify(ossimNotifyLevel_DEBUG) << M <<" entered..." << std::endl;
67
69  if (traceDebug()) ossimNotify(ossimNotifyLevel_DEBUG)<<M<< "Trying ossimPointCloudImageHandler...\n";
70  result = new ossimPointCloudImageHandler();
71  if (!result->loadState(kwl, prefix))
72  result = 0;
73
74  return result.get();
75 }
◆ openOverview()
ossimRefPtr< ossimImageHandler > ossimPointCloudImageHandlerFactory::openOverview ( const ossimFilename file) const
virtual
This default implementation returns a null ref pointer. Derived factories that have overview readers should override.
Parameters
fileFile to open.
Returns
Definition at line 77 of file ossimPointCloudImageHandlerFactory.cpp.
79 {
81  return result;
82 }
Member Data Documentation
◆ m_instance
ossimPointCloudImageHandlerFactory * ossimPointCloudImageHandlerFactory::m_instance = 0
staticprivate
