#include <ossimPolyCutter.h>
Public Types | |
enum | ossimPolyCutterCutType { OSSIM_POLY_NULL_INSIDE = 0, OSSIM_POLY_NULL_OUTSIDE = 1 } |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
ossimPolyCutter () | |
ossimPolyCutter (ossimImageSource *inputSource, const ossimPolygon &polygon) | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
This will return the bounding rect of the source. More... | |
virtual void | initialize () |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual void | setPolygon (const vector< ossimDpt > &polygon, ossim_uint32 i=0) |
virtual void | setPolygon (const vector< ossimIpt > &polygon, ossim_uint32 i=0) |
virtual void | addPolygon (const vector< ossimIpt > &polygon) |
virtual void | addPolygon (const vector< ossimDpt > &polygon) |
virtual void | addPolygon (const ossimPolygon &polygon) |
virtual void | setNumberOfPolygons (ossim_uint32 count) |
virtual std::vector< ossimPolygon > & | getPolygonList () |
virtual const std::vector< ossimPolygon > & | getPolygonList () const |
void | setCutType (ossimPolyCutterCutType cutType) |
ossimPolyCutterCutType | getCutType () const |
void | clear () |
const ossimIrect & | getRectangle () const |
void | setRectangle (const ossimIrect &rect) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
ossimImageSourceFilter (ossimObject *owner=NULL) | |
ossimImageSourceFilter (ossimImageSource *inputSource) | |
ossimImageSourceFilter (ossimObject *owner, ossimImageSource *inputSource) | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
virtual ossim_uint32 | getNumberOfInputBands () const |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual void | refreshEvent (ossimRefreshEvent &event) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
virtual | ~ossimPolyCutter () |
void | allocate () |
Called on first getTile, will initialize all data needed. More... | |
void | computeBoundingRect () |
virtual | ~ossimImageSourceFilter () |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
Definition at line 22 of file ossimPolyCutter.h.
Enumerator | |
OSSIM_POLY_NULL_INSIDE | |
OSSIM_POLY_NULL_OUTSIDE |
Definition at line 25 of file ossimPolyCutter.h.
ossimPolyCutter::ossimPolyCutter | ( | ) |
Definition at line 23 of file ossimPolyCutter.cpp.
ossimPolyCutter::ossimPolyCutter | ( | ossimImageSource * | inputSource, |
const ossimPolygon & | polygon | ||
Definition at line 35 of file ossimPolyCutter.cpp.
References computeBoundingRect(), initialize(), and thePolygonList.
protectedvirtual |
Definition at line 47 of file ossimPolyCutter.cpp.
Reimplemented in ossimGeoPolyCutter.
Definition at line 305 of file ossimPolyCutter.cpp.
References computeBoundingRect(), and thePolygonList.
Referenced by ossimGeoPolyCutter::addPolygon().
Definition at line 311 of file ossimPolyCutter.cpp.
Definition at line 317 of file ossimPolyCutter.cpp.
protected |
Definition at line 200 of file ossimPolyCutter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
Referenced by getTile().
void ossimPolyCutter::clear | ( | ) |
Definition at line 334 of file ossimPolyCutter.cpp.
References setNumberOfPolygons().
Referenced by ossimTilingPoly::nextFeature().
protected |
Definition at line 355 of file ossimPolyCutter.cpp.
References ossimIrect::combine(), ossimIrect::hasNans(), ossimIrect::makeNan(), theBoundingRect, and thePolygonList.
Referenced by addPolygon(), ossimPolyCutter(), setPolygon(), and ossimGeoPolyCutter::transformVertices().
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 151 of file ossimPolyCutter.cpp.
References ossimImageSource::getBoundingRect(), ossimImageSource::getDecimationFactor(), ossimDpt::hasNans(), ossimIrect::hasNans(), ossimSource::isSourceEnabled(), ossimIrect::makeNan(), OSSIM_POLY_NULL_OUTSIDE, theBoundingRect, theCutType, and ossimImageSourceFilter::theInputConnection.
ossimPolyCutter::ossimPolyCutterCutType ossimPolyCutter::getCutType | ( | ) | const |
Definition at line 402 of file ossimPolyCutter.cpp.
References thePolygonList.
Definition at line 407 of file ossimPolyCutter.cpp.
Definition at line 344 of file ossimPolyCutter.cpp.
References ossimImageSourceFilter::getProperty().
Definition at line 350 of file ossimPolyCutter.cpp.
References ossimImageSourceFilter::getPropertyNames().
const ossimIrect & ossimPolyCutter::getRectangle | ( | ) | const |
Definition at line 378 of file ossimPolyCutter.cpp.
References theBoundingRect.
Referenced by ossimTilingPoly::next(), and ossimTilingPoly::setRect().
Definition at line 51 of file ossimPolyCutter.cpp.
References allocate(), ossimImageDataHelper::copyInputToThis(), ossimImageDataHelper::fill(), ossimRefPtr< T >::get(), getBoundingRect(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getDecimationFactor(), ossimImageData::getNullPix(), ossimImageSource::getTile(), ossimDpt::hasNans(), ossimIrect::hasNans(), ossimIrect::intersects(), ossimSource::isSourceEnabled(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, OSSIM_POLY_NULL_INSIDE, OSSIM_POLY_NULL_OUTSIDE, ossimDataObject::setDataObjectStatus(), ossimImageDataHelper::setImageData(), ossimImageData::setImageRectangle(), theBoundingRect, theCutType, theHelper, ossimImageSourceFilter::theInputConnection, thePolygonList, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Referenced by ossimTrimFilter::getTile().
Definition at line 191 of file ossimPolyCutter.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
Referenced by ossimTrimFilter::initialize(), and ossimPolyCutter().
Definition at line 241 of file ossimPolyCutter.cpp.
References ossimKeywordlist::find().
Definition at line 212 of file ossimPolyCutter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), thePolygonList, and ossimString::toString().
void ossimPolyCutter::setCutType | ( | ossimPolyCutterCutType | cutType | ) |
Definition at line 324 of file ossimPolyCutter.cpp.
References theCutType.
Definition at line 389 of file ossimPolyCutter.cpp.
Referenced by clear(), ossimTrimFilter::initialize(), and ossimGeoPolyCutter::setNumberOfPolygons().
Definition at line 283 of file ossimPolyCutter.cpp.
Referenced by ossimTrimFilter::initialize(), and ossimGeoPolyCutter::setPolygon().
Definition at line 295 of file ossimPolyCutter.cpp.
Definition at line 339 of file ossimPolyCutter.cpp.
References ossimImageSourceFilter::setProperty().
void ossimPolyCutter::setRectangle | ( | const ossimIrect & | rect | ) |
Definition at line 383 of file ossimPolyCutter.cpp.
References m_boundingOverwrite, and theBoundingRect.
Referenced by ossimTilingPoly::setRect().
protected |
Definition at line 104 of file ossimPolyCutter.h.
Referenced by setRectangle().
protected |
Will hold a pre-computed bounding rect of the polygon data.
Definition at line 95 of file ossimPolyCutter.h.
Referenced by computeBoundingRect(), getBoundingRect(), getRectangle(), getTile(), and setRectangle().
protected |
theDefault fill will be outside.
Definition at line 102 of file ossimPolyCutter.h.
Referenced by getBoundingRect(), getCutType(), getTile(), ossimGeoPolyCutter::loadState(), and setCutType().
protected |
Definition at line 103 of file ossimPolyCutter.h.
protected |
Definition at line 97 of file ossimPolyCutter.h.
Referenced by addPolygon(), ossimGeoPolyCutter::addPolygon(), computeBoundingRect(), getPolygonList(), getTile(), ossimGeoPolyCutter::invertPolygon(), ossimGeoPolyCutter::loadState(), ossimPolyCutter(), saveState(), ossimGeoPolyCutter::saveState(), setNumberOfPolygons(), setPolygon(), and ossimGeoPolyCutter::transformVertices().
protected |
Definition at line 89 of file ossimPolyCutter.h.
Referenced by allocate(), getTile(), and initialize().
