#include <ossimGeoPolyCutter.h>
ossimGeoPolyCutter () | |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
Method to save the state of an object to a keyword list. More... | |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual void | setPolygon (const vector< ossimDpt > &polygon, ossim_uint32 i=0) |
virtual void | setPolygon (const vector< ossimIpt > &polygon, ossim_uint32 i=0) |
virtual void | setPolygon (const vector< ossimGpt > &polygon, ossim_uint32 i=0) |
virtual void | setPolygon (const ossimGeoPolygon &polygon, ossim_uint32 i=0) |
virtual void | addPolygon (const vector< ossimIpt > &polygon) |
virtual void | addPolygon (const vector< ossimDpt > &polygon) |
virtual void | addPolygon (const vector< ossimGpt > &polygon) |
virtual void | addPolygon (const ossimPolygon &polygon) |
virtual void | addPolygon (const ossimGeoPolygon &polygon) |
virtual void | setNumberOfPolygons (ossim_uint32 count) |
virtual std::vector< ossimGeoPolygon > & | getGeoPolygonList () |
virtual const std::vector< ossimGeoPolygon > & | getGeoPolygonList () const |
virtual bool | setView (ossimObject *baseObject) |
virtual ossimObject * | getView () |
virtual const ossimObject * | getView () const |
ossimPolyCutter () | |
ossimPolyCutter (ossimImageSource *inputSource, const ossimPolygon &polygon) | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
This will return the bounding rect of the source. More... | |
virtual void | initialize () |
virtual std::vector< ossimPolygon > & | getPolygonList () |
virtual const std::vector< ossimPolygon > & | getPolygonList () const |
void | setCutType (ossimPolyCutterCutType cutType) |
ossimPolyCutterCutType | getCutType () const |
void | clear () |
const ossimIrect & | getRectangle () const |
void | setRectangle (const ossimIrect &rect) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
ossimImageSourceFilter (ossimObject *owner=NULL) | |
ossimImageSourceFilter (ossimImageSource *inputSource) | |
ossimImageSourceFilter (ossimObject *owner, ossimImageSource *inputSource) | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
virtual ossim_uint32 | getNumberOfInputBands () const |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | connectInputEvent (ossimConnectionEvent &event) |
virtual void | disconnectInputEvent (ossimConnectionEvent &event) |
virtual void | propertyEvent (ossimPropertyEvent &event) |
virtual void | refreshEvent (ossimRefreshEvent &event) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
Will return the decimation factor for the given resolution level. More... | |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getNumberOfOutputBands () const |
Returns the number of bands in a tile returned from this TileSource. More... | |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
ossimViewInterface () | |
ossimViewInterface (ossimObject *base) | |
virtual | ~ossimViewInterface () |
virtual void | refreshView () |
ossimObject * | getBaseObject () |
virtual | ~ossimGeoPolyCutter () |
void | invertPolygon (int polygonNumber) |
void | transformVertices () |
void | transformVertices (int i) |
virtual | ~ossimPolyCutter () |
void | allocate () |
Called on first getTile, will initialize all data needed. More... | |
void | computeBoundingRect () |
virtual | ~ossimImageSourceFilter () |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
enum | ossimPolyCutterCutType { OSSIM_POLY_NULL_INSIDE = 0, OSSIM_POLY_NULL_OUTSIDE = 1 } |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
This classes overrides the 2-d counter part ossimPolyCutter. It will automatically map 2-D to 3-D (ground) polygons if you add 2-D polygons and will automatically compute the forward transform when adding a ground polygon.
you can set the view trough the ossimViewInterface by calling setView(object, true); it will cast to an ossimProjection and use that as the transformation. For igen this is set automatically and does not need to be set by the user.
This class has no keywords but does use 2 prefix values to store out the view and the ground polygon for example if we have only one polygon then here is a sample keyword list for the polygons: NOTE we can have any number of polygons just increment the geo_polygon0 to geo_polygon1 .. geo_polygonN for the Nth one
geo_polygon0.datum: WGE geo_polygon0.number_vertices: 18 geo_polygon0.type: ossimGeoPolygon geo_polygon0.v0: 38.023634368488452 -122.542245818545709 nan geo_polygon0.v1: 38.016619667868909 -122.548990722987568 nan geo_polygon0.v2: 38.018238444934966 -122.546292761210807 nan geo_polygon0.v3: 38.012932453440698 -122.547911538276864 nan geo_polygon0.v4: 38.014731094625191 -122.542065954427244 nan geo_polygon0.v5: 38.007446597827986 -122.541796158249582 nan geo_polygon0.v6: 38.009694899308606 -122.537569351466018 nan geo_polygon0.v7: 38.005108364288141 -122.537119691169892 nan geo_polygon0.v8: 38.008255986361007 -122.532353292030976 nan geo_polygon0.v9: 38.003039926925965 -122.531274107320272 nan geo_polygon0.v10: 38.013292181677599 -122.529565398195004 nan geo_polygon0.v11: 38.009874763427050 -122.526867436418243 nan geo_polygon0.v12: 38.019587425823332 -122.528306349365849 nan geo_polygon0.v13: 38.023904164666128 -122.537299555288328 nan geo_polygon0.v14: 38.024983349376825 -122.544584052085540 nan geo_polygon0.v15: 38.023904164666128 -122.548720926809878 nan geo_polygon0.v16: 38.022195455540853 -122.562210735693611 nan geo_polygon0.v17: 38.019317629645663 -122.562930192167400 nan
the example for the view information is
view.central_meridian: -123.000000000000000 view.datum: WGE view.decimal_degrees_per_pixel_lat: 0.000089932059225 view.decimal_degrees_per_pixel_lon: 0.000089932059225 view.ellipse_code: WE view.ellipse_name: WGS 84 view.false_easting: 0.000000000000000 view.false_northing: 0.000000000000000 view.major_axis: 6378137.000000000000000 view.meters_per_pixel_x: 10.000000000000000 view.meters_per_pixel_y: 10.000000000000000 view.minor_axis: 6356752.314199999906123 view.origin_latitude: 0.000000000000000 view.rotation: 0.000000000000000 view.scale_x: 1.000000000000000 view.scale_y: 1.000000000000000 view.tie_point_easting: 0.000000000000000 view.tie_point_lat: 0.000000000000000 view.tie_point_lon: -123.000000000000000 view.tie_point_northing: 0.000000000000000 view.translation_x: 0.000000000000000 view.translation_y: 0.000000000000000 view.type: ossimEquDistCylProjection
Definition at line 88 of file ossimGeoPolyCutter.h.
ossimGeoPolyCutter::ossimGeoPolyCutter | ( | ) |
Definition at line 22 of file ossimGeoPolyCutter.cpp.
References ossimViewInterface::theObject.
protectedvirtual |
Definition at line 32 of file ossimGeoPolyCutter.cpp.
Will invert this polygon out to world space and add it to the polygon list
Reimplemented from ossimPolyCutter.
Definition at line 182 of file ossimGeoPolyCutter.cpp.
References ossimPolyCutter::addPolygon(), invertPolygon(), m_geoPolygonList, m_viewGeometry, ossimPolyCutter::thePolygonList, and ossimRefPtr< T >::valid().
Referenced by ossimSingleImageChain::addGeoPolyCutterPolygon(), and ossimTilingPoly::nextFeature().
Will invert the passed in polygon to world space and add to the polygon list
Definition at line 192 of file ossimGeoPolyCutter.cpp.
Will add the ground polygon to the list
Definition at line 171 of file ossimGeoPolyCutter.cpp.
References m_geoPolygonList, m_viewGeometry, ossimPolyCutter::thePolygonList, transformVertices(), and ossimRefPtr< T >::valid().
Will invert te polygon to ground and add.
Definition at line 202 of file ossimGeoPolyCutter.cpp.
Will add the passed in polygon.
Definition at line 212 of file ossimGeoPolyCutter.cpp.
References ossimPolyCutter::addPolygon(), m_geoPolygonList, m_viewGeometry, transformVertices(), and ossimRefPtr< T >::valid().
This should only be used for informational uses only. If updates are to be made please go through the access methods that change the polygon data.
Definition at line 236 of file ossimGeoPolyCutter.cpp.
References m_geoPolygonList.
Definition at line 241 of file ossimGeoPolyCutter.cpp.
Implements ossimViewInterface.
Definition at line 305 of file ossimGeoPolyCutter.cpp.
References ossimRefPtr< T >::get(), and m_viewGeometry.
Definition at line 310 of file ossimGeoPolyCutter.cpp.
protected |
Utility method used to invert any passed in projected polygons to be changed or added to the list.
polygonNumber | the index of the polygon to invert to ground. |
Definition at line 246 of file ossimGeoPolyCutter.cpp.
References ossimGeoPolygon::clear(), ossimPolygon::getVertexCount(), ossimImageGeometry::localToWorld(), m_geoPolygonList, m_viewGeometry, ossimGeoPolygon::resize(), and ossimPolyCutter::thePolygonList.
Referenced by addPolygon(), and setPolygon().
Definition at line 73 of file ossimGeoPolyCutter.cpp.
References ossimKeywordlist::find(), ossimKeywordlist::getSubstringKeyList(), ossimImageSourceFilter::loadState(), ossimImageGeometry::loadState(), m_geoPolygonList, m_viewGeometry, ossimPolyCutter::OSSIM_POLY_NULL_INSIDE, ossimPolyCutter::OSSIM_POLY_NULL_OUTSIDE, ossimPolyCutter::theCutType, ossimPolyCutter::thePolygonList, ossimString::toInt(), ossimString::toString(), and transformVertices().
Definition at line 36 of file ossimGeoPolyCutter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), m_geoPolygonList, ossimPolyCutter::thePolygonList, and ossimString::toString().
Will set the number of polygons and will call the base class set number of polygons.
Definition at line 223 of file ossimGeoPolyCutter.cpp.
References m_geoPolygonList, and ossimPolyCutter::setNumberOfPolygons().
Sets the polygon to the specified polygon index. /param polygon A vector of points in projected 2-D. /param i index of the polygon to change.
Definition at line 128 of file ossimGeoPolyCutter.cpp.
References invertPolygon(), m_viewGeometry, ossimPolyCutter::setPolygon(), and ossimRefPtr< T >::valid().
Referenced by ossimIgenGenerator::generateGeoTiledSpecList(), ossimIgenGenerator::generateNoTiledSpecList(), ossimIgenGenerator::generatePixelTiledSpecList(), and ossimTilingPoly::nextFeature().
Definition at line 138 of file ossimGeoPolyCutter.cpp.
Sets the polygon to the specified polygon index. /param polygon A Ground polygon. /param i index of the polygon to change.
Definition at line 148 of file ossimGeoPolyCutter.cpp.
References m_geoPolygonList, and transformVertices().
Definition at line 159 of file ossimGeoPolyCutter.cpp.
References ossimGeoPolygon::getVertexList(), m_geoPolygonList, and transformVertices().
Will set the view to the passed in object. Once set it will project the ground polygon relative to the passed in view.
Definition at line 263 of file ossimGeoPolyCutter.cpp.
References ossimRefPtr< T >::get(), ossimImageGeometry::isEqualTo(), m_viewGeometry, ossimNotify(), ossimNotifyLevel_WARN, transformVertices(), and ossimRefPtr< T >::valid().
Referenced by ossimSingleImageChain::addGeoPolyCutter(), and ossimTilingPoly::nextFeature().
protected |
Transforms all vertices based on the current m_viewProjection.
Definition at line 315 of file ossimGeoPolyCutter.cpp.
References ossimPolyCutter::computeBoundingRect(), ossimPolygon::getVertexCount(), m_geoPolygonList, m_viewGeometry, ossimPolygon::resize(), ossimGeoPolygon::size(), ossimPolyCutter::thePolygonList, ossimRefPtr< T >::valid(), ossimImageGeometry::worldToLocal(), x, and y.
Referenced by addPolygon(), loadState(), setPolygon(), and setView().
protected |
Transforms the specified polygon index.
i | The polygon index to project. |
Definition at line 351 of file ossimGeoPolyCutter.cpp.
protected |
Definition at line 215 of file ossimGeoPolyCutter.h.
Referenced by addPolygon(), getGeoPolygonList(), invertPolygon(), loadState(), saveState(), setNumberOfPolygons(), setPolygon(), and transformVertices().
protected |
The view projection used to project the ground coordinates.
Definition at line 213 of file ossimGeoPolyCutter.h.
Referenced by addPolygon(), getView(), invertPolygon(), loadState(), setPolygon(), setView(), and transformVertices().
