Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimSrtmSupportData Class Reference
#include <ossimSrtmSupportData.h>
Inheritance diagram for ossimSrtmSupportData:
ossimObject ossimReferenced
 ossimSrtmSupportData ()
 default constructor More...
virtual ~ossimSrtmSupportData ()
 destructor More...
bool setFilename (const ossimFilename &srtmFile, bool scanForMinMax=false)
 Initializes object from file. More...
ossimFilename getFilename () const
ossim_uint32 getNumberOfLines () const
ossim_uint32 getNumberOfSamples () const
virtual bool getImageGeometry (ossimKeywordlist &kwl, const char *prefix=0)
 Populates the keyword list with image geometry information. More...
ossimRefPtr< ossimProjectiongetProjection () const
 Gets the projection for srtm cell. More...
 Method to save the state of the object to a keyword list. More...
 Method to the load (recreate) the state of the object from a keyword list. More...
ossim_float64 getSouthwestLatitude () const
ossim_float64 getSouthwestLongitude () const
ossim_float64 getLatitudeSpacing () const
ossim_float64 getLongitudeSpacing () const
ossim_float64 getMinPixelValue () const
ossim_float64 getMaxPixelValue () const
ossimScalarType getScalarType () const
 Prints data members for debug. More...
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
bool loadOmd (const ossimKeywordlist &kwl, const char *prefix=0)
 This is a loadState called by setFilename that does not reset "theFile". More...
void clear ()
 Sets all data members to an unitialized state. More...
bool setCornerPoints ()
 Sets corner points from "theFile". More...
bool setSize ()
 Sets lines and samples from "theFile" size. More...
bool computeMinMax ()
 Scans file for min and max pixels. More...
template<class T >
bool computeMinMaxTemplate (T dummy, double defaultNull)
Private Attributes
ossimFilename m_file
ossim_uint32 m_numberOfLines
ossim_uint32 m_numberOfSamples
ossim_float64 m_southwestLatitude
ossim_float64 m_southwestLongitude
ossim_float64 m_latSpacing
ossim_float64 m_lonSpacing
ossim_float64 m_minPixelValue
ossim_float64 m_maxPixelValue
ossimScalarType m_scalarType
std::shared_ptr< ossim::istreamm_str
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 35 of file ossimSrtmSupportData.h.
◆ ossimSrtmSupportData()
ossimSrtmSupportData::ossimSrtmSupportData ( )
default constructor
Definition at line 45 of file ossimSrtmSupportData.cpp.
46  :
47  m_file(),
48  m_numberOfLines(0),
54  m_minPixelValue(DEFAULT_MIN),
55  m_maxPixelValue(DEFAULT_MAX),
57  m_str(0)
58 {
59 }
double nan()
Definition: ossimCommon.h:135
std::shared_ptr< ossim::istream > m_str
◆ ~ossimSrtmSupportData()
ossimSrtmSupportData::~ossimSrtmSupportData ( )
virtual
destructor
Definition at line 61 of file ossimSrtmSupportData.cpp.
62 {
63 }
Member Function Documentation
◆ clear()
void ossimSrtmSupportData::clear ( )
private
Definition at line 537 of file ossimSrtmSupportData.cpp.
References m_file, m_latSpacing, m_lonSpacing, m_minPixelValue, m_numberOfLines, m_numberOfSamples, m_southwestLatitude, m_southwestLongitude, ossim::nan(), and ossimFilename::NIL.
538 {
540  m_numberOfLines = 0;
541  m_numberOfSamples = 0;
546  m_minPixelValue = DEFAULT_MIN;
547  m_maxPixelValue = DEFAULT_MAX;
548 }
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
double nan()
◆ computeMinMax()
bool ossimSrtmSupportData::computeMinMax ( )
private
Definition at line 820 of file ossimSrtmSupportData.cpp.
References computeMinMaxTemplate(), m_scalarType, and OSSIM_FLOAT32.
821 {
823  {
825  -32768.0);
826  }
828  -32768.0);
829 }
float ossim_float32
32 bit floating point
bool computeMinMaxTemplate(T dummy, double defaultNull)
signed short ossim_sint16
◆ computeMinMaxTemplate()
template<class T >
bool ossimSrtmSupportData::computeMinMaxTemplate ( dummy,
double  defaultNull
private
Definition at line 832 of file ossimSrtmSupportData.cpp.
References ossim::byteOrder(), ossim::StreamFactoryRegistry::createIstream(), ossim::defaultNull(), FLT_EPSILON, ossim::StreamFactoryRegistry::instance(), m_file, m_maxPixelValue, m_minPixelValue, m_numberOfLines, m_numberOfSamples, m_str, OSSIM_LITTLE_ENDIAN, and ossimEndian::swap().
Referenced by computeMinMax().
834 {
835
836  if(!m_str)
837  {
838  m_str =
840  m_file);
841  }
842
843  if (!m_str)
844  {
845  return false;
846  }
847
848  if(m_str->fail())
849  {
850  return false;
851  }
852
853  const size_t BYTES_IN_LINE = m_numberOfSamples * 2;
854  const T NULL_PIX = (T)defaultNull;
855
856  double minValue = 1.0/FLT_EPSILON;
857  double maxValue = -1.0/FLT_EPSILON;
858  T* line_buf = new T[m_numberOfSamples];
859  char* char_buf = (char*)line_buf;
860  ossimEndian swapper;
861
862  ossimByteOrder endianType = ossim::byteOrder();
863  for (ossim_uint32 line = 0; line < m_numberOfLines; ++line)
864  {
865  m_str->read(char_buf, (std::streamsize)BYTES_IN_LINE);
866  if(endianType == OSSIM_LITTLE_ENDIAN)
867  {
868  swapper.swap(line_buf, m_numberOfSamples);
869  }
870  for (ossim_uint32 sample = 0; sample < m_numberOfSamples; ++sample)
871  {
872  if (line_buf[sample] == NULL_PIX) continue;
873  if (line_buf[sample] > maxValue) maxValue = line_buf[sample];
874  if (line_buf[sample] < minValue) minValue = line_buf[sample];
875  }
876  }
877  delete [] line_buf;
878  m_minPixelValue = minValue;
879  m_maxPixelValue = maxValue;
880
881  m_str = 0;
882  return true;
883 }
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static StreamFactoryRegistry * instance()
#define FLT_EPSILON
OSSIM_DLL double defaultNull(ossimScalarType scalarType)
unsigned int ossim_uint32
ossimByteOrder
virtual std::shared_ptr< ossim::istream > createIstream(const std::string &connectionString, const ossimKeywordlist &options=ossimKeywordlist(), std::ios_base::openmode mode=std::ios_base::in|std::ios_base::binary) const
Will try to creates an istream interface to the connectionString passed in.
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
◆ getFilename()
ossimFilename ossimSrtmSupportData::getFilename ( ) const
Returns
Returns the srtm file name.
Definition at line 182 of file ossimSrtmSupportData.cpp.
References m_file.
183 {
184  return m_file;
185 }
◆ getImageGeometry()
bool ossimSrtmSupportData::getImageGeometry ( ossimKeywordlist kwl,
const char *  prefix = 0
virtual
This method is used to relay projection information to users.
Parameters
kwlKeyword list that will be initialized with geometry info. Returns true if geometry info is present, false if not.
prefixThe prefix is added to the resulting keyword list keywords. So is you if you pass in a prefix of "image01.", the keyword ul_lat will be like: "image01.ul_lat: -40.00000"
Definition at line 197 of file ossimSrtmSupportData.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::CENTRAL_MERIDIAN_KW, ossimKeywordNames::DATUM_KW, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LAT, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LON, ossimDatumFactory::instance(), m_file, m_latSpacing, m_lonSpacing, m_numberOfLines, m_numberOfSamples, m_southwestLatitude, m_southwestLongitude, ossimFilename::NIL, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimKeywordNames::ORIGIN_LATITUDE_KW, ossimKeywordNames::TIE_POINT_LAT_KW, ossimKeywordNames::TIE_POINT_LON_KW, and ossimKeywordNames::TYPE_KW.
199 {
200  if (m_file == ossimFilename::NIL)
201  {
202  return false;
203  }
204
205  kwl.add(prefix,
207  "ossimEquDistCylProjection",
208  true);
209
210  kwl.add(prefix,
212  0.0,
213  true);
214
215  kwl.add(prefix,
218  true);
219
220  kwl.add(prefix,
222  (m_southwestLatitude+1.0),
223  true);
224
225  kwl.add(prefix,
228  true);
229
230  // Add the pixel scale.
231  kwl.add(prefix,
233  m_latSpacing,
234  true);
235
236  kwl.add(prefix,
238  m_lonSpacing,
239  true);
240
241  // Add the datum. (always WGS-84 per spec)
242  kwl.add(prefix,
244  ossimDatumFactory::instance()->wgs84()->code(),
245  true);
246
247  // Add the number of lines and samples.
248  kwl.add(prefix,
251  true);
252
253  kwl.add(prefix,
256  true);
257
258  return true;
259 }
static const char * DECIMAL_DEGREES_PER_PIXEL_LAT
static const char * DATUM_KW
static const char * CENTRAL_MERIDIAN_KW
static const char * NUMBER_LINES_KW
static const char * TIE_POINT_LON_KW
static const char * TYPE_KW
static ossimDatumFactory * instance()
static const char * DECIMAL_DEGREES_PER_PIXEL_LON
static const char * ORIGIN_LATITUDE_KW
static const char * TIE_POINT_LAT_KW
static const char * NUMBER_SAMPLES_KW
◆ getLatitudeSpacing()
ossim_float64 ossimSrtmSupportData::getLatitudeSpacing ( ) const
Returns
Returns the latitude spacing in decimal degrees. Returns OSSIM_DBL_NAN if not initialized or file was invalid.
Definition at line 527 of file ossimSrtmSupportData.cpp.
References m_latSpacing.
Referenced by ossimSrtmHandler::open().
528 {
529  return m_latSpacing;
530 }
◆ getLongitudeSpacing()
ossim_float64 ossimSrtmSupportData::getLongitudeSpacing ( ) const
Returns
Returns the longitude spacing in decimal degrees. Returns OSSIM_DBL_NAN if not initialized or file was invalid.
Definition at line 532 of file ossimSrtmSupportData.cpp.
References m_lonSpacing.
533 {
534  return m_lonSpacing;
535 }
◆ getMaxPixelValue()
ossim_float64 ossimSrtmSupportData::getMaxPixelValue ( ) const
Returns
Returns the maximum pixel value. This is also the minimum height above sea level. Returns OSSIM_SSHORT_NAN if not initialized or file was invalid.
Definition at line 890 of file ossimSrtmSupportData.cpp.
References m_maxPixelValue.
891 {
892  return m_maxPixelValue;
893 }
◆ getMinPixelValue()
ossim_float64 ossimSrtmSupportData::getMinPixelValue ( ) const
Returns
Returns the minimum pixel value. This is also the minimum height above sea level. Returns OSSIM_SSHORT_NAN if not initialized or file was invalid.
Definition at line 885 of file ossimSrtmSupportData.cpp.
References m_minPixelValue.
886 {
887  return m_minPixelValue;
888 }
◆ getNumberOfLines()
ossim_uint32 ossimSrtmSupportData::getNumberOfLines ( ) const
Returns
Returns the number of lines or rows. Returns OSSIM_UINT_NAN if not initialized or file was invalid.
Definition at line 187 of file ossimSrtmSupportData.cpp.
References m_numberOfLines.
188 {
189  return m_numberOfLines;
190 }
◆ getNumberOfSamples()
ossim_uint32 ossimSrtmSupportData::getNumberOfSamples ( ) const
Returns
Returns the number of samples or columns. Returns OSSIM_UINT_NAN if not initialized or file was invalid.
Definition at line 192 of file ossimSrtmSupportData.cpp.
References m_numberOfSamples.
193 {
194  return m_numberOfSamples;
195 }
◆ getProjection()
ossimRefPtr< ossimProjection > ossimSrtmSupportData::getProjection ( ) const
Returns
The projection for srtm cell.
Definition at line 261 of file ossimSrtmSupportData.cpp.
References ossimDatum::ellipsoid(), ossimRefPtr< T >::get(), ossimDatumFactory::instance(), m_latSpacing, m_lonSpacing, m_southwestLatitude, m_southwestLongitude, ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setUlTiePoints(), and ossimDatumFactory::wgs84().
262 {
263  //---
264  // Make an Equidistant Cylindrical projection with a origin at the equator
265  // since the DTED post spacing is considered to be square.
266  //---
267  const ossimDatum* datum = ossimDatumFactory::instance()->wgs84();
269
270  //---
271  // Set the tie point.
272  // NOTE: Latitude southwest corner we need northwest; hence, the +1.
273  //---
275
276  // Set the scale:
278
279  ossimRefPtr<ossimProjection> proj = eq.get();
280
281  return proj;
282 }
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
virtual const ossimEllipsoid * ellipsoid() const
Definition: ossimDatum.h:60
virtual void setUlTiePoints(const ossimGpt &gpt)
const ossimDatum * wgs84() const
◆ getScalarType()
ossimScalarType ossimSrtmSupportData::getScalarType ( ) const
Definition at line 895 of file ossimSrtmSupportData.cpp.
References m_scalarType.
896 {
897  return m_scalarType;
898 }
◆ getSouthwestLatitude()
ossim_float64 ossimSrtmSupportData::getSouthwestLatitude ( ) const
Returns
Returns the Southwest latitude in decimal degrees. Returns OSSIM_DBL_NAN if not initialized or file was invalid.
Definition at line 518 of file ossimSrtmSupportData.cpp.
References m_southwestLatitude.
519 {
520  return m_southwestLatitude;
521 }
◆ getSouthwestLongitude()
ossim_float64 ossimSrtmSupportData::getSouthwestLongitude ( ) const
Returns
Returns the Southwest longitude in decimal degrees. Returns OSSIM_DBL_NAN if not initialized or file was invalid.
Definition at line 523 of file ossimSrtmSupportData.cpp.
References m_southwestLongitude.
524 {
525  return m_southwestLongitude;
526 }
◆ loadOmd()
bool ossimSrtmSupportData::loadOmd ( const ossimKeywordlist kwl,
private
Definition at line 418 of file ossimSrtmSupportData.cpp.
References ossimKeywordlist::findKey(), ossimLookUpTable::getEntryNumber(), ossimScalarTypeLut::instance(), m_latSpacing, m_lonSpacing, m_maxPixelValue, m_minPixelValue, m_numberOfLines, m_numberOfSamples, m_scalarType, m_southwestLatitude, m_southwestLongitude, ossimKeywordNames::MAX_VALUE_KW, ossimKeywordNames::MIN_VALUE_KW, ossimLookUpTable::NOT_FOUND, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, OSSIM_FLOAT32, OSSIM_SINT16, ossimString::size(), ossimString::string(), ossimKeywordNames::TIE_POINT_LAT_KW, ossimKeywordNames::TIE_POINT_LON_KW, ossimString::toFloat64(), and ossimString::toUInt32().
Referenced by loadState().
420 {
421  std::string pfx;
422  std::string bandPrefix;
423
424  if (prefix) // Cannot give null to std::string.
425  {
426  pfx = prefix;
427  bandPrefix = prefix;
428  }
429  bandPrefix += "band1.";
430
431  ossimString value;
432
433  //---
434  // Look for the min and max first since they could have been populated by
435  // "cmm" (compute min max). Min and Max are not required by this method
436  // as they are handled elsewhere if they are not found here.
437  //---
438
439  // Not an error if not present.
440  value.string() = kwl.findKey(bandPrefix, std::string(ossimKeywordNames::MIN_VALUE_KW));
441  if ( value.size() )
442  {
443  m_minPixelValue = value.toFloat64();
444  }
445
446  // Not an error if not present.
447  value.string() = kwl.findKey(bandPrefix.c_str(), std::string(ossimKeywordNames::MAX_VALUE_KW));
448  if ( value.size() )
449  {
450  m_maxPixelValue = value.toFloat64();
451  }
452
453  value.string() = kwl.findKey(pfx, std::string(ossimKeywordNames::NUMBER_LINES_KW));
454  if ( value.size() )
455  {
456  m_numberOfLines = value.toUInt32();
457  }
458  else
459  {
460  return false;
461  }
462
463  value.string() = kwl.findKey(pfx, std::string(ossimKeywordNames::NUMBER_SAMPLES_KW));
464  if ( value.size() )
465  {
466  m_numberOfSamples = value.toUInt32();
467  }
468  else
469  {
470  return false;
471  }
472
473  //---
474  // Special case the tie point was stored as the upper left so we must
475  // subtract one.
476  //---
477  value.string() = kwl.findKey(pfx, std::string(ossimKeywordNames::TIE_POINT_LAT_KW));
478  if ( value.size() )
479  {
480  m_southwestLatitude = value.toFloat64() - 1.0;
481  }
482  else
483  {
484  return false;
485  }
486
487  value.string() = kwl.findKey(pfx, std::string(ossimKeywordNames::TIE_POINT_LON_KW));
488  if ( value.size() )
489  {
491  }
492  else
493  {
494  return false;
495  }
496
497  int scalar = ossimScalarTypeLut::instance()->getEntryNumber(kwl, prefix);
498
499  if (scalar != ossimLookUpTable::NOT_FOUND)
500  {
501  m_scalarType = (ossimScalarType)scalar;
503  {
504  return false;
505  }
506  }
507  else
508  {
509  return false;
510  }
511
512  m_latSpacing = 1.0 / (m_numberOfLines - 1);
513  m_lonSpacing = 1.0 / (m_numberOfSamples - 1);
514
515  return true;
516 }
static const char * MIN_VALUE_KW
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
static const char * MAX_VALUE_KW
16 bit signed integer
ossim_uint32 toUInt32() const
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
std::string::size_type size() const
Definition: ossimString.h:405
ossim_float64 toFloat64() const
ossimScalarType
const std::string & string() const
Definition: ossimString.h:414
◆ loadState()
bool ossimSrtmSupportData::loadState ( const ossimKeywordlist kwl,
virtual
Definition at line 381 of file ossimSrtmSupportData.cpp.
References ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimKeywordNames::IMAGE_FILE_KW, loadOmd(), and m_file.
383 {
384  ossimString bandPrefix;
385  if (prefix)
386  {
387  bandPrefix = prefix;
388  }
389  bandPrefix += "band1.";
390
391  ossimString s; // For numeric conversions.
392
393  const char* lookup;
394
395  // Look for "filename" then look for deprecated "image_file" next.
396  lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
397  if (lookup)
398  {
399  m_file = lookup;
400  }
401  else
402  {
403  // Deprecated...
404  lookup = kwl.find(prefix, ossimKeywordNames::IMAGE_FILE_KW);
405  if (lookup)
406  {
407  m_file = lookup;
408  }
409  else
410  {
411  return false;
412  }
413  }
414
415  return loadOmd(kwl, prefix);
416 }
bool loadOmd(const ossimKeywordlist &kwl, const char *prefix=0)
static const char * IMAGE_FILE_KW
static const char * FILENAME_KW
◆ print()
std::ostream & ossimSrtmSupportData::print ( std::ostream &  out) const
virtual
Returns
std::ostream&
Definition at line 900 of file ossimSrtmSupportData.cpp.
References m_file, m_latSpacing, m_lonSpacing, m_maxPixelValue, m_minPixelValue, m_numberOfLines, m_numberOfSamples, m_southwestLatitude, and m_southwestLongitude.
901 {
902  out << std::setprecision(15) << "ossimSrtmSupportData data members:"
903  << "\nFile: " << m_file
904  << "\nLines: " << m_numberOfLines
905  << "\nSamples: " << m_numberOfSamples
906  << "\nSouth West Latitude: " << m_southwestLatitude
907  << "\nSouth West Longitude: " << m_southwestLongitude
908  << "\nLatitude spacing: " << m_latSpacing
909  << "\nLongitude spacing: " << m_lonSpacing
910  << "\nMin post value: " << m_minPixelValue
911  << "\nMax post value: " << m_maxPixelValue
912  << std::endl;
913  return out;
914 }
◆ saveState()
bool ossimSrtmSupportData::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 284 of file ossimSrtmSupportData.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LAT, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LON, ossimKeywordNames::FILENAME_KW, m_file, m_latSpacing, m_lonSpacing, m_minPixelValue, m_numberOfLines, m_numberOfSamples, m_southwestLatitude, m_southwestLongitude, ossimFilename::NIL, ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimKeywordNames::TIE_POINT_LAT_KW, and ossimKeywordNames::TIE_POINT_LON_KW.
286 {
287  if (m_file == ossimFilename::NIL)
288  {
289  return false;
290  }
291
292  ossimString bandPrefix;
293  if (prefix)
294  {
295  bandPrefix = prefix;
296  }
297  bandPrefix += "band1.";
298
299  kwl.add(prefix,
301  m_file.c_str(),
302  true);
303
304  kwl.add(prefix,
306  1,
307  true);
308
309  kwl.add(prefix,
312  true);
313
314  kwl.add(prefix,
317  true);
318
319  //---
320  // Special case, store the tie point as the upper left lat so add one.
321  //---
322  kwl.add(prefix,
324  (m_southwestLatitude + 1.0),
325  true);
326
327  kwl.add(prefix,
330  true);
331
332  kwl.add(prefix,
334  m_latSpacing,
335  true);
336
337  kwl.add(prefix,
339  m_lonSpacing,
340  true);
341
342  // User can opt out of scanning for this so don't save if it is still nan.
343  if (m_minPixelValue != DEFAULT_MIN)
344  {
345  kwl.add(bandPrefix,
348  true);
349  }
350
351  // User can opt out of scanning for this so don't save if it is still nan.
352  if (m_maxPixelValue != DEFAULT_MAX)
353  {
354  kwl.add(bandPrefix.c_str(),
357  true);
358  }
359
360  // constant
361  kwl.add(bandPrefix,
363  "-32768",
364  true);
365
366  // constant
367  kwl.add(prefix,
369  "big_endian",
370  true);
371
372  // constant
373  kwl.add(prefix,
375  ossimScalarTypeLut::instance()->getEntryString(m_scalarType),
376  true);
377
378  return true;
379 }
static const char * BYTE_ORDER_KW
static const char * NULL_VALUE_KW
static const char * NUMBER_BANDS_KW
const char * c_str() const
Definition: ossimString.h:396
static const char * SCALAR_TYPE_KW
◆ setCornerPoints()
bool ossimSrtmSupportData::setCornerPoints ( )
private
Returns
Definition at line 550 of file ossimSrtmSupportData.cpp.
551 {
552  if(traceDebug())
553  {
555  << "ossimSrtmSupportData::setCornerPoints(): entered..." << std::endl;
556  }
557
559  ossimString regularExp1 = "[N|S][0-9][0-9][E|W][0-9][0-9][0-9]";
560  ossimString regularExp2 = "[E|W][0-9][0-9][0-9][N|S][0-9][0-9]";
561  ossimRegExp regEx;
562  bool latLonOrderFlag = true;
563  bool foundFlag = false;
564  f = f.upcase();
565
566  regEx.compile(regularExp1.c_str());
567  foundFlag = regEx.find(f.c_str());
568  if(!foundFlag)
569  {
570  regEx.compile(regularExp2.c_str());
571  foundFlag = regEx.find(f.c_str());
572  if(foundFlag)
573  {
574  latLonOrderFlag = false;
575  f = ossimFilename(ossimString(f.begin()+regEx.start(),
576  f.begin()+regEx.end()));
577  }
578  }
579  if(foundFlag)
580  {
581  f = ossimFilename(ossimString(f.begin()+regEx.start(),
582  f.begin()+regEx.end()));
583  }
584  if (f.size() != 7)
585  {
586  return false;
587  }
588 // ossimString s;
589
590  if(latLonOrderFlag)
591  {
592
593 // s.push_back(f[1]);
594 // s.push_back(f[2]);
596  f.begin()+3).toDouble();//s.toDouble();
597  // Get the latitude.
598  if (f[static_cast<std::string::size_type>(0)] == 'S')
599  {
600  m_southwestLatitude *= -1;
601  }
602  else if (f[static_cast<std::string::size_type>(0)] != 'N')
603  {
604  return false; // Must be either 's' or 'n'.
605  }
606  // Get the longitude.
607 // s.clear();
608 // s.push_back(f[4]);
609 // s.push_back(f[5]);
610 // s.push_back(f[6]);
612  f.begin()+7).toDouble();//s.toDouble();
613  if (f[static_cast<std::string::size_type>(3)] == 'W')
614  {
615  m_southwestLongitude *= -1;
616  }
617  else if (f[static_cast<std::string::size_type>(3)] != 'E')
618  {
619  return false; // Must be either 'e' or 'w'.
620  }
621  }
622  else
623  {
624  // Get the longitude.
625 // s.clear();
626 // s.push_back(f[1]);
627 // s.push_back(f[2]);
628 // s.push_back(f[3]);
630  f.begin()+4).toDouble();//s.toDouble();
631  if (f[static_cast<std::string::size_type>(0)] == 'W')
632  {
633  m_southwestLongitude *= -1;
634  }
635  else if (f[static_cast<std::string::size_type>(0)] != 'E')
636  {
637  return false; // Must be either 'e' or 'w'.
638  }
639 // s.clear();
640
641 // s.push_back(f[5]);
642 // s.push_back(f[6]);
644  f.begin()+7).toDouble();//s.toDouble();
645  // Get the latitude.
646  if (f[static_cast<std::string::size_type>(4)] == 'S')
647  {
648  m_southwestLatitude *= -1;
649  }
650  else if (f[static_cast<std::string::size_type>(4)] != 'N')
651  {
652  return false; // Must be either 's' or 'n'.
653  }
654  }
655
656
657  if(traceDebug())
658  {
660  << "ossimSrtmSupportData::setCornerPoints(): leaving with true..."
661  << std::endl;
662  }
663  return true;
664 }
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
std::string::iterator begin()
Definition: ossimString.h:420
void compile(const char *)
ossim_uint32 start() const
Definition: ossimRegExp.h:209
ossim_uint32 end() const
Definition: ossimRegExp.h:217
ossimFilename fileNoExtension() const
bool find(const char *)
◆ setFilename()
bool ossimSrtmSupportData::setFilename ( const ossimFilename srtmFile,
bool  scanForMinMax = false
File is expected to be in a format like N27W081.hgt or n27w081.hgt where "N27" is the South West latitude of the cell and "W081" is the South West longitude of the cell.
Parameters
srtmFileFile to set.
scanForMinMaxIf true and there is no ossim meta data file with the min and max keywords in it, this will call computeMinMax which will scan the file for min and max.
Returns
Returns true if file is deemed to be an srtm, false if not.
Note
This will write an ossim meta data (.omd) if one does not exists.
Definition at line 65 of file ossimSrtmSupportData.cpp.
References m_file.
67 {
68  m_file = srtmFile;
69
70  if(traceDebug())
71  {
73  << "ossimSrtmSupportData::setFilename: entered:"
74  << "\nsrtmFile: " << srtmFile
75  << "\nscanForMinMax flag: " << scanForMinMax
76  << std::endl;
77  }
78
80  createIstream(m_file);
81  if (m_str)
82  {
83  if(m_str->fail())
84  {
85  if(traceDebug())
86  {
88  << m_file << " does not exist: leaving ..." << std::endl;
89  }
90  clear();
91  return false;
92  }
93  }
94  else
95  {
96  return false;
97  }
98
99  // Start with default.
100  m_minPixelValue = DEFAULT_MIN;
101  m_maxPixelValue = DEFAULT_MAX;
102
103  // See if we have an ossim metadata file to initialize from.
104  bool outputOmd = false;
105  bool loadedFromOmd = false;
106
107  ossimFilename omdFile = m_file;
108  omdFile.setExtension(ossimString("omd"));
109  if (omdFile.exists())
110  {
111  //---
112  // The loadOmd is called instead of loadState so m_file is not
113  // overwrote.
114  //---
115  ossimKeywordlist kwl(omdFile);
116  loadedFromOmd = loadOmd(kwl);
117  }
118
119  if (!loadedFromOmd)
120  {
121  if (!setCornerPoints())
122  {
123  clear();
124  return false;
125  }
126  if (!setSize())
127  {
128  clear();
129  return false;
130  }
131  outputOmd = true;
132  }
133
134  if (scanForMinMax)
135  {
136  // These could have been picked up in the loadOmd.
137  if ( (m_minPixelValue == DEFAULT_MIN) ||
138  (m_maxPixelValue == DEFAULT_MAX) )
139  {
140  if ( computeMinMax() )
141  {
142  outputOmd = true;
143  }
144  else
145  {
146  if(traceDebug())
147  {
149  << "Unable to compute min max: leaving ..." << std::endl;
150  }
151  clear();
152  return false;
153  }
154  }
155  }
156
157  //---
158  // NOTE: The outputOmd flag should probably be set if !loadedFromOmd.
159  // Leaving as is for now (only set if scanForMinMax).
160  //---
161  if (outputOmd)
162  {
163  ossimKeywordlist kwl;
164  saveState(kwl);
165  kwl.write(omdFile);
166  }
167
168  m_str = 0;
169  // if(m_str->is_open())
170  // {
171  // m_str->close();
172  // }
173
174  if (traceDebug())
175  {
176  ossimNotify(ossimNotifyLevel_DEBUG) << *this << std::endl;
177  }
178
179  return true;
180 }
bool setCornerPoints()
bool setSize()
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
bool exists() const
void clear()
bool computeMinMax()
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
◆ setSize()
bool ossimSrtmSupportData::setSize ( )
private
Returns
Definition at line 666 of file ossimSrtmSupportData.cpp.
667 {
668  if(traceDebug())
669  {
671  << "ossimSrtmSupportData::setSize(): entered..." << std::endl;
672  }
673  if(!m_str)
674  {
676  m_file);
677  }
678
679  if (!m_str)
680  {
681  return false;
682  }
683
684  if(m_str->fail())
685  {
686  return false;
687  }
688
689  ossim_float64 size = 0.0;
690  m_str->seekg(0, std::ios::beg);
691
692 #if 0 /* tmp drb */
693  if(m_str->isCompressed())
694  {
695  ossimFilename tmp = m_file;
696  tmp.setExtension("hgt");
697  if(!tmp.exists())
698  {
699  ossimOFStream out(tmp.c_str(),
700  std::ios::out|std::ios::binary);
701
702  if(!out.fail())
703  {
704  bool done = false;
705  char buf[1024];
706  while(!done&&!m_str->fail())
707  {
708  m_str->read(buf, 1024);
709  if(m_str->gcount() < 1024)
710  {
711  done = true;
712  }
713  if(m_str->gcount() > 0)
714  {
715  out.write(buf, m_str->gcount());
716  }
717  }
718  out.close();
719  size = tmp.fileSize();
720  tmp.remove();
721  }
722  }
723  }
724  else
725  {
726  size = m_file.fileSize();
727  }
728 #endif /* tmp drb */
729
730  size = m_file.fileSize();
731  if (!size)
732  {
733  if(traceDebug())
734  {
736  << "ossimSrtmSupportData::setSize(): leaving with false at line "
737  << __LINE__ << std::endl;
738  }
739  return false;
740  }
741
743
744  //---
745  // Assuming square for now. Have to check the spec for this.
746  //---
747  if (size == 25934402) // 2 * 3601 * 3601 three arc second
748  {
749  m_numberOfLines = 3601;
750  m_numberOfSamples = 3601;
752  }
753  else if(size == 51868804) // 4*3601*3601
754  {
755  m_numberOfLines = 3601;
756  m_numberOfSamples = 3601;
758  }
759  else if (size == 2884802) // 2 * 1201 * 1201 one arc second
760  {
761  m_numberOfLines = 1201;
762  m_numberOfSamples = 1201;
764  }
765  else if (size == 5769604)
766  {
767  m_numberOfLines = 1201;
768  m_numberOfSamples = 1201;
770  }
771  else // try to get a square width and height
772  {
773  ossim_uint64 lines = (ossim_uint64)sqrt((ossim_float64)(size / 2));
774  ossim_uint64 samples = (ossim_uint64)sqrt((ossim_float64)(size / 2));
775  // check square
776  if(lines*samples*2 == size)
777  {
778  m_numberOfLines = lines;
779  m_numberOfSamples = samples;
781
782  }
783  else
784  {
785  ossim_uint64 lines = (ossim_uint64)sqrt((ossim_float64)(size / 4));
786  ossim_uint64 samples = (ossim_uint64)sqrt((ossim_float64)(size / 4));
787  // check square
788  if(lines*samples*4 == size)
789  {
790  m_numberOfLines = lines;
791  m_numberOfSamples = samples;
793  }
794  else
795  {
796  if(traceDebug())
797  {
799  << "ossimSrtmSupportData::setSize(): leaving with false at line " << __LINE__ << std::endl;
800  }
801  return false;
802  }
803  }
804  }
805
806  m_latSpacing = 1.0 / (m_numberOfLines - 1);
807  m_lonSpacing = 1.0 / (m_numberOfSamples - 1);
808  if(traceDebug())
809  {
811  << "ossimSrtmSupportData::setSize(): leaving with true..."
812  << std::endl;
813  }
814
815  m_str=0;
816
817  return true;
818 }
static bool remove(const ossimFilename &pathname)
Removes pathname from filesystem if supported by platform.
ossim_int64 fileSize() const
double ossim_float64
yy_size_t size
bool exists() const
unsigned long long ossim_uint64
Member Data Documentation
◆ m_file
ossimFilename ossimSrtmSupportData::m_file
private
◆ m_latSpacing
ossim_float64 ossimSrtmSupportData::m_latSpacing
private
◆ m_lonSpacing
ossim_float64 ossimSrtmSupportData::m_lonSpacing
private
◆ m_maxPixelValue
ossim_float64 ossimSrtmSupportData::m_maxPixelValue
private
Definition at line 195 of file ossimSrtmSupportData.h.
Referenced by computeMinMaxTemplate(), getMaxPixelValue(), loadOmd(), and print().
◆ m_minPixelValue
ossim_float64 ossimSrtmSupportData::m_minPixelValue
private
◆ m_numberOfLines
ossim_uint32 ossimSrtmSupportData::m_numberOfLines
private
◆ m_numberOfSamples
ossim_uint32 ossimSrtmSupportData::m_numberOfSamples
private
◆ m_scalarType
ossimScalarType ossimSrtmSupportData::m_scalarType
private
Definition at line 197 of file ossimSrtmSupportData.h.
Referenced by computeMinMax(), getScalarType(), and loadOmd().
◆ m_southwestLatitude
ossim_float64 ossimSrtmSupportData::m_southwestLatitude
private
◆ m_southwestLongitude
ossim_float64 ossimSrtmSupportData::m_southwestLongitude
private
◆ m_str
std::shared_ptr<ossim::istream> ossimSrtmSupportData::m_str
mutableprivate
Definition at line 200 of file ossimSrtmSupportData.h.
Referenced by computeMinMaxTemplate().
